[PATCH 06/21] score: Simplify TLS area allocation
Mon Dec 16 14:28:11 UTC 2019
Use the stack area to allocate the TLS area.
Update #3835.
 cpukit/Makefile.am                      |  2 +
 cpukit/include/rtems/confdefs.h         |  3 +-
 cpukit/include/rtems/config.h           |  8 +---
 cpukit/include/rtems/score/stack.h      | 11 ++++-
 cpukit/include/rtems/score/stackimpl.h  |  4 +-
 cpukit/include/rtems/score/tls.h        | 25 ++----------
 cpukit/score/src/configstackspacesize.c | 54 +++++++++++++++++++++++++
 cpukit/score/src/threadinitialize.c     | 30 +++++++-------
 cpukit/score/src/threadrestart.c        |  2 -
 cpukit/score/src/tlsallocsize.c         | 72 +++++++++++++++++++++++++++++++++
 cpukit/score/src/wkspace.c              | 38 -----------------
 11 files changed, 161 insertions(+), 88 deletions(-)
 create mode 100644 cpukit/score/src/configstackspacesize.c
 create mode 100644 cpukit/score/src/tlsallocsize.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 62c34c9c00..3ced5bdd4d 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1006,6 +1006,7 @@ librtemscpu_a_SOURCES += score/src/ioprintf.c
 librtemscpu_a_SOURCES += score/src/iovprintf.c
 librtemscpu_a_SOURCES += score/src/isrisinprogress.c
 librtemscpu_a_SOURCES += score/src/condition.c
+librtemscpu_a_SOURCES += score/src/configstackspacesize.c
 librtemscpu_a_SOURCES += score/src/futex.c
 librtemscpu_a_SOURCES += score/src/profilingisrentryexit.c
 librtemscpu_a_SOURCES += score/src/mutex.c
@@ -1016,6 +1017,7 @@ librtemscpu_a_SOURCES += score/src/smpbarrierwait.c
 librtemscpu_a_SOURCES += score/src/kern_tc.c
 librtemscpu_a_SOURCES += score/src/libatomic.c
 librtemscpu_a_SOURCES += score/src/processormaskcopy.c
+librtemscpu_a_SOURCES += score/src/tlsallocsize.c
 librtemscpu_a_SOURCES += sapi/src/chainappendnotify.c
 librtemscpu_a_SOURCES += sapi/src/chaingetnotify.c
 librtemscpu_a_SOURCES += sapi/src/chaingetwait.c
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 186ab0f39e..069666abda 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2791,12 +2791,13 @@ struct _reent *__getreent(void)
   uint32_t rtems_minimum_stack_size =
     CONFIGURE_MINIMUM_TASK_STACK_SIZE;
+  const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
    * This is the primary Configuration Table for this application.
   const rtems_configuration_table Configuration = {
     CONFIGURE_EXECUTIVE_RAM_SIZE,             /* required RTEMS workspace */
-    _CONFIGURE_STACK_SPACE_SIZE,               /* required stack space */
     CONFIGURE_MAXIMUM_USER_EXTENSIONS,        /* maximum dynamic extensions */
     CONFIGURE_MICROSECONDS_PER_TICK,          /* microseconds per clock tick */
     CONFIGURE_TICKS_PER_TIMESLICE,            /* ticks per timeslice quantum */
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index 15e944dd2f..6e3fa39a5f 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -94,11 +94,6 @@ typedef struct {
   uintptr_t                      work_space_size;
-   * This field specifies the size in bytes of the RTEMS thread stack space.
-  uintptr_t                      stack_space_size;
    * This field contains the maximum number of POSIX API
    * key value pairs which are configured for this application.
@@ -198,8 +193,7 @@ extern const rtems_configuration_table Configuration;
 #define rtems_configuration_get_stack_allocator_avoids_work_space() \
         (Configuration.stack_allocator_avoids_work_space)
-#define rtems_configuration_get_stack_space_size() \
-        (Configuration.stack_space_size)
+uintptr_t rtems_configuration_get_stack_space_size( void );
 #define rtems_configuration_get_work_space_size() \
         (Configuration.work_space_size + \
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index 1158f3472e..2ad362abd2 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -58,12 +58,19 @@ typedef struct {
 }   Stack_Control;
- *  This variable contains the the minimum stack size;
+ * @brief The minimum stack size.
- *  @note It is instantiated and set by User Configuration via confdefs.h.
+ * Application provided via <rtems/confdefs.h>.
 extern uint32_t rtems_minimum_stack_size;
+ * @brief The configured stack space size.
