Raspberrypi3: Mini UART driver
Christian Mauderer list at c-mauderer.de
Fri Dec 27 10:15:16 UTC 2019
On 27/12/2019 11:12, Niteesh wrote:
> On Fri, Dec 27, 2019 at 3:38 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
>     On 27/12/2019 11:03, Niteesh wrote:
>     > I tried building it. I basically ran make in previously create
>     rpi2 BSP
>     > folder.
>     > I did get some compile-time error, but I have fixed them. Now I get
>     > an*undefined reference to `arm_pl011_write_polled'*
>     > How to include the arm_pl011.c file?
>     You have to add the file here:
>     c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> Did you mean the header.am <http://header.am> file? Or should I make a
> Makefile.am?
I mean that one:
https://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
Note: It's in a different folder. Like I said: That's a left over of an
old directory structure.
>     Note that you will have to execute a bootstrap again as soon as you
>     change anything there.
>     These files still follow an old folder structure. But they will be
>     replaced soon by Sebastians work on the new build system.
>     > On Fri, Dec 27, 2019 at 3:15 PM Niteesh <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>
>     > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>> wrote:
>     >     The changes I have made so far
>     >     diff --git a/bsps/arm/raspberrypi/console/console-config.c
>     >     b/bsps/arm/raspberrypi/console/console-config.c
>     >     index d2186c918b..d982b2c9c2 100644
>     >     --- a/bsps/arm/raspberrypi/console/console-config.c
>     >     +++ b/bsps/arm/raspberrypi/console/console-config.c
>     >     @@ -22,45 +22,53 @@
>     >      #include <libchip/serial.h>
>     >     -#include <bspopts.h>
>     >      #include <bsp/irq.h>
>     >      #include <bsp/usart.h>
>     >      #include <bsp/raspberrypi.h>
>     >     +#include <bsp/arm-pl011.h>
>     >      #include <bsp/fbcons.h>
>     >     -console_tbl Console_Configuration_Ports [] = {
>     >     -      .sDeviceName = "/dev/ttyS0",
>     >     -      .deviceType = SERIAL_CUSTOM,
>     >     -      .pDeviceFns = &bcm2835_usart_fns,
>     >     -      .deviceProbe = NULL,
>     >     -      .pDeviceFlow = NULL,
>     >     -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>     >     -      .ulCtrlPort2 = 0,
>     >     -      .ulClock = USART0_DEFAULT_BAUD,
>     >     -      .ulIntVector = BCM2835_IRQ_ID_UART
>     >     -      .sDeviceName ="/dev/fbcons",
>     >     -      .pDeviceFns = &fbcons_fns,
>     >     -      .deviceProbe = fbcons_probe,
>     >     +#include <bspopts.h>
>     >     +arm_pl011_context pl011_context = {
>     >     +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>     >     +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
>     >     +  .initial_baud = PL011_DEFAULT_BAUD
>     >     -#define PORT_COUNT \
>     >     -  (sizeof(Console_Configuration_Ports) \
>     >     -    / sizeof(Console_Configuration_Ports [0]))
>     >     +rpi_fb_context fb_context = {
>     >     +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
>     >     -unsigned long Console_Configuration_Count = PORT_COUNT;
>     >     +const console_device console_device_table[] = {
>     >     +    .device_file = "/dev/ttyS0",
>     >     +    .probe = console_device_probe_default,
>     >     +    .handler = &arm_pl011_fns,
>     >     +    .context = &pl011_context.base
>     >     +    .device_file = "/dev/fb0",
>     >     +    // Should be changed to fbcons_probe (but it still use old
>     >     interface)
>     >     +    .probe = fbcons_probe,
>     >     +    .handler = &fbcons_fns,
>     >     +    .context = &fb_context.base
>     >     +const size_t console_device_count =
>     >     RTEMS_ARRAY_SIZE(console_device_table);
>     >      static void output_char(char c)
>     >     -  const console_fns *con =
>     >     -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>     >     -  con->deviceWritePolled((int) Console_Port_Minor, c);
>     >     +  switch(SERIAL){
>     >     +    case FB:
>     >     +      fbcons_write_polled(&fb_context.base, c);
>     >     +      break;
>     >     +    case PL011:
>     >     +      arm_pl011_write_polled(&pl011_context.base, c);
>     >     +      break;
>     >      BSP_output_char_function_type BSP_output_char = output_char;
>     >     diff --git a/bsps/arm/raspberrypi/console/console_select.c
>     >     b/bsps/arm/raspberrypi/console/console_select.c
>     >     index bd246ca868..dbca5c324f 100644
>     >     --- a/bsps/arm/raspberrypi/console/console_select.c
>     >     +++ b/bsps/arm/raspberrypi/console/console_select.c
>     >     @@ -15,7 +15,7 @@
>     >       *  http://www.rtems.org/license/LICENSE
>     >     +#include <bsp/raspberrypi.h>
>     >      #include <bsp.h>
>     >      #include <bsp/fatal.h>
>     >      #include <rtems/libio.h>
>     >     @@ -30,53 +30,7 @@
>     >      #include <bsp/rpi-fb.h>
>     >      rtems_device_minor_number BSPPrintkPort = 0;
>     >     - * Method to return true if the device associated with the
>     >     - * minor number probs available.
>     >     -static bool bsp_Is_Available( rtems_device_minor_number minor )
>     >     -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>     >     -   * First perform the configuration dependent probe, then the
>     >     -   * device dependent probe
>     >     -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>     >     -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>     >     -    return true;
>     >     -  return false;
>     >     - * Method to return the first available device.
>     >     -static rtems_device_minor_number bsp_First_Available_Device(
>     void )
>     >     -  rtems_device_minor_number minor;
>     >     -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>     >     -      return minor;
>     >     -   *  Error No devices were found.  We will want to bail here.
>     >     -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>     >     +CURRENT_SERIAL SERIAL = PL011;
>     >      void bsp_console_select( void )
>     >     @@ -90,25 +44,13 @@ void bsp_console_select( void )
>     >        const char *opt;
>     >     -  Console_Port_Minor = BSP_CONSOLE_UART0;
>     >     -  BSPPrintkPort = BSP_CONSOLE_UART0;
>     >        opt = rpi_cmdline_get_arg( "--console=" );
>     >        if ( opt ) {
>     >          if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) ==
>     0 ) {
>     >            if ( rpi_video_is_initialized() > 0 ) {
>     >     -        Console_Port_Minor = BSP_CONSOLE_FB;
>     >     -        BSPPrintkPort = BSP_CONSOLE_FB;
>     >     +        SERIAL = FB;
>     >     -   * If the device that was selected isn't available then
>     >     -   * let the user know and select the first available device.
