[PATCH 1/5] c-user: Move basic system configuration
Sebastian Huber
Tue Dec 10 13:11:29 UTC 2019
Move the basic system configuration to the front. Rename it to "General
System Configuration".
Update #3836.
c-user/configuring_a_system.rst | 1376 +++++++++++++++++++--------------------
1 file changed, 688 insertions(+), 688 deletions(-)
diff --git a/c-user/configuring_a_system.rst b/c-user/configuring_a_system.rst
index 85c4e0f..0c0cb4a 100644
--- a/c-user/configuring_a_system.rst
+++ b/c-user/configuring_a_system.rst
@@ -476,334 +476,429 @@ NOTES:
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 5
-Classic API Configuration
+General System Configuration
-This section defines the Classic API related system configuration parameters
-supported by ``<rtems/confdefs.h>``.
+This section defines the general system configuration options supported by
+``<rtems/confdefs.h>``.
-.. index:: CONFIGURE_MAXIMUM_TASKS
+.. index:: CONFIGURE_EXTRA_TASK_STACKS
+.. index:: memory for task tasks
-.. _CONFIGURE_MAXIMUM_TASKS:
+.. _CONFIGURE_EXTRA_TASK_STACKS:
-CONFIGURE_MAXIMUM_TASKS
+CONFIGURE_EXTRA_TASK_STACKS
CONSTANT:
- ``CONFIGURE_MAXIMUM_TASKS``
+ ``CONFIGURE_EXTRA_TASK_STACKS``
DATA TYPE:
- Unsigned integer (``uint32_t``).
+ Unsigned integer (``size_t``).
RANGE:
- Zero or positive.
+ Undefined or positive.
DEFAULT VALUE:
- The default value is ``0``.
+ The default value is 0.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
- can be concurrently active.
+ This configuration parameter is set to the number of bytes the applications
+ wishes to add to the task stack requirements calculated by
+ ``<rtems/confdefs.h>``.
NOTES:
- This object class can be configured in unlimited allocation mode.
- The calculations for the required memory in the RTEMS Workspace for tasks
- assume that each task has a minimum stack size and has floating point
- support enabled. The configuration parameter
- ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
- *ABOVE* the minimum size required. See :ref:`Reserve Task/Thread Stack
- Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
- The maximum number of POSIX threads is specified by
- :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
- A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
- assumption that all tasks have floating point enabled. This would require
- the addition of a new configuration parameter to specify the number of
- tasks which enable floating point support.
-.. COMMENT: XXX - Add xref to CONFIGURE_MAXIMUM_POSIX_THREADS.
+ This parameter is very important. If the application creates tasks with
+ stacks larger then the minimum, then that memory is NOT accounted for by
-.. index:: CONFIGURE_MAXIMUM_TIMERS
+.. index:: CONFIGURE_INITIAL_EXTENSIONS
-.. _CONFIGURE_MAXIMUM_TIMERS:
+.. _CONFIGURE_INITIAL_EXTENSIONS:
-CONFIGURE_MAXIMUM_TIMERS
+CONFIGURE_INITIAL_EXTENSIONS
CONSTANT:
- ``CONFIGURE_MAXIMUM_TIMERS``
+ ``CONFIGURE_INITIAL_EXTENSIONS``
DATA TYPE:
+ List of user extension initializers (``rtems_extensions_table``).
RANGE:
- Zero or positive.
+ Undefined or a list of one or more user extensions.
DEFAULT VALUE:
- The default value is 0.
+ This is not defined by default.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
- that can be concurrently active.
+ If ``CONFIGURE_INITIAL_EXTENSIONS`` is defined by the application, then
+ this application specific set of initial extensions will be placed in the
+ initial extension table.
NOTES:
+ None.
-.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
+.. index:: CONFIGURE_INTERRUPT_STACK_SIZE
+.. index:: interrupt stack size
-.. _CONFIGURE_MAXIMUM_SEMAPHORES:
+.. _CONFIGURE_INTERRUPT_STACK_SIZE:
-CONFIGURE_MAXIMUM_SEMAPHORES
+CONFIGURE_INTERRUPT_STACK_SIZE
CONSTANT:
- ``CONFIGURE_MAXIMUM_SEMAPHORES``
+ ``CONFIGURE_INTERRUPT_STACK_SIZE``
DATA TYPE:
+ Unsigned integer.
RANGE:
- Zero or positive.
+ Positive.
DEFAULT VALUE:
+ The default value is ``BSP_INTERRUPT_STACK_SIZE`` in case it is defined,
+ otherwise the default value is ``CPU_STACK_MINIMUM_SIZE``.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
- Semaphores that can be concurrently active.
+ The ``CONFIGURE_INTERRUPT_STACK_SIZE`` configuration option defines the
+ size of an interrupt stack in bytes.
NOTES:
+ The interrupt stack size must be aligned according to
+ ``CPU_INTERRUPT_STACK_ALIGNMENT``.
-.. index:: CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+ There is one interrupt stack available for each configured processor
+ (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`). The
+ interrupt stack areas are statically allocated in a special linker section
+ (``.rtemsstack.interrupt``). The placement of this linker section is
+ BSP-specific.
-.. _CONFIGURE_MAXIMUM_MRSP_SEMAPHORES:
+ Some BSPs use the interrupt stack as the initialization stack which is used
+ to perform the sequential system initialization before the multithreading
+ is started.
-CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
+ The interrupt stacks are covered by the :ref:`stack checker
+ <CONFIGURE_STACK_CHECKER_ENABLED>`. However, using a too small interrupt
+ stack size may still result in undefined behaviour.
+ In releases before RTEMS 5.1 the default value was
+ :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE
+ <CONFIGURE_MINIMUM_TASK_STACK_SIZE>` instead of ``CPU_STACK_MINIMUM_SIZE``.
+.. index:: CONFIGURE_MAXIMUM_PRIORITY
+.. index:: maximum priority
+.. index:: number of priority levels
+.. _CONFIGURE_MAXIMUM_PRIORITY:
+CONFIGURE_MAXIMUM_PRIORITY
CONSTANT:
- ``CONFIGURE_MAXIMUM_MRSP_SEMAPHORES``
+ ``CONFIGURE_MAXIMUM_PRIORITY``
DATA TYPE:
+ Unsigned integer (``uint8_t``).
RANGE:
- Zero or positive.
+ Valid values for this configuration parameter must be one (1) less than
+ than a power of two (2) between 4 and 256 inclusively. In other words,
+ valid values are 3, 7, 31, 63, 127, and 255.
DEFAULT VALUE:
+ The default value is 255, because RTEMS must support 256 priority levels to
+ be compliant with various standards. These priorities range from zero (0)
+ to 255.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_MRSP_SEMAPHORES`` is the maximum number of Classic API
- Semaphores using the :ref:`MrsP` that can be concurrently active.
+ This configuration parameter specified the maximum numeric priority of any
+ task in the system and one less that the number of priority levels in the
+ system.
