Raspberrypi3: Mini UART driver
Niteesh gsnb.gn at gmail.com
Fri Dec 27 09:42:47 UTC 2019
On Fri, Dec 27, 2019 at 2:53 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> Hello Niteesh,
> let me repeat two important questions:
> - How do you plan to test the changes? Simulator is OK for me but
> untested is not OK.
Since I don't have the older pi's, the simulator will be my only option.
And did you
take a look at the exception?
> - Isn't it possible to just use the driver from
> bsps/arm/shared/serial/arm-pl011.c and remove the BSP specific completely?
Yes, I have done this. I usart.c file is now completely empty. All we have
to define was
the start address for the PL011 peripheral in usart.h.
> On 27/12/2019 06:29, Niteesh wrote:
> > On Fri, Dec 27, 2019 at 1:58 AM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     Hello Niteesh,
> >     sorry for not answering earlier. During this time of the year you
> have
> >     to expect some delays on the mailing list due to public holydays and
> >     vacations.
> > That's okay, I understand.
> >     On 25/12/2019 10:50, Niteesh wrote:
> >     > Just to make sure I am going in the right track.
> >     > I moved the uart register definitions to bsp/usart.h into a struct
> of
> >     > uint32_t called usart0_regs
> >     > here is git diff of usart.c after changing it to the latest console
> >     > interface.
> >     Do you have a plan how you want to test these changes?
> >     The direction looks OK. Some notes below.
> >     By the way: Maybe it would be a better idea to just remove it
> completely
> >     and use the bsps/arm/shared/serial/arm-pl011.c driver instead? That
> >     reduces the ammount of code and therefore ammount of bugs we have in
> >     this BSP.
> >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
> >     > b/bsps/arm/raspberrypi/console/usart.c
> >     > index 25fb523621..b12f375a1c 100644
> >     > --- a/bsps/arm/raspberrypi/console/usart.c
> >     > +++ b/bsps/arm/raspberrypi/console/usart.c
> >     > @@ -47,6 +47,12 @@ static uint32_t usart_get_baud(const
> >     console_tbl *ct)
> >     >  #endif
> >     > +typedef struct {
> >     > +  rtems_termios_device_context base;
> >     > +  const char *device_name;
> >     > +  volatile usart0_regs *regs;
> >     > +}uart0_context;
> >     Why uart0_context and not usart_context? All other names in this file
> >     are called usart_...
> > Sorry, for the inconsistent naming, should I rename it as pl011_context
> > since we will be adding
> > mini uart for rpi3, IMHO it would be better.
> If you touch nearly all locations where the name is used: Yes. But
> again: There is already a generic pl011 driver. Use that driver if
> possible.
> >     >  static void usart_set_baud(int minor, int baud)
> >     > @@ -55,10 +61,17 @@ static void usart_set_baud(int minor, int baud)
> >     >   return;
> >     > -static void usart_initialize(int minor)
> >     > +static volatile usart0_regs
> >     > *rpi_uart_get_regs(rtems_termios_device_context *base)
> >     > -  unsigned int gpio_reg;
> >     > +  uart0_context *ctx;
> >     > +  ctx = (usart0_regs *) base;
> >     > +  return ctx->regs;
> >     > +static void usart_initialize(rtems_termios_device_context *base)
> >     > +  unsigned int gpio_reg;
> >     >    ** Program GPIO pins for UART 0
> >     > @@ -75,67 +88,81 @@ static void usart_initialize(int minor)
> >     >    usart_delay(150);
> >     >    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> >     > +  volatile uint32_t *uart_regs = rpi_uart_get_regs(base);
> >     >    ** Init the PL011 UART
> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> >     > -  usart_set_baud(minor, 115000);
> >     > +  uart_regs->cr  = 0;
> >     > +  uart_regs->icr = 0x7ff;
> >     > +  uart_regs->imsc = 0;
> >     > +  uart_regs->ibrd = 1;
> >     > +  uart_regs->fbrd= 40;
> >     > +  uart_regs->lcrh= 0x70;
> >     > +  uart_regs->rsrecr= 0;
> >     > +  uart_regs->cr = 0x301;
> >     > +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
> >     > +  // usart_set_baud(minor, 115000);
> >     Why is this line commented now?
> > It actually does nothing. The function body was empty. The current baud
> > rate is set directly
> > in the initialization function. I was planning to update it once, I was
> > finished with the interface.
