[PATCH v2] Raspberrypi: updated the console interface.
Christian Mauderer
list at c-mauderer.de
Sun Dec 29 09:03:20 UTC 2019
On 29/12/2019 07:09, Niteesh wrote:
> Is there any way to test and debug this? Maybe using GDB to
> see if a proper node is getting selected or not?
Without a debugger debugging code that is started before the console is
initialized is always a bit hard.
- You can try to use your qemu setup. Most likely you'll have to add
another parameter to load a FDT for it. Please take some notes for the
documentation. Even only one line like "Use FDT from official image and
use the following line to start qemu:..." is very helpfull.
- You can initialize your serial port manually just like before and use
printk debugging till you are sure your code does what it should do.
- You can use a real hardware debugger for it. That's what I currently
do - also qemu + gdb could be more powerfull. For that you basically
connect the Alt4 pins (see https://pinout.xyz/pinout/jtag) to a hardware
debugger (something supported by OpenOCD, Segger J-Link, ...) add
"gpio=22-27=a4" to your config.txt and load a very minimal kernel that
does just an endless loop. Note that I had some trouble debugging more
than one core with my debugger.
If possible I would suggest the first solution (qemu). It's most likely
the most robust one.
> My plan is to remove console_select.c and usart.c files. And do all of
> the initialization in
> the console-config.c.
OK for me. No need to split up code if it belongs together.
> I looked at some of the device files from FreeBSD,
> the address for the
> peripheral's are the virtual address or the bus address, so I will
> convert them to arm physical
> addresses, using a macro, which subtracts an offset to get the physical
> address.
I would suggest to create something similar like the imx_get_reg_of_node
function in the imx BSP.
> For finding the UART ports, we could traverse through the alias node.
> For rpi1 and rpi2 there should be just one(uart0), but
> for newer models, there would two (uart0 and uart1). And then read the
> stdout-path to find the serial that has to be used.
Sounds OK.
> And in console_initialize function, we should also parse the cmdline to
> find if FB is to be used. And link the appropriate
> driver to /dev/console.
OK.
> But how to handle the different types of device
> instances? for all the bsp's that I used as reference,
> all the uart devices were of same type, but here we have 3 different
> serial devices.
> My idea is manually intialize the devices, that is to traverse the alias
> node, and intialize uart0 to pl011 and uart1 to aux if
> it is available. and then seperately intialize the FB, Is there any
> better way to do it?
In FreeBSD the drivers usually have a probe and an attach function.
Basically the system just loops through every (non-disabled) fdt node
and asks every driver whether it wants that node (probe). If the driver
wants it it calls the matching attach function.
Currently there is no such infrastructure in RTEMS. Although it would be
nice to implement one I think it would be a bigger project (maybe could
be a complete GSoC project: plan a system; implement or port it;
integrate it in at least one BSP). But a simmilar direction is possible
here too:
- Every driver gets it's "register" function (instead of probe and attach).
- The register function checks for all nodes that it can handle and
registers the driver. For the raspberry fdt that will be 0 or 1 devices
for the pl011 and 0 or 1 for the mini UART and exactly one for the
framebuffer.
- You call all relevant register functions in the console initialization.
- After that you parse the command line and create the link.
I think that is basically what you described already just with a few
more words ;-)
> On Sun, Dec 29, 2019 at 2:11 AM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
> On 28/12/2019 20:03, Niteesh wrote:
> > I will start working on a patch that uses FDT. Instead of merging this
> > I create a patch v3 that uses FDT. Shall I remove some files, I
> will be
> > heavily using
> > the imx and other FDT based drivers as a reference.
> You can remove everything that is no longer used. I expect that it will
> be mainly the files containing the table based selection and console
> selection code.
> > On Sun, Dec 29, 2019 at 12:27 AM Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> > On 28/12/2019 19:48, Niteesh wrote:
> > > Is bsp_console_select legacy? And the new way will be by linking
> > > the correct serial device to /dev/console in
> > console_initialization, right?
> > > If so, shall I add one?
> > The function is only called from legacy-console.c. So yes:
> This function
> > can be removed. The logic on the other hand should move to
> somewhere
> > else.
