[PATCH 16/21] score: _Objects_Extend_information()
Sebastian Huber
Mon Dec 16 14:28:21 UTC 2019
Return block index in _Objects_Extend_information(). This allows to
customize the objects information extend.
Update #3835.
cpukit/include/rtems/score/objectimpl.h | 5 ++++-
cpukit/score/src/objectextendinformation.c | 21 ++++++---------------
2 files changed, 10 insertions(+), 16 deletions(-)
diff --git a/cpukit/include/rtems/score/objectimpl.h b/cpukit/include/rtems/score/objectimpl.h
index eb63101b76..e5d5347895 100644
--- a/cpukit/include/rtems/score/objectimpl.h
+++ b/cpukit/include/rtems/score/objectimpl.h
@@ -91,8 +91,11 @@ _Objects_Information_table[ OBJECTS_APIS_LAST + 1 ];
* @brief Extends an object class information record.
* @param information Points to an object class information block.
+ * @retval 0 The extend operation failed.
+ * @retval block The block index of the new objects block.
-void _Objects_Extend_information(
+Objects_Maximum _Objects_Extend_information(
Objects_Information *information
diff --git a/cpukit/score/src/objectextendinformation.c b/cpukit/score/src/objectextendinformation.c
index 688d0f90bb..65fef94e44 100644
--- a/cpukit/score/src/objectextendinformation.c
+++ b/cpukit/score/src/objectextendinformation.c
@@ -28,18 +28,7 @@
#include <string.h> /* for memcpy() */
- * _Objects_Extend_information
- * This routine extends all object information related data structures.
- * Input parameters:
- * information - object information table
- * Output parameters: NONE
@@ -98,7 +87,7 @@ void _Objects_Extend_information(
* case of 16-bit Ids, this is only 256 object instances.
if ( new_maximum > OBJECTS_ID_FINAL_INDEX ) {
- return;
+ return 0;
@@ -108,7 +97,7 @@ void _Objects_Extend_information(
object_block_size = extend_count * information->object_size;
new_object_block = _Workspace_Allocate( object_block_size );
if ( new_object_block == NULL ) {
- return;
+ return 0;
@@ -157,7 +146,7 @@ void _Objects_Extend_information(
object_blocks = _Workspace_Allocate( table_size );
if ( object_blocks == NULL ) {
_Workspace_Free( new_object_block );
- return;
+ return 0;
@@ -249,4 +238,6 @@ void _Objects_Extend_information(
the_object = _Addresses_Add_offset( the_object, information->object_size );
+ return block;
2.16.4
