[PATCH v2] Raspberrypi: updated the console interface.
Niteesh gsnb.gn at gmail.com
Sat Dec 28 18:20:04 UTC 2019
I am sorry if this question sounds silly, but how can I access the
output_char_fb if it
is marked as static in console-select.c, currently the fb context is in
console-config.c
Should I move the BSP_select_function to console-config? for shall I remove
the static qualifier
from the function?
Currently, the console_select has 2 functions, bsp_Is_Available and
bsp_console_select.
On Sat, Dec 28, 2019 at 11:30 PM Niteesh <gsnb.gn at gmail.com> wrote:
> On Sat, Dec 28, 2019 at 11:12 PM Christian Mauderer <list at c-mauderer.de>
> wrote:
>> On 28/12/2019 17:22, Niteesh wrote:
>> > I think you misunderstood, I was talking about the casting in the
>> > rtems_termios_device_handler
>> Yes, I misunderstood you there.
>> > const rtems_termios_device_handler fbcons_fns =
>> >   .first_open = fbcons_open,
>> >   .last_close = fbcons_close,
>> >   .poll_read = fbcons_inbyte_nonblocking_polled,
>> >   .write = (void (*)(rtems_termios_device_context *, const char *,
>> > size_t))fbcons_write_support_polled,
>> >   .set_attributes = fbcons_set_attributes,
>> >   .mode = TERMIOS_POLLED
>> > the write requires a function type of
>> >   *void (*write)(
>> >     rtems_termios_device_context *context,
>> >     const char *buf,
>> >     size_t len
>> > but the fbcons function is of type
>> > *static ssize_t fbcons_write_support_polled(
>> >   rtems_termios_device_context *base,
>> >   const char *buf,
>> >   size_t      len
>> > Well, if the above cast in the device handler causes a problem, can you
>> > elaborate more on
>> > what kind of a problem would it be?
>> In that case it should work. But why do you need to cast it there?
>> Wouldn't it be simpler to just change the fbcons_write_support_polled
>> function? It isn't used anywhere else or did I miss something?
> No, it is not used anywhere. I'll change the function.
>> > And for the BSP_output_char function, I used a function pointer. The
>> > console_select assigns the
>> > appropriate function to the function pointer and the output_char call's
>> > it by providing the context.
>> > static void output_char(char c)
>> >   const console_device *dev = &console_device_table[console_select];
>> >   rtems_termios_device_context *con = dev->context;
>> >   console_instance(con, c);
>> > console_instance is the function pointer, which is assigned to
>> > arm_pl011_write_polled  by
>> > default, or to fbcons_write_polled, if frame buffer is decided to be
>> used.
>> Yes it will work and it's resonable performant. We are talking about a
>> slow serial interface in an exception case. But anyway I'm not entirely
>> happy.
>> The compiler should make something like the following out of it:
>> - Look up and call the value of BSP_output_char
>> - Load the context (start of table + console_select + fixed offset) into
>> "con"
>> - Look up and call the value of console_instance
>> If you use the way I suggested below you will have about the following:
>> - Look up and call the value of BSP_output_char (one of the wrappers)
>> - Call the right function with a fixed parameter
>> So it's a bit shorter and beneath that you save a global variable.
> Sure, will change it.
>> > On Sat, Dec 28, 2019 at 8:50 PM Christian Mauderer <list at c-mauderer.de
>> > <mailto:list at c-mauderer.de>> wrote:
>> >     On 28/12/2019 14:10, G S Niteesh wrote:
>> >     > The patch updates the older console interface used by the BSP,
>> >     > to newer one. It also replaces the custom usart(PL011) driver
>> >     > with arm-pl011. The fb function's signatures where also changed
>> >     > to accommodate with interface update.