+ Reducing the number of priorities in the system reduces the amount of memory
+ allocated from the RTEMS Workspace.
NOTES:
- This configuration option is only used in SMP configurations. In
- uniprocessor configurations, the :ref:`PriorityCeiling` is used for MrsP
- semaphores and thus no extra memory is necessary.
+ The numerically greatest priority is the logically lowest priority in the
+ system and will thus be used by the IDLE task.
-.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+ Priority zero (0) is reserved for internal use by RTEMS and is not available
+ to applications.
-.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
+ With some schedulers, reducing the number of priorities can reduce the
+ amount of memory used by the scheduler. For example, the Deterministic
+ Priority Scheduler (DPS) used by default uses three pointers of storage per
+ priority level. Reducing the number of priorities from 256 levels to
+ sixteen (16) can reduce memory usage by about three (3) kilobytes.
-CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+.. index:: CONFIGURE_MAXIMUM_PROCESSORS
+.. _CONFIGURE_MAXIMUM_PROCESSORS:
+CONFIGURE_MAXIMUM_PROCESSORS
CONSTANT:
- ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
+ ``CONFIGURE_MAXIMUM_PROCESSORS``
DATA TYPE:
RANGE:
- Zero or positive.
+ Positive.
DEFAULT VALUE:
+ The default value is 1.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
- Message Queues that can be concurrently active.
+ ``CONFIGURE_MAXIMUM_PROCESSORS`` must be set to the maximum number of
+ processors an application intends to use. The number of actually available
+ processors depends on the hardware and may be less. It is recommended to
+ use the smallest value suitable for the application in order to save
+ memory. Each processor needs an idle thread and interrupt stack for
+ example.
NOTES:
+ If there are more processors available than configured, the rest will be
+ ignored. This configuration define is ignored in uniprocessor
+ configurations.
-.. index:: CONFIGURE_MAXIMUM_BARRIERS
+.. index:: CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
+.. index:: maximum thread name size
-.. _CONFIGURE_MAXIMUM_BARRIERS:
+.. _CONFIGURE_MAXIMUM_THREAD_NAME_SIZE:
-CONFIGURE_MAXIMUM_BARRIERS
+CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
CONSTANT:
- ``CONFIGURE_MAXIMUM_BARRIERS``
+ ``CONFIGURE_MAXIMUM_THREAD_NAME_SIZE``
DATA TYPE:
RANGE:
- Zero or positive.
+ No restrictions.
DEFAULT VALUE:
+ The default value is 16. This value was chosen for Linux compatibility,
+ see
+ `PTHREAD_SETNAME_NP(3) <http://man7.org/linux/man-pages/man3/pthread_setname_np.3.html>`_.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
- Barriers that can be concurrently active.
+ This configuration parameter specifies the maximum thread name size
+ including the terminating `NUL` character.
-NOTES:
+NOTE:
+ The size of the thread control block is increased by the maximum thread name
+ size. This configuration option is available since RTEMS 5.1.
-.. index:: CONFIGURE_MAXIMUM_PERIODS
+.. index:: CONFIGURE_MICROSECONDS_PER_TICK
+.. index:: tick quantum
-.. _CONFIGURE_MAXIMUM_PERIODS:
+.. _CONFIGURE_MICROSECONDS_PER_TICK:
-CONFIGURE_MAXIMUM_PERIODS
+CONFIGURE_MICROSECONDS_PER_TICK
CONSTANT:
- ``CONFIGURE_MAXIMUM_PERIODS``
+ ``CONFIGURE_MICROSECONDS_PER_TICK``
DATA TYPE:
RANGE:
- Zero or positive.
+ Positive.
DEFAULT VALUE:
+ This is not defined by default. When not defined, the clock tick quantum is
+ configured to be 10,000 microseconds which is ten (10) milliseconds.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
+ This constant is used to specify the length of time between clock ticks.
+ When the clock tick quantum value is too low, the system will spend so much
+ time processing clock ticks that it does not have processing time available
+ to perform application work. In this case, the system will become
+ unresponsive.
+ The lowest practical time quantum varies widely based upon the speed of the
+ target hardware and the architectural overhead associated with
+ interrupts. In general terms, you do not want to configure it lower than is
+ needed for the application.
+ The clock tick quantum should be selected such that it all blocking and
+ delay times in the application are evenly divisible by it. Otherwise,
+ rounding errors will be introduced which may negatively impact the
+ application.
NOTES:
+ This configuration parameter has no impact if the Clock Tick Device driver
+ is not configured.
-.. index:: CONFIGURE_MAXIMUM_PARTITIONS
+ There may be BSP specific limits on the resolution or maximum value of a
+ clock tick quantum.
-.. _CONFIGURE_MAXIMUM_PARTITIONS:
+.. index:: CONFIGURE_MINIMUM_TASK_STACK_SIZE
+.. index:: minimum task stack size
-CONFIGURE_MAXIMUM_PARTITIONS
+.. _CONFIGURE_MINIMUM_TASK_STACK_SIZE:
+CONFIGURE_MINIMUM_TASK_STACK_SIZE
CONSTANT:
- ``CONFIGURE_MAXIMUM_PARTITIONS``
+ ``CONFIGURE_MINIMUM_TASK_STACK_SIZE``
DATA TYPE:
RANGE:
- Zero or positive.
+ Positive.
DEFAULT VALUE:
+ The default value is architecture-specific.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
- Partitions that can be concurrently active.
+ This configuration parameter defines the minimum stack size in bytes for
+ every user task or thread in the system.
NOTES:
+ Adjusting this parameter should be done with caution. Examining the actual
+ stack usage using the stack checker usage reporting facility is recommended
+ (see also :ref:`CONFIGURE_STACK_CHECKER_ENABLED <CONFIGURE_STACK_CHECKER_ENABLED>`).
-.. index:: CONFIGURE_MAXIMUM_REGIONS
+ This parameter can be used to lower the minimum from that recommended. This
+ can be used in low memory systems to reduce memory consumption for
+ stacks. However, this must be done with caution as it could increase the
+ possibility of a blown task stack.
-.. _CONFIGURE_MAXIMUM_REGIONS:
+ This parameter can be used to increase the minimum from that
+ recommended. This can be used in higher memory systems to reduce the risk
+ of stack overflow without performing analysis on actual consumption.
-CONFIGURE_MAXIMUM_REGIONS
+ By default, this configuration parameter defines also the minimum stack
+ size of POSIX threads. This can be changed with the
+ :ref:`CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE <CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE>`
+ configuration option.
+ In releases before RTEMS 5.1 the ``CONFIGURE_MINIMUM_TASK_STACK_SIZE`` was
+ used to define the default value of :ref:`CONFIGURE_INTERRUPT_STACK_SIZE
+ <CONFIGURE_INTERRUPT_STACK_SIZE>`.