>     >     -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>     >     -    Console_Port_Minor = bsp_First_Available_Device();
>     >     diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>     >     b/bsps/arm/raspberrypi/console/fbcons.c
>     >     index 3669ba458d..26a694ac9f 100644
>     >     --- a/bsps/arm/raspberrypi/console/fbcons.c
>     >     +++ b/bsps/arm/raspberrypi/console/fbcons.c
>     >     @@ -18,6 +18,7 @@
>     >      #include <rtems.h>
>     >     +#include <rtems/termiostypes.h>
>     >      #include <stdlib.h>
>     >     @@ -46,9 +47,10 @@ static void fbcons_init( int minor )
>     >       *  Default state is 9600 baud, 8 bits, No parity, and 1 stop
>     bit.
>     >      static int fbcons_open(
>     >     -  int   major,
>     >     -  int   minor,
>     >     -  void *arg
>     >     +  struct rtems_termios_tty *tty,
>     >     +  rtems_termios_device_context *base,
>     >     +  struct termios *term,
>     >     +  rtems_libio_open_close_args_t *args
>     >        return RTEMS_SUCCESSFUL;
>     >     @@ -60,9 +62,9 @@ static int fbcons_open(
>     >       *  This function shuts down the requested port.
>     >      static int fbcons_close(
>     >     -  int   major,
>     >     -  int   minor,
>     >     -  void *arg
>     >        return ( RTEMS_SUCCESSFUL );
>     >     @@ -73,8 +75,8 @@ static int fbcons_close(
>     >       *  This routine polls out the requested character.
>     >     -static void fbcons_write_polled(
>     >     -  int  minor,
>     >     +void fbcons_write_polled(
>     >        char c
>     >     @@ -91,7 +93,7 @@ static void fbcons_write_polled(
>     >      static ssize_t fbcons_write_support_polled(
>     >     -  int         minor,
>     >        const char *buf,
>     >        size_t      len
>     >     @@ -102,7 +104,7 @@ static ssize_t fbcons_write_support_polled(
>     >         * poll each byte in the string out of the port.
>     >        while ( nwrite < len ) {
>     >     -    fbcons_write_polled( minor, *buf++ );
>     >     +    fbcons_write_polled( base, *buf++ );
>     >          nwrite++;
>     >     @@ -117,7 +119,9 @@ static ssize_t fbcons_write_support_polled(
>     >       *  Console Termios polling input entry point.
>     >     -static int fbcons_inbyte_nonblocking_polled( int minor )
>     >     +static int fbcons_inbyte_nonblocking_polled(
>     >        // if( rtems_kbpoll() ) {
>     >        //   int c = getch();
>     >     @@ -134,14 +138,16 @@ static int fbcons_inbyte_nonblocking_polled(
>     >     int minor )
>     >       *  port settings.
>     >      static int fbcons_set_attributes(
>     >     -  int                   minor,
>     >        const struct termios *t
>     >        return 0;
>     >     -bool fbcons_probe( int minor )
>     >     +bool fbcons_probe(
>     >        // rtems_status_code status;
>     >        static bool firstTime = true;
>     >     @@ -163,15 +169,11 @@ bool fbcons_probe( int minor )
>     >        return ret;
>     >     -const console_fns fbcons_fns =
>     >     +const rtems_termios_device_handler fbcons_fns =
>     >     -  .deviceProbe = libchip_serial_default_probe,     /*
>     deviceProbe */
>     >     -  .deviceFirstOpen = fbcons_open,                 /*
>     deviceFirstOpen */
>     >     -  .deviceLastClose = fbcons_close,                /*
>     deviceLastClose */
>     >     -  .deviceRead = fbcons_inbyte_nonblocking_polled, /*
>     deviceRead */
>     >     -  .deviceWrite = fbcons_write_support_polled,     /*
>     deviceWrite */
>     >     -  .deviceInitialize = fbcons_init,                /*
>     >     deviceInitialize */
>     >     -  .deviceWritePolled = fbcons_write_polled,       /*
>     >     deviceWritePolled */
>     >     -  .deviceSetAttributes = fbcons_set_attributes,   /*
>     >     deviceSetAttributes */
>     >     -  .deviceOutputUsesInterrupts = FALSE,           /*
>     >     deviceOutputUsesInterrupts*/
>     >     +  .first_open = fbcons_open,
>     >     +  .last_close = fbcons_close,
>     >     +  .poll_read = fbcons_inbyte_nonblocking_polled,
>     >     +  .write = fbcons_write_support_polled,
>     >     +  .mode = TERMIOS_POLLED
>     >     \ No newline at end of file
>     >     diff --git a/bsps/arm/raspberrypi/console/usart.c
>     >     b/bsps/arm/raspberrypi/console/usart.c
>     >     index 25fb523621..471d0c553f 100644
>     >     --- a/bsps/arm/raspberrypi/console/usart.c
>     >     +++ b/bsps/arm/raspberrypi/console/usart.c
>     >     @@ -23,145 +23,3 @@
>     >      #include <rtems/bspIo.h>
>     >     -static void usart_delay(uint32_t n)
>     >     - volatile uint32_t i = 0;
>     >     - for(i = 0; i < n; i++)
>     >     -#if 0
>     >     - *  These will be useful when the driver supports interrupt
>     driven IO.