> If it is empty: Is it necessary? There is a
> rtems_termios_set_initial_baud(...) which should do the same.
> >     > -static int usart_first_open(int major, int minor, void *arg)
> >     > +static bool usart_first_open(
> >     > +  rtems_termios_tty *tty,
> >     > +  rtems_termios_device_context *base,
> >     > +  struct termios *term,
> >     > +  rtems_libio_open_close_args_t *args
> >     > -  rtems_libio_open_close_args_t *oc =
> >     (rtems_libio_open_close_args_t *)
> >     > arg;
> >     > -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> >     > oc->iop->data1;
> >     > -  const console_tbl *ct = Console_Port_Tbl [minor];
> >     > -  console_data *cd = &Console_Port_Data [minor];
> >     > +  rtems_status_code sc;
> >     > +  bool ok;
> >     > -  cd->termios_data = tty;
> >     > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
> >     > +  ctx = (uart0_context *) base;
> >     > -  return 0;
> >     > +  usart_initialize(base);
> >     > +  sc = rtems_termios_set_initial_baud(tty,  USART0_DEFAULT_BAUD);
> >     > +  if ( sc != RTEMS_SUCCESSFUL ){
> >     > +    printk("Error setting the baud for termios\n");
> >     > +    return false;
> >     There is a return missing here. Did you compile the code? The
> compiler
> >     should give you a warning about that.
> >     > -static int usart_last_close(int major, int minor, void *arg)
> >     > +static int usart_last_close(
> >     The first_open returns a bool but last_close returns still an int? Is
> >     this correct? I don't have the interface memorized.
> > last_close return type is void.
> Then you should fix that here.
> >     > +  rtems_termios_open_close_args_t *arg)
> >     >    return 0;
> >     > -static int usart_read_polled(int minor)
> >     > +static int usart_read_polled(rtems_termios_device_context *base)
> >     > -  if (minor == 0) {
> >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
> >     == 0) {
> >     > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> >     > -    } else {
> >     > -      return -1;
> >     > -  } else {
> >     > -    printk("Unknown console minor number: %d\n", minor);
> >     > -    return -1;
> >     > +  regs = rpi_uart_get_regs(base);
> >     Just noted that here: Why rpi_uart_get_regs and not usart_get_regs?
> >     Please use a consitent naming scheme.
> >     > +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
> >     > +    return (regs->dr & 0xFF);
> >     > +  return -1;
> >     > -static void usart_write_polled(int minor, char c)
> >     > +static void usart_write_polled(rtems_termios_device_context
> >     *base, char c)
> >     > -   while (1) {
> >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
> >     == 0)
> >     > -       break;
> >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
> >     > +  while (1) {
> >     > +    if (((regs->fr) & BCM2835_UART0_FR_TXFF) == 0)
> >     > +      break;
> >     > +  regs->dr = c;
> >     >  static ssize_t usart_write_support_polled(
> >     > -  int minor,
> >     >    const char *s,
> >     >    size_t n
> >     > @@ -143,7 +170,7 @@ static ssize_t usart_write_support_polled(
> >     >    ssize_t i = 0;
> >     >    for (i = 0; i < n; ++i) {
> >     > -    usart_write_polled(minor, s [i]);
> >     > +    usart_write_polled(base, s[i]);
> >     >    return n;
> >     > @@ -154,14 +181,11 @@ static int usart_set_attributes(int minor,
> const
> >     > struct termios *term)
> >     >    return -1;
> >     > -const console_fns bcm2835_usart_fns = {
> >     > -  .deviceProbe = libchip_serial_default_probe,
> >     > -  .deviceFirstOpen = usart_first_open,
> >     > -  .deviceLastClose = usart_last_close,
> >     > -  .deviceRead = usart_read_polled,
> >     > -  .deviceWrite = usart_write_support_polled,
> >     > -  .deviceInitialize = usart_initialize,
> >     > -  .deviceWritePolled = usart_write_polled,
> >     > -  .deviceSetAttributes = usart_set_attributes,
> >     > -  .deviceOutputUsesInterrupts = false
> >     > +const rtems_termios_device_handler bcm2835_uart0_handler_polled =
> >     > +  .first_open = usart_first_open,
> >     > +  .last_close = usart_last_close,
> >     > +  .poll_read = usart_read_polled,
> >     > +  .set_attributes = usart_set_attributes,
> >     > +  .write = usart_write_support_polled,
> >     > +  .mode = TERMIOS_POLLED
> >     > \ No newline at end of file
> >     > On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill <joel at rtems.org
> >     <mailto:joel at rtems.org>
> >     > <mailto:joel at rtems.org <mailto:joel at rtems.org>>> wrote:
> >     >     On Tue, Dec 24, 2019, 12:19 PM Niteesh <gsnb.gn at gmail.com
> >     <mailto:gsnb.gn at gmail.com>
> >     >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
> >     >         And also the register definitions are in raspberrpi.h file
> >     >         should I move them to usart.h.
