Ada configuration options
Tue Dec 17 13:38:46 UTC 2019
On Tue, Dec 17, 2019 at 3:45 AM Sebastian Huber <
> Hello,
> we have currently three Ada related configuration options:
> * CONFIGURE_GNAT_RTEMS
> * CONFIGURE_MAXIMUM_ADA_TASKS
> * CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS option has no effect.  The
> CONFIGURE_GNAT_RTEMS is mandatory to use the CONFIGURE_MAXIMUM_ADA_TASKS
> option. So, if you just use
> #define CONFIGURE_MAXIMUM_ADA_TASKS 123
> then you get a re-definition warning and hopefully pay attention to it.
> This is not very user friendly from point of view.
> The CONFIGURE_MAXIMUM_ADA_TASKS just adds the configured count to
> CONFIGURE_MAXIMUM_POSIX_THREADS.
> I would obsolete all three options.
The original purpose of these was to:
CONFIGURE_GNAT_RTEMS - add in resources required by Ada run-time independent
of the number of Ada tasks (e.g. POSIX threads)
CONFIGURE_MAXIMUM_ADA_TASKS - add in POSIX threads, condition variable,
and mutex required for each Ada task
CONFIGURE_MAXIMUM_FAKE_ADA_TASKS - add in condition variables and mutex
required by Ada run-time for a task/thread created outside the Ada run-time
which
invokes Ada code and is thus a user of the run-time.
Given that you can turn on unlimited threads now and condition variables
and mutexes
are static, I don't think they have a need any longer. Plus it sounds like
they bit rotted.
If we needed them still, they would have to be fixed.
We still need documentation that Ada tasks are POSIX threads and must be
accounted
for in configuring the system. So when moving documentation around, please
make that
point clear in the CONFIGURE_MAXIMUM_POSIX_THREADS description.
--joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191217/ac0354ab/attachment.html>