+.. index:: CONFIGURE_STACK_CHECKER_ENABLED
+.. _CONFIGURE_STACK_CHECKER_ENABLED:
+CONFIGURE_STACK_CHECKER_ENABLED
CONSTANT:
- ``CONFIGURE_MAXIMUM_REGIONS``
+ ``CONFIGURE_STACK_CHECKER_ENABLED``
DATA TYPE:
+ Boolean feature macro.
RANGE:
- Zero or positive.
+ Defined or undefined.
DEFAULT VALUE:
+ This is not defined by default, and thus stack checking is disabled.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
+ This configuration parameter is defined when the application wishes to
+ enable run-time stack bounds checking.
NOTES:
- None.
+ In 4.9 and older, this configuration parameter was named ``STACK_CHECKER_ON``.
-.. index:: CONFIGURE_MAXIMUM_PORTS
+ This increases the time required to create tasks as well as adding overhead
+ to each context switch.
-.. _CONFIGURE_MAXIMUM_PORTS:
+.. index:: CONFIGURE_TICKS_PER_TIMESLICE
+.. index:: ticks per timeslice
-CONFIGURE_MAXIMUM_PORTS
+.. _CONFIGURE_TICKS_PER_TIMESLICE:
+CONFIGURE_TICKS_PER_TIMESLICE
CONSTANT:
- ``CONFIGURE_MAXIMUM_PORTS``
+ ``CONFIGURE_TICKS_PER_TIMESLICE``
DATA TYPE:
RANGE:
- Zero or positive.
+ Positive.
DEFAULT VALUE:
+ The default value is 50.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
+ This configuration parameter specifies the length of the timeslice quantum
+ in ticks for each task.
NOTES:
-.. index:: CONFIGURE_MAXIMUM_USER_EXTENSIONS
+.. index:: CONFIGURE_UNIFIED_WORK_AREAS
+.. index:: unified work areas
+.. index:: separate work areas
+.. index:: RTEMS Workspace
+.. index:: C Program Heap
-.. _CONFIGURE_MAXIMUM_USER_EXTENSIONS:
+.. _CONFIGURE_UNIFIED_WORK_AREAS:
-CONFIGURE_MAXIMUM_USER_EXTENSIONS
+CONFIGURE_UNIFIED_WORK_AREAS
CONSTANT:
- ``CONFIGURE_MAXIMUM_USER_EXTENSIONS``
+ ``CONFIGURE_UNIFIED_WORK_AREAS``
DATA TYPE:
RANGE:
- Zero or positive.
DEFAULT VALUE:
+ This is not defined by default, which specifies that the C Program Heap and
+ the RTEMS Workspace will be separate.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_USER_EXTENSIONS`` is the maximum number of Classic API
- User Extensions that can be concurrently active.
+ When defined, the C Program Heap and the RTEMS Workspace will be one pool
+ of memory.
-NOTES:
+ When not defined, there will be separate memory pools for the RTEMS
+ Workspace and C Program Heap.
-Classic API Initialization Tasks Table Configuration
+NOTES:
+ Having separate pools does have some advantages in the event a task blows a
+ stack or writes outside its memory area. However, in low memory systems the
+ overhead of the two pools plus the potential for unused memory in either
+ pool is very undesirable.
-The ``<rtems/confdefs.h>`` configuration system can automatically generate an
-Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
-The following parameters control the generation of that table.
+ In high memory environments, this is desirable when you want to use the
+ RTEMS "unlimited" objects option. You will be able to create objects until
+ you run out of all available memory rather then just until you run out of
+ RTEMS Workspace.
-.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
+.. index:: CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
+.. index:: clear C Program Heap
+.. index:: clear RTEMS Workspace
+.. index:: zero C Program Heap
+.. index:: zero RTEMS Workspace
-.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
+.. _CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY:
-CONFIGURE_RTEMS_INIT_TASKS_TABLE
+CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
CONSTANT:
- ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
+ ``CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY``
DATA TYPE:
@@ -812,259 +907,261 @@ RANGE:
DEFAULT VALUE:
- This is not defined by default.
+ This is not defined by default, unless overridden by the BSP. The default
+ is *NOT* to zero out the RTEMS Workspace or C Program Heap.
DESCRIPTION:
- ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
- Classic RTEMS API Initialization Task Table. The table built by
- ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
- sufficient for applications which initialization the system from a single
- task.
- By default, this field is not defined as the user MUST select their own API
- for initialization tasks.
+ This macro indicates whether RTEMS should zero the RTEMS Workspace and C
+ Program Heap as part of its initialization. If defined, the memory regions
+ are zeroed. Otherwise, they are not.
NOTES:
- The application may choose to use the initialization tasks or threads table
- from another API.
+ Zeroing memory can add significantly to system boot time. It is not
+ necessary for RTEMS but is often assumed by support libraries.
- A compile time error will be generated if the user does not configure any
- initialization tasks or threads.
+Classic API Configuration
-.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
+This section defines the Classic API related system configuration parameters
+supported by ``<rtems/confdefs.h>``.
-.. _CONFIGURE_INIT_TASK_ENTRY_POINT:
+.. index:: CONFIGURE_MAXIMUM_TASKS
-CONFIGURE_INIT_TASK_ENTRY_POINT
+.. _CONFIGURE_MAXIMUM_TASKS:
+CONFIGURE_MAXIMUM_TASKS
CONSTANT:
- ``CONFIGURE_INIT_TASK_ENTRY_POINT``
+ ``CONFIGURE_MAXIMUM_TASKS``
DATA TYPE:
- Task entry function pointer (``rtems_task_entry``).
+ Unsigned integer (``uint32_t``).
RANGE:
- Valid task entry function pointer.
+ Zero or positive.
DEFAULT VALUE:
- The default value is ``Init``.
+ The default value is ``0``.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ENTRY_POINT`` is the entry point (a.k.a. function
- name) of the single initialization task defined by the Classic API
- Initialization Tasks Table.
+ ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
+ can be concurrently active.
NOTES:
- The user must implement the function ``Init`` or the function name provided
- in this configuration parameter.
+ This object class can be configured in unlimited allocation mode.
-.. index:: CONFIGURE_INIT_TASK_NAME
+ The calculations for the required memory in the RTEMS Workspace for tasks
+ assume that each task has a minimum stack size and has floating point
+ support enabled. The configuration parameter
+ ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
+ *ABOVE* the minimum size required. See :ref:`Reserve Task/Thread Stack
+ Memory Above Minimum` for more information about
+ ``CONFIGURE_EXTRA_TASK_STACKS``.
-.. _CONFIGURE_INIT_TASK_NAME:
+ The maximum number of POSIX threads is specified by
+ :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
-CONFIGURE_INIT_TASK_NAME
+ A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
+ assumption that all tasks have floating point enabled. This would require
+ the addition of a new configuration parameter to specify the number of
+ tasks which enable floating point support.
+.. COMMENT: XXX - Add xref to CONFIGURE_MAXIMUM_POSIX_THREADS.