> >     >     Sounds right if you mean bsp/usart.h
> >     >         I have a doubt we have a register field in device_context
> >     >         typedef struct {
> >     >             volatile some_chip_registers *regs;
> >     >         } my_driver_context;
> >     >         How does the reg field point to the correct
> >     memory location? for
> >     >         instance in IMX BSP,
> >     >         there is a struct with register field's but none of the
> >     define a
> >     >         memory location?
> >     >     Make sure the structure has volatiles and proper alignment. :)
> >     >         On Tue, Dec 24, 2019 at 11:37 PM Niteesh
> >     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> wrote:
> >     >             How to handle different serial devices? In other BSPs
> the
> >     >             uart devices are the same, so
> >     >             they were able to put it under a single array? But
> here we
> >     >             have 2 uarts and a FB?
> >     >             On Tue, Dec 24, 2019 at 8:18 PM Christian Mauderer
> >     >             <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >                 On 24/12/2019 12:06, Niteesh wrote:
> >     >                 > The current raspi console section is like this:
> >     >                 > The bsp_console_select in console_select.c is
> >     >                 responsible for selecting
> >     >                 > between uart and the framebuffer. It does so
> >     >                 > by setting the Console_port_minor.
> >     >                 > The console_config is responsible for output_char
> >     >                 function.
> >     >                 > And other files are driver code.
> >     >                 > If rewriting, this would be my approach,
> >     >                 > Rewrite the bsp_console_select to set some kind
> of a
> >     >                 variable like in
> >     >                 > IMX, then in console_initialize function
> >     >                 > link the right driver to /dev/console.
> >     >                 > Replace the console_tbl with the device_context
> and
> >     >                 console_fns with
> >     >                 > termios_device_handlers and
> >     >                 > finally add in the console_initialization
> function.
> >     >                 I agree that this would be a clean solution. So if
> you
> >     >                 want you can do
> >     >                 that. But there might is a hurdle: As far as I
> >     >                 understood you you only
> >     >                 have a Pi3? So you might have a hard time testing
> the
> >     >                 changes. Maybe the
> >     >                 simulator could work.
> >     >                 Another possibility could be to set the
> >     >                 "Console_port_minor" to
> >     >                 something unused (for example -1). In that case
> >     you can
> >     >                 define another
> >     >                 /dev/console.
> >     >                 Best regards and merry Christmas (in case you
> >     celebrate)
> >     >                 Christian
> >     >                 > On Tue, Dec 24, 2019 at 2:13 PM Niteesh
> >     <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
> >     <mailto:gsnb.gn at gmail.com>>>>
> >     >                 wrote:
> >     >                 >     Thank you so much, for such a detailed
> >     answer. Now
> >     >                 things make
> >     >                 >     really good sense to me,
> >     >                 >     going through the code now is just a breeze.
> >     But I
> >     >                 still have one
> >     >                 >     question
> >     >                 >     for the newer driver interface is
> >     >                 console_initialize the function
> >     >                 >     which RTEMS calls while initializing
> >     >                 >     the console? Which means I can't mess with
> the
> >     >                 name right? It is
> >     >                 >     similar to the main function, right?
> >     >                 >     The current driver is a legacy one, how do
> you
> >     >                 want me to proceed,
> >     >                 >     shall I rewrite the legacy to a
> >     >                 >     the new one, this is will be a great
> >     >                 learning experience for me also
> >     >                 >     and we also get the BSP updated to the latest
> >     >                 interface.
