[PATCH 2/5] config: Add _MPCI_Configuration
Thu Dec 12 08:43:04 UTC 2019
Replace the user MPCI configuration table with a system provided
_MPCI_Configuration.
Update #3735.
 bsps/include/shm_driver.h            |  2 +-
 cpukit/Makefile.am                   |  1 +
 cpukit/include/rtems/confdefs.h      | 16 +++++----
 cpukit/include/rtems/config.h        | 63 ++----------------------------------
 cpukit/include/rtems/rtems/types.h   |  5 +++
 cpukit/include/rtems/score/mpci.h    | 34 +++++++++++++++++++
 cpukit/libmisc/monitor/mon-monitor.c |  3 +-
 cpukit/libmisc/monitor/mon-mpci.c    | 15 +++------
 cpukit/libmisc/monitor/mon-server.c  |  4 +--
 cpukit/score/src/mpci.c              | 26 ++-------------
 cpukit/score/src/mpcidefault.c       | 31 ++++++++++++++++++
 cpukit/score/src/objectmp.c          |  6 ++--
 cpukit/score/src/thread.c            |  2 +-
 testsuites/sptests/spsize/size.c     |  9 +-----
 14 files changed, 99 insertions(+), 118 deletions(-)
 create mode 100644 cpukit/score/src/mpcidefault.c
diff --git a/bsps/include/shm_driver.h b/bsps/include/shm_driver.h
index 3dca866aa1..f81945b3d8 100644
--- a/bsps/include/shm_driver.h
+++ b/bsps/include/shm_driver.h
@@ -433,7 +433,7 @@ struct shm_config_info {
 typedef struct shm_config_info shm_config_table;
-#define SHM_MAXIMUM_NODES Multiprocessing_configuration.maximum_nodes
+#define SHM_MAXIMUM_NODES _MPCI_Configuration.maximum_nodes
 /* global variables */
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 71daca821a..6e5d05ceea 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1060,6 +1060,7 @@ librtemscpu_a_SOURCES += rtems/src/semmp.c
 librtemscpu_a_SOURCES += rtems/src/signalmp.c
 librtemscpu_a_SOURCES += rtems/src/taskmp.c
 librtemscpu_a_SOURCES += score/src/mpci.c
+librtemscpu_a_SOURCES += score/src/mpcidefault.c
 librtemscpu_a_SOURCES += score/src/objectmp.c
 librtemscpu_a_SOURCES += score/src/threadmp.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 6265350bef..c827f2c188 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -1853,7 +1853,15 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #endif
     #ifdef CONFIGURE_INIT
-      rtems_multiprocessing_table Multiprocessing_configuration = {
+      #if CONFIGURE_MP_NODE_NUMBER < 1
+        #error "CONFIGURE_MP_NODE_NUMBER must be greater than or equal to one"
+      #endif
+      #if CONFIGURE_MP_NODE_NUMBER > CONFIGURE_MP_MAXIMUM_NODES
+        #error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
+      #endif
+      const MPCI_Configuration _MPCI_Configuration = {
         CONFIGURE_MP_NODE_NUMBER,               /* local node number */
         CONFIGURE_MP_MAXIMUM_NODES,             /* maximum # nodes */
         CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS,    /* maximum # global objects */
@@ -1863,11 +1871,8 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
     #endif
-    #define CONFIGURE_MULTIPROCESSING_TABLE    &Multiprocessing_configuration
     #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
   #else
-    #define CONFIGURE_MULTIPROCESSING_TABLE NULL
     #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
   #endif /* CONFIGURE_MP_APPLICATION */
 #else
@@ -2896,9 +2901,6 @@ struct _reent *__getreent(void)
         false,
       #endif
     #endif
-    #if defined(RTEMS_MULTIPROCESSING)
-      CONFIGURE_MULTIPROCESSING_TABLE,        /* pointer to MP config table */
-    #endif
     #ifdef RTEMS_SMP
       _CONFIGURE_MAXIMUM_PROCESSORS,
     #endif
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 23fad8d83c..15e944dd2f 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -35,7 +35,7 @@
 #include <rtems/posix/config.h>
 #include <rtems/extension.h>
-#include <rtems/score/mpci.h>
+#include <rtems/rtems/types.h>
 #endif
 #ifdef __cplusplus
@@ -53,35 +53,6 @@ extern "C" {
 #define rtems_resource_maximum_per_allocation(resource) \
   _Objects_Maximum_per_allocation(resource)
-#if defined(RTEMS_MULTIPROCESSING)
- *  The following records define the Multiprocessor Configuration
- *  Table.  This table defines the multiprocessor system
- *  characteristics which must be known by RTEMS in a multiprocessor
- *  system.