+.. index:: CONFIGURE_MAXIMUM_TIMERS
+.. _CONFIGURE_MAXIMUM_TIMERS:
+CONFIGURE_MAXIMUM_TIMERS
CONSTANT:
- ``CONFIGURE_INIT_TASK_NAME``
+ ``CONFIGURE_MAXIMUM_TIMERS``
DATA TYPE:
- RTEMS Name (``rtems_name``).
RANGE:
- Any value.
+ Zero or positive.
DEFAULT VALUE:
- The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
- defined by the Classic API Initialization Tasks Table.
+ ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
+ that can be concurrently active.
NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
+.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
-.. _CONFIGURE_INIT_TASK_STACK_SIZE:
+.. _CONFIGURE_MAXIMUM_SEMAPHORES:
-CONFIGURE_INIT_TASK_STACK_SIZE
+CONFIGURE_MAXIMUM_SEMAPHORES
CONSTANT:
- ``CONFIGURE_INIT_TASK_STACK_SIZE``
+ ``CONFIGURE_MAXIMUM_SEMAPHORES``
DATA TYPE:
- Unsigned integer (``size_t``).
RANGE:
Zero or positive.
DEFAULT VALUE:
- The default value is RTEMS_MINIMUM_STACK_SIZE.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
- initialization task defined by the Classic API Initialization Tasks Table.
+ ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
+ Semaphores that can be concurrently active.
NOTES:
- If the stack size specified is greater than the configured minimum, it must
- be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
- Task/Thread Stack Memory Above Minimum` for more information about
-.. index:: CONFIGURE_INIT_TASK_PRIORITY
+.. index:: CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
-.. _CONFIGURE_INIT_TASK_PRIORITY:
+.. _CONFIGURE_MAXIMUM_MRSP_SEMAPHORES:
-CONFIGURE_INIT_TASK_PRIORITY
+CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
CONSTANT:
- ``CONFIGURE_INIT_TASK_PRIORITY``
+ ``CONFIGURE_MAXIMUM_MRSP_SEMAPHORES``
DATA TYPE:
- RTEMS Task Priority (``rtems_task_priority``).
RANGE:
- One (1) to CONFIGURE_MAXIMUM_PRIORITY.
+ Zero or positive.
DEFAULT VALUE:
- The default value is 1, which is the highest priority in the Classic API.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_PRIORITY`` is the initial priority of the single
+ ``CONFIGURE_MAXIMUM_MRSP_SEMAPHORES`` is the maximum number of Classic API
+ Semaphores using the :ref:`MrsP` that can be concurrently active.
NOTES:
- None.
+ This configuration option is only used in SMP configurations. In
+ uniprocessor configurations, the :ref:`PriorityCeiling` is used for MrsP
+ semaphores and thus no extra memory is necessary.
-.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
+.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
-.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
+.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
-CONFIGURE_INIT_TASK_ATTRIBUTES
+CONFIGURE_MAXIMUM_MESSAGE_QUEUES
CONSTANT:
- ``CONFIGURE_INIT_TASK_ATTRIBUTES``
+ ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
DATA TYPE:
- RTEMS Attributes (``rtems_attribute``).
RANGE:
- Valid task attribute sets.
+ Zero or positive.
DEFAULT VALUE:
- The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
+ ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
+ Message Queues that can be concurrently active.
NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
+.. index:: CONFIGURE_MAXIMUM_BARRIERS
-.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
+.. _CONFIGURE_MAXIMUM_BARRIERS:
-CONFIGURE_INIT_TASK_INITIAL_MODES
+CONFIGURE_MAXIMUM_BARRIERS
CONSTANT:
- ``CONFIGURE_INIT_TASK_INITIAL_MODES``
+ ``CONFIGURE_MAXIMUM_BARRIERS``
DATA TYPE:
- RTEMS Mode (``rtems_mode``).
RANGE:
- Valid task mode sets.
+ Zero or positive.
DEFAULT VALUE:
- The default value is ``RTEMS_NO_PREEMPT``.
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
- single initialization task defined by the Classic API Initialization Tasks
- Table.
+ ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
+ Barriers that can be concurrently active.
NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
+.. index:: CONFIGURE_MAXIMUM_PERIODS
-.. _CONFIGURE_INIT_TASK_ARGUMENTS:
+.. _CONFIGURE_MAXIMUM_PERIODS:
-CONFIGURE_INIT_TASK_ARGUMENTS
+CONFIGURE_MAXIMUM_PERIODS
CONSTANT:
- ``CONFIGURE_INIT_TASK_ARGUMENTS``
+ ``CONFIGURE_MAXIMUM_PERIODS``
DATA TYPE:
- RTEMS Task Argument (``rtems_task_argument``).
RANGE:
- Complete range of the type.
+ Zero or positive.
DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
+ ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
NOTES:
- None.
-.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+.. index:: CONFIGURE_MAXIMUM_PARTITIONS
-.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
+.. _CONFIGURE_MAXIMUM_PARTITIONS:
-CONFIGURE_HAS_OWN_INIT_TASK_TABLE
+CONFIGURE_MAXIMUM_PARTITIONS
CONSTANT:
- ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE``
+ ``CONFIGURE_MAXIMUM_PARTITIONS``
DATA TYPE:
- Boolean feature macro.
RANGE:
- Defined or undefined.
+ Zero or positive.
DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE`` is defined if the user wishes to
- define their own Classic API Initialization Tasks Table. This table should
- be named ``Initialization_tasks``.
+ ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
+ Partitions that can be concurrently active.
NOTES:
- This is a seldom used configuration parameter. The most likely use case is
- when an application desires to have more than one initialization task.
-POSIX API Configuration
-The parameters in this section are used to configure resources for the POSIX
-API supported by RTEMS. Most POSIX API objects are available by default since
-RTEMS 5.1. The queued signals and timers are only available if RTEMS was built
-with the ``--enable-posix`` build configuration option.
-.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
+.. index:: CONFIGURE_MAXIMUM_REGIONS
-.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
+.. _CONFIGURE_MAXIMUM_REGIONS:
-CONFIGURE_MAXIMUM_POSIX_KEYS
+CONFIGURE_MAXIMUM_REGIONS
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_KEYS``
+ ``CONFIGURE_MAXIMUM_REGIONS``
DATA TYPE:
@@ -1076,21 +1173,21 @@ DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
+ ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
NOTES:
+ None.
-.. index:: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+.. index:: CONFIGURE_MAXIMUM_PORTS
-.. _CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+.. _CONFIGURE_MAXIMUM_PORTS:
-CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+CONFIGURE_MAXIMUM_PORTS
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS``
+ ``CONFIGURE_MAXIMUM_PORTS``
DATA TYPE:
@@ -1099,30 +1196,24 @@ RANGE:
Zero or positive.
DEFAULT VALUE:
- :ref:`CONFIGURE_MAXIMUM_POSIX_KEYS <CONFIGURE_MAXIMUM_POSIX_KEYS>` *
- :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>` +
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS`` is the maximum number of key
- value pairs used by POSIX API Keys that can be concurrently active.
+ ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
NOTES:
- A key value pair is created by :c:func:`pthread_setspecific` if the value
- is not :c:macro:`NULL`, otherwise it is deleted.
-.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+.. index:: CONFIGURE_MAXIMUM_USER_EXTENSIONS
-.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
+.. _CONFIGURE_MAXIMUM_USER_EXTENSIONS:
-CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+CONFIGURE_MAXIMUM_USER_EXTENSIONS
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
+ ``CONFIGURE_MAXIMUM_USER_EXTENSIONS``
DATA TYPE:
@@ -1134,279 +1225,253 @@ DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
- API Message Queues that can be concurrently active.
+ ``CONFIGURE_MAXIMUM_USER_EXTENSIONS`` is the maximum number of Classic API
+ User Extensions that can be concurrently active.
NOTES:
-.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+Classic API Initialization Tasks Table Configuration
-.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
+The ``<rtems/confdefs.h>`` configuration system can automatically generate an
+Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
+The following parameters control the generation of that table.
-CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
+.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
+CONFIGURE_RTEMS_INIT_TASKS_TABLE
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
+ ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
DATA TYPE:
RANGE:
- Zero or positive.
DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
- API Queued Signals that can be concurrently active.
+ ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
+ Classic RTEMS API Initialization Task Table. The table built by
+ ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
+ sufficient for applications which initialization the system from a single
+ task.
+ By default, this field is not defined as the user MUST select their own API
+ for initialization tasks.
NOTES:
- Unlimited objects are not available for queued signals.
+ The application may choose to use the initialization tasks or threads table
+ from another API.
- Queued signals are only available if RTEMS was built with the
- ``--enable-posix`` build configuration option.
+ A compile time error will be generated if the user does not configure any
+ initialization tasks or threads.
-.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
-.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
+.. _CONFIGURE_INIT_TASK_ENTRY_POINT:
-CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+CONFIGURE_INIT_TASK_ENTRY_POINT
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
+ ``CONFIGURE_INIT_TASK_ENTRY_POINT``
DATA TYPE:
+ Task entry function pointer (``rtems_task_entry``).
RANGE:
- Zero or positive.
+ Valid task entry function pointer.
DEFAULT VALUE:
+ The default value is ``Init``.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
- Named Semaphores that can be concurrently active.
+ ``CONFIGURE_INIT_TASK_ENTRY_POINT`` is the entry point (a.k.a. function
+ name) of the single initialization task defined by the Classic API
+ Initialization Tasks Table.
NOTES:
- Named semaphores are created with ``sem_open()``. Semaphores initialized
- with ``sem_init()`` are not affected by this configuration option since the
- storage space for these semaphores is user-provided.
+ The user must implement the function ``Init`` or the function name provided
+ in this configuration parameter.
-.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
+.. index:: CONFIGURE_INIT_TASK_NAME
-.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
+.. _CONFIGURE_INIT_TASK_NAME:
-CONFIGURE_MAXIMUM_POSIX_TIMERS
+CONFIGURE_INIT_TASK_NAME
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
+ ``CONFIGURE_INIT_TASK_NAME``
DATA TYPE:
+ RTEMS Name (``rtems_name``).
RANGE:
- Zero or positive.
+ Any value.
DEFAULT VALUE:
+ The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
- Timers that can be concurrently active.
+ ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
+ defined by the Classic API Initialization Tasks Table.
NOTES:
- Timers are only available if RTEMS was built with the
+ None.
-.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
+.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
-.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
+.. _CONFIGURE_INIT_TASK_STACK_SIZE:
-CONFIGURE_MAXIMUM_POSIX_THREADS
+CONFIGURE_INIT_TASK_STACK_SIZE
CONSTANT:
- ``CONFIGURE_MAXIMUM_POSIX_THREADS``
+ ``CONFIGURE_INIT_TASK_STACK_SIZE``
DATA TYPE:
RANGE:
Zero or positive.
DEFAULT VALUE:
+ The default value is RTEMS_MINIMUM_STACK_SIZE.
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
- Threads that can be concurrently active.
+ ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
+ initialization task defined by the Classic API Initialization Tasks Table.
NOTES:
- This calculations for the required memory in the RTEMS Workspace for
- threads assume that each thread has a minimum stack size and has floating
- point support enabled. The configuration parameter
- ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
- requirements *ABOVE* the minimum size required. See :ref:`Reserve
+ If the stack size specified is greater than the configured minimum, it must
+ be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
- The maximum number of Classic API Tasks is specified by
- :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>`.
- All POSIX threads have floating point enabled.
-.. index:: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
-.. index:: minimum POSIX thread stack size
+.. index:: CONFIGURE_INIT_TASK_PRIORITY
-.. _CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE:
+.. _CONFIGURE_INIT_TASK_PRIORITY:
-CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+CONFIGURE_INIT_TASK_PRIORITY
CONSTANT:
- ``CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE``
+ ``CONFIGURE_INIT_TASK_PRIORITY``
DATA TYPE:
+ RTEMS Task Priority (``rtems_task_priority``).
RANGE:
- Positive.
+ One (1) to CONFIGURE_MAXIMUM_PRIORITY.
DEFAULT VALUE:
- The default value is two times the value of
- :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE <CONFIGURE_MINIMUM_TASK_STACK_SIZE>`.
+ The default value is 1, which is the highest priority in the Classic API.
DESCRIPTION:
- This configuration parameter defines the minimum stack size in bytes for
- every POSIX thread in the system.
+ ``CONFIGURE_INIT_TASK_PRIORITY`` is the initial priority of the single
NOTES:
None.
-POSIX Initialization Threads Table Configuration
-POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
-a single entry. The following parameters control the generation of that table.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
+.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
-.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
+.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
-CONFIGURE_POSIX_INIT_THREAD_TABLE
+CONFIGURE_INIT_TASK_ATTRIBUTES
CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
+ ``CONFIGURE_INIT_TASK_ATTRIBUTES``
DATA TYPE:
+ RTEMS Attributes (``rtems_attribute``).
RANGE:
-DEFAULT VALUE:
- This field is not defined by default, as the user MUST select their own API
+ Valid task attribute sets.
-DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
- a POSIX API Initialization Threads Table. The table built by
- ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
- is sufficient for applications which initialization the system from a
- single task.
+DEFAULT VALUE:
+ The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
NOTES:
- from another API.
+ None.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
-.. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
+.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
-CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+CONFIGURE_INIT_TASK_INITIAL_MODES
CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT``
+ ``CONFIGURE_INIT_TASK_INITIAL_MODES``
DATA TYPE:
- POSIX thread function pointer (``void *(*entry_point)(void *)``).
+ RTEMS Mode (``rtems_mode``).
RANGE:
- Undefined or a valid POSIX thread function pointer.
+ Valid task mode sets.
DEFAULT VALUE:
- The default value is ``POSIX_Init``.
