[PATCH] Add a C++ thread with attributes
Chris Johns
chrisj at rtems.org
Tue Dec 10 11:00:43 UTC 2019
On 10/12/19 5:05 pm, Sebastian Huber wrote:
> On 10/12/2019 00:28, chrisj at rtems.org wrote:
>> This patch adds C++ thread support that is similar to the standard
>> C++ std::thread class however it has attributes so you can control
>> a thread priority, stack size and other attributes.
> looks good, but I don't like the short library name. I think it should start
> with librtems* just like the other RTEMS libraries.
I found doorstop or YAML or something did not like the ++ in a file name so I
switched to using xx.
What about librtemscxx? This means the library and spec file names match?
> Maybe librtems++.a even though we had such a library before.
I decided not to copy the same name because it could incorrectly be associated
with the old library.
>> The patch is against Sebastian's waf build repo. I would like it
>> say it was a pleasure to add the new files to the new build system.
>> Well done Sebastian it is really great.
> Thanks for testing the new build system.
It was easy. I did notice when I followed the eng manual's guide to adding a
test the created build type was object and not test-program and that confused me.
