[PATCH] Raspberrypi: updated the console interface.
Christian Mauderer list at c-mauderer.de
Sat Dec 28 10:16:52 UTC 2019
And I think you can add an "Update #3034" to your commit message:
https://devel.rtems.org/ticket/3034
It's a bit hidden but the old driver uses "rtems_termios_open" via the
legacy-console.c. You removed that from the build for raspberry.
On 28/12/2019 10:50, Christian Mauderer wrote:
> Missed your question further below in my first mail.
> On 28/12/2019 10:45, Christian Mauderer wrote:
>> On 28/12/2019 09:38, Niteesh wrote:
>>> I didn't get any of these warnings, which command did you use?
>> Just the usual make in the build directory. I configured with the
>> following line:
>> /home/christian/rtems/rtems-bbb/build/..//libs/rtems/configure
>> --target=arm-rtems5
>> --prefix=/home/christian/rtems/rtems-bbb/build/..//install/rtems/5/
>> --enable-rtemsbsp=raspberrypi --enable-maintainer-mode
>> --enable-tests=samples --disable-networking
>> Don't let the "bbb" irritate you: I hacked my normal beagle build
>> environment for use with the raspberry.
>> There are quite a lot of messages. So the warnings might are a bit
>> hidden. Also note that you only get them if the file is recompiled. So
>> either you have to change something or remove the console-config.o and
>> fbcons.o object file to trigger them on a re-make.
>>> On Sat, Dec 28, 2019 at 3:48 AM Christian Mauderer <list at c-mauderer.de
>>> <mailto:list at c-mauderer.de>> wrote:
>>>     Hello,
>>>     git complained about some whitespaces when applying the patch:
>>>     git am \[PATCH\]\ Raspberrypi:\ updated\ the\ console\ interface..eml
>>>     Applying: Raspberrypi: updated the console interface.
>>>     /home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:96:
>>>     trailing
>>>     whitespace.
>>>     /home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:304:
>>>     trailing whitespace.
>>>     const rtems_termios_device_handler fbcons_fns =
>>>     /home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:481:
>>>     bool fbcons_probe(
>>>     /home/christian/rtems/rtems-bbb/.git/modules/rtems/rebase-apply/patch:515:
>>>      * @name Current Serial Device
>>>     warning: 4 lines add whitespace errors.
>>> Fixed all the whitespace erros.
>>>     When compiling I get some warnings like
>>>     /home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/console-config.c:
>>>     In function 'output_char':
>>>     /home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/console-config.c:64:3:
>>>     warning: enumeration value 'AUX_UART' not handled in switch [-Wswitch]
>>>        switch(SERIAL){
>>>     and
>>>     /home/christian/rtems/rtems-bbb/build/..//libs/rtems/c/src/lib/libbsp/arm/raspberrypi/../../../../../../bsps/arm/raspberrypi/console/fbcons.c:174:17:
>>>     warning: initialization from incompatible pointer type
>>>     [-Wincompatible-pointer-types]
>>>        .first_open = fbcons_open,
>>>     Please fix these. I'm not entirely sure about the first warning. That
>>>     might has been there before. If possible it would be nice if you could
>>>     fix it anyway. In that case maybe in an extra commit.
>>>     At least the PL011 works on a Pi2 on real hardware too. I haven't tested
>>>     the framebuffer yet. I'm still trying to find out how to select it
>>>     before or after the patch.
>>>     Please see my notes in the patch below regarding some points.
>>>     Best regards
>>>     Christian
>>>     On 27/12/2019 12:08, G S Niteesh wrote:
>>>     > The patch updates the older console interface used by the BSP,
>>>     > to newer one. It also replaces the custom usart(PL011) driver
>>>     > with arm-pl011. The fb functions signatures where also changed
>>>     > to accommodate with interface update.