+ The default value is ``RTEMS_NO_PREEMPT``.
DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT`` is the entry point
- (a.k.a. function name) of the single initialization thread defined by the
- POSIX API Initialization Threads Table.
+ ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
+ single initialization task defined by the Classic API Initialization Tasks
+ Table.
NOTES:
- The user must implement the function ``POSIX_Init`` or the function name
- provided in this configuration parameter.
+ None.
-.. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
-.. _CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE:
+.. _CONFIGURE_INIT_TASK_ARGUMENTS:
-CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+CONFIGURE_INIT_TASK_ARGUMENTS
CONSTANT:
- ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE``
+ ``CONFIGURE_INIT_TASK_ARGUMENTS``
DATA TYPE:
+ RTEMS Task Argument (``rtems_task_argument``).
RANGE:
- Zero or positive.
+ Complete range of the type.
DEFAULT VALUE:
- The default value is 2 \* RTEMS_MINIMUM_STACK_SIZE.
DESCRIPTION:
- ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE`` is the stack size of the single
- initialization thread defined by the POSIX API Initialization Threads
- Table.
+ ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
NOTES:
+ None.
-.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+.. index:: CONFIGURE_HAS_OWN_INIT_TASK_TABLE
-.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
+.. _CONFIGURE_HAS_OWN_INIT_TASK_TABLE:
-CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
+CONFIGURE_HAS_OWN_INIT_TASK_TABLE
CONSTANT:
- ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE``
+ ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE``
DATA TYPE:
@@ -1418,456 +1483,391 @@ DEFAULT VALUE:
DESCRIPTION:
- ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE`` is defined if the user wishes
- to define their own POSIX API Initialization Threads Table. This table
- should be named ``POSIX_Initialization_threads``.
+ ``CONFIGURE_HAS_OWN_INIT_TASK_TABLE`` is defined if the user wishes to
+ define their own Classic API Initialization Tasks Table. This table should
+ be named ``Initialization_tasks``.
NOTES:
-Basic System Information
+POSIX API Configuration
-This section defines the general system configuration parameters supported by
-``<rtems/confdefs.h>``.
+The parameters in this section are used to configure resources for the POSIX
+API supported by RTEMS. Most POSIX API objects are available by default since
+RTEMS 5.1. The queued signals and timers are only available if RTEMS was built
+with the ``--enable-posix`` build configuration option.
-.. index:: CONFIGURE_UNIFIED_WORK_AREAS
-.. index:: unified work areas
-.. index:: separate work areas
-.. index:: RTEMS Workspace
-.. index:: C Program Heap
+.. index:: CONFIGURE_MAXIMUM_POSIX_KEYS
-.. _CONFIGURE_UNIFIED_WORK_AREAS:
+.. _CONFIGURE_MAXIMUM_POSIX_KEYS:
-CONFIGURE_UNIFIED_WORK_AREAS
+CONFIGURE_MAXIMUM_POSIX_KEYS
CONSTANT:
- ``CONFIGURE_UNIFIED_WORK_AREAS``
+ ``CONFIGURE_MAXIMUM_POSIX_KEYS``
DATA TYPE:
RANGE:
+ Zero or positive.
DEFAULT VALUE:
- This is not defined by default, which specifies that the C Program Heap and
- the RTEMS Workspace will be separate.
DESCRIPTION:
- When defined, the C Program Heap and the RTEMS Workspace will be one pool
- of memory.
- When not defined, there will be separate memory pools for the RTEMS
- Workspace and C Program Heap.
+ ``CONFIGURE_MAXIMUM_POSIX_KEYS`` is the maximum number of POSIX API Keys
NOTES:
- Having separate pools does have some advantages in the event a task blows a
- stack or writes outside its memory area. However, in low memory systems the
- overhead of the two pools plus the potential for unused memory in either
- pool is very undesirable.
- In high memory environments, this is desirable when you want to use the
- RTEMS "unlimited" objects option. You will be able to create objects until
- you run out of all available memory rather then just until you run out of
- RTEMS Workspace.
-.. index:: CONFIGURE_MAXIMUM_PROCESSORS
+.. index:: CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
-.. _CONFIGURE_MAXIMUM_PROCESSORS:
+.. _CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
-CONFIGURE_MAXIMUM_PROCESSORS
+CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
CONSTANT:
- ``CONFIGURE_MAXIMUM_PROCESSORS``
+ ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS``
DATA TYPE:
RANGE:
- Positive.
+ Zero or positive.
DEFAULT VALUE:
- The default value is 1.
+ :ref:`CONFIGURE_MAXIMUM_POSIX_KEYS <CONFIGURE_MAXIMUM_POSIX_KEYS>` *
+ :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>` +
DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PROCESSORS`` must be set to the maximum number of
- processors an application intends to use. The number of actually available
- processors depends on the hardware and may be less. It is recommended to
- use the smallest value suitable for the application in order to save
- memory. Each processor needs an idle thread and interrupt stack for
- example.
+ ``CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS`` is the maximum number of key
+ value pairs used by POSIX API Keys that can be concurrently active.
NOTES:
- If there are more processors available than configured, the rest will be
- ignored. This configuration define is ignored in uniprocessor
- configurations.
-.. index:: CONFIGURE_MICROSECONDS_PER_TICK
-.. index:: tick quantum
+ A key value pair is created by :c:func:`pthread_setspecific` if the value
+ is not :c:macro:`NULL`, otherwise it is deleted.
-.. _CONFIGURE_MICROSECONDS_PER_TICK:
+.. index:: CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
-CONFIGURE_MICROSECONDS_PER_TICK
+.. _CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES:
+CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
CONSTANT:
- ``CONFIGURE_MICROSECONDS_PER_TICK``
+ ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES``
DATA TYPE:
RANGE:
- Positive.
+ Zero or positive.
DEFAULT VALUE:
- This is not defined by default. When not defined, the clock tick quantum is
- configured to be 10,000 microseconds which is ten (10) milliseconds.
DESCRIPTION:
- This constant is used to specify the length of time between clock ticks.
- When the clock tick quantum value is too low, the system will spend so much
- time processing clock ticks that it does not have processing time available
- to perform application work. In this case, the system will become
- unresponsive.
- The lowest practical time quantum varies widely based upon the speed of the
- target hardware and the architectural overhead associated with
- interrupts. In general terms, you do not want to configure it lower than is
- needed for the application.
- The clock tick quantum should be selected such that it all blocking and
- delay times in the application are evenly divisible by it. Otherwise,
- rounding errors will be introduced which may negatively impact the
- application.
+ ``CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES`` is the maximum number of POSIX
+ API Message Queues that can be concurrently active.
NOTES:
- This configuration parameter has no impact if the Clock Tick Device driver
- is not configured.
- There may be BSP specific limits on the resolution or maximum value of a
- clock tick quantum.