>     >     -static rtems_vector_number usart_get_irq_number(const
>     console_tbl *ct)
>     >     -  return ct->ulIntVector;
>     >     -static uint32_t usart_get_baud(const console_tbl *ct)
>     >     -  return ct->ulClock;
>     >     -#endif
>     >     -static void usart_set_baud(int minor, int baud)
>     >     -  * Nothing for now
>     >     - return;
>     >     -static void usart_initialize(int minor)
>     >     -  unsigned int gpio_reg;
>     >     -  ** Program GPIO pins for UART 0
>     >     -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>     >     -  gpio_reg &= ~(7<<12);    /* gpio14 */
>     >     -  gpio_reg |=  (4<<12);    /* alt0   */
>     >     -  gpio_reg &= ~(7<<15);    /* gpio15 */
>     >     -  gpio_reg |=  (4<<15);    /* alt0   */
>     >     -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>     >     -  usart_delay(150);
>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>     >     -  usart_delay(150);
>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>     >     -  ** Init the PL011 UART
>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>     >     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>     >     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>     >     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>     >     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>     >     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>     >     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>     >     -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>     >     -  usart_set_baud(minor, 115000);
>     >     -static int usart_first_open(int major, int minor, void *arg)
>     >     -  rtems_libio_open_close_args_t *oc =
>     >     (rtems_libio_open_close_args_t *) arg;
>     >     -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>     >     oc->iop->data1;
>     >     -  const console_tbl *ct = Console_Port_Tbl [minor];
>     >     -  console_data *cd = &Console_Port_Data [minor];
>     >     -  cd->termios_data = tty;
>     >     -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>     >     -  return 0;
>     >     -static int usart_last_close(int major, int minor, void *arg)
>     >     -  return 0;
>     >     -static int usart_read_polled(int minor)
>     >     -  if (minor == 0) {
>     >     -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>     >     == 0) {
>     >     -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>     >     -    } else {
>     >     -      return -1;
>     >     -  } else {
>     >     -    printk("Unknown console minor number: %d\n", minor);
>     >     -    return -1;
>     >     -static void usart_write_polled(int minor, char c)
>     >     -   while (1) {
>     >     -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>     BCM2835_UART0_FR_TXFF) == 0)
>     >     -       break;
>     >     -   BCM2835_REG(BCM2835_UART0_DR) = c;
>     >     -static ssize_t usart_write_support_polled(
>     >     -  int minor,
>     >     -  const char *s,
>     >     -  size_t n
>     >     -  ssize_t i = 0;
>     >     -  for (i = 0; i < n; ++i) {
>     >     -    usart_write_polled(minor, s [i]);
>     >     -  return n;
>     >     -static int usart_set_attributes(int minor, const struct
>     termios *term)
>     >     -  return -1;
>     >     -const console_fns bcm2835_usart_fns = {
>     >     -  .deviceFirstOpen = usart_first_open,
>     >     -  .deviceLastClose = usart_last_close,
>     >     -  .deviceRead = usart_read_polled,
>     >     -  .deviceWrite = usart_write_support_polled,
>     >     -  .deviceInitialize = usart_initialize,
>     >     -  .deviceWritePolled = usart_write_polled,
>     >     -  .deviceSetAttributes = usart_set_attributes,
>     >     -  .deviceOutputUsesInterrupts = false
>     >     diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >     index d0e126699a..f2ff25dc63 100644
>     >     --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >     +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>     >     @@ -33,12 +33,23 @@ extern "C" {
>     >      #define FB_CONSOLE 0x50492835
>     >     -bool fbcons_probe( int minor );
>     >     +bool fbcons_probe(
>     >     +  char c
>     >     +typedef struct {
>     >     +    rtems_termios_device_context base;
>     >     +} rpi_fb_context ;
>     >       * Driver function table
>     >     -extern const console_fns fbcons_fns;
>     >     +extern const rtems_termios_device_handler fbcons_fns;
>     >      #ifdef __cplusplus
>     >     diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >     index 40c80cf408..4e5c84c741 100644
>     >     --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >     +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>     >     @@ -60,6 +60,22 @@
>     >      #define RPI_PERIPHERAL_SIZE         0x01000000
>     >     + * @name Current Serial Device
>     >     +typedef enum {
>     >     +  PL011 = 0,
>     >     +  AUX_UART,
>     >     +  FB
>     >     +}CURRENT_SERIAL;
>     >     +extern CURRENT_SERIAL SERIAL;
>     >       * @name Internal ARM Timer Registers
>     >     @@ -184,42 +200,6 @@
>     >     - * @name UART 0 (PL011) Registers
>     >     -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>     >     -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>     >     -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>     >     -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>     >     -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>     >     -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>     >     -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>     >     -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>     >     -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>     >     -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>     >     -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>     >     -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>     >     -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>     >     -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>     >     -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>     >     -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>     >     -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>     >     -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>     >     -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>     >     -#define BCM2835_UART0_MIS_RX    0x10
>     >     -#define BCM2835_UART0_MIS_TX    0x20
>     >     -#define BCM2835_UART0_IMSC_RX   0x10
>     >     -#define BCM2835_UART0_IMSC_TX   0x20
>     >     -#define BCM2835_UART0_FR_RXFE   0x10
>     >     -#define BCM2835_UART0_FR_TXFF   0x20
>     >     -#define BCM2835_UART0_ICR_RX    0x10
>     >     -#define BCM2835_UART0_ICR_TX    0x20
>     >     diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>     >     b/bsps/arm/raspberrypi/include/bsp/usart.h
>     >     index d3e710c5e9..abbf53626c 100644
>     >     --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>     >     +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>     >     @@ -32,9 +32,8 @@
>     >      extern "C" {
>     >      #endif /* __cplusplus */
>     >     -#define USART0_DEFAULT_BAUD 115000
>     >     -extern const console_fns bcm2835_usart_fns;
>     >     +#define PL011_DEFAULT_BAUD 115000
>     >     +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>     >      #ifdef __cplusplus
>     >     On Fri, Dec 27, 2019 at 3:12 PM Niteesh <gsnb.gn at gmail.com
>     >         On Fri, Dec 27, 2019 at 2:53 PM Christian Mauderer
>     >         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >             Hello Niteesh,
>     >             let me repeat two important questions:
>     >             - How do you plan to test the changes? Simulator is OK for
>     >             me but
>     >             untested is not OK.
>     >         Since I don't have the older pi's, the simulator will be
>     my only
>     >         option. And did you
>     >         take a look at the exception?
>     >             - Isn't it possible to just use the driver from
>     >             bsps/arm/shared/serial/arm-pl011.c and remove the BSP
>     >             specific completely?
>     >         Yes, I have done this. I usart.c file is now completely empty.
>     >         All we have to define was
>     >         the start address for the PL011 peripheral in usart.h.
>     >             On 27/12/2019 06:29, Niteesh wrote:
>     >             > On Fri, Dec 27, 2019 at 1:58 AM Christian Mauderer
>     >             > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>
>     >             wrote:
>     >             >     Hello Niteesh,
>     >             >     sorry for not answering earlier. During this time of
>     >             the year you have
>     >             >     to expect some delays on the mailing list due to
>     >             public holydays and
>     >             >     vacations.
>     >             > That's okay, I understand.
>     >             >     On 25/12/2019 10:50, Niteesh wrote:
>     >             >     > Just to make sure I am going in the right track.
>     >             >     > I moved the uart register definitions to
>     bsp/usart.h
>     >             into a struct of
>     >             >     > uint32_t called usart0_regs
>     >             >     > here is git diff of usart.c after changing it
>     to the
>     >             latest console
>     >             >     > interface.
>     >             >     Do you have a plan how you want to test these
>     changes?
>     >             >     The direction looks OK. Some notes below.
>     >             >     By the way: Maybe it would be a better idea to just
>     >             remove it completely
>     >             >     and use the bsps/arm/shared/serial/arm-pl011.c
>     driver
>     >             instead? That
>     >             >     reduces the ammount of code and therefore ammount of
>     >             bugs we have in
>     >             >     this BSP.
>     >             >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
>     >             >     > b/bsps/arm/raspberrypi/console/usart.c
>     >             >     > index 25fb523621..b12f375a1c 100644
>     >             >     > --- a/bsps/arm/raspberrypi/console/usart.c
>     >             >     > +++ b/bsps/arm/raspberrypi/console/usart.c
>     >             >     > @@ -47,6 +47,12 @@ static uint32_t
>     >             >     console_tbl *ct)
>     >             >     >  #endif
>     >             >     > +typedef struct {
>     >             >     > +  rtems_termios_device_context base;
>     >             >     > +  const char *device_name;
>     >             >     > +  volatile usart0_regs *regs;
>     >             >     > +}uart0_context;
>     >             >     Why uart0_context and not usart_context? All other
>     >             names in this file
>     >             >     are called usart_...