>>>     >  bsps/arm/raspberrypi/console/console-config.c |  67 +++++----
>>>     >  bsps/arm/raspberrypi/console/console_select.c |  65 +-------
>>>     >  bsps/arm/raspberrypi/console/fbcons.c         |  50 +++---
>>>     >  bsps/arm/raspberrypi/console/usart.c          | 142
>>>     >  bsps/arm/raspberrypi/include/bsp/fbcons.h     |  19 ++-
>>>     >  .../arm/raspberrypi/include/bsp/raspberrypi.h |  52 ++-----
>>>     >  bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
>>>     >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   5 +-
>>>     >  8 files changed, 105 insertions(+), 300 deletions(-)
>>>     > diff --git a/bsps/arm/raspberrypi/console/console-config.c
>>>     b/bsps/arm/raspberrypi/console/console-config.c
>>>     > index d2186c918b..1f6dec384a 100644
>>>     > --- a/bsps/arm/raspberrypi/console/console-config.c
>>>     > +++ b/bsps/arm/raspberrypi/console/console-config.c
>>>     > @@ -22,45 +22,54 @@
>>>     >  #include <libchip/serial.h>
>>>     > -#include <bspopts.h>
>>>     > -#include <bsp/irq.h>
>>>     > +#include <bsp.h>
>>>     >  #include <bsp/usart.h>
>>>     >  #include <bsp/raspberrypi.h>
>>>     > +#include <bsp/arm-pl011.h>
>>>     >  #include <bsp/fbcons.h>
>>>     > +#include <bsp/console-termios.h>
>>>     > +#include <bspopts.h>
>>>     > -console_tbl Console_Configuration_Ports [] = {
>>>     > -      .sDeviceName = "/dev/ttyS0",
>>>     > -      .deviceType = SERIAL_CUSTOM,
>>>     > -      .pDeviceFns = &bcm2835_usart_fns,
>>>     > -      .deviceProbe = NULL,
>>>     > -      .pDeviceFlow = NULL,
>>>     > -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>>>     > -      .ulCtrlPort2 = 0,
>>>     > -      .ulClock = USART0_DEFAULT_BAUD,
>>>     > -      .ulIntVector = BCM2835_IRQ_ID_UART
>>>     > -      .sDeviceName ="/dev/fbcons",
>>>     > -      .pDeviceFns = &fbcons_fns,
>>>     > -      .deviceProbe = fbcons_probe,
>>>     > +arm_pl011_context pl011_context = {
>>>     > +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>>     > +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
>>>     > +  .initial_baud = PL011_DEFAULT_BAUD
>>>     > -#define PORT_COUNT \
>>>     > -  (sizeof(Console_Configuration_Ports) \
>>>     > -    / sizeof(Console_Configuration_Ports [0]))
>>>     > +rpi_fb_context fb_context = {
>>>     > +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
>>>     > -unsigned long Console_Configuration_Count = PORT_COUNT;
>>>     > +const console_device console_device_table[] = {
>>>     > +    .device_file = "/dev/ttyS0",
>>>     > +    .probe = console_device_probe_default,
>>>     > +    .handler = &arm_pl011_fns,
>>>     > +    .context = &pl011_context.base
>>>     > +    .device_file = "/dev/fbcons",
>>>     > +    // Should be changed to fbcons_probe (but it still use old
>>>     interface)
>>>     What do you mean with that comment?
>>> I am sorry, I actually forgot to remove the comment. Previously I was
>>> using default
>>> probe function. But then changed it to fbcons_probe.
>>>     > +    .probe = fbcons_probe,
>>>     > +    .handler = &fbcons_fns,
>>>     > +    .context = &fb_context.base
>>>     > +const size_t console_device_count =
>>>     RTEMS_ARRAY_SIZE(console_device_table);
>>>     >  static void output_char(char c)
>>>     > -  const console_fns *con =
>>>     > -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>>>     > -  con->deviceWritePolled((int) Console_Port_Minor, c);
>>>     > +  switch(SERIAL){
>>>     > +    case FB:
>>>     > +      fbcons_write_polled(&fb_context.base, c);
>>>     > +      break;
>>>     > +    case PL011:
>>>     > +      arm_pl011_write_polled(&pl011_context.base, c);
>>>     > +      break;
>>>     I don't like that selection method.
>>>     1. I'm not happy with that naming. It's a variable so please write it in
>>>     lower case. Same is true for the type CURRENT_SERIAL. It should be a
>>>     lower case name.
