Problem running RTEMS on raspberrypi3
Niteesh
gsnb.gn at gmail.com
Mon Dec 16 14:54:38 UTC 2019
What about using U-boot? I just tried running my own bare metal example
using u-boot and it works fine.
The 3rd stage bootloader start the u-boot and I was able to interact with
it through serial. and then I used
fatload mmc 0 0x8000 kernel.img ; go 0x8000
to load and run the img. I tried the same for rtems
fatload mmc 0 0x200000 rtems_kernel.img ; go 0x200080
but this result's in a
## Starting application at 0x00200080 ...
"Synchronous Abort" handler, esr 0x02000000
elr: ffffffffc1d29080 lr : 00000000000838b0 (reloc)
elr: 0000000000200080 lr : 000000003e55a8b0
x0 : 0000000000000001 x1 : 000000003e15e6c8
x2 : 000000003e15e6c8 x3 : 0000000000200080
x4 : 0000000000000000 x5 : 0000000000000000
x6 : 0000000000c0c0c0 x7 : 000000000000000f
x8 : 00000000ffffffd0 x9 : 0000000000000008
x10: 0000000000000010 x11: 000000003e159cc0
x12: 0000000000000000 x13: 0000000000000200
x14: 0000000000000005 x15: 0000000000000008
x16: 0000000000000000 x17: 0000000000000020
x18: 000000003e152de0 x19: 000000003e15e6c8
x20: 0000000000000002 x21: 0000000000200080
x22: 000000003e15e6c0 x23: 0000000000000002
x24: 000000003e5d4d44 x25: 0000000000000000
x26: 0000000000000000 x27: 0000000000000000
x28: 000000003e1567e0 x29: 000000003e152b20
Code: 0020b048 0020b048 0020b048 0020b048 (e1a05001)
Resetting CPU ...
On Mon, Dec 16, 2019 at 8:11 PM Niteesh <gsnb.gn at gmail.com> wrote:
> But I am not able to boot using the 3 stage bootloader. Can someone try
> booting any examples on raspi3 or other newer models? If it's work's please
> post the instructions. The steps that I followed are:
> 1. arm-rtems5-objcopy -Obinary hello.exe kernel.img
> 2. copied the kernel image to sd card and modified the config.txt to load
> the kernel img.
> No success in following these steps.
> I think this is maybe because of the different start addresses. The
> default kernel load address for raspberry pi is 0x8000 in 32bit mode and
> 0x80000 in 64bit mode.
> but RTEMS has a start address of 0x200080.
> On Mon, Dec 16, 2019 at 7:51 PM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> I think I have guided you to a wrong path here. I mentioned U-Boot
>> because it is often used on a lot of evaluation boards. In the raspberry
>> case it seems that the stage 3 loader is something different. But
>> everything should work with that stage 3 loader. I don't think that
>> U-Boot is necessary.
>> On 16/12/2019 14:01, Niteesh wrote:
>> > I got uboot running on my raspi3. But I can't figure out to load and run
>> > a custom kernel. Can you explain the steps or point me to some
>> > reference.
>> > On Mon, Dec 16, 2019 at 5:13 PM Niteesh <gsnb.gn at gmail.com
>> > <mailto:gsnb.gn at gmail.com>> wrote:
>> > On Mon, Dec 16, 2019 at 2:36 AM Christian Mauderer
>> > <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>> > On 15/12/2019 21:29, Niteesh wrote:
>> > > On Mon, Dec 16, 2019 at 12:53 AM Christian Mauderer
>> > > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>> wrote:
>> > > On 15/12/2019 19:46, Niteesh wrote:
>> > > > On Sun, Dec 15, 2019 at 10:15 PM Christian Mauderer
>> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>
>> wrote:
>> > > > Hello Niteesh,
>> > > > On 15/12/2019 09:05, Niteesh wrote:
>> > > > > I am trying to get RTEMS examples running on the
>> > RPI3, the
>> > > RPI3 is
>> > > > > similar to RPI2 so the examples built for RPI2
>> should
>> > > technically
>> > > > run on
>> > > > > the RPi3.But they don't :(, I am really sure of
>> > what is causing
>> > > > the problem.