> > The console-termios-init.c creates a link named
> CONSOLE_DEVICE_NAME. So
> > you can't use that code and create your link manually. If you
> use the
> > table based approach (which is OK as a first step) you can't
> really
> > select the console.
> > I would suggest to either clean that patch up so it can be
> merged and
> > move to a fdt based approach simmilar to imx in a second
> patch. In that
> > case the console_initialize() function from
> console-termios-init.c will
> > be replaced by a custom function that searches the FDT for the
> devices.
> > The FDT will make it simpler to adapt to RPi3. Or if you
> prefere it you
> > can do that right now and create a patch v3 that directly uses
> FDT.
> > > On Sat, Dec 28, 2019 at 11:50 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>
> > <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
> <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>> wrote:
> > > I am sorry if this question sounds silly, but how can I
> access the
> > > output_char_fb if it
> > > is marked as static in console-select.c, currently the fb
> > context is
> > > in console-config.c
> > > Should I move the BSP_select_function to console-config? for
> > shall I
> > > remove the static qualifier
> > > from the function?
> > > Currently, the console_select has 2 functions,
> > bsp_Is_Available and
> > > bsp_console_select.
> > > On Sat, Dec 28, 2019 at 11:30 PM Niteesh
> <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> > > On Sat, Dec 28, 2019 at 11:12 PM Christian Mauderer
> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> > > On 28/12/2019 17:22, Niteesh wrote:
> > > > I think you misunderstood, I was talking about the
> > casting
> > > in the
> > > > rtems_termios_device_handler
> > > Yes, I misunderstood you there.
> > > > const rtems_termios_device_handler fbcons_fns =
> > > > .first_open = fbcons_open,
> > > > .last_close = fbcons_close,
> > > > .poll_read = fbcons_inbyte_nonblocking_polled,
> > > > .write = (void
> (*)(rtems_termios_device_context *,
> > const
> > > char *,
> > > > size_t))fbcons_write_support_polled,
> > > > .set_attributes = fbcons_set_attributes,
> > > > .mode = TERMIOS_POLLED
> > > > the write requires a function type of
> > > > *void (*write)(
> > > > rtems_termios_device_context *context,
> > > > const char *buf,
> > > > size_t len
> > > > but the fbcons function is of type
> > > > *static ssize_t fbcons_write_support_polled(
> > > > rtems_termios_device_context *base,
> > > > const char *buf,
> > > > size_t len
> > > > Well, if the above cast in the device handler
> causes a
> > > problem, can you
> > > > elaborate more on
> > > > what kind of a problem would it be?
> > > In that case it should work. But why do you need to
> > cast it
> > > there?
> > > Wouldn't it be simpler to just change the
> > > function? It isn't used anywhere else or did I miss
> > something?
> > > No, it is not used anywhere. I'll change the function.
> > > > And for the BSP_output_char function, I used a
> function
> > > pointer. The
> > > > console_select assigns the
> > > > appropriate function to the function pointer
> and the
> > > output_char call's
> > > > it by providing the context.
> > > > static void output_char(char c)
> > > > const console_device *dev =
> > > &console_device_table[console_select];
> > > > rtems_termios_device_context *con =
> dev->context;
> > > > console_instance(con, c);
> > > > console_instance is the function pointer, which is
> > assigned to
> > > > arm_pl011_write_polled by
> > > > default, or to fbcons_write_polled, if frame
> buffer is
> > > decided to be used.
> > > Yes it will work and it's resonable performant.
> We are
> > > talking about a
> > > slow serial interface in an exception case. But
> anyway I'm
> > > not entirely
> > > happy.
> > > The compiler should make something like the
> following
> > out of it:
> > > - Look up and call the value of BSP_output_char
> > > - Load the context (start of table +
> console_select +
> > fixed
> > > offset) into
> > > "con"
> > > - Look up and call the value of console_instance
> > > If you use the way I suggested below you will have
> > about the
> > > following:
> > > - Look up and call the value of BSP_output_char (one
> > of the
> > > wrappers)
> > > - Call the right function with a fixed parameter
> > > So it's a bit shorter and beneath that you save
> a global
> > > variable.
> > > Sure, will change it.