> >     >                 >     On Tue, Dec 24, 2019 at 3:20 AM Christian
> >     Mauderer
> >     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
> >     <mailto:list at c-mauderer.de>>>>
> >     >                 wrote:
> >     >                 >         Hello Niteesh,
> >     >                 >         quite a lot of questions. I'll try to
> answer
> >     >                 them. Note that it
> >     >                 >         has been
> >     >                 >         some time since I had a detailed look at
> >     that
> >     >                 code so if something I
> >     >                 >         tell seems odd please don't hesitate to
> >     >                 question it.
> >     >                 >         Please note that in RTEMS their are more
> or
> >     >                 less two "levels" of
> >     >                 >         support
> >     >                 >         for a serial console:
> >     >                 >         1. A very basic polled system console
> (also
> >     >                 known as
> >     >                 >         "debug-console" in
> >     >                 >         some BSPs). This one is used for printk
> and
> >     >                 should work in basically
> >     >                 >         every case. It is used for critical
> system
> >     >                 messages like
> >     >                 >         printing the
> >     >                 >         exception frame. For that a BSP has to
> >     provide a
> >     >                 >         "BSP_output_char" function.
> >     >                 >         2. A full featured UART driver
> >     integrated into
> >     >                 Termios. That one
> >     >                 >         will be
> >     >                 >         used for all normal I/O on the UARTs.
> >     >                 >         As far as I know the "console_tbl
> >     >                 Console_Configuration_Ports"
> >     >                 >         belongs
> >     >                 >         to a table based legacy interface. It is
> >     >                 handled in the file
> >     >                 >         bsps/shared/dev/serial/legacy-console.c.
> I'm
> >     >                 not sure whether it is
> >     >                 >         documented in the BSP guide because it
> >     >                 shouldn't be used for new
> >     >                 >         BSPs.
> >     >                 >         Same is true for the "major" and "minor"
> >     >                 stuff: It's not really
> >     >                 >         used for
> >     >                 >         new drivers.
> >     >                 >         Newer drivers use the initialization
> that is
> >     >                 described in the manual
> >     >                 >         that you have already found. Basically
> >     they use
> >     >                 >         "rtems_termios_device_install" to
> register a
> >     >                 new UART as
> >     >                 >         "/dev/ttySomething". Some recent (ARM)
> BSPs
> >     >                 that do that are the
> >     >                 >         imx or
> >     >                 >         the atsam.
> >     >                 >         The console that is used for stdin,
> >     stdout and
> >     >                 stderr (printf,
> >     >                 >         scanf,
> >     >                 >         ...) is the one called "/dev/console"
> >     (defined in
> >     >                 >         CONSOLE_DEVICE_NAME).
> >     >                 >         For the legacy table based interface
> >     it's the
> >     >                 one with the index of
> >     >                 >         "Console_Port_Minor".
> >     >                 >         If you want to access any UART other
> >     than the
> >     >                 one for stdin and
> >     >                 >         stdout
> >     >                 >         you do that the same way like on Linux:
> Just
> >     >                 use the "open"
> >     >                 >         function on
> >     >                 >         the "/dev/ttySomething" and use "read",
> >     >                 "write" and simmilar or use
> >     >                 >         "fopen" together with "fread", "fwrite",
> >     >                 "fprintf", ...
> >     >                 >         "printf" (and family) is a function
> >     belonging
> >     >                 to the C library.
> >     >                 >         In our
> >     >                 >         case that's newlib. It will format your
> >     >                 message and after some other
> >     >                 >         preprocessing will call the "write"
> function
> >     >                 of the file that is
> >     >                 >         opened
> >     >                 >         as stdout (which is "/dev/console" in the
> >     >                 default case).
> >     >                 >         I hope that I helped you with that
> >     >                 explanation. Please feel free
> >     >                 >         to ask
> >     >                 >         anything if it isn't clear.
> >     >                 >         Best regards
> >     >                 >         Christian
> >     >                 >         On 23/12/2019 19:50, Niteesh wrote:
> >     >                 >         > And finally, how does printf work? It
> is a
> >     >                 macro? In that
> >     >                 >         case, how does
> >     >                 >         > any write to
> >     >                 >         > a console work?
> >     >                 >         > On Tue, Dec 24, 2019 at 12:18 AM
> Niteesh
> >     <mailto:gsnb.gn at gmail.com>> <mailto:gsnb.gn at gmail.com
> >     <mailto:gsnb.gn at gmail.com>>>>> wrote:
> >     >                 >         >     Is the correct port minor number
> set
> >     >                 during the
> >     >                 >         initialization? What
> >     >                 >         >     is the application want's to
> >     >                 >         >     access some other port?
