[PATCH v3] Raspberrypi: updated the console interface.
Christian Mauderer list at c-mauderer.de
Sun Dec 29 20:05:40 UTC 2019
On 29/12/2019 18:44, Niteesh wrote:
> Where does RTEMS except the DTB file to be present?
See my mail in the other thread regarding that. You might have to add a
define in the configure.ac.
> On Sun, Dec 29, 2019 at 8:27 PM Niteesh <gsnb.gn at gmail.com
> <mailto:gsnb.gn at gmail.com>> wrote:
>     I am sorry, I sent the previous without testing and building, so it
>     might contain some errors.
>     Just tell me if you are happy with the code, I will fix all the
>     error's and send in a new patch.
That's no problem. I'll take a look and add some comments in a few minutes.
>     On Sun, Dec 29, 2019 at 8:04 PM G S Niteesh <gsnb.gn at gmail.com
>         The patch updates the older console interface used by the BSP,
>         to newer one. It also replaces the custom usart(PL011) driver
>         with arm-pl011. The fb function's signatures where also changed
>         to accommodate with interface update.
>         Update #3034
>          bsps/arm/raspberrypi/console/console-config.c | 182
>          bsps/arm/raspberrypi/console/console_select.c |  97 +---------
>          bsps/arm/raspberrypi/console/fbcons.c         |  79 ++++----
>          bsps/arm/raspberrypi/console/usart.c          | 167
>          bsps/arm/raspberrypi/include/bsp/fbcons.h     |  21 +-
>          .../arm/raspberrypi/include/bsp/raspberrypi.h |  48 ++---
>          bsps/arm/raspberrypi/include/bsp/usart.h      |   5 +-
>          c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |   5 +-
>          8 files changed, 225 insertions(+), 379 deletions(-)
>          delete mode 100644 bsps/arm/raspberrypi/console/usart.c
>         diff --git a/bsps/arm/raspberrypi/console/console-config.c
>         b/bsps/arm/raspberrypi/console/console-config.c
>         index d2186c918b..52859656f4 100644
>         --- a/bsps/arm/raspberrypi/console/console-config.c
>         +++ b/bsps/arm/raspberrypi/console/console-config.c
>         @@ -19,50 +19,162 @@
>          #include <rtems/bspIo.h>
>         +#include <rtems/console.h>
>          #include <libchip/serial.h>
>         -#include <bspopts.h>
>         -#include <bsp/irq.h>
>         -#include <bsp/usart.h>
>         +#include <bsp.h>
>          #include <bsp/raspberrypi.h>
>         +#include <bsp/usart.h>
>         +#include <bsp/arm-pl011.h>
>          #include <bsp/fbcons.h>
>         +#include <bsp/console-termios.h>
>         +#include <bsp/fatal.h>
>         +#include <bspopts.h>
>         +#include <libfdt.h>
>         +arm_pl011_context pl011_context;
>         +rpi_fb_context fb_context;
>         +static void output_char_serial(char c)
>         +  arm_pl011_write_polled(&pl011_context.base, c);
>         +void output_char_fb(char c)
>         +  fbcons_write_polled(&fb_context.base, c);
>         +static void *get_reg_of_node(const void *fdt, int node)
>         +  int len;
>         +  const uint32_t *val;
>         +  val = fdt_getprop(fdt, node, "reg", &len);
>         +  if (val == NULL || len < 4) {
>         +    return NULL;
>         +  return (void *) fdt32_to_cpu(val[0]);
>         +static bool register_arm_pl011(const void *fdt, const char
>         *serial, const char *path)
>         +  arm_pl011_context *ctx = &pl011_context;
>         +  int node;
>         +  if (strcmp(serial, "uart0")) {
>         +    rtems_termios_device_context_initialize(&ctx->base, "UART");
>         +    node = fdt_path_offset(fdt, serial);
>         +    ctx->regs = get_reg_of_node(fdt, node);
>         +    rtems_termios_device_install(
>         +      path,
>         +      &arm_pl011_fns,
>         +      NULL,
>         +      &pl011_context.base
>         +    return true;
>         +  return false;
>         -console_tbl Console_Configuration_Ports [] = {
>         -      .sDeviceName = "/dev/ttyS0",
>         -      .deviceType = SERIAL_CUSTOM,
>         -      .pDeviceFns = &bcm2835_usart_fns,
>         -      .deviceProbe = NULL,
>         -      .pDeviceFlow = NULL,
>         -      .ulCtrlPort1 = BCM2835_UART0_BASE,
>         -      .ulCtrlPort2 = 0,
>         -      .ulClock = USART0_DEFAULT_BAUD,