> > > > On Sat, Dec 28, 2019 at 8:50 PM Christian Mauderer
> > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>
> > > wrote:
> > > > On 28/12/2019 14:10, G S Niteesh wrote:
> > > > > The patch updates the older console
> interface used
> > > by the BSP,
> > > > > to newer one. It also replaces the custom
> > > usart(PL011) driver
> > > > > with arm-pl011. The fb function's
> signatures where
> > > also changed
> > > > > to accommodate with interface update.
> > > > > Update #3034
> bsps/arm/raspberrypi/console/console-config.c
> > | 62
> bsps/arm/raspberrypi/console/console_select.c
> > | 68
> > > > > bsps/arm/raspberrypi/console/fbcons.c
> > | 71
> > > > > bsps/arm/raspberrypi/console/usart.c
> > | 142
> bsps/arm/raspberrypi/include/bsp/fbcons.h
> > | 19 ++-
> .../arm/raspberrypi/include/bsp/raspberrypi.h
> > | 70
> bsps/arm/raspberrypi/include/bsp/usart.h
> > | 5 +-
> c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > | 5 +-
> > > > > 8 files changed, 136 insertions(+), 306
> > deletions(-)
> > > > > diff --git
> > > a/bsps/arm/raspberrypi/console/console-config.c
> b/bsps/arm/raspberrypi/console/console-config.c
> > > > > index d2186c918b..f479e19d99 100644
> > > > > @@ -22,45 +22,47 @@
> > > > > #include <libchip/serial.h>
> > > > > -#include <bspopts.h>
> > > > > -#include <bsp/irq.h>
> > > > > -#include <bsp/usart.h>
> > > > > +#include <bsp.h>
> > > > > #include <bsp/raspberrypi.h>
> > > > > +#include <bsp/usart.h>
> > > > > +#include <bsp/arm-pl011.h>
> > > > > #include <bsp/fbcons.h>
> > > > > +#include <bsp/console-termios.h>
> > > > > +#include <bspopts.h>
> > > > > -console_tbl Console_Configuration_Ports
> > > > > - .sDeviceName = "/dev/ttyS0",
> > > > > - .deviceType = SERIAL_CUSTOM,
> > > > > - .pDeviceFns = &bcm2835_usart_fns,
> > > > > - .deviceProbe = NULL,
> > > > > - .pDeviceFlow = NULL,
> > > > > - .ulCtrlPort1 = BCM2835_UART0_BASE,
> > > > > - .ulCtrlPort2 = 0,
> > > > > - .ulClock = USART0_DEFAULT_BAUD,
> > > > > - .ulIntVector = BCM2835_IRQ_ID_UART
> > > > > - .sDeviceName ="/dev/fbcons",
> > > > > - .pDeviceFns = &fbcons_fns,
> > > > > - .deviceProbe = fbcons_probe,
> > > > > +arm_pl011_context pl011_context = {
> > > > > + .base =
> > > RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
> > > > > + .regs = (volatile pl011 *)
> BCM2835_PL011_BASE,
> > > > > + .initial_baud = PL011_DEFAULT_BAUD
> > > > > -#define PORT_COUNT \
> > > > > - (sizeof(Console_Configuration_Ports) \
> sizeof(Console_Configuration_Ports [0]))
> > > > > +rpi_fb_context fb_context = {
> > > > > + .base =
> > > RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("FB")
> > > > > +const console_device
> console_device_table[] = {
> > > > > + .device_file = "/dev/ttyS0",
> > > > > + .probe = console_device_probe_default,
> > > > > + .handler = &arm_pl011_fns,
> > > > > + .context = &pl011_context.base
> > > > > + .device_file = "/dev/fbcons",
> > > > > + .probe = fbcons_probe,
> > > > > + .handler = &fbcons_fns,
> > > > > + .context = &fb_context.base
> > > > > -unsigned long Console_Configuration_Count =
> > PORT_COUNT;
> > > > > +const size_t console_device_count =
> > > > RTEMS_ARRAY_SIZE(console_device_table);
> > > > > - const console_fns *con =
> > > > > - Console_Configuration_Ports
> > > [Console_Port_Minor].pDeviceFns;
> > > > > - con->deviceWritePolled((int)
> > Console_Port_Minor, c);
> > > > > + const console_device *dev =
> > > > > + rtems_termios_device_context *con =
> > dev->context;
> > > > > + console_instance(con, c);