> >     >                 >         >     On Tue, Dec 24, 2019 at 12:16 AM
> >     Niteesh
> >     >                 >         >         I would like to clarify my
> doubts
> >     >                 regarding the
> >     >                 >         console driver.
> >     >                 >         >         I went through the
> documentation
> >     >                 >         >         for the console
> >        driver
> https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction
> >     >                 >         >         But it is quite different from
> how
> >     >                 some BSPs initialize.
> >     >                 >         >         Correct me if I am wrong
> >     >                 >         >         The console_tbl contains the
> >     various
> >     >                 entries of serial
> >     >                 >         ports.
> >     >                 >         >         The console_fns is a struct of
> >     >                 function pointers,
> >     >                 >         which point to
> >     >                 >         >         the BSP uart functions.
> >     >                 >         >         The
> >     BSP_output_char_function_type is
> >     >                 what will be
> >     >                 >         called for
> >     >                 >         >         printing a char on to the
> console.
> >     >                 >         >         How does RTEMS initialize the
> >     uart?
> >     >                 It's seems not to
> >     >                 >         be same
> >     >                 >         >         for all BSPs.
> >     >                 >         >         The doc says that the driver's
> >     >                 >         is called
> >     >                 >         >         once during the rtems
> >     initialization
> >     >                 process.
> >     >                 >         >         The console init function
> install
> >     >                 the serial driver using
> but
> >     >                 there seems to be
> >     >                 >         >         no such function in the
> raspberry
> >     >                 pi? But there is a
> >     >                 >         entry in
> >     >                 >         >         console_fns for init function,
> but
> >     >                 then how does it
> >     >                 >         >         gets called?
> >     >                 >         >         And for BSP's with multiple
> >     >                 serial's, the output function
> >     >                 >         >         chooses the right serial using
> >     >                 console_port_minor,
> >     >                 >         >         Is it during initialization?
> >     >                 >         >         What is the need for get and
> set
> >     >                 register functions?
> >     >                 >         >         On Mon, Dec 23, 2019 at 1:04 AM
> >     >                 Christian Mauderer
> >     <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
> >     <mailto:list at c-mauderer.de>>>>> wrote:
> >     >                 >         >             On 22/12/2019 19:45, Joel
> >     >                 Sherrill wrote:
> >     >                 >         >             > On Sun, Dec 22, 2019,
> >     12:29 PM
> >     >                 Niteesh
> >     <mailto:gsnb.gn at gmail.com>>> <mailto:gsnb.gn at gmail.com
> at
> >     >                 8:44 PM Christian
> >     >                 >         Mauderer
> >     <mailto:list at c-mauderer.de>>> <mailto:list at c-mauderer.de
> >     <mailto:list at c-mauderer.de>>>>>> wrote:
> >     >                 >         >             >         Hello Niteesh,
> >     >                 >         >             >         thanks for doing
> >     that
> >     >                 work.
> >     >                 >         >             >         On 22/12/2019
> 12:10,
> >     >                 Niteesh wrote:
> >     >                 >         >             >         > The rpi1 and
> rpi2
> >     >                 use the PL011 UART,
> >     >                 >         whereas,
> >     >                 >         >             with RPI's
> >     >                 >         >             >         equipped with
> wireless/Bluetooth
> >     >                 module, the PL011 is
> >     >                 >         >             connected to the Bluetooth
> >     >                 >         >             >         > module, and
> >     the mini
> >     >                 UART is used as
> >     >                 >         the primary
> >     >                 >         >             UART.
> >     >                 >         >             >         In my opinion it
> >     would
> >     >                 be great if you
> >     >                 >         could use
> >     >                 >         >             the FDT to
> >     >                 >         >             >         distinguish
> >     >                 >         >             >         between the
> boards.
> >     >                 That should allow to add
> >     >                 >         >             raspberry 3 (and
> >     >                 >         >             >         maybe 4)
> >     >                 >         >             >         support without
> >     adding
> >     >                 another BSP. More
> >     >                 >         BSPs mean
> >     >                 >         >             a bigger
> >     >                 >         >             >         maintenance
> >     >                 >         >             >         effort for the
> RTEMS
> >     >                 community.
