raspberry BSP: Maybe there is a bug in the linker file?
Christian Mauderer list at c-mauderer.de
Sun Dec 22 08:50:32 UTC 2019
Hello Niteesh,
thanks for the detailed information. I agree that this is a completely
different hardware module and will need a different driver.
The data sheet (by the way: one of the worst I've ever seen) tells that
the Mini UART has "16550 like registers" that are "as far as possible
[...] like a 16550". So maybe the driver from
bsps/shared/dev/serial/ns16550.c can be used or extended.
By the way: It's a really odd idea to integrate two completely different
UARTs into one chip. I know chips with variations but completely
different is unusual. Especially because most serial peripherals are
small and need very few chip area compared to memory. But maybe they had
a reason ...
Best regards
Christian
On 22/12/2019 08:12, Niteesh wrote:
> On raspberry pis equipped with the wireless/Bluetooth module, the PL011
> is connected to the Bluetooth module,
> and the mini UART is used as the primary UART. On all other models, the
> PL011 is used as the primary UART.
> The mini UART has smaller FIFOs. Combined with the lack of flow control,
> this makes it more prone to losing characters at higher baudrates. It is
> also generally less capable than the PL011, mainly due to its baud rate
> link to the VPU clock speed.
> The particular deficiencies of the mini UART compared to the PL011 are :
> No break detection
> No framing errors detection
> No parity bit
> No receive timeout interrupt
> No DCD, DSR, DTR or RI signals
> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
> the official doc from broadcom, this is what I used while developing
> drivers for bare metal project.
> On Sun, Dec 22, 2019 at 1:56 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     I haven't had a look at the different types of UARTS yet. What is the
>     difference? What do you use as reference?
>     If it is just a variant of an existing driver, the existing one should
>     be extended to support both variants.
>     On 21/12/2019 20:45, Niteesh wrote:
>     > On inspecting the code, the driver is for PL011. We have to write a
>     > driver for the mini uart.
>     > which we will have start from scratch. So, how do you want the
>     structure
>     > to be?
>     > The code of PL011 can be improved. We could use gpio functions to
>     > configure pins.
>     > And also many of the UART values are set in place instead of using the
>     > appropriate function, for example
>     > the usart_set_baud is empty and the baud rate is set directly in the
>     > init function.
>     > What do you think about these changes? Should we change them also?
>     > On Sun, Dec 22, 2019 at 12:25 AM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     On 21/12/2019 19:26, Niteesh wrote:
>     >     > There is already a PL011 driver in the arm shared section.
>     should we
>     >     > just import it?
>     >     If you say "import" and you mean "use" and not "copy": yes,
>     that would
>     >     be great.
>     >     > On Sat, Dec 21, 2019 at 10:46 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>
>     >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
>     >     > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>> wrote:
>     >     >     Shall I start writing a driver for raspberrypi3 PL011?
>     >     >     On Sat, Dec 21, 2019 at 8:40 PM Christian Mauderer
>     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     >         On 19/12/2019 15:05, Christian Mauderer wrote:
>     >     >         > On 19/12/2019 14:27, Sebastian Huber wrote:
>     >     >         >> On 19/12/2019 14:24, Christian Mauderer wrote:
>     >     >         >>> Hello,
>     >     >         >>> triggered by the discussion regarding RTEMS on
>     >     raspberrypi 3
>     >     >         I did some
>     >     >         >>> tests. I haven't been able to start a RTEMS on
>     my Pi 1
>     >     if I
>     >     >         tried a
>     >     >         >>> version after commit
>     >     >         c5fd79cd4704a4270ba0114a1009ab8556f997c9 from
>     >     >         >>> 29.07.2019. Right before it everything works as
>     expected.
>     >     >         >>> The commit changes the memory locations. From what I
>     >     >         understood, the
>     >     >         >>> bootloader on a raspberry always jumps to
>     address 0x8000
>     >     >         after loading
>     >     >         >>> the application. So I'm not convinced that the
>     change is
>     >     >         correct.
>     >     >         >> Is the 0x8000 a fixed address or you configure
>     this in
>     >     a boot
>     >     >         image header?
>     >     >         >>From what I've seen the bootloader just uses a fixed
>     >     address.
>     >     >         All guides
>     >     >         > that I've found just use objcopy to generate a binary
>     >     from the
>     >     >         elf files
>     >     >         > without adding a header. For example a guide for
>     RTEMS:
>       http://alanstechnotes.blogspot.com/2013/03/running-your-first-rtems-program-on.html
>     >     >         > A FreeRTOS port mentions this behavior explicitly in a
>     >     comment
>     >     >         in the
>     >     >         > linker file:
>       https://github.com/jameswalmsley/RaspberryPi-FreeRTOS/blob/master/raspberrypi.ld#L17
>     >     >         > The "graphics processor" is no typo here. It seems the
>     >     >         initialization is
>     >     >         > really done by the graphics processor on the pi.
>     >     >         > _______________________________________________
>     >     >         > devel mailing list
>     >     >         > devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >     >         > http://lists.rtems.org/mailman/listinfo/devel
>     >     >         I just found an option: It is possible to set a
>     >     "kernel_address"
>     >     >         in the
>     >     >         config.txt:
>       https://www.raspberrypi.org/documentation/configuration/config-txt/boot.md
>     >     >         So the start address can be changed and maybe the
>     adaption to
>     >     >         the linker
>     >     >         file isn't necessary.
