[PATCH 0/2] bsp/raspberrypi: Fix bug regarding SDRAM size.
list at c-mauderer.de list at c-mauderer.de
Fri Dec 27 21:08:10 UTC 2019
Hello,
like mentioned here:
    https://lists.rtems.org/pipermail/devel/2019-December/056581.html
there is a problem with adapting the work area based on the raspberrys
SDRAM size. The patch set fixes bugs when getting the size of the SDRAM
and uses a method simmilar to the one in the imx BSP to adapt the MMU
table.
I tested it on an old Pi1 and a Pi2 (loaded via a debugger - I still
have problems loading it via an image on the Pi2).
Best regards
Christian
