psim tests timing out
Sebastian Huber
Fri Dec 13 08:01:26 UTC 2019
On 11/11/2019 23:51, Joel Sherrill wrote:
> Hi
> I was running tests on psim and they are all timing out.
> Any ideas or is this working for someone else?
Yes, I have the same problem. Running them by hand works:
powerpc-rtems5-run -f
/scratch/git-rtems-tools/tester/rtems/testing/bsps/psim-device-tree
ticker.exe
OpenPIC Version ? (1 CPUs and 1 IRQ sources) at 0x202571776
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
Overriding NumSources (1) from configuration with 16
OpenPIC timer frequency is not set
BATs must not overlap; area 0x08000000..0x09000000 hits DBAT 0
BATs must not overlap; area 0x0c000000..0x0d000000 hits DBAT 0
*** BEGIN OF TEST CLOCK TICK ***
*** TEST VERSION: 5.0.0.782113767f3e60389423c169f5c337ec3fb50feb
*** TEST STATE: EXPECTED_PASS
*** TEST BUILD: RTEMS_MULTIPROCESSING RTEMS_NETWORKING RTEMS_POSIX_API
*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB
f3b44b25d1353253d1454abc695621aafb8c4a97, Newlib d14714c69)
TA1 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:00 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:04 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:09 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:09 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:14 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:14 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:19 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:19 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:24 12/31/1988
TA3 - rtems_clock_get_tod - 09:00:29 12/31/1988
TA2 - rtems_clock_get_tod - 09:00:29 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:29 12/31/1988
TA1 - rtems_clock_get_tod - 09:00:34 12/31/1988
*** END OF TEST CLOCK TICK ***
*** FATAL ***
fatal source: 5 (RTEMS_FATAL_SOURCE_EXIT)
fatal code: 0 (0x00000000)
RTEMS version: 5.0.0.782113767f3e60389423c169f5c337ec3fb50feb
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB
executing thread ID: 0x08a010003
executing thread name: TA2
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