>     >             > Sorry, for the inconsistent naming, should I rename
>     it as
>     >             pl011_context
>     >             > since we will be adding
>     >             > mini uart for rpi3, IMHO it would be better.
>     >             If you touch nearly all locations where the name is used:
>     >             Yes. But
>     >             again: There is already a generic pl011 driver. Use that
>     >             driver if possible.
>     >             >     >  static void usart_set_baud(int minor, int baud)
>     >             >     > @@ -55,10 +61,17 @@ static void usart_set_baud(int
>     >             minor, int baud)
>     >             >     >   return;
>     >             >     > -static void usart_initialize(int minor)
>     >             >     > +static volatile usart0_regs
>     *rpi_uart_get_regs(rtems_termios_device_context *base)
>     >             >     > -  unsigned int gpio_reg;
>     >             >     > +  uart0_context *ctx;
>     >             >     > +  ctx = (usart0_regs *) base;
>     >             >     > +  return ctx->regs;
>     >             >     > +static void
>     >             usart_initialize(rtems_termios_device_context *base)
>     >             >     > +  unsigned int gpio_reg;
>     >             >     >    ** Program GPIO pins for UART 0
>     >             >     > @@ -75,67 +88,81 @@ static void
>     >             minor)
>     >             >     >    usart_delay(150);
>     >             >     >    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>     >             >     > +  volatile uint32_t *uart_regs =
>     >             rpi_uart_get_regs(base);
>     >             >     >    ** Init the PL011 UART
>     >             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>     >             >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>     >             >     > -  usart_set_baud(minor, 115000);
>     >             >     > +  uart_regs->cr  = 0;
>     >             >     > +  uart_regs->icr = 0x7ff;
>     >             >     > +  uart_regs->imsc = 0;
>     >             >     > +  uart_regs->ibrd = 1;
>     >             >     > +  uart_regs->fbrd= 40;
>     >             >     > +  uart_regs->lcrh= 0x70;
>     >             >     > +  uart_regs->rsrecr= 0;
>     >             >     > +  uart_regs->cr = 0x301;
>     >             >     > +  uart_regs->imsc = BCM2835_UART0_IMSC_RX;
>     >             >     > +  // usart_set_baud(minor, 115000);
>     >             >     Why is this line commented now?
>     >             > It actually does nothing. The function body was
>     empty. The
>     >             current baud
>     >             > rate is set directly
>     >             > in the initialization function. I was planning to update
>     >             it once, I was
>     >             > finished with the interface.
>     >             If it is empty: Is it necessary? There is a
>     >             rtems_termios_set_initial_baud(...) which should do
>     the same.
>     >             >     > -static int usart_first_open(int major, int minor,
>     >             void *arg)
>     >             >     > +static bool usart_first_open(
>     >             >     > +  rtems_termios_tty *tty,
>     >             >     > +  rtems_termios_device_context *base,
>     >             >     > +  struct termios *term,
>     >             >     > +  rtems_libio_open_close_args_t *args
>     >             >     > -  rtems_libio_open_close_args_t *oc =
>     >             >     (rtems_libio_open_close_args_t *)
>     >             >     > arg;
>     >             >     > -  struct rtems_termios_tty *tty = (struct
>     >             >     > oc->iop->data1;
>     >             >     > -  const console_tbl *ct = Console_Port_Tbl
>     [minor];
>     >             >     > -  console_data *cd = &Console_Port_Data [minor];
>     >             >     > +  rtems_status_code sc;
>     >             >     > +  bool ok;
>     >             >     > -  cd->termios_data = tty;
>     >             >     > -  rtems_termios_set_initial_baud(tty,
>     ct->ulClock);
>     >             >     > +  ctx = (uart0_context *) base;
>     >             >     > -  return 0;
>     >             >     > +  usart_initialize(base);
>     >             >     > +  sc = rtems_termios_set_initial_baud(tty,
>     >              USART0_DEFAULT_BAUD);
>     >             >     > +  if ( sc != RTEMS_SUCCESSFUL ){
>     >             >     > +    printk("Error setting the baud for
>     termios\n");
>     >             >     > +    return false;
>     >             >     There is a return missing here. Did you compile the
>     >             code? The compiler
>     >             >     should give you a warning about that.
>     >             >     > -static int usart_last_close(int major, int minor,
>     >             void *arg)
>     >             >     > +static int usart_last_close(
>     >             >     The first_open returns a bool but last_close returns
>     >             still an int? Is
>     >             >     this correct? I don't have the interface memorized.
>     >             > last_close return type is void.
>     >             Then you should fix that here.
>     >             >     > +  rtems_termios_open_close_args_t *arg)
>     >             >     >    return 0;
>     >             >     > -static int usart_read_polled(int minor)
>     >             >     > +static int
>     >             usart_read_polled(rtems_termios_device_context *base)
>     >             >     > -  if (minor == 0) {
>     >             >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>     >             >     == 0) {
>     >             >     > -       return((BCM2835_REG(BCM2835_UART0_DR))
>     & 0xFF );
>     >             >     > -    } else {
>     >             >     > -      return -1;
>     >             >     > -  } else {
>     >             >     > -    printk("Unknown console minor number: %d\n",
>     >             minor);
>     >             >     > -    return -1;
>     >             >     > +  regs = rpi_uart_get_regs(base);
>     >             >     Just noted that here: Why rpi_uart_get_regs and not
>     >             usart_get_regs?
>     >             >     Please use a consitent naming scheme.
