[PATCH 5/5] c-user: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
Sebastian Huber
Tue Dec 10 13:11:33 UTC 2019
Move CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS to general system
configuration. Remove now empty "C Library Support Configuration"
section.
Update #3836.
c-user/configuring_a_system.rst | 66 +++++++++++++++++++----------------------
1 file changed, 30 insertions(+), 36 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 00973be..51a66b8 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -529,6 +529,36 @@ NOTES:
:ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE
<CONFIGURE_MINIMUM_TASK_STACK_SIZE>` instead of ``CPU_STACK_MINIMUM_SIZE``.
+.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+.. index:: maximum file descriptors
+.. _CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS:
+CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
+CONSTANT:
+ ``CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS``
+DATA TYPE:
+ Unsigned integer (``uint32_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ If ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` is defined, then the
+ default value is 3, otherwise the default value is 0. Three file
+ descriptors allows RTEMS to support standard input, output, and error I/O
+ streams on ``/dev/console``.
+DESCRIPTION:
+ This configuration parameter is set to the maximum number of file like
+ objects that can be concurrently open.
+NOTES:
+ None.
.. index:: CONFIGURE_MAXIMUM_PRIORITY
.. index:: maximum priority
.. index:: number of priority levels
@@ -2099,42 +2129,6 @@ NOTES:
500, sizeof(other_message_type) \
-C Library Support Configuration
-This section defines the file system and IO library related configuration
-parameters supported by ``<rtems/confdefs.h>``.
-.. index:: CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-.. index:: maximum file descriptors
-.. _CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS:
-CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
-CONSTANT:
- ``CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS``
-DATA TYPE:
- Unsigned integer (``uint32_t``).
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- If ``CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER`` is defined, then the
- default value is 3, otherwise the default value is 0. Three file
- descriptors allows RTEMS to support standard input, output, and error I/O
- streams on ``/dev/console``.
-DESCRIPTION:
- This configuration parameter is set to the maximum number of file like
- objects that can be concurrently open.
-NOTES:
- None.
File System Configuration Parameters
2.16.4
