psim tests timing out
Fri Dec 13 13:10:27 UTC 2019
On Fri, Dec 13, 2019, 6:30 AM Chris Johns <chrisj at rtems.org> wrote:
> On 13/12/19 11:05 pm, Sebastian Huber wrote:
> > On 13/12/2019 13:03, Joel Sherrill wrote:
> >> It appears based on testing with Chris that the gdb mi code from the
> tester
> >> works with Python 3 and not 2. Would you happen to be using python 2?
> > This seems to be the case:
> > python --version
> > Python 2.7.14
> > I guess with the next OpenSUSE update Python 2 is history.
> I think there is an issue with the locking in gdb.py or the locking and
> piped IO
> in execute.py. I need to take a closer look when I get home.
I haven't confirmed this but MIPS/jmr3904 should be broken the same way if
it isn't using run.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191213/544953d8/attachment.html>