-typedef struct {
-  /** This is the local node number. */
-  uint32_t            node;
-  /** This is the maximum number of nodes in system. */
-  uint32_t            maximum_nodes;
-  /** This is the maximum number of global objects. */
-  uint32_t            maximum_global_objects;
-  /** This is the maximum number of proxies. */
-  uint32_t            maximum_proxies;
-   * The MPCI Receive server is assumed to have a stack of at least
-   * minimum stack size.  This field specifies the amount of extra
-   * stack this task will be given in bytes.
-  uint32_t            extra_mpci_receive_server_stack;
-  /** This is a pointer to User/BSP provided MPCI Table. */
-  rtems_mpci_table   *User_mpci_table;
-} rtems_multiprocessing_table;
-#endif
  * @brief Task stack allocator initialization hook.
@@ -206,9 +177,6 @@ typedef struct {
     bool                         smp_enabled;
   #endif
-    rtems_multiprocessing_table   *User_multiprocessing_table;
-  #endif
   #ifdef RTEMS_SMP
     uint32_t                     maximum_processors;
   #endif
@@ -219,31 +187,6 @@ typedef struct {
 extern const rtems_configuration_table Configuration;
-   *  This points to the multiprocessing configuration table.
-  extern rtems_multiprocessing_table *_Configuration_MP_table;
-#endif
-   * @brief RTEMS multiprocessing configuration table.
-   * This is the RTEMS Multiprocessing Configuration Table expected to
-   * be generated by confdefs.h.
-  extern rtems_multiprocessing_table Multiprocessing_configuration;
-   *  This is the default Multiprocessing Configuration Table.
-   *  It is used in single processor configurations.
-  extern const rtems_multiprocessing_table
-    _Initialization_Default_multiprocessing_table;
-#endif
  *  Some handy macros to avoid dependencies on either the BSP
  *  or the exact format of the configuration table.
@@ -308,10 +251,10 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
   #define rtems_configuration_get_user_multiprocessing_table() \
-        (Configuration.User_multiprocessing_table)
+    (&_MPCI_Configuration)
 #else
-        NULL
+    NULL
 #endif
diff --git a/cpukit/include/rtems/rtems/types.h b/cpukit/include/rtems/rtems/types.h
index 47c3b4c04e..b0600eb0a8 100644
--- a/cpukit/include/rtems/rtems/types.h
+++ b/cpukit/include/rtems/rtems/types.h
@@ -221,6 +221,11 @@ typedef MPCI_Entry                 rtems_mpci_entry;
 typedef MPCI_Control               rtems_mpci_table;
+ * @brief Structure which is used to configure an MPCI handler.
+typedef MPCI_Configuration         rtems_multiprocessing_table;
 #endif
diff --git a/cpukit/include/rtems/score/mpci.h b/cpukit/include/rtems/score/mpci.h
index e5bcdbaced..a72b1f0d5b 100644
--- a/cpukit/include/rtems/score/mpci.h
+++ b/cpukit/include/rtems/score/mpci.h
@@ -128,6 +128,40 @@ typedef struct {
   MPCI_receive_entry         receive_packet;
 } MPCI_Control;
+ *  The following records define the Multiprocessor Configuration
+ *  Table.  This table defines the multiprocessor system
+ *  characteristics which must be known by RTEMS in a multiprocessor
+ *  system.
+typedef struct {
+  /** This is the local node number. */
+  uint32_t            node;
+  /** This is the maximum number of nodes in system. */
+  uint32_t            maximum_nodes;
+  /** This is the maximum number of global objects. */
+  uint32_t            maximum_global_objects;
+  /** This is the maximum number of proxies. */
+  uint32_t            maximum_proxies;
+   * The MPCI Receive server is assumed to have a stack of at least
+   * minimum stack size.  This field specifies the amount of extra
+   * stack this task will be given in bytes.
+  uint32_t            extra_mpci_receive_server_stack;
+  /** This is a pointer to User/BSP provided MPCI Table. */
+  MPCI_Control       *User_mpci_table;
+} MPCI_Configuration;
+ * @brief The MPCI configuration.
+ * Provided by the application via <rtems/confdefs.h>.
