[PATCH 1/7] score: Add Memory Handler
Mon Dec 16 12:42:06 UTC 2019
Update #3838.
 cpukit/Makefile.am                  |   1 +
 cpukit/headers.am                   |   1 +
 cpukit/include/rtems/score/memory.h | 331 ++++++++++++++++++++++++++++++++++++
 cpukit/score/src/memoryallocate.c   |  67 ++++++++
 4 files changed, 400 insertions(+)
 create mode 100644 cpukit/include/rtems/score/memory.h
 create mode 100644 cpukit/score/src/memoryallocate.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 2983fc5b9e..4f21b48a32 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -852,6 +852,7 @@ librtemscpu_a_SOURCES += score/src/heapresizeblock.c
 librtemscpu_a_SOURCES += score/src/heapiterate.c
 librtemscpu_a_SOURCES += score/src/heapgreedy.c
 librtemscpu_a_SOURCES += score/src/heapnoextend.c
+librtemscpu_a_SOURCES += score/src/memoryallocate.c
 librtemscpu_a_SOURCES += score/src/objectallocate.c
 librtemscpu_a_SOURCES += score/src/objectclose.c
 librtemscpu_a_SOURCES += score/src/objectextendinformation.c
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 90cf80369f..aa2db5771a 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -331,6 +331,7 @@ include_rtems_score_HEADERS += include/rtems/score/io.h
 include_rtems_score_HEADERS += include/rtems/score/isr.h
 include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
 include_rtems_score_HEADERS += include/rtems/score/isrlock.h
+include_rtems_score_HEADERS += include/rtems/score/memory.h
 include_rtems_score_HEADERS += include/rtems/score/mpci.h
 include_rtems_score_HEADERS += include/rtems/score/mpciimpl.h
 include_rtems_score_HEADERS += include/rtems/score/mppkt.h
diff --git a/cpukit/include/rtems/score/memory.h b/cpukit/include/rtems/score/memory.h
new file mode 100644
index 0000000000..e4d1198862
--- /dev/null
+++ b/cpukit/include/rtems/score/memory.h
@@ -0,0 +1,331 @@
+ * @file
+ * @ingroup RTEMSScoreMemory
+ * @brief Memory Handler API
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 embedded brains GmbH
+ * are met:
+#ifndef _RTEMS_SCORE_MEMORY_H
+#define _RTEMS_SCORE_MEMORY_H
+#include <rtems/score/basedefs.h>
+#include <rtems/score/assert.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @defgroup RTEMSScoreMemory Memory Handler
+ * @brief Low level handler to provide memory areas for higher level memory
+ * handlers such as the Workspace Handler.
+ * @brief The memory area description.
+typedef struct {
+   * @brief A pointer to the begin of the memory area.
+  const void *begin;
+   * @brief A pointer to the begin of the free area of the memory area.
+  void *free;
+   * @brief A pointer to the end of the memory area.
+  const void *end;
+} Memory_Area;
+ * @brief The memory information.
+typedef struct {
+   * @brief The count of memory areas.
+  size_t count;
+   * @brief The memory area table.
+  Memory_Area *areas;
+} Memory_Information;
+ * @brief Statically initialize a memory information.
+ * @param areas The designator of an array of the memory areas.
+#define MEMORY_INFORMATION_INITIALIZER( areas ) \
+  { RTEMS_ARRAY_SIZE( areas ), ( areas ) }
+ * @brief Statically initialize a memory area.
+ * @param begin The begin of the memory area.
+ * @param end The end of the memory area.
+#define MEMORY_INITIALIZER( begin, end ) { ( begin ), ( begin ), ( end ) }
+ * @brief Get the memory area count.
+ * @param information The memory information.
+ * @return The memory area count.
+RTEMS_INLINE_ROUTINE size_t _Memory_Get_count(
+  const Memory_Information *information
+  return information->count;
+ * @brief Get a memory area by index.
+ * @param index The index of the memory area to return.
+ * @return The memory area of the specified index.
+RTEMS_INLINE_ROUTINE Memory_Area *_Memory_Get_area(
+  const Memory_Information *information,
+  size_t                    index
+  _Assert( index < _Memory_Get_count( information ) );
+  return &information->areas[ index ];
+ * @brief Initialize the memory area.
+ * @param area The memory area.
+RTEMS_INLINE_ROUTINE void _Memory_Initialize(
+  Memory_Area *area,
+  void        *begin,
+  void        *end
+  area->begin = begin;
+  area->free = begin;
+  area->end = end;
+ * @brief Initialize the memory area by size.