>> >     > Update #3034
>> >     >  bsps/arm/raspberrypi/console/console-config.c |  62 ++++----
>> >     >  bsps/arm/raspberrypi/console/console_select.c |  68 ++-------
>> >     >  bsps/arm/raspberrypi/console/fbcons.c         |  71 ++++-----
>> >     >  bsps/arm/raspberrypi/console/usart.c          | 142
>> >     >  bsps/arm/raspberrypi/include/bsp/fbcons.h     |  19 ++-
>> >     >  .../arm/raspberrypi/include/bsp/raspberrypi.h |  70 +++++----
>> >     >  bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
>> >     >  c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   5 +-
>> >     >  8 files changed, 136 insertions(+), 306 deletions(-)
>> >     > diff --git a/bsps/arm/raspberrypi/console/console-config.c
>> >     b/bsps/arm/raspberrypi/console/console-config.c
>> >     > index d2186c918b..f479e19d99 100644
>> >     > --- a/bsps/arm/raspberrypi/console/console-config.c
>> >     > +++ b/bsps/arm/raspberrypi/console/console-config.c
>> >     > @@ -22,45 +22,47 @@
>> >     >  #include <libchip/serial.h>
>> >     > -#include <bspopts.h>
>> >     > -#include <bsp/irq.h>
>> >     > -#include <bsp/usart.h>
>> >     > +#include <bsp.h>
>> >     >  #include <bsp/raspberrypi.h>
>> >     > +#include <bsp/usart.h>
>> >     > +#include <bsp/arm-pl011.h>
>> >     >  #include <bsp/fbcons.h>
>> >     > +#include <bsp/console-termios.h>
>> >     > +#include <bspopts.h>
>> >     > -console_tbl Console_Configuration_Ports [] = {
>> >     > -      .sDeviceName = "/dev/ttyS0",
>> >     > -      .deviceType = SERIAL_CUSTOM,
>> >     > -      .pDeviceFns = &bcm2835_usart_fns,
>> >     > -      .deviceProbe = NULL,
>> >     > -      .pDeviceFlow = NULL,
>> >     > -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>> >     > -      .ulCtrlPort2 = 0,
>> >     > -      .ulClock = USART0_DEFAULT_BAUD,
>> >     > -      .ulIntVector = BCM2835_IRQ_ID_UART
>> >     > -      .sDeviceName ="/dev/fbcons",
>> >     > -      .pDeviceFns = &fbcons_fns,
>> >     > -      .deviceProbe = fbcons_probe,
>> >     > +arm_pl011_context pl011_context = {
>> >     > +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>> >     > +  .regs = (volatile pl011 *) BCM2835_PL011_BASE,
>> >     > +  .initial_baud = PL011_DEFAULT_BAUD
>> >     > -#define PORT_COUNT \
>> >     > -  (sizeof(Console_Configuration_Ports) \
>> >     > -    / sizeof(Console_Configuration_Ports [0]))
>> >     > +rpi_fb_context fb_context = {
>> >     > +  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
>> >     > +const console_device console_device_table[] = {
>> >     > +    .device_file = "/dev/ttyS0",
>> >     > +    .probe = console_device_probe_default,
>> >     > +    .handler = &arm_pl011_fns,
>> >     > +    .context = &pl011_context.base
>> >     > +    .device_file = "/dev/fbcons",
>> >     > +    .probe = fbcons_probe,
>> >     > +    .handler = &fbcons_fns,
>> >     > +    .context = &fb_context.base
>> >     > -unsigned long Console_Configuration_Count = PORT_COUNT;
>> >     > +const size_t console_device_count =
>> >     RTEMS_ARRAY_SIZE(console_device_table);
>> >     > -  const console_fns *con =
>> >     > -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>> >     > -  con->deviceWritePolled((int) Console_Port_Minor, c);
>> >     > +  const console_device *dev =
>> >     > +  rtems_termios_device_context *con = dev->context;
>> >     > +  console_instance(con, c);
>> >     I'm still not happy with that. What I had in mind was more or less:
>> >     static void output_char_serial(char c)
>> >       arm_pl011_write_polled(&pl011_context.base, c);
>> >     static void output_char_fb(char c)
>> >       fbcons_write_polled(&fb_context.base, c);
>> >     BSP_output_char_function_type BSP_output_char = output_char_serial;
>> >     And if you decide that the frame buffer should be used in the select
>> >     function you do a
>> >         BSP_output_char = output_char_fb;
>> >     >  BSP_output_char_function_type BSP_output_char = output_char;
>> >     > diff --git a/bsps/arm/raspberrypi/console/console_select.c
>> >     b/bsps/arm/raspberrypi/console/console_select.c