> > > > I'm still not happy with that. What I had in
> > mind was
> > > more or less:
> > > > static void output_char_serial(char c)
> arm_pl011_write_polled(&pl011_context.base, c);
> > > > static void output_char_fb(char c)
> > > > fbcons_write_polled(&fb_context.base, c);
> > > > BSP_output_char_function_type
> BSP_output_char =
> > > output_char_serial;
> > > > And if you decide that the frame buffer should
> > be used
> > > in the select
> > > > function you do a
> > > > BSP_output_char = output_char_fb;
> BSP_output_char =
> > > output_char;
> > > > > diff --git
> > > a/bsps/arm/raspberrypi/console/console_select.c
> b/bsps/arm/raspberrypi/console/console_select.c
> > > > > index bd246ca868..ea3325266f 100644
> > > > > @@ -15,69 +15,40 @@
> > > > > * http://www.rtems.org/license/LICENSE
> > > > > #include <bsp.h>
> > > > > +#include <bsp/raspberrypi.h>
> > > > > +#include <bsp/fbcons.h>
> > > > > +#include <bsp/rpi-fb.h>
> > > > > #include <bsp/fatal.h>
> > > > > #include <rtems/libio.h>
> > > > > #include <stdlib.h>
> > > > > #include <string.h>
> > > > > #include <assert.h>
> > > > > #include <termios.h>
> > > > > -#include <rtems/termiostypes.h>
> > > > > -#include
> > "../../shared/dev/serial/legacy-console.h"
> > > > > -#include <bsp/rpi-fb.h>
> > > > > -rtems_device_minor_number BSPPrintkPort
> = 0;
> > > > > +int console_select = PL011;
> > > > > +console console_instance =
> > arm_pl011_write_polled;
> > > > > - * Method to return true if the device
> associated
> > > with the
> > > > > - * minor number probs available.
> > > > > -static bool bsp_Is_Available(
> > > rtems_device_minor_number minor )
> > > > > +static bool bsp_Is_Available( int index )
> > > > > - console_tbl *cptr = Console_Port_Tbl[
> minor ];
> > > &console_device_table[index];
> > dev->context;
> > > > > * First perform the configuration
> dependent
> > > probe, then the
> > > > > * device dependent probe
> > > > > - if ( ( !cptr->deviceProbe ||
> cptr->deviceProbe(
> > > minor ) ) &&
> > > > > - cptr->pDeviceFns->deviceProbe(
> minor ) ) {
> > > > > + if ( ( !dev->probe || dev->probe( con
> > > > > return true;
> > > > > return false;
> > > > > - * Method to return the first available
> device.
> > > > > -static rtems_device_minor_number
> > > bsp_First_Available_Device( void )
> > > > > - rtems_device_minor_number minor;
> > > > > - for ( minor = 0; minor <
> Console_Port_Count;
> > > minor++ ) {
> > minor ];
> > > > > - * First perform the configuration
> dependent
> > > probe, then the
> > > > > - * device dependent probe
> > cptr->deviceProbe(
> > > minor ) ) &&
> minor
> > > > > - return minor;
> > > > > - * Error No devices were found. We will
> > want to
> > > bail here.
> > > > > - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> > > > > void bsp_console_select( void )
> > > > > @@ -90,25 +61,18 @@ void bsp_console_select(
> > void )
> > > > > const char *opt;
> > > > > - Console_Port_Minor = BSP_CONSOLE_UART0;
> > > > > - BSPPrintkPort = BSP_CONSOLE_UART0;
> > > > > opt = rpi_cmdline_get_arg(
> "--console=" );
> > > > > if ( opt ) {
> > > > > if ( strncmp( opt, "fbcons", sizeof(
> > "fbcons" )
> > > - 1 ) == 0 ) {
> > > > > if ( rpi_video_is_initialized() >
> 0 ) {
> BSP_CONSOLE_FB;
> > > > > - BSPPrintkPort = BSP_CONSOLE_FB;
> > > > > + console_select = FB;
> > > > > + console_instance =
> fbcons_write_polled;
> > > > > - * If the device that was selected isn't
> > > available then
> > > > > - * let the user know and select the first
> > > available device.
