Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Tue Dec 24 11:06:55 UTC 2019
The current raspi console section is like this:
The bsp_console_select in console_select.c is responsible for selecting
between uart and the framebuffer. It does so
by setting the Console_port_minor.
The console_config is responsible for output_char function.
And other files are driver code.
If rewriting, this would be my approach,
Rewrite the bsp_console_select to set some kind of a variable like in IMX,
then in console_initialize function
link the right driver to /dev/console.
Replace the console_tbl with the device_context and console_fns with
termios_device_handlers and
finally add in the console_initialization function.
On Tue, Dec 24, 2019 at 2:13 PM Niteesh <gsnb.gn at gmail.com> wrote:
> Thank you so much, for such a detailed answer. Now things make really good
> sense to me,
> going through the code now is just a breeze. But I still have one question
> for the newer driver interface is console_initialize the function which
> RTEMS calls while initializing
> the console? Which means I can't mess with the name right? It is similar
> to the main function, right?
> The current driver is a legacy one, how do you want me to proceed, shall I
> rewrite the legacy to a
> the new one, this is will be a great learning experience for me also and
> we also get the BSP updated to the latest interface.
> On Tue, Dec 24, 2019 at 3:20 AM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> Hello Niteesh,
>> quite a lot of questions. I'll try to answer them. Note that it has been
>> some time since I had a detailed look at that code so if something I
>> tell seems odd please don't hesitate to question it.
>> Please note that in RTEMS their are more or less two "levels" of support
>> for a serial console:
>> 1. A very basic polled system console (also known as "debug-console" in
>> some BSPs). This one is used for printk and should work in basically
>> every case. It is used for critical system messages like printing the
>> exception frame. For that a BSP has to provide a "BSP_output_char"
>> function.
>> 2. A full featured UART driver integrated into Termios. That one will be
>> used for all normal I/O on the UARTs.
>> As far as I know the "console_tbl Console_Configuration_Ports" belongs
>> to a table based legacy interface. It is handled in the file
>> bsps/shared/dev/serial/legacy-console.c. I'm not sure whether it is
>> documented in the BSP guide because it shouldn't be used for new BSPs.
>> Same is true for the "major" and "minor" stuff: It's not really used for
>> new drivers.
>> Newer drivers use the initialization that is described in the manual
>> that you have already found. Basically they use
>> "rtems_termios_device_install" to register a new UART as
>> "/dev/ttySomething". Some recent (ARM) BSPs that do that are the imx or
>> the atsam.
>> The console that is used for stdin, stdout and stderr (printf, scanf,
>> ...) is the one called "/dev/console" (defined in CONSOLE_DEVICE_NAME).
>> For the legacy table based interface it's the one with the index of
>> "Console_Port_Minor".
>> If you want to access any UART other than the one for stdin and stdout
>> you do that the same way like on Linux: Just use the "open" function on
>> the "/dev/ttySomething" and use "read", "write" and simmilar or use
>> "fopen" together with "fread", "fwrite", "fprintf", ...
>> "printf" (and family) is a function belonging to the C library. In our
>> case that's newlib. It will format your message and after some other
>> preprocessing will call the "write" function of the file that is opened
>> as stdout (which is "/dev/console" in the default case).
>> I hope that I helped you with that explanation. Please feel free to ask
>> anything if it isn't clear.
>> Best regards
>> Christian
>> On 23/12/2019 19:50, Niteesh wrote:
>> > And finally, how does printf work? It is a macro? In that case, how does
>> > any write to
>> > a console work?
>> > On Tue, Dec 24, 2019 at 12:18 AM Niteesh <gsnb.gn at gmail.com
>> > <mailto:gsnb.gn at gmail.com>> wrote:
>> >     Is the correct port minor number set during the initialization? What
>> >     is the application want's to
>> >     access some other port?
>> >     On Tue, Dec 24, 2019 at 12:16 AM Niteesh <gsnb.gn at gmail.com
>> >         I would like to clarify my doubts regarding the console driver.
>> >         I went through the documentation
>> >         for the console
>> >         driver
>> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
>> >         But it is quite different from how some BSPs initialize.
>> >         Correct me if I am wrong
>> >         The console_tbl contains the various entries of serial ports.
>> >         The console_fns is a struct of function pointers, which point to
>> >         the BSP uart functions.
>> >         The BSP_output_char_function_type is what will be called for
>> >         printing a char on to the console.
>> >         How does RTEMS initialize the uart? It's seems not to be same
>> >         for all BSPs.
>> >         The doc says that the driver's initialization function is called
>> >         once during the rtems initialization process.
>> >         The console init function install the serial driver using
>> >         rtems_termios_device_install but there seems to be
>> >         no such function in the raspberry pi? But there is a entry in
>> >         console_fns for init function, but then how does it
>> >         gets called?
>> >         And for BSP's with multiple serial's, the output function
>> >         chooses the right serial using console_port_minor,
>> >         Is it during initialization?
>> >         What is the need for get and set register functions?
>> >         On Mon, Dec 23, 2019 at 1:04 AM Christian Mauderer
>> >         <list at c-mauderer.de <mailto:list at c-mauderer.de>> wrote:
>> >             On 22/12/2019 19:45, Joel Sherrill wrote:
>> >             > On Sun, Dec 22, 2019, 12:29 PM Niteesh <gsnb.gn at gmail.com
>> >             > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
>> wrote:
>> >             >     On Sun, Dec 22, 2019 at 8:44 PM Christian Mauderer
>> >             <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>
>> wrote:
>> >             >         Hello Niteesh,
>> >             >         thanks for doing that work.
