[PATCH 04/21] score: Remove _Stack_Ensure_minimum() call
Mon Dec 16 14:28:09 UTC 2019
This call is superfluous since _Thread_Initialize() will do this also.
Update #3835.
 cpukit/score/src/threadcreateidle.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/cpukit/score/src/threadcreateidle.c b/cpukit/score/src/threadcreateidle.c
index 65199f0f7d..3e6f19ee69 100644
--- a/cpukit/score/src/threadcreateidle.c
+++ b/cpukit/score/src/threadcreateidle.c
@@ -21,7 +21,6 @@
-#include <rtems/score/stackimpl.h>
 #include <rtems/score/sysstate.h>
 #include <rtems/score/userextimpl.h>
 #include <rtems/config.h>
@@ -55,7 +54,7 @@ static void _Thread_Create_idle_for_CPU( Per_CPU_Control *cpu )
     idle,
     scheduler,
     NULL,        /* allocate the stack */
-    _Stack_Ensure_minimum( rtems_configuration_get_idle_task_stack_size() ),
+    rtems_configuration_get_idle_task_stack_size(),
     CPU_IDLE_TASK_IS_FP,
     _Scheduler_Map_priority( scheduler, scheduler->maximum_priority ),
     true,        /* preemptable */
2.16.4