+ * @param size The size of the memory area in bytes.
+RTEMS_INLINE_ROUTINE void _Memory_Initialize_by_size(
+  void        *begin,
+  uintptr_t    size
+  area->end = (char *) begin + size;
+ * @brief Get the memory area begin.
+ * @return The memory area begin.
+RTEMS_INLINE_ROUTINE const void *_Memory_Get_begin( const Memory_Area *area )
+  return area->begin;
+ * @brief Set the memory area begin.
+ * @param begin The memory area begin.
+RTEMS_INLINE_ROUTINE void _Memory_Set_begin(
+  const void  *begin
+ * @brief Get the memory area end.
+ * @return The memory area end.
+RTEMS_INLINE_ROUTINE const void *_Memory_Get_end( const Memory_Area *area )
+  return area->end;
+ * @brief Set the memory area end.
+ * @param end The memory area end.
+RTEMS_INLINE_ROUTINE void _Memory_Set_end(
+  const void  *end
+  area->end = end;
+ * @brief Get the memory area size.
+ * @return The memory area size in bytes.
+RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_size( const Memory_Area *area )
+  return (uintptr_t) area->end - (uintptr_t) area->begin;
+ * @brief Get the begin of the free area of the memory area.
+ * @return The free memory area begin the memory area.
+RTEMS_INLINE_ROUTINE void *_Memory_Get_free_begin( const Memory_Area *area )
+  return area->free;
+ * @brief Set the begin of the free area of the memory area.
+ * @param begin The free memory area begin the memory area.
+RTEMS_INLINE_ROUTINE void _Memory_Set_free_begin(
+  void        *begin
+ * @brief Get the size of the free memory area of the memory area.
+ * @return The free memory area size in bytes of the memory area.
+RTEMS_INLINE_ROUTINE uintptr_t _Memory_Get_free_size( const Memory_Area *area )
+  return (uintptr_t) area->end - (uintptr_t) area->free;
+ * @brief Consume the specified size from the free memory area of the memory
+ * area.
+ * @param consume The bytes to consume from the free memory area of the memory
+ *   area.
+RTEMS_INLINE_ROUTINE void _Memory_Consume(
+  uintptr_t    consume
+  area->free = (char *) area->free + consume;
+ * @brief Return the memory information of this platform.
+ * This function is provided by the Board Support Package (BSP).  Using a
+ * function gives the BSPs a bit more freedom with respect to the
+ * implementation.  Calling this function shall not have side-effects.
+ * Initialization steps to set up the memory information shall be done in a
+ * system initialization handler (RTEMS_SYSINIT_MEMORY).
+ * @return The memory information.
+const Memory_Information *_Memory_Get( void );
+ * @brief Allocate a memory area from the memory information.
+ * It is not possible to free the memory allocated by this function.
+ * @param size The size in bytes of the memory area to allocate.
+ * @param alignment The alignment in bytes of the memory area to allocate.  It
+ *   must be a power of two.
+ * @retval NULL No such memory area available.
+ * @retval begin The begin of the allocated memory area.
+void *_Memory_Allocate(
+  uintptr_t                 size,
+  uintptr_t                 alignment
+#ifdef __cplusplus
+#endif /* _RTEMS_SCORE_MEMORY_H */
diff --git a/cpukit/score/src/memoryallocate.c b/cpukit/score/src/memoryallocate.c
index 0000000000..73de49d28c
--- /dev/null
+++ b/cpukit/score/src/memoryallocate.c
@@ -0,0 +1,67 @@
+ * Copyright (C) 2018, 2019 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/memory.h>
+  uintptr_t                 size,
+  Memory_Area       *area;
+  const Memory_Area *end;
+  uintptr_t          alignment_mask;
+  area = &information->areas[ 0 ];
+  end = &information->areas[ information->count ];
+  alignment_mask = alignment - 1;
+  while ( area != end ) {
+    uintptr_t alloc_begin;
+    uintptr_t alloc_end;
+    alloc_begin = (uintptr_t) area->free;
+    alloc_begin += alignment_mask;
+    alloc_begin &= ~alignment_mask;
+    alloc_end = alloc_begin + size;
+    if ( alloc_begin <= alloc_end && alloc_end <= (uintptr_t) area->end ) {
+      area->free = (void *) alloc_end;
+      return (void *) alloc_begin;
+    ++area;
+  return NULL;
2.16.4