>> > > > Note that there are at least two different versions
>> > of the
>> > > RPi3 which
>> > > > use different chips. The original RPi3 which uses a
>> > BCM2837
>> > > (same like
>> > > > later versions of RPi2) and the RPi3+ which uses a
>> > BCM2837B0.
>> > > Broadcom
>> > > > is always quite sparse with documentation so it's
>> > not easy to
>> > > tell the
>> > > > differences. Which one do you have?
>> > > > I have Rpi3 model b v1.2 which uses BCM2837 SOC, in my
>> > bare-metal
>> > > > programming I used the
>> > > > 2835 doc as a reference because the only major
>> > difference these
>> > > two SOC
>> > > > is the peripheral base address
>> > > > offset. But this is arm cpu is also capable of
>> > executing in 64bit
>> > > mode.
>> > > OK. Did you check, whether the offset is correct? In the
>> > raspberrypi.h
>> > > in RTEMS there is the following define:
>> > > #if (BSP_IS_RPI2 == 1)
>> > > #define RPI_PERIPHERAL_BASE 0x3F000000
>> > > #else
>> > > #define RPI_PERIPHERAL_BASE 0x20000000
>> > > #endif
>> > > The offsets are right.
>> > Good.
>> > > > > I followed the steps
>> > from
>> http://alanstechnotes.blogspot.com/2013/03/running-your-first-rtems-program-on.html
>> (modified
>> > > > > commands to use rtems5) to build the kernel img.
>> > > > It's a bit odd that the Bootloader doesn't use some
>> > image
>> > > format like
>> > > > U-Boot but if that's the case for Raspberry, that's
>> OK.
>> > > > Do you want me to try U-Boot, I was planning to use it
>> > for my
>> > > bare-metal
>> > > > stuff because copying the kernel
>> > > > to SD-card was a real pain. Will it even work with
>> RTEMS?
>> > > The manual that you linked uses the default Raspberry
>> > bootloader. I'm
>> > > not sure whether it's an U-Boot. If you skip the
>> > bootloader entirely,
>> > > your SDRAM might isn't initialized.
>> > > The manual uses the default bootloader. I don't think we have
>> > to worry
>> > > about the SDRAM initialization
>> > > because all of that is taken care of by the GPU.
>> > Sounds OK.
>> > > When using Uboot, the
>> > > GPU will load the uboot image and
>> > > pass the control to the CPU. And then the uboot continue's
>> > it's execution.
>> > I don't wanted to suggest to use an extra U-Boot. I was just not
>> > sure
>> > whether the stage 3 loader is an U-Boot. Your approach sounds
>> > fine so far.
>> > > PS: You answered that further below. You are using the
>> > stage 3 loader.
>> > > > > I did try running it on
>> > > > > Qemu but it doesn't always work, sometimes it
>> gives
>> > > weird output.
>> > > > How did you run it on Qemu? Did you build some image
>> > for that too?
>> > > > qemu-system-arm -M raspi2 -m 1G -kernel hello.exe
>> > -serial mon:stdio
>> > > > -nographic
>> > > > qemu-system-aarch64: GLib: g_mapped_file_unref:
>> > assertion 'file !=
>> > > NULL'
>> > > > failed *I get this error
>> > > > while trying to emulate raspi3.
>> > > That sounds like a problem with Qemu. Is there some
>> > official test image
>> > > for rpi3 on qemu? Note that this isn't really relevant for
>> > your current
>> > > problem. So if you don't have some manual just ignore the
>> > question.
>> > > > I ran qemu along with GDB to find what was causing the
>> > wrong output. I
>> > > > am really not sure if this is right,
>> > > > I still have a lot to learn, but my assumption's using
>> > GDB are as
>> > > follows.