>>>     2. There is no default case.
>>>     3. This adds lot's of overhead. It means that for every character a
>>>     switch case has to be evaluated. BSP_output_char is a pointer so you can
>>>     just change it's value to point to one of two functions.
>>> Fixed this also. Removed the enum and switch, added a function pointer
>>> to the poll function, which is then called
>>> from outputchar by providing the right context.
>>> I modified and added the is_bsp_available, which check's if the current
>>> serial is
>>> available, if not throws BSP_FATAL_CONSOLE_NO_DEV.
>>> I was getting many warnings regarding incompatible pointer for eg: the
>>> write function in the device handler
>>> expects a void function, so I modified the fbcons_write_support_polled
>>> to void, which was previously returning
>>> the size of bytes written. Is that fine?
> If it isn't used anywhere else, it's OK. But isn't that function used
> for termios too?
> You can also write a small wrapper function if you have to adapt
> something. That adds very few overhead. If the parameters match and only
> the return type should be ignored, a cast would be an alternative.
>>> How should I now apply this modified patch?
> Add the changes to your previous patch ("git commit --amend" or "git
> rebase -i") and create a version 2 ("git format-patch -v2 HEAD^") and
> send that just like before with "git send-email". That will give you the
> [PATCH v2] headers that you find on our mailing list.
>>>     >  BSP_output_char_function_type BSP_output_char = output_char;
>>>     > diff --git a/bsps/arm/raspberrypi/console/console_select.c
>>>     b/bsps/arm/raspberrypi/console/console_select.c
>>>     > index bd246ca868..a7bd844bb0 100644
>>>     > --- a/bsps/arm/raspberrypi/console/console_select.c
>>>     > +++ b/bsps/arm/raspberrypi/console/console_select.c
>>>     > @@ -15,7 +15,7 @@
>>>     >   *  http://www.rtems.org/license/LICENSE
>>>     > +#include <bsp/raspberrypi.h>
>>>     >  #include <bsp.h>
>>>     >  #include <bsp/fatal.h>
>>>     >  #include <rtems/libio.h>
>>>     > @@ -24,59 +24,12 @@
>>>     >  #include <assert.h>
>>>     >  #include <termios.h>
>>>     > -#include <rtems/termiostypes.h>
>>>     >  #include "../../shared/dev/serial/legacy-console.h"
>>>     >  #include <bsp/rpi-fb.h>
>>>     >  rtems_device_minor_number BSPPrintkPort = 0;
>>>     > - * Method to return true if the device associated with the
>>>     > - * minor number probs available.
>>>     > -static bool bsp_Is_Available( rtems_device_minor_number minor )
>>>     > -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>>>     > -   * First perform the configuration dependent probe, then the
>>>     > -   * device dependent probe
>>>     > -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>>>     > -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>>>     > -    return true;
>>>     > -  return false;
>>>     > - * Method to return the first available device.
>>>     > -static rtems_device_minor_number bsp_First_Available_Device( void )
>>>     > -  rtems_device_minor_number minor;
>>>     > -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>>>     > -      return minor;
>>>     > -   *  Error No devices were found.  We will want to bail here.
>>>     > -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>>>     > +CURRENT_SERIAL SERIAL = PL011;>
>>>     >  void bsp_console_select( void )
>>>     > @@ -90,25 +43,13 @@ void bsp_console_select( void )
>>>     >    const char *opt;
>>>     > -  Console_Port_Minor = BSP_CONSOLE_UART0;
>>>     > -  BSPPrintkPort = BSP_CONSOLE_UART0;
>>>     >    opt = rpi_cmdline_get_arg( "--console=" );
>>>     >    if ( opt ) {
>>>     >      if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>>>     >        if ( rpi_video_is_initialized() > 0 ) {
>>>     > -        Console_Port_Minor = BSP_CONSOLE_FB;
>>>     > -        BSPPrintkPort = BSP_CONSOLE_FB;
>>>     > +        SERIAL = FB;
>>>     > -   * If the device that was selected isn't available then
>>>     > -   * let the user know and select the first available device.