>     >             >     > +  if ((regs->fr & BCM2835_UART0_FR_RXFE) == 0) {
>     >             >     > +    return (regs->dr & 0xFF);
>     >             >     > +  return -1;
>     >             >     > -static void usart_write_polled(int minor, char c)
>     >             >     > +static void
>     >             usart_write_polled(rtems_termios_device_context
>     >             >     *base, char c)
>     >             >     > -   while (1) {
>     >             >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>     >             >     == 0)
>     >             >     > -       break;
>     >             >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>     >             >     > +  while (1) {
>     >             >     > +    if (((regs->fr) & BCM2835_UART0_FR_TXFF)
>     == 0)
>     >             >     > +      break;
>     >             >     > +  regs->dr = c;
>     >             >     >  static ssize_t usart_write_support_polled(
>     >             >     > -  int minor,
>     >             >     >    const char *s,
>     >             >     >    size_t n
>     >             >     > @@ -143,7 +170,7 @@ static ssize_t
>     >             >     >    ssize_t i = 0;
>     >             >     >    for (i = 0; i < n; ++i) {
>     >             >     > -    usart_write_polled(minor, s [i]);
>     >             >     > +    usart_write_polled(base, s[i]);
>     >             >     >    return n;
>     >             >     > @@ -154,14 +181,11 @@ static int
>     >             >     > struct termios *term)
>     >             >     >    return -1;
>     >             >     > -const console_fns bcm2835_usart_fns = {
>     >             >     > -  .deviceProbe = libchip_serial_default_probe,
>     >             >     > -  .deviceFirstOpen = usart_first_open,
>     >             >     > -  .deviceLastClose = usart_last_close,
>     >             >     > -  .deviceRead = usart_read_polled,
>     >             >     > -  .deviceWrite = usart_write_support_polled,
>     >             >     > -  .deviceInitialize = usart_initialize,
>     >             >     > -  .deviceWritePolled = usart_write_polled,
>     >             >     > -  .deviceSetAttributes = usart_set_attributes,
>     >             >     > -  .deviceOutputUsesInterrupts = false
>     >             >     > +const rtems_termios_device_handler
>     >             bcm2835_uart0_handler_polled = {
>     >             >     > +  .first_open = usart_first_open,
>     >             >     > +  .last_close = usart_last_close,
>     >             >     > +  .poll_read = usart_read_polled,
>     >             >     > +  .set_attributes = usart_set_attributes,
>     >             >     > +  .write = usart_write_support_polled,
>     >             >     > +  .mode = TERMIOS_POLLED
>     >             >     > \ No newline at end of file
>     >             >     > On Wed, Dec 25, 2019 at 12:36 AM Joel Sherrill
>     >             <joel at rtems.org <mailto:joel at rtems.org>
>     <mailto:joel at rtems.org <mailto:joel at rtems.org>>
>     >             >     <mailto:joel at rtems.org <mailto:joel at rtems.org>
>     <mailto:joel at rtems.org <mailto:joel at rtems.org>>>
>     >             >     > <mailto:joel at rtems.org <mailto:joel at rtems.org>
>     <mailto:joel at rtems.org <mailto:joel at rtems.org>>>>> wrote:
>     >             >     >     On Tue, Dec 24, 2019, 12:19 PM Niteesh
>     >             <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     >             >     <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com> <mailto:gsnb.gn at gmail.com
>     >             >     >     <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>>>>> wrote:
>     >             >     >         And also the register definitions are in
>     >             raspberrpi.h file
>     >             >     >         should I move them to usart.h.
>     >             >     >     Sounds right if you mean bsp/usart.h
>     >             >     >         I have a doubt we have a register field in
>     >             device_context
>     >             >     >         typedef struct {
>     >             >     >             rtems_termios_device_context base;
>     >             >     >             const char *device_name;
>     >             >     >             volatile some_chip_registers *regs;
>     >             >     >         } my_driver_context;
>     >             >     >         How does the reg field point to the
>     correct
>     >             >     memory location? for
>     >             >     >         instance in IMX BSP,
>     >             >     >         there is a struct with register
>     field's but
>     >             none of the
>     >             >     define a
>     >             >     >         memory location?
>     >             >     >     Make sure the structure has volatiles and
>     proper
>     >             alignment. :)
>     >             >     >         On Tue, Dec 24, 2019 at 11:37 PM Niteesh
>     >             >     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     >             >     >             How to handle different serial
>     devices?
>     >             In other BSPs the
>     >             >     >             uart devices are the same, so
>     >             >     >             they were able to put it under a
>     single
>     >             array? But here we
>     >             >     >             have 2 uarts and a FB?
>     >             >     >             On Tue, Dec 24, 2019 at 8:18 PM
>     >             Christian Mauderer
>     >             >     >             <list at c-mauderer.de
>     <mailto:list at c-mauderer.de>> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >             >     >                 On 24/12/2019 12:06, Niteesh
>     wrote:
>     >             >     >                 > The current raspi console
>     section
>     >             is like this:
>     >             >     >                 > The bsp_console_select in
>     >             console_select.c is
>     >             >     >                 responsible for selecting
>     >             >     >                 > between uart and the
>     framebuffer.
>     >             It does so
>     >             >     >                 > by setting the
>     Console_port_minor.
>     >             >     >                 > The console_config is
>     responsible
>     >             for output_char
>     >             >     >                 function.
>     >             >     >                 > And other files are driver code.
>     >             >     >                 > If rewriting, this would be my
>     >             approach,
>     >             >     >                 > Rewrite the
>     bsp_console_select to
>     >             set some kind of a
>     >             >     >                 variable like in
>     >             >     >                 > IMX, then in console_initialize
>     >             function
>     >             >     >                 > link the right driver to
>     /dev/console.
>     >             >     >                 > Replace the console_tbl with the
>     >             device_context and
>     >             >     >                 console_fns with
>     >             >     >                 > termios_device_handlers and
>     >             >     >                 > finally add in the
>     >             console_initialization function.
>     >             >     >                 I agree that this would be a clean
>     >             solution. So if you
>     >             >     >                 want you can do
>     >             >     >                 that. But there might is a hurdle:
>     >             As far as I
>     >             >     >                 understood you you only
>     >             >     >                 have a Pi3? So you might have
>     a hard
>     >             time testing the
>     >             >     >                 changes. Maybe the
>     >             >     >                 simulator could work.
>     >             >     >                 Another possibility could be
>     to set the
>     >             >     >                 "Console_port_minor" to
>     >             >     >                 something unused (for example -1).
>     >             In that case
>     >             >     you can
>     >             >     >                 define another
>     >             >     >                 /dev/console.
>     >             >     >                 Best regards and merry
>     Christmas (in
>     >             case you
>     >             >     celebrate)
>     >             >     >                 Christian
>     >             >     >                 > On Tue, Dec 24, 2019 at 2:13 PM
>     >             Niteesh
>     >             >     >                 <gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>>
>     >             >     >                 > <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>>>>>>
>     >             >     >                 wrote:
>     >             >     >                 >     Thank you so much, for
>     such a
>     >             detailed
>     >             >     answer. Now
>     >             >     >                 things make
>     >             >     >                 >     really good sense to me,
>     >             >     >                 >     going through the code
>     now is
>     >             just a breeze.
>     >             >     But I
>     >             >     >                 still have one
>     >             >     >                 >     question
>     >             >     >                 >     for the newer driver
>     interface is
>     >             >     >                 console_initialize the function
>     >             >     >                 >     which RTEMS calls while
>     >             initializing
>     >             >     >                 >     the console? Which means I
>     >             can't mess with the
>     >             >     >                 name right? It is
>     >             >     >                 >     similar to the main
>     function,
>     >             right?
>     >             >     >                 >     The current driver is a
>     legacy
>     >             one, how do you
>     >             >     >                 want me to proceed,
>     >             >     >                 >     shall I rewrite the
>     legacy to a
>     >             >     >                 >     the new one, this is
>     will be a
>     >             great
>     >             >     >                 learning experience for me also
>     >             >     >                 >     and we also get the BSP
>     >             updated to the latest
>     >             >     >                 interface.