>> > > > There are 4 active thread which run the same code.
>> > > > (gdb) info thread
>> > > > Id Target Id Frame
>> > > > * 1 Thread 1.1 (CPU#0 [running]) _start () at
>> ../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/shared/start/start.S:153
>> > > > 2 Thread 1.2 (CPU#1 [running]) _start () at
>> > > > 3 Thread 1.3 (CPU#2 [running]) _start () at
>> > > > 4 Thread 1.4 (CPU#3 [running]) _start () at
>> > > In this case that are not threads but it's the CPU cores.
>> > GDB shows them
>> > > as threads. Most likely it wouldn't be able to detect the
>> > RTEMS threads.
>> > > It's a bit odd that they are all pointing to start.S:153.
>> > That's the
>> > > entry point for the program. It looks like not even one
>> > instruction has
>> > > been executed yet.
>> > > I took this output before executing the program, that the
>> > reason why not
>> > > even a single instruction has been
>> > > executed yet.
>> > OK.
>> > > > After some time one of the thread call's the BSP reset
>> > function
>> > > this is
>> > > > when the program crashes, the other threads complain
>> > "*executing
>> > > thread
>> > > > is NULL*"
>> > > I would rather assume that one core tries to do the
>> > initialization while
>> > > the others hang in a endless loop till they are needed.
>> > The one core
>> > > doing the initialization work hits an exception somewhere
>> > and calls the
>> > > exception handler which calls the bsp reset function.
>> > > The executing thread is NULL is a sign that it happens
>> > somewhere during
>> > > initialization when the RTEMS threading hasn't been
>> > started yet.
>> > > The PC has an odd value. The linker command file tells
>> > that there is a
>> > > RAM_MMU at 0x00100000. It only puts a
>> > bsp_translation_table there but
>> > > there shouldn't be any code. So I don't know what the
>> > processor is doing
>> > > there. You could try to set a breakpoint on the address
>> > 0x00100fc4 and
>> > > take a look at why the processor is there with a "bt"
>> > (backtrace).
>> > > When I re-run it again, it now stops at a different address.
>> > As you said
>> > > that the other cores are put
>> > > in an endless loop, I don't think that's is happening. I
>> > single stepped
>> > > the instruction and later at some point checked the threads
>> > > (gdb) info threads
>> > > Target Id Frame
>> arm_ccsidr_get_line_power
>> > > (ccsidr=<optimized out>)
>> > > at
>> /home/niteesh/development/rtems/kernel/rtems/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h:850
>> > arm_cp15_cache_invalidate_level
>> > > (inst_data_fl=0, level=1)
>> > > at
>> /home/niteesh/development/rtems/kernel/rtems/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h:1162
>> > > at
>> > > * 4 Thread 1.4 (CPU#3 [running])
>> > > arm_cp15_get_cache_size_id_for_level
>> (level_and_inst_dat=0)
>> > > at
>> /home/niteesh/development/rtems/kernel/rtems/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h:936
>> > > (gdb)
>> > > They all are executing different instructions at the same
>> time.
>> > Some of the initialization is done on all cores. Some isn't. I
>> > took a
>> > look at the initialization and it seems that I was wrong: There
>> > is no
>> > wait loop. All processors are running through the initialization
>> > process. Some just skip parts. The part where they really start
>> to
>> > differ is in bsp_start_hook_0.
>> > > I> googled about just running one thread or CPU as you said at
>> > a time and
>> > > used "*set scheduler-locking on" *on doing this I always get
>> > the right
>> > > output.
>> > > (gdb) info threads
>> > > Id Target Id Frame
>> > > * 1 Thread 1.1 (CPU#0 [running]) bsp_reset ()
>> > > at
>> ../../../../../../../../rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/start/bspreset.c:18
>> > > at
>> > > at
>> > > at
>> > > (gdb)
>> > > The above command allow's only a single thread to run.