-.. index:: CONFIGURE_TICKS_PER_TIMESLICE
-.. index:: ticks per timeslice
+.. index:: CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
-.. _CONFIGURE_TICKS_PER_TIMESLICE:
+.. _CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS:
-CONFIGURE_TICKS_PER_TIMESLICE
+CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
CONSTANT:
- ``CONFIGURE_TICKS_PER_TIMESLICE``
+ ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS``
DATA TYPE:
RANGE:
- Positive.
+ Zero or positive.
DEFAULT VALUE:
- The default value is 50.
DESCRIPTION:
- This configuration parameter specifies the length of the timeslice quantum
- in ticks for each task.
+ ``CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS`` is the maximum number of POSIX
+ API Queued Signals that can be concurrently active.
NOTES:
+ Unlimited objects are not available for queued signals.
-.. index:: CONFIGURE_MAXIMUM_PRIORITY
-.. index:: maximum priority
-.. index:: number of priority levels
+ Queued signals are only available if RTEMS was built with the
+ ``--enable-posix`` build configuration option.
-.. _CONFIGURE_MAXIMUM_PRIORITY:
+.. index:: CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
-CONFIGURE_MAXIMUM_PRIORITY
+.. _CONFIGURE_MAXIMUM_POSIX_SEMAPHORES:
+CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
CONSTANT:
- ``CONFIGURE_MAXIMUM_PRIORITY``
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES``
DATA TYPE:
- Unsigned integer (``uint8_t``).
RANGE:
- Valid values for this configuration parameter must be one (1) less than
- than a power of two (2) between 4 and 256 inclusively. In other words,
- valid values are 3, 7, 31, 63, 127, and 255.
+ Zero or positive.
DEFAULT VALUE:
- The default value is 255, because RTEMS must support 256 priority levels to
- be compliant with various standards. These priorities range from zero (0)
- to 255.
DESCRIPTION:
- This configuration parameter specified the maximum numeric priority of any
- task in the system and one less that the number of priority levels in the
- system.
- Reducing the number of priorities in the system reduces the amount of memory
- allocated from the RTEMS Workspace.
-NOTES:
- The numerically greatest priority is the logically lowest priority in the
- system and will thus be used by the IDLE task.
+ ``CONFIGURE_MAXIMUM_POSIX_SEMAPHORES`` is the maximum number of POSIX API
+ Named Semaphores that can be concurrently active.
- Priority zero (0) is reserved for internal use by RTEMS and is not available
- to applications.
+NOTES:
- With some schedulers, reducing the number of priorities can reduce the
- amount of memory used by the scheduler. For example, the Deterministic
- Priority Scheduler (DPS) used by default uses three pointers of storage per
- priority level. Reducing the number of priorities from 256 levels to
- sixteen (16) can reduce memory usage by about three (3) kilobytes.
+ Named semaphores are created with ``sem_open()``. Semaphores initialized
+ with ``sem_init()`` are not affected by this configuration option since the
+ storage space for these semaphores is user-provided.
-.. index:: CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
-.. index:: maximum thread name size
+.. index:: CONFIGURE_MAXIMUM_POSIX_TIMERS
-.. _CONFIGURE_MAXIMUM_THREAD_NAME_SIZE:
+.. _CONFIGURE_MAXIMUM_POSIX_TIMERS:
-CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
+CONFIGURE_MAXIMUM_POSIX_TIMERS
CONSTANT:
- ``CONFIGURE_MAXIMUM_THREAD_NAME_SIZE``
+ ``CONFIGURE_MAXIMUM_POSIX_TIMERS``
DATA TYPE:
RANGE:
- No restrictions.
+ Zero or positive.
DEFAULT VALUE:
- The default value is 16. This value was chosen for Linux compatibility,
- see
- `PTHREAD_SETNAME_NP(3) <http://man7.org/linux/man-pages/man3/pthread_setname_np.3.html>`_.
DESCRIPTION:
- This configuration parameter specifies the maximum thread name size
- including the terminating `NUL` character.
+ ``CONFIGURE_MAXIMUM_POSIX_TIMERS`` is the maximum number of POSIX API
+ Timers that can be concurrently active.
-NOTE:
- The size of the thread control block is increased by the maximum thread name
- size. This configuration option is available since RTEMS 5.1.
+NOTES:
-.. index:: CONFIGURE_MINIMUM_TASK_STACK_SIZE
-.. index:: minimum task stack size
+ Timers are only available if RTEMS was built with the
-.. _CONFIGURE_MINIMUM_TASK_STACK_SIZE:
+.. index:: CONFIGURE_MAXIMUM_POSIX_THREADS
-CONFIGURE_MINIMUM_TASK_STACK_SIZE
+.. _CONFIGURE_MAXIMUM_POSIX_THREADS:
+CONFIGURE_MAXIMUM_POSIX_THREADS
CONSTANT:
- ``CONFIGURE_MINIMUM_TASK_STACK_SIZE``
+ ``CONFIGURE_MAXIMUM_POSIX_THREADS``
DATA TYPE:
RANGE:
- Positive.
+ Zero or positive.
DEFAULT VALUE:
- The default value is architecture-specific.
DESCRIPTION:
- every user task or thread in the system.
+ ``CONFIGURE_MAXIMUM_POSIX_THREADS`` is the maximum number of POSIX API
+ Threads that can be concurrently active.
NOTES:
- Adjusting this parameter should be done with caution. Examining the actual
- stack usage using the stack checker usage reporting facility is recommended
- (see also :ref:`CONFIGURE_STACK_CHECKER_ENABLED <CONFIGURE_STACK_CHECKER_ENABLED>`).
- This parameter can be used to lower the minimum from that recommended. This
- can be used in low memory systems to reduce memory consumption for
- stacks. However, this must be done with caution as it could increase the
- possibility of a blown task stack.
- This parameter can be used to increase the minimum from that
- recommended. This can be used in higher memory systems to reduce the risk
- of stack overflow without performing analysis on actual consumption.
+ This calculations for the required memory in the RTEMS Workspace for
+ threads assume that each thread has a minimum stack size and has floating
+ point support enabled. The configuration parameter
+ ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify thread stack
+ requirements *ABOVE* the minimum size required. See :ref:`Reserve
+ Task/Thread Stack Memory Above Minimum` for more information about
- By default, this configuration parameter defines also the minimum stack
- size of POSIX threads. This can be changed with the
- :ref:`CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE <CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE>`
- configuration option.
+ The maximum number of Classic API Tasks is specified by
+ :ref:`CONFIGURE_MAXIMUM_TASKS <CONFIGURE_MAXIMUM_TASKS>`.
- In releases before RTEMS 5.1 the ``CONFIGURE_MINIMUM_TASK_STACK_SIZE`` was
- used to define the default value of :ref:`CONFIGURE_INTERRUPT_STACK_SIZE
- <CONFIGURE_INTERRUPT_STACK_SIZE>`.
+ All POSIX threads have floating point enabled.
