[PATCH 2/7] score: Add _Memory_Dirty()
Sebastian Huber
Mon Dec 16 12:42:07 UTC 2019
Update #3838.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/score/memory.h | 11 ++++++++-
cpukit/score/src/memorydirty.c | 48 +++++++++++++++++++++++++++++++++++++
3 files changed, 59 insertions(+), 1 deletion(-)
create mode 100644 cpukit/score/src/memorydirty.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 4f21b48a32..62c34c9c00 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -853,6 +853,7 @@ librtemscpu_a_SOURCES += score/src/heapiterate.c
librtemscpu_a_SOURCES += score/src/heapgreedy.c
librtemscpu_a_SOURCES += score/src/heapnoextend.c
librtemscpu_a_SOURCES += score/src/memoryallocate.c
+librtemscpu_a_SOURCES += score/src/memorydirty.c
librtemscpu_a_SOURCES += score/src/objectallocate.c
librtemscpu_a_SOURCES += score/src/objectclose.c
librtemscpu_a_SOURCES += score/src/objectextendinformation.c
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
index e4d1198862..dd3b7833a3 100644
--- a/cpukit/include/rtems/score/memory.h
+++ b/cpukit/include/rtems/score/memory.h
@@ -306,7 +306,7 @@ const Memory_Information *_Memory_Get( void );
* @brief Allocate a memory area from the memory information.
- * It is not possible to free the memory allocated by this function.
+ * It is not possible to free the memory area allocated by this function.
* @param information The memory information.
* @param size The size in bytes of the memory area to allocate.
@@ -322,6 +322,15 @@ void *_Memory_Allocate(
uintptr_t alignment
+ * @brief Dirty all free memory areas of the memory information.
+ * Write 0xcf to all bytes of the free memory areas.
+ * @param information The memory information.
+void _Memory_Dirty( const Memory_Information *information );
#ifdef __cplusplus
diff --git a/cpukit/score/src/memorydirty.c b/cpukit/score/src/memorydirty.c
new file mode 100644
index 0000000000..b404ca126c
--- /dev/null
+++ b/cpukit/score/src/memorydirty.c
@@ -0,0 +1,48 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/memory.h>
+#include <string.h>
+ Memory_Area *area;
+ const Memory_Area *end;
+ area = &information->areas[ 0 ];
+ end = &information->areas[ information->count ];
+ while ( area != end ) {
+ memset( _Memory_Free_begin( area ), 0xcf, _Memory_Free_size( area ) );
+ ++area;
2.16.4