>> >             >         On 22/12/2019 12:10, Niteesh wrote:
>> >             >         > The rpi1 and rpi2 use the PL011 UART, whereas,
>> >             with RPI's
>> >             >         equipped with
>> >             >         > wireless/Bluetooth module, the PL011 is
>> >             connected to the Bluetooth
>> >             >         > module, and the mini UART is used as the primary
>> >             UART.
>> >             >         In my opinion it would be great if you could use
>> >             the FDT to
>> >             >         distinguish
>> >             >         between the boards. That should allow to add
>> >             raspberry 3 (and
>> >             >         maybe 4)
>> >             >         support without adding another BSP. More BSPs mean
>> >             a bigger
>> >             >         maintenance
>> >             >         effort for the RTEMS community.
>> >             >     Learning more about FDT is on my list for a long
>> >             time.  I would love
>> >             >     to work on that
>> >             >     but I have almost no exp with FDT's.
>> >             >     But another thing could also be done, in
>> >             >     raspberrypi/start/bspstart.c we get the revision and
>> >             >     model of the board using the mailbox. Every board has
>> >             a unique id,
>> >             >     which we could use to initialize
>> >             >     the BSP. But using FDT seems to be a more elegant
>> >             option, it is a
>> >             >     lot of work I think, but we could take
>> >             >     help from libbsd and linux I suppose. What do you
>> think?
>> >             > I think there are almost always two steps to a project
>> >             like this: get it
>> >             > to work and make it nice. :)
>> >             > If you fix the startup code to read the board revision and
>> >             memory size,
>> >             > you can get a working BSP that dynamically adapts to the
>> >             models and
>> >             > memory variations with minimal modifications. If you want
>> >             to then
>> >             > convert the BSP to FDT, it will be a LOT easier to debug
>> >             with a working BSP.
>> >             > Plus you may be able to identify every variation point
>> >             based on just the
>> >             > model info. Then FDT is just a matter of switching the
>> >             source of
>> >             > some/all of the info.
>> >             > That would be my work plan anyway.
>> >             I agree with Joel that a secure development basis (also
>> >             known as "hack")
>> >             as a first step is a good idea. You maybe even just make the
>> >             mini UART
>> >             the default driver while you are developing. Then you can be
>> >             sure that
>> >             you have the right driver.
>> >             As soon as that works you can either change to the revision
>> >             method or
>> >             (better) to the FDT one and after that the patches can be
>> >             merged. Using
>> >             the FDT isn't that complicated. Basically you search for a
>> >             node based on
>> >             different parameters. For an example you can take a look at
>> >             the imx BSP.
>> >             In imx_uart_probe (bsps/arm/imx/console/console-config.c) a
>> >             fdt node is
>> >             searched and based on that a UART driver is used. But again:
>> >             Follow
>> >             Joels suggestion to start simple and secure.
>> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>> >             >         > But from the above doc (PAGE 10), the mini uart
>> >             has 16550 like
>> >             >         registers
>> >             >         > and RTEMS already has the driver for it
>> >             >         > bsps/shared/dev/serial/ns16550.c. But I am not
>> >             sure how
>> >             >         compatible they
>> >             >         > are? Should a new driver be implemented from
>> >             scratch or use
>> >             >         ns16550 if
>> >             >         > possible?
>> >             >         In general it's better to re-use existing code.
>> >             That has multiple
>> >             >         advantages:
>> >             >         - It reduces the maintenance effort. Fewer code
>> >             means fewer work.
>> >             >         - If you have multiple driver for the same or
>> >             similar hardware
>> >             >         it can
>> >             >         happen that a bug is fixed in one but not the
>> other.
>> >             >         - It's simpler to find a hardware to test changes.
>> >             >         - The driver becomes more universal with every new
>> >             supported
>> >             >         hardware.
>> >             >         That increases the chance that it fits the next
>> >             new hardware.
>> >             >         I'm sure there are some more if you ask someone
>> else.
>> >             >     I do understand the issues, I just spent some time
>> >             reading the
>> >             >     driver code.
>> >             >     I think we could most probably use it. I will take a
>> >             closer look and
>> >             >     will update.
>> >             Great.
>> >             >         > Also, the core clock on which the PL011 is based
>> >             on is changed
>> >             >         in rpi3.
>> >             >         > Rpi1 and 2 use 250Mhz as the default clock but
>> >             it was changed
>> >             >         to 400Mhz
>> >             >         > in Rpi3 and newer
>> >             >         Again: Would be great if that could be adapted
>> >             based on FDT or by
>> >             >         reading the right registers.
>> >             >         > Few differences between PL011 and Mini uart
>> >             >         > The mini UART has smaller FIFOs. Combined with
>> >             the lack of
>> >             >         flow control,
>> >             >         > this makes it more prone to losing characters at
>> >             higher baud
>> >             >         rates. It
>> >             >         > is also generally less capable than the PL011,
>> >             mainly due to
>> >             >         its baud
>> >             >         > rate link to the VPU clock speed.
>> >             >         That shouldn't really be a problem for the system
>> >             console.
>> >             >         > The particular deficiencies of the mini UART
>> >             compared to the
>> >             >         PL011 are :
>> >             >         > No break detection
>> >             >         > No framing errors detection
>> >             >         > No parity bit
>> >             >         > No receive timeout interrupt
>> >             >         > No DCD, DSR, DTR or RI signals
>> >             >     _______________________________________________
>> >             >     devel mailing list
>> >             >     devel at rtems.org <mailto:devel at rtems.org>
>> >             <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>> >             >     http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191224/c1969d7b/attachment-0001.html>