-.. index:: CONFIGURE_INTERRUPT_STACK_SIZE
-.. index:: interrupt stack size
+.. index:: CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+.. index:: minimum POSIX thread stack size
-.. _CONFIGURE_INTERRUPT_STACK_SIZE:
+.. _CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE:
-CONFIGURE_INTERRUPT_STACK_SIZE
+CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
CONSTANT:
- ``CONFIGURE_INTERRUPT_STACK_SIZE``
+ ``CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE``
DATA TYPE:
- Unsigned integer.
RANGE:
Positive.
DEFAULT VALUE:
- The default value is ``BSP_INTERRUPT_STACK_SIZE`` in case it is defined,
- otherwise the default value is ``CPU_STACK_MINIMUM_SIZE``.
+ The default value is two times the value of
+ :ref:`CONFIGURE_MINIMUM_TASK_STACK_SIZE <CONFIGURE_MINIMUM_TASK_STACK_SIZE>`.
DESCRIPTION:
- The ``CONFIGURE_INTERRUPT_STACK_SIZE`` configuration option defines the
- size of an interrupt stack in bytes.
+ every POSIX thread in the system.
NOTES:
- The interrupt stack size must be aligned according to
- ``CPU_INTERRUPT_STACK_ALIGNMENT``.
- There is one interrupt stack available for each configured processor
- (:ref:`CONFIGURE_MAXIMUM_PROCESSORS <CONFIGURE_MAXIMUM_PROCESSORS>`). The
- interrupt stack areas are statically allocated in a special linker section
- (``.rtemsstack.interrupt``). The placement of this linker section is
- BSP-specific.
- Some BSPs use the interrupt stack as the initialization stack which is used
- to perform the sequential system initialization before the multithreading
- is started.
+ None.
- The interrupt stacks are covered by the :ref:`stack checker
- <CONFIGURE_STACK_CHECKER_ENABLED>`. However, using a too small interrupt
- stack size may still result in undefined behaviour.
+POSIX Initialization Threads Table Configuration
- In releases before RTEMS 5.1 the default value was
- <CONFIGURE_MINIMUM_TASK_STACK_SIZE>` instead of ``CPU_STACK_MINIMUM_SIZE``.
+POSIX Initialization Threads Table named ``POSIX_Initialization_threads`` with
+a single entry. The following parameters control the generation of that table.
-.. index:: CONFIGURE_EXTRA_TASK_STACKS
-.. index:: memory for task tasks
+.. index:: CONFIGURE_POSIX_INIT_THREAD_TABLE
-.. _CONFIGURE_EXTRA_TASK_STACKS:
+.. _CONFIGURE_POSIX_INIT_THREAD_TABLE:
-CONFIGURE_EXTRA_TASK_STACKS
+CONFIGURE_POSIX_INIT_THREAD_TABLE
CONSTANT:
+ ``CONFIGURE_POSIX_INIT_THREAD_TABLE``
DATA TYPE:
RANGE:
- Undefined or positive.
DEFAULT VALUE:
+ This field is not defined by default, as the user MUST select their own API
DESCRIPTION:
- This configuration parameter is set to the number of bytes the applications
- wishes to add to the task stack requirements calculated by
- ``<rtems/confdefs.h>``.
+ ``CONFIGURE_POSIX_INIT_THREAD_TABLE`` is defined if the user wishes to use
+ a POSIX API Initialization Threads Table. The table built by
+ ``<rtems/confdefs.h>`` specifies the parameters for a single thread. This
+ is sufficient for applications which initialization the system from a
+ single task.
NOTES:
- This parameter is very important. If the application creates tasks with
- stacks larger then the minimum, then that memory is NOT accounted for by
+ from another API.
-.. index:: CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
-.. index:: clear C Program Heap
-.. index:: clear RTEMS Workspace
-.. index:: zero C Program Heap
-.. index:: zero RTEMS Workspace
-.. _CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY:
+.. index:: CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
-CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
+.. _CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT:
+CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
CONSTANT:
- ``CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY``
+ ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT``
DATA TYPE:
+ POSIX thread function pointer (``void *(*entry_point)(void *)``).
RANGE:
+ Undefined or a valid POSIX thread function pointer.
DEFAULT VALUE:
- This is not defined by default, unless overridden by the BSP. The default
- is *NOT* to zero out the RTEMS Workspace or C Program Heap.
+ The default value is ``POSIX_Init``.
DESCRIPTION:
- This macro indicates whether RTEMS should zero the RTEMS Workspace and C
- Program Heap as part of its initialization. If defined, the memory regions
- are zeroed. Otherwise, they are not.
+ ``CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT`` is the entry point
+ (a.k.a. function name) of the single initialization thread defined by the
+ POSIX API Initialization Threads Table.
NOTES:
- Zeroing memory can add significantly to system boot time. It is not
- necessary for RTEMS but is often assumed by support libraries.
+ The user must implement the function ``POSIX_Init`` or the function name
+ provided in this configuration parameter.
-.. index:: CONFIGURE_STACK_CHECKER_ENABLED
+.. index:: CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
-.. _CONFIGURE_STACK_CHECKER_ENABLED:
+.. _CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE:
-CONFIGURE_STACK_CHECKER_ENABLED
+CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
CONSTANT:
- ``CONFIGURE_STACK_CHECKER_ENABLED``
+ ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE``
DATA TYPE:
RANGE:
+ Zero or positive.
DEFAULT VALUE:
- This is not defined by default, and thus stack checking is disabled.
+ The default value is 2 \* RTEMS_MINIMUM_STACK_SIZE.
DESCRIPTION:
- This configuration parameter is defined when the application wishes to
- enable run-time stack bounds checking.
+ ``CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE`` is the stack size of the single
+ initialization thread defined by the POSIX API Initialization Threads
+ Table.
NOTES:
- In 4.9 and older, this configuration parameter was named ``STACK_CHECKER_ON``.
- This increases the time required to create tasks as well as adding overhead
- to each context switch.
-.. index:: CONFIGURE_INITIAL_EXTENSIONS
+.. index:: CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
-.. _CONFIGURE_INITIAL_EXTENSIONS:
+.. _CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE:
-CONFIGURE_INITIAL_EXTENSIONS
+CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
CONSTANT:
- ``CONFIGURE_INITIAL_EXTENSIONS``
+ ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE``
DATA TYPE:
- List of user extension initializers (``rtems_extensions_table``).
RANGE:
- Undefined or a list of one or more user extensions.
DEFAULT VALUE:
DESCRIPTION:
- If ``CONFIGURE_INITIAL_EXTENSIONS`` is defined by the application, then
- this application specific set of initial extensions will be placed in the
- initial extension table.
+ ``CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE`` is defined if the user wishes
+ to define their own POSIX API Initialization Threads Table. This table
+ should be named ``POSIX_Initialization_threads``.
NOTES:
- None.
+ This is a seldom used configuration parameter. The most likely use case is
+ when an application desires to have more than one initialization task.
Configuring Custom Task Stack Allocation
2.16.4