>> >     > index bd246ca868..ea3325266f 100644
>> >     > --- a/bsps/arm/raspberrypi/console/console_select.c
>> >     > +++ b/bsps/arm/raspberrypi/console/console_select.c
>> >     > @@ -15,69 +15,40 @@
>> >     >   *  http://www.rtems.org/license/LICENSE
>> >     >  #include <bsp.h>
>> >     > +#include <bsp/raspberrypi.h>
>> >     > +#include <bsp/fbcons.h>
>> >     > +#include <bsp/rpi-fb.h>
>> >     >  #include <bsp/fatal.h>
>> >     >  #include <rtems/libio.h>
>> >     >  #include <stdlib.h>
>> >     >  #include <string.h>
>> >     >  #include <assert.h>
>> >     >  #include <termios.h>
>> >     > -#include <rtems/termiostypes.h>
>> >     > -#include "../../shared/dev/serial/legacy-console.h"
>> >     > -#include <bsp/rpi-fb.h>
>> >     > -rtems_device_minor_number BSPPrintkPort = 0;
>> >     > +int console_select = PL011;
>> >     > +console console_instance = arm_pl011_write_polled;
>> >     > - * Method to return true if the device associated with the
>> >     > - * minor number probs available.
>> >     > -static bool bsp_Is_Available( rtems_device_minor_number minor )
>> >     > +static bool bsp_Is_Available( int index )
>> >     > -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>> >     > +  const console_device *dev = &console_device_table[index];
>> >     >     * First perform the configuration dependent probe, then the
>> >     >     * device dependent probe
>> >     > -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>> >     > -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>> >     > +  if ( ( !dev->probe || dev->probe( con ) ) ){
>> >     >      return true;
>> >     >    return false;
>> >     > - * Method to return the first available device.
>> >     > -static rtems_device_minor_number bsp_First_Available_Device(
>> void )
>> >     > -  rtems_device_minor_number minor;
>> >     > -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>> >     > -     * First perform the configuration dependent probe, then the
>> >     > -     * device dependent probe
>> >     > -      return minor;
>> >     > -   *  Error No devices were found.  We will want to bail here.
>> >     > -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>> >     >  void bsp_console_select( void )
>> >     > @@ -90,25 +61,18 @@ void bsp_console_select( void )
>> >     >    const char *opt;
>> >     > -  Console_Port_Minor = BSP_CONSOLE_UART0;
>> >     > -  BSPPrintkPort = BSP_CONSOLE_UART0;
>> >     >    opt = rpi_cmdline_get_arg( "--console=" );
>> >     >    if ( opt ) {
>> >     >      if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 )
>> >     >        if ( rpi_video_is_initialized() > 0 ) {
>> >     > -        Console_Port_Minor = BSP_CONSOLE_FB;
>> >     > -        BSPPrintkPort = BSP_CONSOLE_FB;
>> >     > +        console_select = FB;
>> >     > +        console_instance = fbcons_write_polled;
>> >     > -   * If the device that was selected isn't available then
>> >     > -   * let the user know and select the first available device.
>> >     > -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>> >     > -    Console_Port_Minor = bsp_First_Available_Device();
>> >     > +  if( !bsp_Is_Available( console_select ) ){
>> >     > +    bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>> >     > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>> >     b/bsps/arm/raspberrypi/console/fbcons.c
>> >     > index 3669ba458d..6e710e252d 100644
>> >     > --- a/bsps/arm/raspberrypi/console/fbcons.c
>> >     > +++ b/bsps/arm/raspberrypi/console/fbcons.c
>> >     > @@ -18,6 +18,7 @@
>> >     >  #include <rtems.h>
>> >     > +#include <rtems/termiostypes.h>
>> >     >  #include <stdlib.h>
>> >     > @@ -29,15 +30,6 @@
>> >     >  #include <bsp/vc.h>
>> >     > - *  fbcons_init
>> >     > - *  This function initializes the fb console to a quiecsent
>> state.
>> >     > -static void fbcons_init( int minor )
>> >     >   *  fbcons_open
>> >     > @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
>> >     >   *  Default state is 9600 baud, 8 bits, No parity, and 1 stop
>> bit.
