[PATCH] config: Remove Ada configuration options
Joel Sherrill
joel at rtems.org
Thu Dec 19 14:20:49 UTC 2019
Given a cursory review, this looks OK.
What native GNAT version do you use to build the RTEMS GNAT?
--joel
On Wed, Dec 18, 2019 at 9:26 AM Sebastian Huber <
> Update #3845.
> cpukit/include/rtems/confdefs.h | 80
> 1 file changed, 18 insertions(+), 62 deletions(-)
> diff --git a/cpukit/include/rtems/confdefs.h
> b/cpukit/include/rtems/confdefs.h
> index f4ada7ead4..ae0c9874a6 100644
> --- a/cpukit/include/rtems/confdefs.h
> +++ b/cpukit/include/rtems/confdefs.h
> @@ -2300,43 +2300,6 @@ struct _reent *__getreent(void)
> #endif
> /**@}*/ /* end of POSIX API Configuration */
> - * @defgroup ConfigurationGNAT GNAT/RTEMS Configuration
> - * @addtogroup Configuration
> - * This modules includes configuration parameters for applications which
> - * use GNAT/RTEMS. GNAT implements each Ada task as a POSIX thread.
> -#ifdef CONFIGURE_GNAT_RTEMS
> - * This is the maximum number of Ada tasks which can be concurrently
> - * in existence. Twenty (20) are required to run all tests in the
> - * ACATS (formerly ACVC).
> - #ifndef CONFIGURE_MAXIMUM_ADA_TASKS
> - #define CONFIGURE_MAXIMUM_ADA_TASKS 20
> - #endif
> - * This is the number of non-Ada tasks which invoked Ada code.
> - #ifndef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> - #define CONFIGURE_MAXIMUM_FAKE_ADA_TASKS 0
> - #endif
> -#else
> - /** This defines he number of POSIX mutexes GNAT needs. */
> - /** This defines he number of Ada tasks needed by the application. */
> - #define CONFIGURE_MAXIMUM_ADA_TASKS 0
> - * This defines he number of non-Ada tasks/threads that will invoke
> - * Ada subprograms or functions.
> -#endif
> -/**@}*/ /* end of GNAT Configuration */
> * This is so we can account for tasks with stacks greater than minimum
> * size. This is in bytes.
> @@ -2345,13 +2308,6 @@ struct _reent *__getreent(void)
> #define CONFIGURE_EXTRA_TASK_STACKS 0
> #endif
> - * This macro provides a summation of the various POSIX thread
> requirements.
> -#define _CONFIGURE_POSIX_THREADS \
> - (CONFIGURE_MAXIMUM_POSIX_THREADS + \
> - CONFIGURE_MAXIMUM_ADA_TASKS)
> * We must be able to split the free block used for the second last
> allocation
> * into two parts so that we have a free block for the last allocation.
> See
> @@ -2478,20 +2434,11 @@ struct _reent *__getreent(void)
> (_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
> _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
> - * This macro is calculated to specify the memory required for
> - * the stacks of all Ada tasks.
> -#define _CONFIGURE_ADA_TASKS_STACK \
> - (_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \
> - _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
> #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
> #define _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS 0
> #define _CONFIGURE_TASKS_STACK 0
> #define _CONFIGURE_POSIX_THREADS_STACK 0
> -#define _CONFIGURE_ADA_TASKS_STACK 0
> #if CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK != 0
> #error "CONFIGURE_EXECUTIVE_RAM_SIZE defined with request for
> CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK"
> @@ -2512,7 +2459,6 @@ struct _reent *__getreent(void)
> _CONFIGURE_INITIALIZATION_THREADS_EXTRA_STACKS + \
> _CONFIGURE_TASKS_STACK + \
> _CONFIGURE_POSIX_THREADS_STACK + \
> - _CONFIGURE_ADA_TASKS_STACK + \
> _CONFIGURE_LIBBLOCK_TASK_EXTRA_STACKS + \
> CONFIGURE_EXTRA_TASK_STACKS + \
> _CONFIGURE_HEAP_HANDLER_OVERHEAD \
> @@ -2639,7 +2585,7 @@ struct _reent *__getreent(void)
> const size_t _Thread_Initial_thread_count =
> rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
> - rtems_resource_maximum_per_allocation( _CONFIGURE_POSIX_THREADS );
> + rtems_resource_maximum_per_allocation(
> CONFIGURE_MAXIMUM_POSIX_THREADS );
> THREAD_INFORMATION_DEFINE(
> _Thread,
> @@ -2740,7 +2686,7 @@ struct _reent *__getreent(void)
> POSIX_SHM_INFORMATION_DEFINE( CONFIGURE_MAXIMUM_POSIX_SHMS );
> #endif
> - #if _CONFIGURE_POSIX_THREADS > 0
> + #if CONFIGURE_MAXIMUM_POSIX_THREADS > 0
> _POSIX_Threads,
> OBJECTS_POSIX_API,
> @@ -2978,12 +2924,10 @@ struct _reent *__getreent(void)
> * tasks/threads so there is a smaller set of calls to
> _Workspace_Allocate
> * to analyze.
> -#if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION)
> - #if (CONFIGURE_MAXIMUM_TASKS == 0) && \
> - (CONFIGURE_MAXIMUM_POSIX_THREADS == 0) && \
> - (CONFIGURE_MAXIMUM_ADA_TASKS == 0)
> - #error "CONFIGURATION ERROR: No tasks or threads configured!!"
> - #endif
> +#if !defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) \
> + && CONFIGURE_MAXIMUM_TASKS == 0 \
> + && CONFIGURE_MAXIMUM_POSIX_THREADS == 0
> + #error "CONFIGURATION ERROR: No tasks or threads configured!!"
> #endif
> #ifndef RTEMS_SCHEDSIM
> @@ -3087,6 +3031,14 @@ struct _reent *__getreent(void)
> #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is
> obsolete since RTEMS 5.1"
> #endif
> +#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
> + #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is
> +#endif
> +#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
> + #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is
> +#endif
> #ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
> #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is
> #endif
> @@ -3151,6 +3103,10 @@ struct _reent *__getreent(void)
> #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete
> since RTEMS 5.1"
> #endif
> +#ifdef CONFIGURE_GNAT_RTEMS
> + #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete
> since RTEMS 5.1"
> +#endif
> #ifdef CONFIGURE_MAXIMUM_GOROUTINES
> #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is
> #endif
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191219/92a48573/attachment-0001.html>