> > > > > - if ( !bsp_Is_Available(
> Console_Port_Minor
> > bsp_First_Available_Device();
> > > > > + if( !bsp_Is_Available( console_select
> > > > > + bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> > > > > diff --git
> a/bsps/arm/raspberrypi/console/fbcons.c
> > > > b/bsps/arm/raspberrypi/console/fbcons.c
> > > > > index 3669ba458d..6e710e252d 100644
> > > > > --- a/bsps/arm/raspberrypi/console/fbcons.c
> > > > > +++ b/bsps/arm/raspberrypi/console/fbcons.c
> > > > > @@ -18,6 +18,7 @@
> > > > > #include <rtems.h>
> > > > > +#include <rtems/termiostypes.h>
> > > > > #include <stdlib.h>
> > > > > @@ -29,15 +30,6 @@
> > > > > #include <bsp/vc.h>
> > > > > - * fbcons_init
> > > > > - * This function initializes the fb
> console to a
> > > quiecsent state.
> > > > > -static void fbcons_init( int minor )
> > > > > * fbcons_open
> > > > > @@ -45,13 +37,14 @@ static void fbcons_init(
> > int minor )
> > > > > * Default state is 9600 baud, 8 bits, No
> > parity,
> > > and 1 stop bit.
> > > > > -static int fbcons_open(
> > > > > - int major,
> > > > > - int minor,
> > > > > - void *arg
> > > > > +static bool fbcons_open(
> > > > > + struct rtems_termios_tty *tty,
> > > > > + rtems_termios_device_context *base,
> > > > > + struct termios *term,
> > > > > + rtems_libio_open_close_args_t *args
> > > > > - return RTEMS_SUCCESSFUL;
> > > > > + return true;
> > > > > @@ -59,13 +52,12 @@ static int fbcons_open(
> > > > > * This function shuts down the
> requested port.
> > > > > -static int fbcons_close(
> > > > > - int major,
> > > > > - int minor,
> > > > > - void *arg
> > > > > +static void fbcons_close(
> > > > > - return ( RTEMS_SUCCESSFUL );
> > > > > @@ -73,8 +65,8 @@ static int fbcons_close(
> > > > > * This routine polls out the requested
> > character.
> > > > > -static void fbcons_write_polled(
> > > > > - int minor,
> > > > > +void fbcons_write_polled(
> > > > > char c
> > > > > @@ -91,7 +83,7 @@ static void
> > > > > - int minor,
> > > > > const char *buf,
> > > > > size_t len
> > > > > @@ -102,7 +94,7 @@ static ssize_t
> > > > > * poll each byte in the string out
> of the
> > port.
> > > > > while ( nwrite < len ) {
> > > > > - fbcons_write_polled( minor, *buf++ );
> > > > > + fbcons_write_polled( base, *buf++ );
> > > > > nwrite++;
> > > > > @@ -117,7 +109,9 @@ static ssize_t
> > > > > * Console Termios polling input entry
> point.
> > > > > -static int
> fbcons_inbyte_nonblocking_polled( int
> > > minor )
> > > > > +int fbcons_inbyte_nonblocking_polled(
> > > > > // if( rtems_kbpoll() ) {
> > > > > // int c = getch();
> > > > > @@ -133,15 +127,17 @@ static int
> > > > int minor )
> > > > > * This function sets the UART channel to
> > reflect
> > > the requested
> > > > termios
> > > > > * port settings.
