[PATCH v3] Raspberrypi: updated the console interface.
Niteesh gsnb.gn at gmail.com
Sun Dec 29 18:48:25 UTC 2019
I am not happy with my code at all, I can please provide some suggestions.
On Mon, Dec 30, 2019 at 12:17 AM Niteesh <gsnb.gn at gmail.com> wrote:
> arm_pl011_context pl011_context;
> rpi_fb_context fb_context;
> char uart_instance[20];
> static void output_char_serial(char c)
> arm_pl011_write_polled(&pl011_context.base, c);
> void output_char_fb(char c)
> fbcons_write_polled(&fb_context.base, c);
> static void *get_reg_of_node(const void *fdt, int node)
> int len;
> const uint32_t *val;
> val = fdt_getprop(fdt, node, "reg", &len);
> if (val == NULL || len < 4) {
> return NULL;
> return (void *) fdt32_to_cpu(val[0]);
> static void arm_pl011_init_ctx(
> const void *fdt,
> const char *serial
> arm_pl011_context *ctx = &pl011_context;
> int node;
> if (strcmp(serial, "uart0") == 0) {
> rtems_termios_device_context_initialize(&ctx->base, "UART");
> node = fdt_path_offset(fdt, serial);
> ctx->regs = get_reg_of_node(fdt, node);
> static void console_select( const char *console )
> const char *opt;
> opt = rpi_cmdline_get_arg("--console=");
> if ( opt ) {
> if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
> if ( rpi_video_is_initialized() > 0 ) {
> strcpy(uart_instance, "/dev/fbcons");
> BSP_output_char = output_char_fb;
> }else{
> if ( console == NULL ){
> bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> BSP_output_char = output_char_serial;
> strcpy(uart_instance, "/dev/ttyS0");
> static void uart_probe(void)
> const void *fdt;
> const char *console;
> int node;
> fdt = bsp_fdt_get();
> node = fdt_path_offset(fdt, "/chosen");
> console = fdt_getprop(fdt, node, "stdout-path", NULL);
> node = fdt_path_offset(fdt, "/aliases");
> int offset = fdt_first_property_offset(fdt, node);
> while (offset >= 0) {
> const struct fdt_property *prop;
> prop = fdt_get_property_by_offset(fdt, offset, NULL);
> if (prop != NULL) {
> const char *name;
> name = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
> if(strstr(name, "serial") != NULL) {
> const char *serial;
> serial = prop->data;
> arm_pl011_init_ctx(fdt, serial);
> offset = fdt_next_property_offset(fdt, offset);
> console_select(console);
> static void output_char(char c)
> uart_probe();
> (*BSP_output_char)(c);
> rtems_status_code console_initialize(
> rtems_device_major_number major,
> rtems_device_minor_number minor,
> void *arg
> rtems_termios_initialize();
> rtems_termios_device_install(
> "/dev/ttyS0",
> &arm_pl011_fns,
> NULL,
> &pl011_context.base
> "/dev/fbcons",
> &fbcons_fns,
> NULL,
> &fb_context.base);
> link(uart_instance, CONSOLE_DEVICE_NAME);
> return RTEMS_SUCCESSFUL;
> BSP_output_char_function_type BSP_output_char = output_char;
> BSP_polling_getchar_function_type BSP_poll_char = NULL;
> RTEMS_SYSINIT_ITEM(
> uart_probe,
> RTEMS_SYSINIT_BSP_START,
> RTEMS_SYSINIT_ORDER_LAST
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191230/544403ed/attachment-0001.html>