>         -      .ulIntVector = BCM2835_IRQ_ID_UART
>         -      .sDeviceName ="/dev/fbcons",
>         -      .pDeviceFns = &fbcons_fns,
>         -      .deviceProbe = fbcons_probe,
>         -#define PORT_COUNT \
>         -  (sizeof(Console_Configuration_Ports) \
>         -    / sizeof(Console_Configuration_Ports [0]))
>         -unsigned long Console_Configuration_Count = PORT_COUNT;
>         -static void output_char(char c)
>         +static bool register_fb()
>         -  const console_fns *con =
>         -    Console_Configuration_Ports [Console_Port_Minor].pDeviceFns;
>         +  if( !fbcons_probe(&fb_context.base) ) {
>         +    return false;
>         +    "/dev/fbcons",
>         +    &fbcons_fns,
>         +    NULL,
>         +    &fb_context.base);
>         +  return true;
>         +static void uart_probe(const void *fdt, int node)
>         +  char path[] = "/dev/ttyS?";
>         +  size_t i = 0;
>         +  int offset = fdt_first_property_offset(fdt, node);
>         +  while (offset >= 0) {
>         +    const struct fdt_property *prop;
>         +    prop = fdt_get_property_by_offset(fdt, offset, NULL);
>         +    if (prop != NULL) {
>         +      const char *name;
>         +      name = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
>         +      if(strstr(name, "serial") != NULL) {
>         +        const char *serial;
>         +        serial = prop->data;
>         +        path[sizeof(path) - 2] = (char) ('0' + i);
>         +        register_arm_pl011(fdt, serial, path);
>         +        i++;
>         +    offset = fdt_get_property_by_offset(fdt, offset, NULL);
>         +static void console_select( const char *console )
>         +  const char *opt;
>         +  opt = rpi_cmdline_get_arg("--console=");
>         +  if ( opt ) {
>         +    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>         +      if ( rpi_video_is_initialized() > 0 ) {
>         +        link("/dev/fbcons", CONSOLE_DEVICE_NAME);
>         +        BSP_output_char = output_char_fb;
>         +    }else{
>         +      if ( console == NULL ){
>         +        bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>         +      path[strlen(path) - 1] = console[strlen(console) - 1];
>         +      link(path, CONSOLE_DEVICE_NAME);
>         +rtems_status_code console_initialize(
>         +  rtems_device_major_number major,
>         +  rtems_device_minor_number minor,
>         +  void *arg
>         +  const void *fdt;
>         +  const char *console;
>         +  int node;
>         +  fdt = bsp_fdt_get();
>         +  node = fdt_path_offset(fdt, "/chosen");
>         +  console = fdt_getprop(fdt, node, "stdout-path", NULL);
>         +  node = fdt_path_offset(fdt, "/aliases");
>         +  rtems_termios_initialize();
>         +  uart_probe(fdt, node);
>         +  register_fb();
>         -  con->deviceWritePolled((int) Console_Port_Minor, c);
>         +  console_select(console);
>         -BSP_output_char_function_type BSP_output_char = output_char;
>         +BSP_output_char_function_type BSP_output_char = output_char_serial;
>          BSP_polling_getchar_function_type BSP_poll_char = NULL;
>         diff --git a/bsps/arm/raspberrypi/console/console_select.c
>         b/bsps/arm/raspberrypi/console/console_select.c
>         index bd246ca868..85f664b65c 100644
>         --- a/bsps/arm/raspberrypi/console/console_select.c
>         +++ b/bsps/arm/raspberrypi/console/console_select.c
>         @@ -15,100 +15,19 @@
>           *  http://www.rtems.org/license/LICENSE
>          #include <bsp.h>
>         +#include <bsp/raspberrypi.h>
>         +#include <bsp/fbcons.h>
>         +#include <bsp/rpi-fb.h>
>          #include <rtems/libio.h>
>         +#include <rtems/bspIo.h>
>          #include <stdlib.h>
>          #include <string.h>
>          #include <assert.h>
>          #include <termios.h>
>         -#include <rtems/termiostypes.h>
>         -#include <libchip/serial.h>
>         -#include "../../shared/dev/serial/legacy-console.h"
>         -#include <bsp/rpi-fb.h>
>         -rtems_device_minor_number BSPPrintkPort = 0;
>         - * Method to return true if the device associated with the
>         - * minor number probs available.