+extern const MPCI_Configuration _MPCI_Configuration;
 #ifdef __cplusplus
diff --git a/cpukit/libmisc/monitor/mon-monitor.c b/cpukit/libmisc/monitor/mon-monitor.c
index a990548e61..9c099dc57c 100644
--- a/cpukit/libmisc/monitor/mon-monitor.c
+++ b/cpukit/libmisc/monitor/mon-monitor.c
@@ -360,8 +360,7 @@ void rtems_monitor_node_cmd(
   if ((new_node >= 1) &&
-    _Configuration_MP_table &&
-    (new_node <= _Configuration_MP_table->maximum_nodes))
+    (new_node <= _MPCI_Configuration.maximum_nodes))
 	rtems_monitor_default_node = new_node;
 #endif
diff --git a/cpukit/libmisc/monitor/mon-mpci.c b/cpukit/libmisc/monitor/mon-mpci.c
index 1ede142e52..9616518473 100644
--- a/cpukit/libmisc/monitor/mon-mpci.c
+++ b/cpukit/libmisc/monitor/mon-mpci.c
@@ -28,13 +28,10 @@ rtems_monitor_mpci_canonical(
     const void           *config_void
-    const rtems_configuration_table *c = &Configuration;
-    rtems_multiprocessing_table *m;
-    rtems_mpci_table *mt;
+    const rtems_multiprocessing_table *m;
+    const rtems_mpci_table *mt;
-    m = c->User_multiprocessing_table;
-    if (m == 0)
-        return;
+    m = rtems_configuration_get_user_multiprocessing_table();
     mt = m->User_mpci_table;
     canonical_mpci->node = m->node;
@@ -70,19 +67,15 @@ rtems_monitor_mpci_next(
     rtems_id              *next_id
     int n = rtems_object_id_get_index(*next_id);
     if (n >= 1)
         goto failed;
-    if ( ! c->User_multiprocessing_table)
-        goto failed;
     _Objects_Allocator_lock();
     *next_id += 1;
-    return (void *) c;
+    return &Configuration;
 failed:
     *next_id = RTEMS_OBJECT_ID_FINAL;
diff --git a/cpukit/libmisc/monitor/mon-server.c b/cpukit/libmisc/monitor/mon-server.c
index 3cb6cdf7ce..d8a1687f0b 100644
--- a/cpukit/libmisc/monitor/mon-server.c
+++ b/cpukit/libmisc/monitor/mon-server.c
@@ -221,9 +221,9 @@ rtems_monitor_server_init(
     rtems_status_code status;
     if (_System_state_Is_multiprocessing    &&
-        (_Configuration_MP_table->maximum_nodes > 1))
+        (_MPCI_Configuration.maximum_nodes > 1))
-        uint32_t   maximum_nodes = _Configuration_MP_table->maximum_nodes;
+        uint32_t   maximum_nodes = _MPCI_Configuration.maximum_nodes;
          * create the msg que our server will listen
diff --git a/cpukit/score/src/mpci.c b/cpukit/score/src/mpci.c
index f488325fc5..424090b117 100644
--- a/cpukit/score/src/mpci.c
+++ b/cpukit/score/src/mpci.c
@@ -27,7 +27,6 @@
-#include <rtems/config.h>
 #include <rtems/sysinit.h>
 RTEMS_STATIC_ASSERT(
@@ -39,18 +38,6 @@ RTEMS_STATIC_ASSERT(
 bool _System_state_Is_multiprocessing;
-rtems_multiprocessing_table *_Configuration_MP_table;
-const rtems_multiprocessing_table
- _Initialization_Default_multiprocessing_table = {
-  1,                        /* local node number */
-  1,                        /* maximum number nodes in system */
-  0,                        /* maximum number global objects */
-  0,                        /* maximum number proxies */
-  STACK_MINIMUM_SIZE,       /* MPCI receive server stack size */
-  NULL                      /* pointer to MPCI address table */
  *  This is the core semaphore which the MPCI Receive Server blocks on.
@@ -72,14 +59,7 @@ static void _MPCI_Handler_early_initialization( void )
    *  In an MP configuration, internally we view single processor
    *  systems as a very restricted multiprocessor system.
