Placement of new unit and validation tests?
Fri Dec 13 06:49:18 UTC 2019
On 12/12/2019 17:10, Chris Johns wrote:
> On 13/12/19 12:56 am, Sebastian Huber wrote:
>> I would like to write new test cases and programs using the RTEMS Test Framework:
>> https://docs.rtems.org/branches/master/eng/test-framework.html
> I have no specific issue with the test framework as a way forward however I am
> not yet comfortable about the integration of these new types of tests into the
> eco-system plus what happens to the existing tests?
I think we should keep the existing tests as is. They are a big asset.
You never know if a new test is identical to existing ones. Maybe the
unit test like tests should move to "testsuites/unit" if someone has
enough spare time.
> Currently the `rtems-test` command is the only supported way we have to run the
> tests on simulators and hardware and I am busy promoting and encouraging users
> in our community to integrate to this tool and to use it to validate their
> systems. I feel it is important we maintain this command and what it does.
Yes, this is also my point of view.
> I am concerned I am expected to integrate these new tests into the `rtems-test`
> command. It would be nice if you could explain what needs to be done in the
> eco-system to integrate these type of tests and how you think this work will be
> done?
The new test still produce the begin/end of test markers. So for now
nothing needs to change. In the long run it would be good to enhance the
test output parser to generate detailed test reports from it. For a
proof of concept see:
https://ftp.rtems.org/pub/rtems/people/sebh/test-report.pdf
This has to develop over time. We need also solutions for the test plans
and the traceability to requirements. Ideally, we should be able to get
a documentation set for a particular target in HTML which provides
cross-references throughout the documentation, e.g. from requirement to
test plan to test code to test report and vice versa.
>> There will be two sets of tests. One set are unit tests. The other set are
>> validation tests. The validation tests check that the implementation meets its
>> requirements. The unit tests don't need a link to requirements. They can be used
>> to test internal APIs like the chains, red-black trees, etc. independent of
>> requirements.
>> I suggest to add "testsuites/unit" for unit tests and "testsuites/validation"
>> for validation tests.
> I am not sure about these names but I cannot think of anything better. I see
> below you will provide another layer of directories in these paths. That is good.
>> For validation tests we need a link from test cases to requirements. This needs
>> to be discussed separately.
> Sure. It would be good if the eco-system aspects are discussed as well.
>> With the RTEMS Test Framework test cases can be written independently from the
>> test runner program defining the test suite. This could be used for example to
>> run a test case in different contexts. Another option is to group test cases
>> depending on the available RAM in the target system, e.g. bigger systems can
>> execute more test cases at once. This gives raise to a different organization
>> compared to the existing tests programs.
> Can you please explain how rtems-test is to handle integrated tests?
The rtems-test command can just grab the *.exe files and run them.
> How do you manage possible cross-talk between tests?
You can plug in checkers which ensure that a particular system state
before and after the test case didn't change:
https://docs.rtems.org/branches/master/eng/test-framework.html#test-case-resource-accounting
https://git.rtems.org/rtems/tree/testsuites/libtests/ttest01/init.c#n253
This helps to ensure that test cases have no persistent effects
influencing test cases which are run after them.
There are test fixtures which help you to setup and tear down a test case:
https://docs.rtems.org/branches/master/eng/test-framework.html#test-fixture
It is currently not implemented, but it is possible to randomly reorder
the test cases and run the test suite again. You can do this multiple
times. If test suite results change, then some test cases have
persistent effects.
> I think the approach is sound as the time to load a test is often much more than
> the time the test runs.
>> I suggest to add topic directories to "testsuites/unit" and
>> "testsuites/validation", e.g. "testsuites/unit/chains". Test case files use a
>> naming scheme of "tc-${topic}-${name}.c" and are placed in the corresponding
>> topic directory.  Test suite files use a naming scheme of "ts-${name}.c" and are
>> placed in "testsuites/unit" or "testsuites/validation".
> Is ${name} a name of a C file selected by the developer? Can there be more than
> one ${name}s ?
Yes, the ${name} is selected by the developer. You can have as many
names as you want.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