>     >             >     >                 >     On Tue, Dec 24, 2019 at 3:20
>     >             AM Christian
>     >             >     Mauderer
>     >             >     >                 >     <list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>> <mailto:list at c-mauderer.de
>     >             >     >                 <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>>>
>     >             >     >                 wrote:
>     >             >     >                 >         Hello Niteesh,
>     >             >     >                 >         quite a lot of
>     questions.
>     >             I'll try to answer
>     >             >     >                 them. Note that it
>     >             >     >                 >         has been
>     >             >     >                 >         some time since I had a
>     >             detailed look at
>     >             >     that
>     >             >     >                 code so if something I
>     >             >     >                 >         tell seems odd please
>     >             don't hesitate to
>     >             >     >                 question it.
>     >             >     >                 >         Please note that in
>     RTEMS
>     >             their are more or
>     >             >     >                 less two "levels" of
>     >             >     >                 >         support
>     >             >     >                 >         for a serial console:
>     >             >     >                 >         1. A very basic polled
>     >             system console (also
>     >             >     >                 known as
>     >             >     >                 >         "debug-console" in
>     >             >     >                 >         some BSPs). This one is
>     >             used for printk and
>     >             >     >                 should work in basically
>     >             >     >                 >         every case. It is
>     used for
>     >             critical system
>     >             >     >                 messages like
>     >             >     >                 >         printing the
>     >             >     >                 >         exception frame. For
>     that
>     >             a BSP has to
>     >             >     provide a
>     >             >     >                 >         "BSP_output_char"
>     function.
>     >             >     >                 >         2. A full featured
>     UART driver
>     >             >     integrated into
>     >             >     >                 Termios. That one
>     >             >     >                 >         will be
>     >             >     >                 >         used for all normal
>     I/O on
>     >             the UARTs.
>     >             >     >                 >         As far as I know the
>     >             "console_tbl
>     >             >     >                 Console_Configuration_Ports"
>     >             >     >                 >         belongs
>     >             >     >                 >         to a table based legacy
>     >             interface. It is
>     >             >     >                 handled in the file
>     >              bsps/shared/dev/serial/legacy-console.c. I'm
>     >             >     >                 not sure whether it is
>     >             >     >                 >         documented in the BSP
>     >             guide because it
>     >             >     >                 shouldn't be used for new
>     >             >     >                 >         BSPs.
>     >             >     >                 >         Same is true for the
>     >             "major" and "minor"
>     >             >     >                 stuff: It's not really
>     >             >     >                 >         used for
>     >             >     >                 >         new drivers.
>     >             >     >                 >         Newer drivers use the
>     >             initialization that is
>     >             >     >                 described in the manual
>     >             >     >                 >         that you have already
>     >             found. Basically
>     >             >     they use
>     >              "rtems_termios_device_install" to register a
>     >             >     >                 new UART as
>     >             >     >                 >         "/dev/ttySomething".
>     Some
>     >             recent (ARM) BSPs
>     >             >     >                 that do that are the
>     >             >     >                 >         imx or
>     >             >     >                 >         the atsam.
>     >             >     >                 >         The console that is used
>     >             for stdin,
>     >             >     stdout and
>     >             >     >                 stderr (printf,
>     >             >     >                 >         scanf,
>     >             >     >                 >         ...) is the one called
>     >             "/dev/console"
>     >             >     (defined in
>     >             >     >                 >         CONSOLE_DEVICE_NAME).
>     >             >     >                 >         For the legacy table
>     based
>     >             interface
>     >             >     it's the
>     >             >     >                 one with the index of
>     >             >     >                 >         "Console_Port_Minor".
>     >             >     >                 >         If you want to
>     access any
>     >             UART other
>     >             >     than the
>     >             >     >                 one for stdin and
>     >             >     >                 >         stdout
>     >             >     >                 >         you do that the same way
>     >             like on Linux: Just
>     >             >     >                 use the "open"
>     >             >     >                 >         function on
>     >             >     >                 >         the "/dev/ttySomething"
>     >             and use "read",
>     >             >     >                 "write" and simmilar or use
>     >             >     >                 >         "fopen" together with
>     >             "fread", "fwrite",
>     >             >     >                 "fprintf", ...
>     >             >     >                 >         "printf" (and
>     family) is a
>     >             function
>     >             >     belonging
>     >             >     >                 to the C library.
>     >             >     >                 >         In our
>     >             >     >                 >         case that's newlib. It
>     >             will format your
>     >             >     >                 message and after some other
>     >             >     >                 >         preprocessing will call
>     >             the "write" function
>     >             >     >                 of the file that is
>     >             >     >                 >         opened
>     >             >     >                 >         as stdout (which is
>     >             "/dev/console" in the
>     >             >     >                 default case).
>     >             >     >                 >         I hope that I helped you
>     >             with that
>     >             >     >                 explanation. Please feel free
>     >             >     >                 >         to ask
>     >             >     >                 >         anything if it isn't
>     clear.
>     >             >     >                 >         Best regards
>     >             >     >                 >         Christian
>     >             >     >                 >         On 23/12/2019 19:50,
>     >             Niteesh wrote:
>     >             >     >                 >         > And finally, how does
>     >             printf work? It is a
>     >             >     >                 macro? In that
>     >             >     >                 >         case, how does
>     >             >     >                 >         > any write to
>     >             >     >                 >         > a console work?
>     >             >     >                 >         > On Tue, Dec 24,
>     2019 at
>     >             12:18 AM Niteesh
>     >             <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>>>
>     >             >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
>     <mailto:gsnb.gn at gmail.com>>>>>>> wrote:
>     >             >     >                 >         >     Is the correct
>     port
>     >             minor number set
>     >             >     >                 during the
>     >             >     >                 >         initialization? What
>     >             >     >                 >         >     is the application
>     >             want's to
>     >             >     >                 >         >     access some
>     other port?
>     >             >     >                 >         >     On Tue, Dec
>     24, 2019
>     >             at 12:16 AM
>     >             >     Niteesh
>     >             >     >                 >         <gsnb.gn at gmail.com
>     >             >     >                 >         >         I would
>     like to
>     >             clarify my doubts
>     >             >     >                 regarding the
>     >             >     >                 >         console driver.
>     >             >     >                 >         >         I went through
>     >             the documentation
>     >             >     >                 >         >         for the
>     console
>          driver https://docs.rtems.org/branches/master/bsp-howto/console.html#introduction.
>     >             >     >                 >         >         But it is
>     quite
>     >             different from how
>     >             >     >                 some BSPs initialize.
>     >             >     >                 >         >         Correct me
>     if I
>     >             am wrong
>     >             >     >                 >         >         The
>     console_tbl
>     >             contains the
>     >             >     various
>     >             >     >                 entries of serial
>     >             >     >                 >         ports.
