[PATCH 6/7] bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG
Sebastian Huber
Tue Dec 17 05:57:18 UTC 2019
On 17/12/2019 00:34, Chris Johns wrote:
>> On 16 Dec 2019, at 11:42 pm, Sebastian Huber <Sebastian.Huber at embedded-brains.de> wrote:
>> The code covered by BSP_GET_WORK_AREA_DEBUG was basically dead code
>> since there was no normal way to activate it (e.g. via a BSP
>> configuration option). BSP developers should use a debugger instead.
> You will need to establish a base level requirement of a debugger across the whole project before this statement makes sense and doing that does not make sense to me.
It is just a recommendation. My experience tells me that doing a BSP
development without a debugger is a waste of time.
>> If this output via printk() turns out to be still wanted by users, it
>> can be added as an application configuration option, e.g.
>> CONFIGURE_ENABLE_VERBOSE_MEMORY_INITIALIZATION.
> Why not use that config define that other part you want to removed?
Sorry, I don't understand this sentence. Do you mean that I should add
this CONFIGURE_ENABLE_VERBOSE_MEMORY_INITIALIZATION configuration
option? Maybe a CONFIGURE_ENABLE_VERBOSE_INITIALIZATION makes more
sense. We can print some information for each step.
> Also please consider at this time of year I am really busy and patches need to sit longer before being considered as OK. :)
Ok, I would like to get the two change sets integrated before we create
the RTEMS 5 branch. This would make back ports easier.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