>         -static bool bsp_Is_Available( rtems_device_minor_number minor )
>         -  console_tbl *cptr = Console_Port_Tbl[ minor ];
>         -   * First perform the configuration dependent probe, then the
>         -   * device dependent probe
>         -  if ( ( !cptr->deviceProbe || cptr->deviceProbe( minor ) ) &&
>         -       cptr->pDeviceFns->deviceProbe( minor ) ) {
>         -    return true;
>         -  return false;
>         - * Method to return the first available device.
>         -static rtems_device_minor_number bsp_First_Available_Device( void )
>         -  rtems_device_minor_number minor;
>         -  for ( minor = 0; minor < Console_Port_Count; minor++ ) {
>         -      return minor;
>         -   *  Error No devices were found.  We will want to bail here.
>         -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
>         -void bsp_console_select( void )
>         -   *  Reset Console_Port_Minor and
>         -   *  BSPPrintkPort here if desired.
>         -   *  This default version allows the bsp to set these
>         -   *  values at creation and will not touch them again
>         -   *  unless the selected port number is not available.
>         -  const char *opt;
>         -  Console_Port_Minor = BSP_CONSOLE_UART0;
>         -  BSPPrintkPort = BSP_CONSOLE_UART0;
>         -  opt = rpi_cmdline_get_arg( "--console=" );
>         -  if ( opt ) {
>         -    if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) - 1 ) == 0 ) {
>         -      if ( rpi_video_is_initialized() > 0 ) {
>         -        Console_Port_Minor = BSP_CONSOLE_FB;
>         -        BSPPrintkPort = BSP_CONSOLE_FB;
>         -   * If the device that was selected isn't available then
>         -   * let the user know and select the first available device.
>         -  if ( !bsp_Is_Available( Console_Port_Minor ) ) {
>         -    Console_Port_Minor = bsp_First_Available_Device();
>         +#include <libchip/serial.h>
>         \ No newline at end of file
>         diff --git a/bsps/arm/raspberrypi/console/fbcons.c
>         b/bsps/arm/raspberrypi/console/fbcons.c
>         index 3669ba458d..f98583bbe7 100644
>         --- a/bsps/arm/raspberrypi/console/fbcons.c
>         +++ b/bsps/arm/raspberrypi/console/fbcons.c
>         @@ -18,6 +18,8 @@
>          #include <rtems.h>
>         +#include <rtems/termiostypes.h>
>         +#include <rtems/status.h>
>          #include <stdlib.h>
>         @@ -29,15 +31,6 @@
>          #include <bsp/vc.h>
>         - *  fbcons_init
>         - *  This function initializes the fb console to a quiecsent state.
>         -static void fbcons_init( int minor )
>           *  fbcons_open
>         @@ -45,13 +38,14 @@ static void fbcons_init( int minor )
>           *  Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
>         -static int fbcons_open(
>         -  int   major,
>         -  int   minor,
>         -  void *arg
>         +static bool fbcons_open(
>         +  struct rtems_termios_tty *tty,
>         +  rtems_termios_device_context *base,
>         +  struct termios *term,
>         +  rtems_libio_open_close_args_t *args
>         -  return RTEMS_SUCCESSFUL;
>         +  return true;
>         @@ -59,13 +53,12 @@ static int fbcons_open(
>           *  This function shuts down the requested port.
>         -static int fbcons_close(
>         -  int   major,
>         -  int   minor,
>         -  void *arg
>         +static void fbcons_close(
>         -  return ( RTEMS_SUCCESSFUL );
>         @@ -73,8 +66,8 @@ static int fbcons_close(
>           *  This routine polls out the requested character.