>>>     > -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>>>     > -    Console_Port_Minor = bsp_First_Available_Device();
>>>     > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>>>     b/bsps/arm/raspberrypi/console/fbcons.c
>>>     > index 3669ba458d..99f2ab1aff 100644
>>>     > --- a/bsps/arm/raspberrypi/console/fbcons.c
>>>     > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>>>     > @@ -18,6 +18,7 @@
>>>     >  #include <rtems.h>
>>>     > +#include <rtems/termiostypes.h>
>>>     >  #include <stdlib.h>
>>>     > @@ -46,9 +47,10 @@ static void fbcons_init( int minor )
>>>     >   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>>>     >  static int fbcons_open(
>>>     > -  int   major,
>>>     > -  int   minor,
>>>     > -  void *arg
>>>     > +  struct rtems_termios_tty *tty,
>>>     > +  rtems_termios_device_context *base,
>>>     > +  struct termios *term,
>>>     > +  rtems_libio_open_close_args_t *args
>>>     >    return RTEMS_SUCCESSFUL;
>>>     > @@ -60,9 +62,9 @@ static int fbcons_open(
>>>     >   *  This function shuts down the requested port.
>>>     >  static int fbcons_close(
>>>     > -  int   major,
>>>     > -  int   minor,
>>>     > -  void *arg
>>>     >    return ( RTEMS_SUCCESSFUL );
>>>     > @@ -73,8 +75,8 @@ static int fbcons_close(
>>>     >   *  This routine polls out the requested character.
>>>     > -static void fbcons_write_polled(
>>>     > -  int  minor,
>>>     > +void fbcons_write_polled(
>>>     >    char c
>>>     > @@ -91,7 +93,7 @@ static void fbcons_write_polled(
>>>     >  static ssize_t fbcons_write_support_polled(
>>>     > -  int         minor,
>>>     >    const char *buf,
>>>     >    size_t      len
>>>     > @@ -102,7 +104,7 @@ static ssize_t fbcons_write_support_polled(
>>>     >     * poll each byte in the string out of the port.
>>>     >    while ( nwrite < len ) {
>>>     > -    fbcons_write_polled( minor, *buf++ );
>>>     > +    fbcons_write_polled( base, *buf++ );
>>>     >      nwrite++;
>>>     > @@ -117,7 +119,9 @@ static ssize_t fbcons_write_support_polled(
>>>     >   *  Console Termios polling input entry point.
>>>     > -static int fbcons_inbyte_nonblocking_polled( int minor )
>>>     > +int fbcons_inbyte_nonblocking_polled(
>>>     >    // if( rtems_kbpoll() ) {
>>>     >    //   int c = getch();
>>>     > @@ -134,14 +138,16 @@ static int fbcons_inbyte_nonblocking_polled(
>>>     int minor )
>>>     >   *  port settings.
>>>     >  static int fbcons_set_attributes(
>>>     > -  int                   minor,
>>>     >    const struct termios *t
>>>     >    return 0;
>>>     > -bool fbcons_probe( int minor )
>>>     > +bool fbcons_probe(
>>>     >    // rtems_status_code status;
>>>     >    static bool firstTime = true;
>>>     > @@ -163,15 +169,11 @@ bool fbcons_probe( int minor )
>>>     >    return ret;
>>>     > -const console_fns fbcons_fns =
>>>     > +const rtems_termios_device_handler fbcons_fns =
>>>     > -  .deviceProbe = libchip_serial_default_probe,     /* deviceProbe */
>>>     > -  .deviceFirstOpen = fbcons_open,                 /*
>>>     deviceFirstOpen */
>>>     > -  .deviceLastClose = fbcons_close,                /*
>>>     deviceLastClose */
>>>     > -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
>>>     > -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
>>>     > -  .deviceInitialize = fbcons_init,                /*
>>>     deviceInitialize */
>>>     > -  .deviceWritePolled = fbcons_write_polled,       /*
>>>     deviceWritePolled */
>>>     > -  .deviceSetAttributes = fbcons_set_attributes,   /*
>>>     deviceSetAttributes */
>>>     > -  .deviceOutputUsesInterrupts = FALSE,           /*
>>>     deviceOutputUsesInterrupts*/
>>>     > +  .first_open = fbcons_open,
>>>     > +  .last_close = fbcons_close,
>>>     > +  .poll_read = fbcons_inbyte_nonblocking_polled,
>>>     > +  .write = fbcons_write_support_polled,
>>>     > +  .mode = TERMIOS_POLLED
>>>     > \ No newline at end of file
>>>     > diff --git a/bsps/arm/raspberrypi/console/usart.c
>>>     b/bsps/arm/raspberrypi/console/usart.c
>>>     > index 25fb523621..471d0c553f 100644
>>>     > --- a/bsps/arm/raspberrypi/console/usart.c
>>>     > +++ b/bsps/arm/raspberrypi/console/usart.c
>>>     > @@ -23,145 +23,3 @@
>>>     >  #include <rtems/bspIo.h>
>>>     > -static void usart_delay(uint32_t n)
>>>     > - volatile uint32_t i = 0;
>>>     > - for(i = 0; i < n; i++)
>>>     > -#if 0
>>>     > - *  These will be useful when the driver supports interrupt
>>>     driven IO.