> > > > > -static int fbcons_set_attributes(
> > > > > - int minor,
> > > > > +static bool fbcons_set_attributes(
> > > > > const struct termios *t
> > > > > - return 0;
> > > > > + return true;
> > > > > -bool fbcons_probe( int minor )
> > > > > +bool fbcons_probe(
> > > > > + rtems_termios_device_context *context
> > > > > // rtems_status_code status;
> > > > > static bool firstTime = true;
> > > > > @@ -163,15 +159,12 @@ bool fbcons_probe( int
> > minor )
> > > > > return ret;
> > > > > -const console_fns fbcons_fns =
> > > > > +const rtems_termios_device_handler
> fbcons_fns =
> > > > > - .deviceProbe =
> libchip_serial_default_probe,
> > > /* deviceProbe */
> > > > > - .deviceFirstOpen = fbcons_open,
> > > > deviceFirstOpen */
> > > > > - .deviceLastClose = fbcons_close,
> > > > deviceLastClose */
> > > > > - .deviceRead =
> > > /* deviceRead */
> > > > > - .deviceWrite =
> > > /* deviceWrite */
> > > > > - .deviceInitialize = fbcons_init,
> > > > deviceInitialize */
> > > > > - .deviceWritePolled =
> > > > deviceWritePolled */
> > > > > - .deviceSetAttributes =
> > fbcons_set_attributes, /*
> > > > deviceSetAttributes */
> > > > > - .deviceOutputUsesInterrupts = FALSE,
> > > > deviceOutputUsesInterrupts*/
> > > > > + .first_open = fbcons_open,
> > > > > + .last_close = fbcons_close,
> > > > > + .poll_read =
> > > > > + .write = (void
> > > *, const char
> > > > *, size_t))fbcons_write_support_polled,
> > > > > + .set_attributes = fbcons_set_attributes,
> > > > > + .mode = TERMIOS_POLLED
> > > > > \ No newline at end of file
> > > > > diff --git
> a/bsps/arm/raspberrypi/console/usart.c
> > > > b/bsps/arm/raspberrypi/console/usart.c
> > > > > index 25fb523621..471d0c553f 100644
> > > > > --- a/bsps/arm/raspberrypi/console/usart.c
> > > > > +++ b/bsps/arm/raspberrypi/console/usart.c
> > > > > @@ -23,145 +23,3 @@
> > > > > #include <rtems/bspIo.h>
> > > > > -static void usart_delay(uint32_t n)
> > > > > - volatile uint32_t i = 0;
> > > > > - for(i = 0; i < n; i++)
> > > > > -#if 0
> > > > > - * These will be useful when the
> driver supports
> > > interrupt
> > > > driven IO.
> > > > > -static rtems_vector_number
> > > usart_get_irq_number(const console_tbl
> > > > *ct)
> > > > > - return ct->ulIntVector;
> > > > > -static uint32_t usart_get_baud(const
> > console_tbl *ct)
> > > > > - return ct->ulClock;
> > > > > -#endif
> > > > > -static void usart_set_baud(int minor,
> int baud)
> > > > > - * Nothing for now
> > > > > - return;
> > > > > -static void usart_initialize(int minor)
> > > > > - unsigned int gpio_reg;
> > > > > - ** Program GPIO pins for UART 0
> > > > > - gpio_reg =
> BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> > > > > - gpio_reg &= ~(7<<12); /* gpio14 */
> > > > > - gpio_reg |= (4<<12); /* alt0 */
> > > > > - gpio_reg &= ~(7<<15); /* gpio15 */
> > > > > - gpio_reg |= (4<<15); /* alt0 */
> > > > > - BCM2835_REG(BCM2835_GPIO_GPFSEL1) =
> gpio_reg;
> > > > > - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> > > > > - usart_delay(150);
> > > > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
> > > (1<<14)|(1<<15);
> > > > > - usart_delay(150);
> > > > > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> > > > > - ** Init the PL011 UART
> > > > > - BCM2835_REG(BCM2835_UART0_CR) = 0;
> > > > > - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
> > > > > - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> > > > > - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> > > > > - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> > > > > - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> > > > > - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
> > > > > - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
> > > BCM2835_UART0_IMSC_RX;
> > > > > - usart_set_baud(minor, 115000);
> > > > > -static int usart_first_open(int major,
> int minor,
> > > void *arg)
> > > > > - rtems_libio_open_close_args_t *oc =
> > > > (rtems_libio_open_close_args_t *) arg;
> > > > > - struct rtems_termios_tty *tty = (struct
> > > rtems_termios_tty *)
> > > > oc->iop->data1;
> > > > > - const console_tbl *ct = Console_Port_Tbl
> > [minor];
> > > > > - console_data *cd = &Console_Port_Data
> [minor];
> > > > > - cd->termios_data = tty;
> > > > > - rtems_termios_set_initial_baud(tty,
> > ct->ulClock);
> > > > > - return 0;
> > > > > -static int usart_last_close(int major,
> int minor,
> > > void *arg)
> > > > > - return 0;
> > > > > -static int usart_read_polled(int minor)
> > > > > - if (minor == 0) {
> > > > > - if (((BCM2835_REG(BCM2835_UART0_FR)) &
> > > BCM2835_UART0_FR_RXFE)
> > > > == 0) {
> return((BCM2835_REG(BCM2835_UART0_DR))
> > & 0xFF );
> > > > > - } else {
> > > > > - return -1;
> > > > > - } else {
> > > > > - printk("Unknown console minor
> number: %d\n",
> > > minor);
> > > > > - return -1;
> > > > > -static void usart_write_polled(int
> minor, char c)
> > > > > - while (1) {
> > > > > - if ((BCM2835_REG(BCM2835_UART0_FR) &
> > > BCM2835_UART0_FR_TXFF)
> > > > == 0)
> > > > > - break;
> > > > > - BCM2835_REG(BCM2835_UART0_DR) = c;
> > > > > -static ssize_t usart_write_support_polled(
> > > > > - int minor,
> > > > > - const char *s,
> > > > > - size_t n
> > > > > - ssize_t i = 0;
> > > > > - for (i = 0; i < n; ++i) {
> > > > > - usart_write_polled(minor, s [i]);
> > > > > - return n;
> > > > > -static int usart_set_attributes(int
> minor, const
> > > struct termios
> > > > *term)
> > > > > - return -1;
> > > > > -const console_fns bcm2835_usart_fns = {
> > > > > - .deviceProbe =
> > > > > - .deviceFirstOpen = usart_first_open,
> > > > > - .deviceLastClose = usart_last_close,
> > > > > - .deviceRead = usart_read_polled,
> > > > > - .deviceWrite =
> usart_write_support_polled,
> > > > > - .deviceInitialize = usart_initialize,
> > > > > - .deviceWritePolled = usart_write_polled,
> usart_set_attributes,
> > > > > - .deviceOutputUsesInterrupts = false
> > > > > diff --git
> > a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > > b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> > > > > index d0e126699a..e3d9e69ff5 100644
> > > > > @@ -33,12 +33,27 @@ extern "C" {
> > > > > #define FB_CONSOLE 0x50492835
> > > > > -bool fbcons_probe( int minor );
> > > > > +bool fbcons_probe(
> > > > > + char c
> > > > > +typedef struct {
> > > > > + rtems_termios_device_context base;
> > > > > +} rpi_fb_context ;
> > > > > * Driver function table
> > > > > -extern const console_fns fbcons_fns;
> > > > > +extern const rtems_termios_device_handler
> > fbcons_fns;
> > > > > #ifdef __cplusplus
> > > > > diff --git
> > > a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> > > > > index 40c80cf408..2ccc49846c 100644
> > > > > @@ -24,6 +24,7 @@
> > > > > #include <stdint.h>
> > > > > #include <bsp/utility.h>
> > > > > * @defgroup raspberrypi_reg Register
> Definitions
> > > > > @@ -60,6 +61,39 @@
> > > > > #define RPI_PERIPHERAL_SIZE
> 0x01000000
> > > > > + * @name Console select definitions
> > > > > +#define PL011 0
> > > > > +#define FB 1
> > > > > +extern int console_select;
> > > > > +typedef void