>     >             >     >                 >         >         The
>     console_fns
>     >             is a struct of
>     >             >     >                 function pointers,
>     >             >     >                 >         which point to
>     >             >     >                 >         >         the BSP uart
>     >             functions.
>     >             >     >                 >         >         The
>     >             >     BSP_output_char_function_type is
>     >             >     >                 what will be
>     >             >     >                 >         called for
>     >             >     >                 >         >         printing a
>     char
>     >             on to the console.
>     >             >     >                 >         >         How does RTEMS
>     >             initialize the
>     >             >     uart?
>     >             >     >                 It's seems not to
>     >             >     >                 >         be same
>     >             >     >                 >         >         for all BSPs.
>     >             >     >                 >         >         The doc says
>     >             that the driver's
>     >             >     >                 initialization function
>     >             >     >                 >         is called
>     >             >     >                 >         >         once
>     during the
>     >             rtems
>     >             >     initialization
>     >             >     >                 process.
>     >             >     >                 >         >         The
>     console init
>     >             function install
>     >             >     >                 the serial driver using
>     >              rtems_termios_device_install but
>     >             >     >                 there seems to be
>     >             >     >                 >         >         no such
>     function
>     >             in the raspberry
>     >             >     >                 pi? But there is a
>     >             >     >                 >         entry in
>      console_fns for
>     >             init function, but
>     >             >     >                 then how does it
>     >             >     >                 >         >         gets called?
>     >             >     >                 >         >         And for BSP's
>     >             with multiple
>     >             >     >                 serial's, the output function
>     >             >     >                 >         >         chooses the
>     >             right serial using
>     >             >     >                 console_port_minor,
>     >             >     >                 >         >         Is it during
>     >             initialization?
>     >             >     >                 >         >         What is
>     the need
>     >             for get and set
>     >             >     >                 register functions?
>     >             >     >                 >         >         On Mon,
>     Dec 23,
>     >             2019 at 1:04 AM
>     >             >     >                 Christian Mauderer
>     <mailto:list at c-mauderer.de>>>> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>>>> wrote:
>     >             >     >                 >         >             On
>     >             22/12/2019 19:45, Joel
>     >             >     >                 Sherrill wrote:
>     >             >     >                 >         >             > On Sun,
>     >             Dec 22, 2019,
>     >             >     12:29 PM
>     >             >     >                 Niteesh
>     <mailto:gsnb.gn at gmail.com>>>>> <mailto:gsnb.gn at gmail.com
>     <mailto:gsnb.gn at gmail.com>>>>>>>> wrote:
>     >             >     >                 >         >             >     On
>     >             Sun, Dec 22, 2019 at
>     >             >     >                 8:44 PM Christian
>     >             >     >                 >         Mauderer
>     <mailto:list at c-mauderer.de>>>>> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de>>>>>>>> wrote:
>     >              Hello Niteesh,
>     >              thanks for doing
>     >             >     that
>     >             >     >                 work.
>        On
>     >             22/12/2019 12:10,
>     >             >     >                 Niteesh wrote:
>     >             The rpi1 and rpi2
>     >             >     >                 use the PL011 UART,
>     >             >     >                 >         whereas,
>     >             >     >                 >         >             with RPI's
>     >              equipped with
>     >             wireless/Bluetooth
>     >             >     >                 module, the PL011 is
>      connected to
>     >             the Bluetooth
>     >             module, and
>     >             >     the mini
>     >             >     >                 UART is used as
>     >             >     >                 >         the primary
>     >             >     >                 >         >             UART.
>        In
>     >             my opinion it
>     >             >     would
>     >             >     >                 be great if you
>     >             >     >                 >         could use
>     >             >     >                 >         >             the FDT to
>     >              distinguish
>     >              between the boards.
>     >             >     >                 That should allow to add
>      raspberry 3 (and
>     >              maybe 4)
>     >              support without
>     >             >     adding
>     >             >     >                 another BSP. More
>     >             >     >                 >         BSPs mean
>     >             >     >                 >         >             a bigger
>     >              maintenance
>     >              effort for the RTEMS
>     >             >     >                 community.
>     >              Learning more about
>     >             >     FDT is
>     >             >     >                 on my list for a long
>     >             >     >                 >         >             time.  I
>     >             would love
>     >             >     >                 >         >             >     to
>     >             work on that
>      but I
>     >             have almost no exp
>     >             >     >                 with FDT's.
>     >             >     >                 >         >             >     But
>     >             another thing could
>     >             >     >                 also be done, in
>     >             >     >                  raspberrypi/start/bspstart.c
>     we get the
>     >             >     >                 >         revision and
>      model
>     >             of the board using
>     >             >     >                 the mailbox. Every
>     >             >     >                 >         board has
>     >             >     >                 >         >             a
>     unique id,
>      which
>     >             we could use to
>     >             >     >                 initialize
>     >             >     >                 >         >             >     the
>     >             BSP. But using FDT
>     >             >     >                 seems to be a more
>     >             >     >                 >         elegant
>      option, it is a
>      lot of
>     >             work I think, but
>     >             >     >                 we could take
>     >             >     >                 >         >             >     help
>     >             from libbsd and
>     >             >     linux
>     >             >     >                 I suppose. What
>     >             >     >                 >         do you think?
>     >             >     >                 >         >             > I think
>     >             there are almost
>     >             >     >                 always two steps to a
>     >             >     >                 >         project
>     >             >     >                 >         >             like this:
>     >             get it
>     >             >     >                 >         >             > to work
>     >             and make it nice. :)
>     >             >     >                 >         >             > If
>     you fix
>     >             the startup
>     >             >     code to
>     >             >     >                 read the board
>     >             >     >                 >         revision and
>     >             >     >                 >         >             memory
>     size,
>     >             >     >                 >         >             > you can
>     >             get a working
>     >             >     BSP that
>     >             >     >                 dynamically
>     >             >     >                 >         adapts to the
>     >             >     >                 >         >             models and
>     >             >     >                 >         >             > memory
>     >             variations with
>     >             >     minimal
>     >             >     >                 modifications. If
>     >             >     >                 >         you want
>     >             >     >                 >         >             to then
>     >             >     >                 >         >             > convert
>     >             the BSP to FDT, it
>     >             >     >                 will be a LOT easier
>     >             >     >                 >         to debug
>     >             >     >                 >         >             with a
>     >             working BSP.
>     >             >     >                 >         >             > Plus you
>     >             may be able to
>     >             >     >                 identify every variation
>     >             >     >                 >         point
>     >             >     >                 >         >             based on
>     >             just the
>     >             >     >                 >         >             > model
>     >             info. Then FDT is
>     >             >     just a
>     >             >     >                 matter of
>     >             >     >                 >         switching the
>     >             >     >                 >         >             source of
>     >             >     >                 >         >             > some/all
>     >             of the info.