+extern const uintptr_t _Stack_Space_size;
 #ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/stackimpl.h b/cpukit/include/rtems/score/stackimpl.h
index 60704534c7..aafde5d1a0 100644
--- a/cpukit/include/rtems/score/stackimpl.h
+++ b/cpukit/include/rtems/score/stackimpl.h
@@ -23,6 +23,7 @@
 #include <rtems/score/stack.h>
 #include <rtems/score/context.h>
+#include <rtems/score/tls.h>
 #ifdef __cplusplus
 extern "C" {
@@ -87,7 +88,8 @@ RTEMS_INLINE_ROUTINE bool _Stack_Is_enough(
   size_t minimum;
-  minimum = _Stack_Minimum();
+  minimum = _TLS_Get_allocation_size();
+  minimum += _Stack_Minimum();
 #if ( CPU_HARDWARE_FP == TRUE ) || ( CPU_SOFTWARE_FP == TRUE )
   if ( is_fp ) {
diff --git a/cpukit/include/rtems/score/tls.h b/cpukit/include/rtems/score/tls.h
index dadcb770ad..1b9dae11b1 100644
--- a/cpukit/include/rtems/score/tls.h
+++ b/cpukit/include/rtems/score/tls.h
@@ -134,30 +134,11 @@ static inline uintptr_t _TLS_Get_thread_control_block_area_size(
- * @brief Returns the actual size that has to be allocated for this size and
- *      alignment.
+ * @brief Return the TLS area allocation size.
- * @param size The size for the operation.
- * @param alignment The alignment for the operation.
- * @return The actual allocation size.
+ * @return The TLS area allocation size.
-static inline uintptr_t _TLS_Get_allocation_size(
-  uintptr_t size,
-  uintptr_t alignment
-  uintptr_t allocation_size = 0;
-  allocation_size += _TLS_Heap_align_up( size );
-  allocation_size += _TLS_Get_thread_control_block_area_size( alignment );
-#ifndef __i386__
-  allocation_size += sizeof(TLS_Dynamic_thread_vector);
-#endif
-  return allocation_size;
+uintptr_t _TLS_Get_allocation_size( void );
  * @brief Copies TLS size bytes from the address tls_area and returns a pointer
diff --git a/cpukit/score/src/configstackspacesize.c b/cpukit/score/src/configstackspacesize.c
new file mode 100644
index 0000000000..4f0c24cee6
--- /dev/null
+++ b/cpukit/score/src/configstackspacesize.c
@@ -0,0 +1,54 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2014, 2019 embedded brains GmbH
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/config.h>
+#include <rtems/score/stack.h>
+#include <rtems/score/thread.h>
+  uintptr_t space_size;
+  space_size = _Stack_Space_size;
+   * In case we have a non-zero TLS size, then we need a TLS area for each
+   * thread.  These areas are allocated within the stack area from the stack
+   * space.  Ensure that the stack space is large enough to fulfill all requests
+   * known at configuration time (so excluding the unlimited option).  It is not
+   * possible to estimate the TLS size in the configuration at compile-time.
+   * The TLS size is determined at application link-time.
+  space_size += _Thread_Initial_thread_count * _TLS_Get_allocation_size();
+  return space_size;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 48444824b2..a1bc3b2939 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -42,7 +42,7 @@ bool _Thread_Initialize(
   Objects_Name                          name
-  uintptr_t                tls_size = _TLS_Get_size();
+  uintptr_t                tls_size;
   bool                     extension_status;
   size_t                   i;
   Scheduler_Node          *scheduler_node;
@@ -83,6 +83,8 @@ bool _Thread_Initialize(
       (char *) the_thread + add_on->source_offset;
+  tls_size = _TLS_Get_allocation_size();
   /* Allocate the stack for this thread */
 #if defined(RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API)
   if ( stack_area == NULL ) {
@@ -95,6 +97,7 @@ bool _Thread_Initialize(
 #endif
+    stack_size += tls_size;
     stack_area = _Stack_Allocate( stack_size );
@@ -116,6 +119,17 @@ bool _Thread_Initialize(
 #endif
+  /* Allocate thread-local storage (TLS) area in stack area */
+  if ( tls_size > 0 ) {
+    uintptr_t tls_align;
+    tls_align = (uintptr_t) _TLS_Alignment;
+    the_thread->Start.tls_area = (void *)
+      ( ( (uintptr_t) stack_area + tls_align - 1 ) & ~( tls_align - 1 ) );
+    stack_size -= tls_size;