>> >     > -static int fbcons_open(
>> >     > -  int   major,
>> >     > -  int   minor,
>> >     > -  void *arg
>> >     > +static bool fbcons_open(
>> >     > +  struct rtems_termios_tty *tty,
>> >     > +  rtems_termios_device_context *base,
>> >     > +  struct termios *term,
>> >     > +  rtems_libio_open_close_args_t *args
>> >     > -  return RTEMS_SUCCESSFUL;
>> >     > +  return true;
>> >     > @@ -59,13 +52,12 @@ static int fbcons_open(
>> >     >   *  This function shuts down the requested port.
>> >     > -static int fbcons_close(
>> >     > -  int   major,
>> >     > -  int   minor,
>> >     > -  void *arg
>> >     > +static void fbcons_close(
>> >     > -  return ( RTEMS_SUCCESSFUL );
>> >     > @@ -73,8 +65,8 @@ static int fbcons_close(
>> >     >   *  This routine polls out the requested character.
>> >     > -static void fbcons_write_polled(
>> >     > -  int  minor,
>> >     > +void fbcons_write_polled(
>> >     >    char c
>> >     > @@ -91,7 +83,7 @@ static void fbcons_write_polled(
>> >     > -  int         minor,
>> >     >    const char *buf,
>> >     >    size_t      len
>> >     > @@ -102,7 +94,7 @@ static ssize_t fbcons_write_support_polled(
>> >     >     * poll each byte in the string out of the port.
>> >     >    while ( nwrite < len ) {
>> >     > -    fbcons_write_polled( minor, *buf++ );
>> >     > +    fbcons_write_polled( base, *buf++ );
>> >     >      nwrite++;
>> >     > @@ -117,7 +109,9 @@ static ssize_t fbcons_write_support_polled(
>> >     >   *  Console Termios polling input entry point.
>> >     > -static int fbcons_inbyte_nonblocking_polled( int minor )
>> >     > +int fbcons_inbyte_nonblocking_polled(
>> >     >    // if( rtems_kbpoll() ) {
>> >     >    //   int c = getch();
>> >     > @@ -133,15 +127,17 @@ static int fbcons_inbyte_nonblocking_polled(
>> >     int minor )
>> >     >   *  This function sets the UART channel to reflect the requested
>> >     termios
>> >     >   *  port settings.
>> >     > -static int fbcons_set_attributes(
>> >     > -  int                   minor,
>> >     > +static bool fbcons_set_attributes(
>> >     >    const struct termios *t
>> >     > -  return 0;
>> >     > +  return true;
>> >     > -bool fbcons_probe( int minor )
>> >     > +bool fbcons_probe(
>> >     > +  rtems_termios_device_context *context
>> >     >    // rtems_status_code status;
>> >     >    static bool firstTime = true;
>> >     > @@ -163,15 +159,12 @@ bool fbcons_probe( int minor )
>> >     >    return ret;
>> >     > -const console_fns fbcons_fns =
>> >     > +const rtems_termios_device_handler fbcons_fns =
>> >     > -  .deviceProbe = libchip_serial_default_probe,     /*
>> deviceProbe */
>> >     > -  .deviceFirstOpen = fbcons_open,                 /*
>> >     deviceFirstOpen */
>> >     > -  .deviceLastClose = fbcons_close,                /*
>> >     deviceLastClose */
>> >     > -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead
>> >     > -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite
>> >     > -  .deviceInitialize = fbcons_init,                /*
>> >     deviceInitialize */
>> >     > -  .deviceWritePolled = fbcons_write_polled,       /*
>> >     deviceWritePolled */
>> >     > -  .deviceSetAttributes = fbcons_set_attributes,   /*
>> >     deviceSetAttributes */
>> >     > -  .deviceOutputUsesInterrupts = FALSE,           /*
>> >     deviceOutputUsesInterrupts*/
>> >     > +  .first_open = fbcons_open,
>> >     > +  .last_close = fbcons_close,
>> >     > +  .poll_read = fbcons_inbyte_nonblocking_polled,
>> >     > +  .write = (void (*)(rtems_termios_device_context *, const char
>> >     *, size_t))fbcons_write_support_polled,
>> >     > +  .set_attributes = fbcons_set_attributes,
>> >     > +  .mode = TERMIOS_POLLED
>> >     > \ No newline at end of file
>> >     > diff --git a/bsps/arm/raspberrypi/console/usart.c
>> >     b/bsps/arm/raspberrypi/console/usart.c
>> >     > index 25fb523621..471d0c553f 100644
>> >     > --- a/bsps/arm/raspberrypi/console/usart.c
>> >     > +++ b/bsps/arm/raspberrypi/console/usart.c
>> >     > @@ -23,145 +23,3 @@
>> >     >  #include <rtems/bspIo.h>
>> >     > -static void usart_delay(uint32_t n)
>> >     > - volatile uint32_t i = 0;
>> >     > - for(i = 0; i < n; i++)
>> >     > -#if 0
>> >     > - *  These will be useful when the driver supports interrupt
>> >     driven IO.
