raspberry BSP: Maybe there is a bug in the linker file?
Niteesh
gsnb.gn at gmail.com
Fri Dec 20 18:19:06 UTC 2019
How do you test a patch? Do you checkout that particular commit and build
and the BSP again?.
@Christian Mauderer <list at c-mauderer.de> how did you build it for the
rpi1? Did you follow the steps as in previous threads?
and how did you come to the conclusion that these changes cause the
exceptions, as a beginner these ideas
will help in the future.
On Fri, Dec 20, 2019 at 2:46 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 20/12/2019 09:22, Christian Mauderer wrote:
> > On 20/12/2019 07:33, Sebastian Huber wrote:
> >> On 19/12/2019 15:28, Niteesh wrote:
> >>> As far as I know, 0x8000 is a fixed address where the bootloader jumps
> >>> to after loading the application assuming the CPU is in 32bit mode.
> >>> For 64bit mode, it jumps to 0x80000.
> >> Would you mind testing this patch:
> >> https://lists.rtems.org/pipermail/devel/2019-December/056551.html
> > On the Pi 1 now the binary has three time the size (with a lot of 0x00
> > in it) and at least RTEMS starts. But it runs into an exception quite
> > fast. I'll investigate that a bit.
> > @Niteesh: For the Pi 3 I would expect that it still doesn't print
> > anything on the console due to the different UART pins.
> > The output on the Pi 1 is:
> > executing�
> > *** FATAL ***
> > fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> > R0 = 0xfc037f80 R8 = 0x00000000
> > R1 = 0xfc345980 R9 = 0x00000010
> > R2 = 0x00000001 R10 = 0xfc037f8a
> > R3 = 0x03fc8080 R11 = 0x0030da00
> > R4 = 0xfc037f80 R12 = 0xfc345988
> > R5 = 0x00000008 SP = 0x00300ba8
> > R6 = 0x0030d9fe LR = 0x00205a78
> > R7 = 0x00305218 PC = 0x00205ac8
> > CPSR = 0x600001d3 VEC = 0x00000004
> > RTEMS version: 5.0.0.254f38583fe68c3e17dfe274a2deeb00a5a538d6
> > RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6c65fc237b9e modified),
> > Newlib d14714c69)
> The exception seems to be caused by some of the changes in bspstart.c
> and bspgetworkarea.c in patch a4d7e4cee77d16b0e34ef543f0804e7eb2954137.
> So the fix for the linker command file is fine.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191220/ebd75c4a/attachment-0001.html>
