[PATCH 21/21] score: Simplify _Thread_Initialize()
Mon Dec 16 14:28:26 UTC 2019
Allocate new thread queue heads during objects information extend.  This
removes an error case and the last dependency on the workspace in
_Thread_Initialize().
Update #3835.
 cpukit/Makefile.am                         |  1 +
 cpukit/include/rtems/score/thread.h        | 10 +++-
 cpukit/score/src/threadallocateunlimited.c | 92 ++++++++++++++++++++++++++++++
 cpukit/score/src/threadinitialize.c        | 11 +---
 testsuites/samples/unlimited/test1.c       |  2 +
 5 files changed, 106 insertions(+), 10 deletions(-)
 create mode 100644 cpukit/score/src/threadallocateunlimited.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 950b73a70a..0db8b7a0a5 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -943,6 +943,7 @@ librtemscpu_a_SOURCES += score/src/rbtreeiterate.c
 librtemscpu_a_SOURCES += score/src/rbtreenext.c
 librtemscpu_a_SOURCES += score/src/rbtreepostorder.c
 librtemscpu_a_SOURCES += score/src/rbtreereplace.c
+librtemscpu_a_SOURCES += score/src/threadallocateunlimited.c
 librtemscpu_a_SOURCES += score/src/thread.c
 librtemscpu_a_SOURCES += score/src/threadchangepriority.c
 librtemscpu_a_SOURCES += score/src/threadclearstate.c
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index ab640c3595..fbd5327b30 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -1039,6 +1039,14 @@ Thread_Information name##_Information = { \
+ * @brief Return an inactive thread object or NULL.
+ * @retval NULL No inactive object is available.
+ * @retval object An inactive object.
+Objects_Control *_Thread_Allocate_unlimited( Objects_Information *information );
 #define THREAD_INFORMATION_DEFINE( name, api, cls, max ) \
 static Objects_Control * \
 name##_Local_table[ _Objects_Maximum_per_allocation( max ) ]; \
@@ -1051,7 +1059,7 @@ Thread_Information name##_Information = { \
     _Objects_Build_id( api, cls, 1, _Objects_Maximum_per_allocation( max ) ), \
     name##_Local_table, \
     _Objects_Is_unlimited( max ) ? \
-      _Objects_Allocate_unlimited : _Objects_Allocate_static, \
+      _Thread_Allocate_unlimited : _Objects_Allocate_static, \
       _Objects_Free_unlimited : _Objects_Free_static, \
     0, \
diff --git a/cpukit/score/src/threadallocateunlimited.c b/cpukit/score/src/threadallocateunlimited.c
new file mode 100644
index 0000000000..81429bc1af
--- /dev/null
+++ b/cpukit/score/src/threadallocateunlimited.c
@@ -0,0 +1,92 @@
+ * @file
+ * @ingroup RTEMSScoreThread
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2019 embedded brains GmbH
+ * Copyright (C) 1989, 2007 On-Line Applications Research Corporation (OAR)
+ * are met:
+#if HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/thread.h>
+#include <rtems/score/objectimpl.h>
+#include <rtems/score/wkspace.h>
+Objects_Control *_Thread_Allocate_unlimited( Objects_Information *base )
+  Thread_Information *information;
+  Objects_Control    *the_object;
+  information = (Thread_Information *) base;
+  _Assert( _Objects_Is_auto_extend( &information->Objects ) );
+   *  OK.  The manager should be initialized and configured to have objects.
+   *  With any luck, it is safe to attempt to allocate an object.
+  the_object = _Objects_Get_inactive( &information->Objects );
+   *  If the list is empty then we are out of objects and need to
+   *  extend information base.
+  if ( the_object == NULL ) {
+    Objects_Maximum block;
+    block = _Objects_Extend_information( &information->Objects );
+    if ( block > 0 ) {
+      void *new_heads;
+      new_heads = _Freechain_Extend(
+        &information->Thread_queue_heads.Free,
+        _Workspace_Allocate,
+        _Objects_Extend_size( &information->Objects ),
+        _Thread_queue_Heads_size
+      if ( new_heads == NULL ) {
+        _Objects_Free_objects_block( &information->Objects, block );
+        return NULL;
+  if ( the_object != NULL ) {
+    _Objects_Activate_unlimited( &information->Objects, the_object );
+  return the_object;
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 6b9b6bef21..4dc6d51d72 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -24,7 +24,6 @@
 #include <rtems/score/tls.h>
 #include <rtems/score/userextimpl.h>
-#include <rtems/score/wkspace.h>
 #include <rtems/config.h>
 bool _Thread_Initialize(
@@ -115,15 +114,9 @@ bool _Thread_Initialize(
    *  Get thread queue heads
-  the_thread->Wait.spare_heads = _Freechain_Get(
-    &information->Thread_queue_heads.Free,
-    _Workspace_Allocate,
-    _Objects_Extend_size( &information->Objects ),
-    _Thread_queue_Heads_size
+  the_thread->Wait.spare_heads = _Freechain_Pop(
-  if ( the_thread->Wait.spare_heads == NULL ) {
-    goto failed;
   _Thread_queue_Heads_initialize( the_thread->Wait.spare_heads );
diff --git a/testsuites/samples/unlimited/test1.c b/testsuites/samples/unlimited/test1.c
index a529c71be3..3fe2688681 100644
--- a/testsuites/samples/unlimited/test1.c
+++ b/testsuites/samples/unlimited/test1.c
@@ -51,6 +51,7 @@ void test1()
     _Objects_Information_table[OBJECTS_CLASSIC_API][OBJECTS_RTEMS_TASKS];
   objects_per_block = the_information->objects_per_block;
   the_information->objects_per_block = 0;
+  the_information->allocate = _Objects_Allocate_static;
   while (task_count < MAX_TASKS)
@@ -102,6 +103,7 @@ void test1()
   destroy_all_tasks("TEST1");
   the_information->objects_per_block = objects_per_block;
+  the_information->allocate = _Thread_Allocate_unlimited;
   printf( " TEST1 : completed\n" );
2.16.4