-  _Configuration_MP_table = rtems_configuration_get_user_multiprocessing_table();
-  if ( _Configuration_MP_table == NULL ) {
-    _Configuration_MP_table = RTEMS_DECONST(
-      rtems_multiprocessing_table *,
-      &_Initialization_Default_multiprocessing_table
-  } else {
+  if ( _MPCI_Configuration.maximum_nodes > 1 ) {
     _System_state_Is_multiprocessing = true;
@@ -92,7 +72,7 @@ static void _MPCI_Handler_initialization( void )
   _Objects_MP_Handler_initialization();
-  users_mpci_table = _Configuration_MP_table->User_mpci_table;
+  users_mpci_table = _MPCI_Configuration.User_mpci_table;
   if ( _System_state_Is_multiprocessing && !users_mpci_table )
     _Internal_error( INTERNAL_ERROR_NO_MPCI );
@@ -152,7 +132,7 @@ static void _MPCI_Create_server( void )
     NULL,        /* allocate the stack */
     _Stack_Minimum() +
       CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK +
-      _Configuration_MP_table->extra_mpci_receive_server_stack,
+      _MPCI_Configuration.extra_mpci_receive_server_stack
     CPU_ALL_TASKS_ARE_FP,
     PRIORITY_PSEUDO_ISR,
     false,       /* no preempt */
diff --git a/cpukit/score/src/mpcidefault.c b/cpukit/score/src/mpcidefault.c
new file mode 100644
index 0000000000..60f1ef31a7
--- /dev/null
+++ b/cpukit/score/src/mpcidefault.c
@@ -0,0 +1,31 @@
+ * @file
+ * @brief Multiprocessing Communications Interface (MPCI) Default Configuration
+ * @ingroup RTEMSScoreMPCI
+ *  COPYRIGHT (c) 1989-2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/mpci.h>
+#include <rtems/score/stack.h>
+const MPCI_Configuration _MPCI_Configuration = {
+  1,                        /* local node number */
+  1,                        /* maximum number nodes in system */
+  0,                        /* maximum number global objects */
+  0,                        /* maximum number proxies */
+  STACK_MINIMUM_SIZE,       /* MPCI receive server stack size */
+  NULL                      /* pointer to MPCI address table */
diff --git a/cpukit/score/src/objectmp.c b/cpukit/score/src/objectmp.c
index 74ed22033a..1910b8ccba 100644
--- a/cpukit/score/src/objectmp.c
+++ b/cpukit/score/src/objectmp.c
@@ -161,8 +161,8 @@ void _Objects_MP_Handler_early_initialization(void)
   uint32_t   node;
-  node                   = _Configuration_MP_table->node;
-  maximum_nodes          = _Configuration_MP_table->maximum_nodes;
+  node                   = _MPCI_Configuration.node;
+  maximum_nodes          = _MPCI_Configuration.maximum_nodes;
   if ( node < 1 || node > maximum_nodes )
     _Internal_error( INTERNAL_ERROR_INVALID_NODE );
@@ -175,7 +175,7 @@ void _Objects_MP_Handler_initialization( void )
-  maximum_global_objects = _Configuration_MP_table->maximum_global_objects;
+  maximum_global_objects = _MPCI_Configuration.maximum_global_objects;
   _Objects_MP_Maximum_global_objects = maximum_global_objects;
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index 812d9296af..32a5132eee 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -62,7 +62,7 @@ void _Thread_Handler_initialization(void)
     rtems_configuration_get_stack_allocate_init_hook();
     uint32_t maximum_proxies =
-      _Configuration_MP_table->maximum_proxies;
+      _MPCI_Configuration.maximum_proxies;
   #endif
   if ( rtems_configuration_get_stack_allocate_hook() == NULL ||
diff --git a/testsuites/sptests/spsize/size.c b/testsuites/sptests/spsize/size.c
index 1369cd7072..578576cba7 100644
--- a/testsuites/sptests/spsize/size.c
+++ b/testsuites/sptests/spsize/size.c
@@ -250,10 +250,7 @@ uninitialized =
 /*clock.h*/     0                                         +
-/*config.h*/
-                (sizeof _Configuration_MP_table)          +
-        #endif
+/*config.h*/    0                                         +
 /*context.h*/   (sizeof _Thread_Dispatch_necessary)        +
@@ -433,10 +430,6 @@ uninitialized += (sizeof _CPU_Interrupt_stack_low) +
 initialized +=
 /*copyrt.h*/    (strlen(_Copyright_Notice)+1)             +
-                (sizeof _Initialization_Default_multiprocessing_table)  +
-#endif
                 (strlen(_RTEMS_version)+1);
2.16.4