+    stack_area = (char *) stack_area + tls_size;
   _Stack_Initialize(
      &the_thread->Start.Initial_stack,
      stack_area,
@@ -124,19 +138,6 @@ bool _Thread_Initialize(
   scheduler_index = 0;
-  /* Thread-local storage (TLS) area allocation */
-  if ( tls_size > 0 ) {
-    uintptr_t tls_align = _TLS_Heap_align_up( (uintptr_t) _TLS_Alignment );
-    uintptr_t tls_alloc = _TLS_Get_allocation_size( tls_size, tls_align );
-    the_thread->Start.tls_area =
-      _Workspace_Allocate_aligned( tls_alloc, tls_align );
-    if ( the_thread->Start.tls_area == NULL ) {
-      goto failed;
    *  Get thread queue heads
@@ -301,7 +302,6 @@ failed:
 #endif
-  _Workspace_Free( the_thread->Start.tls_area );
   _Freechain_Put(
     &information->Thread_queue_heads.Free,
     the_thread->Wait.spare_heads
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index aa47fefd1f..0c6890324c 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -185,8 +185,6 @@ static void _Thread_Free( Thread_Control *the_thread )
   _Stack_Free( the_thread->Start.allocated_stack );
 #if defined(RTEMS_SMP)
   _ISR_lock_Destroy( &the_thread->Scheduler.Lock );
   _ISR_lock_Destroy( &the_thread->Wait.Lock.Default );
diff --git a/cpukit/score/src/tlsallocsize.c b/cpukit/score/src/tlsallocsize.c
index 0000000000..046579814a
--- /dev/null
+++ b/cpukit/score/src/tlsallocsize.c
@@ -0,0 +1,72 @@
+ * are met:
+#if HAVE_CONFIG_H
+#endif
+static uintptr_t _TLS_Allocation_size;
+  uintptr_t size;
+  uintptr_t allocation_size;
+  uintptr_t alignment;
+  size = _TLS_Get_size();
+  if ( size == 0 ) {
+    return 0;
+  allocation_size = _TLS_Allocation_size;
+  if ( allocation_size == 0 ) {
+    allocation_size = _TLS_Heap_align_up( size );
+    alignment = _TLS_Heap_align_up( (uintptr_t) _TLS_Alignment );
+     * The stack allocator does not support aligned allocations.  Allocate
+     * enough to do the alignment manually.
+    if ( alignment > CPU_HEAP_ALIGNMENT ) {
+      allocation_size += alignment;
+    allocation_size += _TLS_Get_thread_control_block_area_size( alignment );
+#ifndef __i386__
+    allocation_size += sizeof(TLS_Dynamic_thread_vector);
+#endif
+    _TLS_Allocation_size = allocation_size;
+  return allocation_size;
diff --git a/cpukit/score/src/wkspace.c b/cpukit/score/src/wkspace.c
index 41c6cd3059..37445ff843 100644
--- a/cpukit/score/src/wkspace.c
+++ b/cpukit/score/src/wkspace.c
@@ -23,7 +23,6 @@
 #include <rtems/score/heapimpl.h>
 #include <rtems/score/interr.h>
-#include <rtems/score/tls.h>
 #include <rtems/posix/pthread.h>
 #include <rtems/sysinit.h>
@@ -37,41 +36,6 @@
 Heap_Control _Workspace_Area;
-static uintptr_t _Workspace_Space_for_TLS( uintptr_t page_size )
-  uintptr_t tls_size;
-  uintptr_t space;
-  tls_size = _TLS_Get_size();
-   * In case we have a non-zero TLS size, then we need a TLS area for each
-   * thread.  These areas are allocated from the workspace.  Ensure that the
-   * workspace is large enough to fulfill all requests known at configuration
-   * time (so excluding the unlimited option).  It is not possible to estimate
-   * the TLS size in the configuration at compile-time.  The TLS size is
-   * determined at application link-time.
-     * Memory allocated with an alignment constraint is allocated from the end
-     * of a free block.  The last allocation may need one free block of minimum
-     * size.
-    space = _Heap_Min_block_size( page_size );
-    space += _Thread_Initial_thread_count
-      * _Heap_Size_with_overhead( page_size, tls_alloc, tls_align );
-  } else {
-    space = 0;
-  return space;
 static void _Workspace_Initialize( void )
   _Workspace_Handler_initialization( _Memory_Get(), _Heap_Extend );
@@ -98,8 +62,6 @@ void _Workspace_Handler_initialization(
   page_size = CPU_HEAP_ALIGNMENT;
   remaining = rtems_configuration_get_work_space_size();
-  remaining += _Workspace_Space_for_TLS( page_size );
   init_or_extend = _Heap_Initialize;
   do_zero = rtems_configuration_get_do_zero_of_workspace();
   unified = rtems_configuration_get_unified_work_area();
2.16.4