> >     >                 >         >             >     Learning more about
> >     FDT is
> >     >                 on my list for a long
> >     >                 >         >             time.  I would love
> >     >                 >         >             >     to work on that
> >     >                 >         >             >     but I have almost no
> exp
> >     >                 with FDT's.
> >     >                 >         >             >     But another thing
> could
> >     >                 also be done, in
> >     >                  raspberrypi/start/bspstart.c we get the
> >     >                 >         revision and
> >     >                 >         >             >     model of the board
> using
> >     >                 the mailbox. Every
> >     >                 >         board has
> >     >                 >         >             a unique id,
> >     >                 >         >             >     which we could use to
> >     >                 initialize
> >     >                 >         >             >     the BSP. But using
> FDT
> >     >                 seems to be a more
> >     >                 >         elegant
> >     >                 >         >             option, it is a
> >     >                 >         >             >     lot of work I think,
> but
> >     >                 we could take
> >     >                 >         >             >     help from libbsd and
> >     linux
> >     >                 I suppose. What
> >     >                 >         do you think?
> >     >                 >         >             > I think there are almost
> >     >                 always two steps to a
> >     >                 >         project
> >     >                 >         >             like this: get it
> >     >                 >         >             > to work and make it
> nice. :)
> >     >                 >         >             > If you fix the startup
> >     code to
> >     >                 read the board
> >     >                 >         revision and
> >     >                 >         >             memory size,
> >     >                 >         >             > you can get a working
> >     BSP that
> >     >                 dynamically
> >     >                 >         adapts to the
> >     >                 >         >             models and
> >     >                 >         >             > memory variations with
> >     minimal
> >     >                 modifications. If
> >     >                 >         you want
> >     >                 >         >             to then
> >     >                 >         >             > convert the BSP to FDT,
> it
> >     >                 will be a LOT easier
> >     >                 >         to debug
> >     >                 >         >             with a working BSP.
> >     >                 >         >             > Plus you may be able to
> >     >                 identify every variation
> >     >                 >         point
> >     >                 >         >             based on just the
> >     >                 >         >             > model info. Then FDT is
> >     just a
> >     >                 matter of
> >     >                 >         switching the
> >     >                 >         >             source of
> >     >                 >         >             > some/all of the info.
> >     >                 >         >             > That would be my work
> >     plan anyway.
> >     >                 >         >             I agree with Joel that a
> >     secure
> >     >                 development basis
> >     >                 >         (also
> >     >                 >         >             known as "hack")
> >     >                 >         >             as a first step is a good
> >     idea.
> >     >                 You maybe even
> >     >                 >         just make the
> >     >                 >         >             mini UART
> >     >                 >         >             the default driver while
> >     you are
> >     >                 developing. Then
> >     >                 >         you can be
> >     >                 >         >             sure that
> >     >                 >         >             you have the right driver.
> >     >                 >         >             As soon as that works you
> can
> >     >                 either change to the
> >     >                 >         revision
> >     >                 >         >             method or
> >     >                 >         >             (better) to the FDT one and
> >     >                 after that the patches
> >     >                 >         can be
> >     >                 >         >             merged. Using
> >     >                 >         >             the FDT isn't that
> >     complicated.
> >     >                 Basically you
> >     >                 >         search for a
> >     >                 >         >             node based on
> >     >                 >         >             different parameters. For
> an
> >     >                 example you can take
> >     >                 >         a look at
> >     >                 >         >             the imx BSP.
> >     >                 >         >             In imx_uart_probe
> >     >                 >         (bsps/arm/imx/console/console-config.c) a
> >     >                 >         >             fdt node is
> >     >                 >         >             searched and based on that
> a
> >     >                 UART driver is used.
> >     >                 >         But again:
> >     >                 >         >             Follow
> >     >                 >         >             Joels suggestion to start
> >     simple
> >     >                 and secure.
> https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
> >     >                 >         >             >         > But from the
> above
> >     >                 doc (PAGE 10), the
> >     >                 >         mini uart
> >     >                 >         >             has 16550 like
> >     >                 >         >             >         registers
> >     >                 >         >             >         > and RTEMS
> already
> >     >                 has the driver for it
> >     >                 bsps/shared/dev/serial/ns16550.c. But
> >     >                 >         I am not
> >     >                 >         >             sure how
> >     >                 >         >             >         compatible they
> >     >                 >         >             >         > are? Should a
> new
> >     >                 driver be
> >     >                 >         implemented from
> >     >                 >         >             scratch or use
> >     >                 >         >             >         ns16550 if
> >     >                 >         >             >         > possible?