>> > Maybe there is a timing difference between the simulator and the
>> > real
>> > hardware. I'm not sure how well tested the SMP code is on the
>> > Raspberry.
>> > There can be a hidden bug.
>> > Just a guess: If there is a bug it could be possible that you
>> hit it
>> > with your rpi3 too. Maybe it would be good to try a single core
>> > version
>> > of the BSP. I assume you have configured with "--enable-smp"?
>> > Can you
>> > try to build without it?
>> > I built 2 versions with SMP enabled and disabled, the one we are
>> > talking about is the SMP disabled version, I ran
>> > the example with SMP enabled, still, the error's are similar, I only
>> > difference is, in the disabled one, there are only 4 or less panic's
>> > (maybe corresponding to 4 cpu's) but the other one has a higher
>> > number of panics.
>> > > Won't it be a good idea to make a separate BSP for rpi3?
>> > As soon as it is necessary: Sure. But from what you told me it
>> seems
>> > that the hardware is very similar so that we won't hit this
>> > point soon.
>> > Or do you already see differences that would make it necessary.
>> > I haven't had a look at the details but it could also be
>> possible to
>> > unify the BSPs and entirely remove the rpi2 variant if the
>> > information
>> > from the flattened device tree are used.
>> > Can you explain how FDT work in RTEMS. Can you mention some BSP's
>> > which use FDT so I can use them as a reference to learn.
>> > I previously took a look at the beagle FDT project (#3784), you
>> > mentioned about hardcoded values and initialization functions, can
>> > you explain more about what exactly do the initialization functions
>> > do? Do they assign a function to a particular pin, like in raspi
>> > the pins are multiplexed for various functions, so do the
>> > initialization functions assign those pins to a particular function?
>> > And also please explain how does the initialization of the system
>> > happen from the DT file.
>> > > > *** FATAL ***
>> > > > fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
>> > > > R0 = 0x400005e6 R8 = 0x00000000
>> > > > R1 = 0x00000001 R9 = 0x00000000
>> > > > R2 = 0xbffffa1a R10 = 0x00000000
>> > > > R3 = 0x00000000 R11 = 0x00000000
>> > > > R4 = 0x002001db R12 = 0x00000000
>> > > > R5 = 0x00000000 SP = 0x00300bd0
>> > > > R6 = 0x00000000 LR = 0x00100fc4
>> > > > R7 = 0x00000000 PC = 0x00100fc4
>> > > > CPSR = 0x000001d3 VEC = 0x00000002
>> > > > FPEXC = 0x40000000
>> > > > FPSCR = 0x00000000
>> > > > D00 = 0x0000000000000000
>> > > > D01 = 0x0000000000000000
>> > > > D02 = 0x0000000000000000
>> > > > D03 = 0x0000000000000000
>> > > > D04 = 0x0000000000000000
>> > > > D05 = 0x0000000000000000
>> > > > D06 = 0x0000000000000000
>> > > > D07 = 0x0000000000000000
>> > > > D08 = 0x0000000000000000
>> > > > D09 = 0x0000000000000000
>> > > > D10 = 0x0000000000000000
>> > > > D11 = 0x0000000000000000
>> > > > D12 = 0x0000000000000000
>> > > > D13 = 0x0000000000000000
>> > > > D14 = 0x0000000000000000
>> > > > D15 = 0x0000000000000000
>> > > > D16 = 0x0000000000000000
>> > > > D17 = 0x0000000000000010
>> > > > D18 = 0x0000000000000000
>> > > > D19 = 0x0000000000000000
>> > > > D20 = 0x0000000000000000
>> > > > D21 = 0x0000000000000000
>> > > > D22 = 0x0000000000000000
>> > > > D23 = 0x0000000000000000
>> > > > D24 = 0x0000000000000000
>> > > > D25 = 0x0000000000000000
>> > > > D26 = 0x0000000000000000
>> > > > D27 = 0x0000000000000000
>> > > > D28 = 0x0000000000000000
>> > > > D29 = 0x0000000000000000
>> > > > D30 = 0x0000000000000000
>> > > > D31 = 0x0000000000000000
>> > > > RTEMS version:
>> > > 5.0.0.c6d8589bb00a9d2a5a094c68c90290df1dc44807-modified
>> > > > RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB
>> > > > 83fa79314dd87c0a8c78fd642b2cea3138be8dd6, Newlib
>> > 3e24fbf6f)
>> > > > > 1. Created a bootable SD card using raspbian.