>         -static void fbcons_write_polled(
>         -  int  minor,
>         +void fbcons_write_polled(
>            char c
>         @@ -90,8 +83,8 @@ static void fbcons_write_polled(
>           *  Console Termios output entry point when using polled output.
>         -static ssize_t fbcons_write_support_polled(
>         -  int         minor,
>         +static void fbcons_write_support_polled(
>            const char *buf,
>            size_t      len
>         @@ -102,14 +95,9 @@ static ssize_t fbcons_write_support_polled(
>             * poll each byte in the string out of the port.
>            while ( nwrite < len ) {
>         -    fbcons_write_polled( minor, *buf++ );
>         +    fbcons_write_polled( base, *buf++ );
>              nwrite++;
>         -   * return the number of bytes written.
>         -  return nwrite;
>         @@ -117,7 +105,9 @@ static ssize_t fbcons_write_support_polled(
>           *  Console Termios polling input entry point.
>         -static int fbcons_inbyte_nonblocking_polled( int minor )
>         +int fbcons_inbyte_nonblocking_polled(
>            // if( rtems_kbpoll() ) {
>            //   int c = getch();
>         @@ -133,15 +123,17 @@ static int
>           *  This function sets the UART channel to reflect the
>         requested termios
>           *  port settings.
>         -static int fbcons_set_attributes(
>         -  int                   minor,
>         +static bool fbcons_set_attributes(
>            const struct termios *t
>         -  return 0;
>         +  return true;
>         -bool fbcons_probe( int minor )
>         +bool fbcons_probe(
>         +  rtems_termios_device_context *context
>            // rtems_status_code status;
>            static bool firstTime = true;
>         @@ -163,15 +155,12 @@ bool fbcons_probe( int minor )
>            return ret;
>         -const console_fns fbcons_fns =
>         +const rtems_termios_device_handler fbcons_fns =
>         -  .deviceProbe = libchip_serial_default_probe,     /*
>         deviceProbe */
>         -  .deviceFirstOpen = fbcons_open,                 /*
>         deviceFirstOpen */
>         -  .deviceLastClose = fbcons_close,                /*
>         deviceLastClose */
>         -  .deviceRead = fbcons_inbyte_nonblocking_polled, /* deviceRead */
>         -  .deviceWrite = fbcons_write_support_polled,     /* deviceWrite */
>         -  .deviceInitialize = fbcons_init,                /*
>         deviceInitialize */
>         -  .deviceWritePolled = fbcons_write_polled,       /*
>         deviceWritePolled */
>         -  .deviceSetAttributes = fbcons_set_attributes,   /*
>         deviceSetAttributes */
>         -  .deviceOutputUsesInterrupts = FALSE,           /*
>         deviceOutputUsesInterrupts*/
>         +  .first_open = fbcons_open,
>         +  .last_close = fbcons_close,
>         +  .poll_read = fbcons_inbyte_nonblocking_polled,
>         +  .write = fbcons_write_support_polled,
>         +  .set_attributes = fbcons_set_attributes,
>         +  .mode = TERMIOS_POLLED
>         diff --git a/bsps/arm/raspberrypi/console/usart.c
>         b/bsps/arm/raspberrypi/console/usart.c
>         deleted file mode 100644
>         index 25fb523621..0000000000
>         --- a/bsps/arm/raspberrypi/console/usart.c
>         +++ /dev/null
>         @@ -1,167 +0,0 @@
>         - * @file
>         - * @ingroup raspberrypi_usart
>         - * @brief USART support.
>         - * Copyright (c) 2013 Alan Cudmore
>         - *  The license and distribution terms for this file may be
>         - *  found in the file LICENSE in this distribution or at
>         - *  http://www.rtems.org/license/LICENSE
>         -#include <libchip/sersupp.h>
>         -#include <bsp.h>
>         -#include <bsp/raspberrypi.h>
>         -#include <rtems/bspIo.h>
>         -static void usart_delay(uint32_t n)
>         - volatile uint32_t i = 0;
>         - for(i = 0; i < n; i++)
>         -#if 0
>         - *  These will be useful when the driver supports interrupt
>         driven IO.