>>>     > -static rtems_vector_number usart_get_irq_number(const console_tbl
>>>     *ct)
>>>     > -  return ct->ulIntVector;
>>>     > -static uint32_t usart_get_baud(const console_tbl *ct)
>>>     > -  return ct->ulClock;
>>>     > -#endif
>>>     > -static void usart_set_baud(int minor, int baud)
>>>     > -  * Nothing for now
>>>     > - return;
>>>     > -static void usart_initialize(int minor)
>>>     > -  unsigned int gpio_reg;
>>>     > -  ** Program GPIO pins for UART 0
>>>     > -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>>>     > -  gpio_reg &= ~(7<<12);    /* gpio14 */
>>>     > -  gpio_reg |=  (4<<12);    /* alt0   */
>>>     > -  gpio_reg &= ~(7<<15);    /* gpio15 */
>>>     > -  gpio_reg |=  (4<<15);    /* alt0   */
>>>     > -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>>>     > -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>>>     > -  usart_delay(150);
>>>     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>>>     > -  usart_delay(150);
>>>     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>>>     > -  ** Init the PL011 UART
>>>     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>>>     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>>>     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>>>     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>>>     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>>>     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>>>     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>>>     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>>>     > -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>>>     > -  usart_set_baud(minor, 115000);
>>>     > -static int usart_first_open(int major, int minor, void *arg)
>>>     > -  rtems_libio_open_close_args_t *oc =
>>>     (rtems_libio_open_close_args_t *) arg;
>>>     > -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>>>     oc->iop->data1;
>>>     > -  const console_tbl *ct = Console_Port_Tbl [minor];
>>>     > -  console_data *cd = &Console_Port_Data [minor];
>>>     > -  cd->termios_data = tty;
>>>     > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>>>     > -  return 0;
>>>     > -static int usart_last_close(int major, int minor, void *arg)
>>>     > -  return 0;
>>>     > -static int usart_read_polled(int minor)
>>>     > -  if (minor == 0) {
>>>     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>>>     == 0) {
>>>     > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>>>     > -    } else {
>>>     > -      return -1;
>>>     > -  } else {
>>>     > -    printk("Unknown console minor number: %d\n", minor);
>>>     > -    return -1;
>>>     > -static void usart_write_polled(int minor, char c)
>>>     > -   while (1) {
>>>     > -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
>>>     == 0)
>>>     > -       break;
>>>     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>>>     > -static ssize_t usart_write_support_polled(
>>>     > -  int minor,
>>>     > -  const char *s,
>>>     > -  size_t n
>>>     > -  ssize_t i = 0;
>>>     > -  for (i = 0; i < n; ++i) {
>>>     > -    usart_write_polled(minor, s [i]);
>>>     > -  return n;
>>>     > -static int usart_set_attributes(int minor, const struct termios
>>>     *term)
>>>     > -  return -1;
>>>     > -const console_fns bcm2835_usart_fns = {
>>>     > -  .deviceFirstOpen = usart_first_open,
>>>     > -  .deviceLastClose = usart_last_close,
>>>     > -  .deviceRead = usart_read_polled,
>>>     > -  .deviceWrite = usart_write_support_polled,
>>>     > -  .deviceInitialize = usart_initialize,
>>>     > -  .deviceWritePolled = usart_write_polled,
>>>     > -  .deviceSetAttributes = usart_set_attributes,
>>>     > -  .deviceOutputUsesInterrupts = false
>>>     > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>     > index d0e126699a..85b16fafe9 100644
>>>     > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>     > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>>>     > @@ -33,12 +33,27 @@ extern "C" {
>>>     >  #define FB_CONSOLE 0x50492835
>>>     > -bool fbcons_probe( int minor );
>>>     > +bool fbcons_probe(
>>>     > +  char c
>>>     > +typedef struct {
>>>     > +    rtems_termios_device_context base;