> > > (*console)(rtems_termios_device_context *, char c);
> > > > > +extern console console_instance;
> > > > > * @name Internal ARM Timer Registers
> > > > > @@ -184,42 +218,6 @@
> > > > > - * @name UART 0 (PL011) Registers
> > > > > -#define BCM2835_UART0_BASE
> > > (RPI_PERIPHERAL_BASE + 0x201000)
> > > > > -#define BCM2835_UART0_DR
> > > (BCM2835_UART0_BASE + 0x00)
> > > > > -#define BCM2835_UART0_RSRECR
> > > (BCM2835_UART0_BASE + 0x04)
> > > > > -#define BCM2835_UART0_FR
> > > (BCM2835_UART0_BASE + 0x18)
> > > > > -#define BCM2835_UART0_ILPR
> > > (BCM2835_UART0_BASE + 0x20)
> > > > > -#define BCM2835_UART0_IBRD
> > > (BCM2835_UART0_BASE + 0x24)
> > > > > -#define BCM2835_UART0_FBRD
> > > (BCM2835_UART0_BASE + 0x28)
> > > > > -#define BCM2835_UART0_LCRH
> > > (BCM2835_UART0_BASE + 0x2C)
> > > > > -#define BCM2835_UART0_CR
> > > (BCM2835_UART0_BASE + 0x30)
> > > > > -#define BCM2835_UART0_IFLS
> > > (BCM2835_UART0_BASE + 0x34)
> > > > > -#define BCM2835_UART0_IMSC
> > > (BCM2835_UART0_BASE + 0x38)
> > > > > -#define BCM2835_UART0_RIS
> > > (BCM2835_UART0_BASE + 0x3C)
> > > > > -#define BCM2835_UART0_MIS
> > > (BCM2835_UART0_BASE + 0x40)
> > > > > -#define BCM2835_UART0_ICR
> > > (BCM2835_UART0_BASE + 0x44)
> > > > > -#define BCM2835_UART0_DMACR
> > > (BCM2835_UART0_BASE + 0x48)
> > > > > -#define BCM2835_UART0_ITCR
> > > (BCM2835_UART0_BASE + 0x80)
> > > > > -#define BCM2835_UART0_ITIP
> > > (BCM2835_UART0_BASE + 0x84)
> > > > > -#define BCM2835_UART0_ITOP
> > > (BCM2835_UART0_BASE + 0x88)
> > > > > -#define BCM2835_UART0_TDR
> > > (BCM2835_UART0_BASE + 0x8C)
> > > > > -#define BCM2835_UART0_MIS_RX 0x10
> > > > > -#define BCM2835_UART0_MIS_TX 0x20
> > > > > -#define BCM2835_UART0_IMSC_RX 0x10
> > > > > -#define BCM2835_UART0_IMSC_TX 0x20
> > > > > -#define BCM2835_UART0_FR_RXFE 0x10
> > > > > -#define BCM2835_UART0_FR_TXFF 0x20
> > > > > -#define BCM2835_UART0_ICR_RX 0x10
> > > > > -#define BCM2835_UART0_ICR_TX 0x20
> > > > > diff --git
> > a/bsps/arm/raspberrypi/include/bsp/usart.h
> > > > b/bsps/arm/raspberrypi/include/bsp/usart.h
> > > > > index d3e710c5e9..abbf53626c 100644
> > > > > @@ -32,9 +32,8 @@
> > > > > extern "C" {
> > > > > #endif /* __cplusplus */
> > > > > -#define USART0_DEFAULT_BAUD 115000
> > > > > -extern const console_fns bcm2835_usart_fns;
> > > > > +#define PL011_DEFAULT_BAUD 115000
> > > > > +#define BCM2835_PL011_BASE
> > > 0x201000)
> > > > > #ifdef __cplusplus
> > > > > diff --git
> > > a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > > b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> > > > > index 11a22f89e3..ce91527f92 100644
> > > > > @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
> > ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> > > > > # Console
> > > > > -librtemsbsp_a_SOURCES +=
> > ../../../../../../bsps/shared/dev/serial/legacy-console.c
> ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
> > ../../../../../../bsps/arm/raspberrypi/console/console-config.c
> > ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> > ../../../../../../bsps/arm/raspberrypi/console/usart.c
> ../../../../../../bsps/arm/raspberrypi/console/fb.c
> > ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> > ../../../../../../bsps/arm/raspberrypi/console/outch.c
> > > > > +librtemsbsp_a_SOURCES +=
> > ../../../../../../bsps/shared/dev/serial/console-termios.c
> > ../../../../../../bsps/shared/dev/serial/console-termios-init.c
> ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> > > > > # Mailbox
> > ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