>> >     > -static rtems_vector_number usart_get_irq_number(const console_tbl
>> >     *ct)
>> >     > -  return ct->ulIntVector;
>> >     > -static uint32_t usart_get_baud(const console_tbl *ct)
>> >     > -  return ct->ulClock;
>> >     > -#endif
>> >     > -static void usart_set_baud(int minor, int baud)
>> >     > -  * Nothing for now
>> >     > - return;
>> >     > -static void usart_initialize(int minor)
>> >     > -  unsigned int gpio_reg;
>> >     > -  ** Program GPIO pins for UART 0
>> >     > -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>> >     > -  gpio_reg &= ~(7<<12);    /* gpio14 */
>> >     > -  gpio_reg |=  (4<<12);    /* alt0   */
>> >     > -  gpio_reg &= ~(7<<15);    /* gpio15 */
>> >     > -  gpio_reg |=  (4<<15);    /* alt0   */
>> >     > -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>> >     > -  usart_delay(150);
>> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>> >     > -  usart_delay(150);
>> >     > -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>> >     > -  ** Init the PL011 UART
>> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>> >     > -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>> >     > -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>> >     > -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>> >     > -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>> >     > -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>> >     > -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>> >     > -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>> >     > -  usart_set_baud(minor, 115000);
>> >     > -static int usart_first_open(int major, int minor, void *arg)
>> >     > -  rtems_libio_open_close_args_t *oc =
>> >     (rtems_libio_open_close_args_t *) arg;
>> >     > -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>> >     oc->iop->data1;
>> >     > -  const console_tbl *ct = Console_Port_Tbl [minor];
>> >     > -  console_data *cd = &Console_Port_Data [minor];
>> >     > -  cd->termios_data = tty;
>> >     > -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>> >     > -  return 0;
>> >     > -static int usart_last_close(int major, int minor, void *arg)
>> >     > -  return 0;
>> >     > -static int usart_read_polled(int minor)
>> >     > -  if (minor == 0) {
>> >     > -    if (((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>> >     == 0) {
>> >     > -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>> >     > -    } else {
>> >     > -      return -1;
>> >     > -  } else {
>> >     > -    printk("Unknown console minor number: %d\n", minor);
>> >     > -    return -1;
>> >     > -static void usart_write_polled(int minor, char c)
>> >     > -   while (1) {
>> >     > -     if ((BCM2835_REG(BCM2835_UART0_FR) & BCM2835_UART0_FR_TXFF)
>> >     == 0)
>> >     > -       break;
>> >     > -   BCM2835_REG(BCM2835_UART0_DR) = c;
>> >     > -static ssize_t usart_write_support_polled(
>> >     > -  int minor,
>> >     > -  const char *s,
>> >     > -  size_t n
>> >     > -  ssize_t i = 0;
>> >     > -  for (i = 0; i < n; ++i) {
>> >     > -    usart_write_polled(minor, s [i]);
>> >     > -  return n;
>> >     > -static int usart_set_attributes(int minor, const struct termios
>> >     *term)
>> >     > -  return -1;
>> >     > -const console_fns bcm2835_usart_fns = {
>> >     > -  .deviceFirstOpen = usart_first_open,
>> >     > -  .deviceLastClose = usart_last_close,
>> >     > -  .deviceRead = usart_read_polled,
>> >     > -  .deviceWrite = usart_write_support_polled,
>> >     > -  .deviceInitialize = usart_initialize,
>> >     > -  .deviceWritePolled = usart_write_polled,
>> >     > -  .deviceSetAttributes = usart_set_attributes,
>> >     > -  .deviceOutputUsesInterrupts = false
>> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> >     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> >     > index d0e126699a..e3d9e69ff5 100644
>> >     > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> >     > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>> >     > @@ -33,12 +33,27 @@ extern "C" {
>> >     >  #define FB_CONSOLE 0x50492835
>> >     > -bool fbcons_probe( int minor );
>> >     > +bool fbcons_probe(
>> >     > +  char c
>> >     > +typedef struct {
>> >     > +    rtems_termios_device_context base;
>> >     > +} rpi_fb_context ;
>> >     >   * Driver function table
>> >     > -extern const console_fns fbcons_fns;