>>>     > +} rpi_fb_context ;
>>>     >   * Driver function table
>>>     > -extern const console_fns fbcons_fns;
>>>     > +extern const rtems_termios_device_handler fbcons_fns;
>>>     >  #ifdef __cplusplus
>>>     > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>     > index 40c80cf408..4e5c84c741 100644
>>>     > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>     > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>>>     > @@ -60,6 +60,22 @@
>>>     >  #define RPI_PERIPHERAL_SIZE         0x01000000
>>>     > + * @name Current Serial Device
>>>     > +typedef enum {
>>>     > +  PL011 = 0,
>>>     > +  AUX_UART,
>>>     > +  FB
>>>     > +}CURRENT_SERIAL;
>>>     > +extern CURRENT_SERIAL SERIAL;
>>>     >   * @name Internal ARM Timer Registers
>>>     > @@ -184,42 +200,6 @@
>>>     > - * @name UART 0 (PL011) Registers
>>>     > -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>>>     > -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>>>     > -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>>>     > -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>>>     > -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>>>     > -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>>>     > -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>>>     > -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>>>     > -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>>>     > -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>>>     > -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>>>     > -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>>>     > -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>>>     > -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>>>     > -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>>>     > -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>>>     > -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>>>     > -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>>>     > -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>>>     > -#define BCM2835_UART0_MIS_RX    0x10
>>>     > -#define BCM2835_UART0_MIS_TX    0x20
>>>     > -#define BCM2835_UART0_IMSC_RX   0x10
>>>     > -#define BCM2835_UART0_IMSC_TX   0x20
>>>     > -#define BCM2835_UART0_FR_RXFE   0x10
>>>     > -#define BCM2835_UART0_FR_TXFF   0x20
>>>     > -#define BCM2835_UART0_ICR_RX    0x10
>>>     > -#define BCM2835_UART0_ICR_TX    0x20
>>>     > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>>>     b/bsps/arm/raspberrypi/include/bsp/usart.h
>>>     > index d3e710c5e9..abbf53626c 100644
>>>     > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>>>     > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>>>     > @@ -32,9 +32,8 @@
>>>     >  extern "C" {
>>>     >  #endif /* __cplusplus */
>>>     > -#define USART0_DEFAULT_BAUD 115000
>>>     > -extern const console_fns bcm2835_usart_fns;
>>>     > +#define PL011_DEFAULT_BAUD 115000
>>>     > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>>>     >  #ifdef __cplusplus
>>>     > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>     b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>     > index 11a22f89e3..ce91527f92 100644
>>>     > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>     > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>>     > @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
>>>     ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>>>     ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>>>     >  # Console
>>>     > -librtemsbsp_a_SOURCES +=
>>>     ../../../../../../bsps/shared/dev/serial/legacy-console.c
>>>     ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>>>     ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>>>     ../../../../../../bsps/arm/raspberrypi/console/usart.c
>>>     ../../../../../../bsps/arm/raspberrypi/console/fb.c
>>>     ../../../../../../bsps/arm/raspberrypi/console/outch.c
>>>     > +librtemsbsp_a_SOURCES +=
>>>     ../../../../../../bsps/shared/dev/serial/console-termios.c
>>>     ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>>>     ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>>>     >  # Mailbox
>>>     ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