>> > > > > 2. Replaced the kernel.img file with RTEMS
>> > kernel.img file and
>> > > > modified
>> > > > > the config.txt to boot from the RTEMs kernel
>> (boots in
>> > > aarch32 bit
>> > > > mode).
>> > > > > I am still not able to wrap my head around the RPI
>> > bsp build
>> > > process.
>> > > > > This is what I understood as of now, correct me if
>> > I am wrong.
>> > > > > Both RPi and Rpi2 are based on the same BSP, they
>> just
>> > > differ in the
>> > > > > peripheral offsets, hardcoded checks are used to
>> > select the
>> > > right
>> > > > offset
>> > > > > at the time of compiling
>> > > > >From what I know of the Raspberry BSPs that is
>> correct.
>> > > > > and the linkercmd file is responsible for
>> > > > > building the final executable file.
>> > > > The linkercmd file is - like for all programs -
>> > responsible
>> > > where the
>> > > > memory regions are that can be used for code or
>> > data. So you
>> > > could more
>> > > > or less explain it like you did.
>> > > > > I looked at the linker script, it seem's to have
>> > the start
>> > > section at
>> > > > > address 0x200000, I also loaded it in GDB and the
>> > start
>> > > address is
>> > > > > *Start address 0x200080,*
>> > > > I agree with that. The different start in GDB is
>> > most likely
>> > > because
>> > > > there is a vector table in front (at least if the
>> > Broadcom chip is
>> > > > similar to a lot of other processors that I have
>> > encountered).
>> > > > Does that mean that you have a debugger connected
>> to the
>> > > raspberry? Can
>> > > > you load code with it? If yes: Is the bootloader
>> > executed
>> > > before you
>> > > > load your code? Otherwise the SDRAM might isn't
>> > initialized yet.
>> > > > I don't have a debugger connected to it. I from what I
>> > have SDRAM is
>> > > > initialized by the 3 stage bootloader(start.elf).
>> > > That should be OK and it answers my question above.
>> > > > > I did some bare metal programming on RPI3
>> > > > > there I had the start section at address 0x8000 Is
>> > this causing
>> > > > the problem?
>> > > > I assume that you used some internal RAM when you
>> > did bare metal
>> > > > programming. You maybe even skipped one or two
>> > bootloader
>> > > stages. From a
>> > > > quick look Raspberry has a quite complex boot
>> > process with at
>> > > least
>> > > > three bootloaders:
>> > > http://lions-wing.net/maker/raspberry-1/boot.html
>> > > > I don't think I have skipped any stages. The boot
>> process is
>> > > exactly the
>> > > > same as how it boot's a normal raspbian or any other
>> linux
>> > > > distro, I just to replace the linux kernel with my own
>> > kernel.
>> > > Sounds reasonable. Does the bootloader print anything
>> > where it puts the
>> > > kernel image? Maybe the start address changed during the
>> > raspberry
>> > > versions.
>> > > the default kernel load address is 0x8000 in 32bit mode and
>> > 0x80000 in
>> > > 64bit mode I have no idea about the raspberry 1,
>> > > but the load address is same for rpi2 and 3.
>> > That sounds odd. Do you have a memory map somewhere? From the
>> linker
>> > command file it seems quite clear that RTEMS is build for a
>> > 0x200000.
>> > > > > I have no idea on how to debug this, any
>> > suggestion on how
>> > > to start
>> > > > > would be really helpfull.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191216/7ce234d3/attachment-0001.html>
