[PATCH] config: CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
Wed Dec 11 14:58:34 UTC 2019
Obsolete the CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration
option.
Update #3735.
 cpukit/include/rtems/confdefs.h | 82 ++++++++++++++++++++---------------------
 1 file changed, 41 insertions(+), 41 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 922e4d7a9d..bee23e7974 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1817,53 +1817,49 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
   #ifdef CONFIGURE_MP_APPLICATION
-    #ifndef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
-      #ifndef CONFIGURE_MP_NODE_NUMBER
-        #define CONFIGURE_MP_NODE_NUMBER                NODE_NUMBER
-      #endif
-      #ifndef CONFIGURE_MP_MAXIMUM_NODES
-        #define CONFIGURE_MP_MAXIMUM_NODES              2
-      #endif
+    #ifndef CONFIGURE_MP_NODE_NUMBER
+      #define CONFIGURE_MP_NODE_NUMBER                NODE_NUMBER
+    #endif
-      #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
-        #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS     32
-      #endif
-      #define _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
-        _Configure_From_workspace( \
-          (_global_objects) * sizeof(Objects_MP_Control) \
+    #ifndef CONFIGURE_MP_MAXIMUM_NODES
+      #define CONFIGURE_MP_MAXIMUM_NODES              2
+    #endif
-      #ifndef CONFIGURE_MP_MAXIMUM_PROXIES
-        #define CONFIGURE_MP_MAXIMUM_PROXIES            32
-      #endif
-      #define _CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \
-        _Configure_From_workspace((_proxies) \
-          * (sizeof(Thread_Proxy_control) \
-            + sizeof(Thread_queue_Configured_heads)))
-      #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
-        #include <mpci.h>
-        #define CONFIGURE_MP_MPCI_TABLE_POINTER         &MPCI_table
-      #endif
+    #ifndef CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
+      #define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS     32
+    #endif
+    #define _CONFIGURE_MEMORY_FOR_GLOBAL_OBJECTS(_global_objects) \
+      _Configure_From_workspace( \
+        (_global_objects) * sizeof(Objects_MP_Control) \
-      #ifdef CONFIGURE_INIT
-        rtems_multiprocessing_table Multiprocessing_configuration = {
-          CONFIGURE_MP_NODE_NUMBER,               /* local node number */
-          CONFIGURE_MP_MAXIMUM_NODES,             /* maximum # nodes */
-          CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,    /* maximum # global objects */
-          CONFIGURE_MP_MAXIMUM_PROXIES,           /* maximum # proxies */
-          CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK, /* MPCI stack > minimum */
-          CONFIGURE_MP_MPCI_TABLE_POINTER         /* ptr to MPCI config table */
-      #endif
+    #ifndef CONFIGURE_MP_MAXIMUM_PROXIES
+      #define CONFIGURE_MP_MAXIMUM_PROXIES            32
+    #endif
+    #define _CONFIGURE_MEMORY_FOR_PROXIES(_proxies) \
+      _Configure_From_workspace((_proxies) \
+        * (sizeof(Thread_Proxy_control) \
+          + sizeof(Thread_queue_Configured_heads)))
+    #ifndef CONFIGURE_MP_MPCI_TABLE_POINTER
+      #include <mpci.h>
+      #define CONFIGURE_MP_MPCI_TABLE_POINTER         &MPCI_table
+    #endif
-      #define CONFIGURE_MULTIPROCESSING_TABLE    &Multiprocessing_configuration
+    #ifdef CONFIGURE_INIT
+      rtems_multiprocessing_table Multiprocessing_configuration = {
+        CONFIGURE_MP_NODE_NUMBER,               /* local node number */
+        CONFIGURE_MP_MAXIMUM_NODES,             /* maximum # nodes */
+        CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,    /* maximum # global objects */
+        CONFIGURE_MP_MAXIMUM_PROXIES,           /* maximum # proxies */
+        CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK, /* MPCI stack > minimum */
+        CONFIGURE_MP_MPCI_TABLE_POINTER         /* ptr to MPCI config table */
+    #endif
-      #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
+    #define CONFIGURE_MULTIPROCESSING_TABLE    &Multiprocessing_configuration
-    #endif /* CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE */
+    #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
   #else
     #define CONFIGURE_MULTIPROCESSING_TABLE NULL
     #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
@@ -3146,6 +3142,10 @@ struct _reent *__getreent(void)
   #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
 #endif
+#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
+  #warning "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
+#endif
 #ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
   #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
 #endif
2.16.4