>> >     > +extern const rtems_termios_device_handler fbcons_fns;
>> >     >  #ifdef __cplusplus
>> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> >     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> >     > index 40c80cf408..2ccc49846c 100644
>> >     > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> >     > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>> >     > @@ -24,6 +24,7 @@
>> >     >  #include <stdint.h>
>> >     >  #include <bsp/utility.h>
>> >     >   * @defgroup raspberrypi_reg Register Definitions
>> >     > @@ -60,6 +61,39 @@
>> >     >  #define RPI_PERIPHERAL_SIZE         0x01000000
>> >     > + * @name Console select definitions
>> >     > +#define PL011 0
>> >     > +#define FB    1
>> >     > +extern int console_select;
>> >     > +typedef void (*console)(rtems_termios_device_context *, char c);
>> >     > +extern console console_instance;
>> >     >   * @name Internal ARM Timer Registers
>> >     > @@ -184,42 +218,6 @@
>> >     > - * @name UART 0 (PL011) Registers
>> >     > -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>> >     > -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>> >     > -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>> >     > -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>> >     > -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>> >     > -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>> >     > -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>> >     > -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>> >     > -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>> >     > -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>> >     > -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>> >     > -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>> >     > -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>> >     > -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>> >     > -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>> >     > -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>> >     > -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>> >     > -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>> >     > -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>> >     > -#define BCM2835_UART0_MIS_RX    0x10
>> >     > -#define BCM2835_UART0_MIS_TX    0x20
>> >     > -#define BCM2835_UART0_IMSC_RX   0x10
>> >     > -#define BCM2835_UART0_IMSC_TX   0x20
>> >     > -#define BCM2835_UART0_FR_RXFE   0x10
>> >     > -#define BCM2835_UART0_FR_TXFF   0x20
>> >     > -#define BCM2835_UART0_ICR_RX    0x10
>> >     > -#define BCM2835_UART0_ICR_TX    0x20
>> >     > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>> >     b/bsps/arm/raspberrypi/include/bsp/usart.h
>> >     > index d3e710c5e9..abbf53626c 100644
>> >     > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>> >     > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>> >     > @@ -32,9 +32,8 @@
>> >     >  extern "C" {
>> >     >  #endif /* __cplusplus */
>> >     > -#define USART0_DEFAULT_BAUD 115000
>> >     > -extern const console_fns bcm2835_usart_fns;
>> >     > +#define PL011_DEFAULT_BAUD 115000
>> >     > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>> >     >  #ifdef __cplusplus
>> >     > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> >     b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> >     > index 11a22f89e3..ce91527f92 100644
>> >     > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> >     > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>> >     > @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
>> >     ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>> >     ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>> >     >  # Console
>> >     > -librtemsbsp_a_SOURCES +=
>> >     ../../../../../../bsps/shared/dev/serial/legacy-console.c
>> >     ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/usart.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/fb.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>> >     ../../../../../../bsps/arm/raspberrypi/console/outch.c
>> >     > +librtemsbsp_a_SOURCES +=
>> >     ../../../../../../bsps/shared/dev/serial/console-termios.c
>> >     ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>> >     ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>> >     >  # Mailbox
>> >     ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191228/54eba14e/attachment-0001.html>