> >     >                 >         >             >         In general it's
> >     better
> >     >                 to re-use
> >     >                 >         existing code.
> >     >                 >         >             That has multiple
> >     >                 >         >             >         advantages:
> >     >                 >         >             >         - It reduces the
> >     >                 maintenance effort.
> >     >                 >         Fewer code
> >     >                 >         >             means fewer work.
> >     >                 >         >             >         - If you have
> >     multiple
> >     >                 driver for the
> >     >                 >         same or
> >     >                 >         >             similar hardware
> >     >                 >         >             >         it can
> >     >                 >         >             >         happen that a
> bug is
> >     >                 fixed in one but
> >     >                 >         not the other.
> >     >                 >         >             >         - It's simpler
> >     to find
> >     >                 a hardware to
> >     >                 >         test changes.
> >     >                 >         >             >         - The driver
> becomes
> >     >                 more universal with
> >     >                 >         every new
> >     >                 >         >             supported
> >     >                 >         >             >         hardware.
> >     >                 >         >             >         That increases
> the
> >     >                 chance that it fits
> >     >                 >         the next
> >     >                 >         >             new hardware.
> >     >                 >         >             >         I'm sure there
> are
> >     >                 some more if you ask
> >     >                 >         someone else.
> >     >                 >         >             >     I do understand the
> >     >                 issues, I just spent
> >     >                 >         some time
> >     >                 >         >             reading the
> >     >                 >         >             >     driver code.
> >     >                 >         >             >     I think we could most
> >     >                 probably use it. I
> >     >                 >         will take a
> >     >                 >         >             closer look and
> >     >                 >         >             >     will update.
> >     >                 >         >             Great.
> >     >                 >         >             >         > Also, the core
> >     clock
> >     >                 on which the
> >     >                 >         PL011 is based
> >     >                 >         >             on is changed
> >     >                 >         >             >         in rpi3.
> >     >                 >         >             >         > Rpi1 and 2 use
> >     >                 250Mhz as the default
> >     >                 >         clock but
> >     >                 >         >             it was changed
> >     >                 >         >             >         to 400Mhz
> >     >                 >         >             >         > in Rpi3 and
> newer
> >     >                 >         >             >         Again: Would be
> >     great
> >     >                 if that could be
> >     >                 >         adapted
> >     >                 >         >             based on FDT or by
> >     >                 >         >             >         reading the right
> >     >                 registers.
> >     >                 >         >             >         > Few differences
> >     >                 between PL011 and Mini
> >     >                 >         uart
> >     >                 >         >             >         > The mini UART
> has
> >     >                 smaller FIFOs.
> >     >                 >         Combined with
> >     >                 >         >             the lack of
> >     >                 >         >             >         flow control,
> >     >                 >         >             >         > this makes it
> more
> >     >                 prone to losing
> >     >                 >         characters at
> >     >                 >         >             higher baud
> >     >                 >         >             >         rates. It
> >     >                 >         >             >         > is also
> generally
> >     >                 less capable than
> >     >                 >         the PL011,
> >     >                 >         >             mainly due to
> >     >                 >         >             >         its baud
> >     >                 >         >             >         > rate link to
> >     the VPU
> >     >                 clock speed.
> >     >                 >         >             >         That shouldn't
> >     really
> >     >                 be a problem for
> >     >                 >         the system
> >     >                 >         >             console.
> >     >                 >         >             >         > The particular
> >     >                 deficiencies of the
> >     >                 >         mini UART
> >     >                 >         >             compared to the
> >     >                 >         >             >         PL011 are :
> >     >                 >         >             >         > No break
> detection
> >     >                 >         >             >         > No framing
> errors
> >     >                 detection
> >     >                 >         >             >         > No parity bit
> >     >                 >         >             >         > No receive
> timeout
> >     >                 interrupt
> >     >                 >         >             >         > No DCD, DSR,
> >     DTR or
> >     >                 RI signals
> >     >                  _______________________________________________
> >     >                 >         >             >     devel mailing list
> >     >                 >         >             >     devel at rtems.org
> >     <mailto:devel at rtems.org>
> >     >                 <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> >     >                 <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
> >     >                  http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191227/e87ce4ef/attachment-0001.html>