>     >             >     >                 >         >             > That
>     would
>     >             be my work
>     >             >     plan anyway.
>     >             >     >                 >         >             I
>     agree with
>     >             Joel that a
>     >             >     secure
>     >             >     >                 development basis
>     >             >     >                 >         (also
>     >             >     >                 >         >             known
>     as "hack")
>     >             >     >                 >         >             as a first
>     >             step is a good
>     >             >     idea.
>     >             >     >                 You maybe even
>     >             >     >                 >         just make the
>     >             >     >                 >         >             mini UART
>     >             >     >                 >         >             the
>     default
>     >             driver while
>     >             >     you are
>     >             >     >                 developing. Then
>     >             >     >                 >         you can be
>     >             >     >                 >         >             sure that
>     >             >     >                 >         >             you
>     have the
>     >             right driver.
>     >             >     >                 >         >             As soon as
>     >             that works you can
>     >             >     >                 either change to the
>     >             >     >                 >         revision
>     >             >     >                 >         >             method or
>      (better) to
>     >             the FDT one and
>     >             >     >                 after that the patches
>     >             >     >                 >         can be
>      merged. Using
>     >             >     >                 >         >             the FDT
>     >             isn't that
>     >             >     complicated.
>     >             >     >                 Basically you
>     >             >     >                 >         search for a
>     >             >     >                 >         >             node
>     based on
>     >             >     >                 >         >             different
>     >             parameters. For an
>     >             >     >                 example you can take
>     >             >     >                 >         a look at
>     >             >     >                 >         >             the
>     imx BSP.
>     >             >     >                 >         >             In
>     >             imx_uart_probe
>     >              (bsps/arm/imx/console/console-config.c) a
>     >             >     >                 >         >             fdt
>     node is
>      searched and
>     >             based on that a
>     >             >     >                 UART driver is used.
>     >             >     >                 >         But again:
>     >             >     >                 >         >             Follow
>     >             >     >                 >         >             Joels
>     >             suggestion to start
>     >             >     simple
>     >             >     >                 and secure.
>           https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf
>     >             But from the above
>     >             >     >                 doc (PAGE 10), the
>     >             >     >                 >         mini uart
>     >             >     >                 >         >             has
>     >              registers
>     >             and RTEMS already
>     >             >     >                 has the driver for it
>      bsps/shared/dev/serial/ns16550.c. But
>     >             >     >                 >         I am not
>     >             >     >                 >         >             sure how
>     >              compatible they
>     >             are? Should a new
>     >             >     >                 driver be
>     >             >     >                 >         implemented from
>      scratch or use
>     >              ns16550 if
>     >             possible?
>        In
>     >             general it's
>     >             >     better
>     >             >     >                 to re-use
>     >             >     >                 >         existing code.
>     >             >     >                 >         >             That has
>     >             multiple
>     >              advantages:
>     >             It reduces the
>     >             >     >                 maintenance effort.
>     >             >     >                 >         Fewer code
>     >             >     >                 >         >             means
>     fewer
>     >             work.
>     >             If you have
>     >             >     multiple
>     >             >     >                 driver for the
>     >             >     >                 >         same or
>      similar hardware
>        it can
>     >              happen that a bug is
>     >             >     >                 fixed in one but
>     >             >     >                 >         not the other.
>     >             It's simpler
>     >             >     to find
>     >             >     >                 a hardware to
>     >             >     >                 >         test changes.
>     >             The driver becomes
>     >             >     >                 more universal with
>     >             >     >                 >         every new
>     >             >     >                 >         >             supported
>     >              hardware.
>     >              That increases the
>     >             >     >                 chance that it fits
>     >             >     >                 >         the next
>     >             >     >                 >         >             new
>     hardware.
>     >              I'm sure there are
>     >             >     >                 some more if you ask
>     >             >     >                 >         someone else.
>     >             >     >                 >         >             >     I do
>     >             understand the
>     >             >     >                 issues, I just spent
>     >             >     >                 >         some time
>      reading the
>      driver
>     >             code.
>     >             >     >                 >         >             >     I
>     >             think we could most
>     >             >     >                 probably use it. I
>     >             >     >                 >         will take a
>     >             >     >                 >         >             closer
>     look and
>     >             >     >                 >         >             >     will
>     >             update.
>     >             >     >                 >         >             Great.
>     >             Also, the core
>     >             >     clock
>     >             >     >                 on which the
>     >             >     >                 >         PL011 is based
>     >             >     >                 >         >             on is
>     changed
>        in
>     >             rpi3.
>     >             Rpi1 and 2 use
>     >             >     >                 250Mhz as the default
>     >             >     >                 >         clock but
>     >             >     >                 >         >             it was
>     changed
>        to
>     >             400Mhz
>     >             in Rpi3 and newer
>     >              Again: Would be
>     >             >     great
>     >             >     >                 if that could be
>     >             >     >                 >         adapted
>     >             >     >                 >         >             based
>     on FDT
>     >             or by
>     >              reading the right
>     >             >     >                 registers.
>     >             Few differences
>     >             >     >                 between PL011 and Mini
>     >             >     >                 >         uart
>     >             The mini UART has
>     >             >     >                 smaller FIFOs.
>     >             >     >                 >         Combined with
>     >             >     >                 >         >             the
>     lack of
>     >              flow control,
>     >             this makes it more
>     >             >     >                 prone to losing
>     >             >     >                 >         characters at
>     >             >     >                 >         >             higher
>     baud
>     >              rates. It
>     >             is also generally
>     >             >     >                 less capable than
>     >             >     >                 >         the PL011,
>     >             >     >                 >         >             mainly
>     due to
>     >              its baud
>     >             rate link to
>     >             >     the VPU
>     >             >     >                 clock speed.
>     >              That shouldn't
>     >             >     really
>     >             >     >                 be a problem for
>     >             >     >                 >         the system
>     >             >     >                 >         >             console.
>     >             The particular
>     >             >     >                 deficiencies of the
>     >             >     >                 >         mini UART
>      compared to the
>     >              PL011 are :
>     >             No break detection
>     >             No framing errors
>     >             >     >                 detection
>     >             No parity bit
>     >             No receive timeout
>     >             >     >                 interrupt
>     >             No DCD, DSR,
>     >             >     DTR or
>     >             >     >                 RI signals
>     >               _______________________________________________
>      devel
>     >             mailing list
>     >              devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
>     >             >     <mailto:devel at rtems.org <mailto:devel at rtems.org>
>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>>
>     >             >     >                 <mailto:devel at rtems.org
>     >             <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>
>     >             <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>>
>     >             <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>>>
>     >             <mailto:devel at rtems.org <mailto:devel at rtems.org>>>>>>>
>     >               http://lists.rtems.org/mailman/listinfo/devel