>         -static rtems_vector_number usart_get_irq_number(const
>         console_tbl *ct)
>         -  return ct->ulIntVector;
>         -static uint32_t usart_get_baud(const console_tbl *ct)
>         -  return ct->ulClock;
>         -#endif
>         -static void usart_set_baud(int minor, int baud)
>         -  * Nothing for now
>         - return;
>         -static void usart_initialize(int minor)
>         -  unsigned int gpio_reg;
>         -  ** Program GPIO pins for UART 0
>         -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>         -  gpio_reg &= ~(7<<12);    /* gpio14 */
>         -  gpio_reg |=  (4<<12);    /* alt0   */
>         -  gpio_reg &= ~(7<<15);    /* gpio15 */
>         -  gpio_reg |=  (4<<15);    /* alt0   */
>         -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>         -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>         -  usart_delay(150);
>         -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>         -  usart_delay(150);
>         -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>         -  ** Init the PL011 UART
>         -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
>         -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>         -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>         -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>         -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>         -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>         -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>         -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>         -  BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>         -  usart_set_baud(minor, 115000);
>         -static int usart_first_open(int major, int minor, void *arg)
>         -  rtems_libio_open_close_args_t *oc =
>         (rtems_libio_open_close_args_t *) arg;
>         -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
>         oc->iop->data1;
>         -  const console_tbl *ct = Console_Port_Tbl [minor];
>         -  console_data *cd = &Console_Port_Data [minor];
>         -  cd->termios_data = tty;
>         -  rtems_termios_set_initial_baud(tty, ct->ulClock);
>         -  return 0;
>         -static int usart_last_close(int major, int minor, void *arg)
>         -  return 0;
>         -static int usart_read_polled(int minor)
>         -  if (minor == 0) {
>         -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
>         BCM2835_UART0_FR_RXFE) == 0) {
>         -       return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>         -    } else {
>         -      return -1;
>         -  } else {
>         -    printk("Unknown console minor number: %d\n", minor);
>         -    return -1;
>         -static void usart_write_polled(int minor, char c)
>         -   while (1) {
>         -     if ((BCM2835_REG(BCM2835_UART0_FR) &
>         BCM2835_UART0_FR_TXFF) == 0)
>         -       break;
>         -   BCM2835_REG(BCM2835_UART0_DR) = c;
>         -static ssize_t usart_write_support_polled(
>         -  int minor,
>         -  const char *s,
>         -  size_t n
>         -  ssize_t i = 0;
>         -  for (i = 0; i < n; ++i) {
>         -    usart_write_polled(minor, s [i]);
>         -  return n;
>         -static int usart_set_attributes(int minor, const struct termios
>         *term)
>         -  return -1;
>         -const console_fns bcm2835_usart_fns = {
>         -  .deviceFirstOpen = usart_first_open,
>         -  .deviceLastClose = usart_last_close,
>         -  .deviceRead = usart_read_polled,
>         -  .deviceWrite = usart_write_support_polled,
>         -  .deviceInitialize = usart_initialize,
>         -  .deviceWritePolled = usart_write_polled,
>         -  .deviceSetAttributes = usart_set_attributes,
>         -  .deviceOutputUsesInterrupts = false
>         diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         index d0e126699a..9bdb4b115e 100644
>         --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
>         @@ -33,12 +33,29 @@ extern "C" {
>          #define FB_CONSOLE 0x50492835
>         -bool fbcons_probe( int minor );
>         +bool fbcons_probe(
>         +  char c
>         +void output_char_fb(char c);
>         +typedef struct {
>         +    rtems_termios_device_context base;
>         +} rpi_fb_context ;
>           * Driver function table
>         -extern const console_fns fbcons_fns;
>         +extern const rtems_termios_device_handler fbcons_fns;
>          #ifdef __cplusplus
>         diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         index 40c80cf408..e052c2becb 100644
>         --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
>         @@ -24,6 +24,7 @@
>          #include <stdint.h>
>          #include <bsp/utility.h>
>           * @defgroup raspberrypi_reg Register Definitions
>         @@ -60,6 +61,17 @@
>          #define RPI_PERIPHERAL_SIZE         0x01000000
>         + * @name Console select definitions
>         +#define PL011 0
>         +#define FB    1
>           * @name Internal ARM Timer Registers
>         @@ -184,42 +196,6 @@
>         - * @name UART 0 (PL011) Registers
>         -#define BCM2835_UART0_BASE       (RPI_PERIPHERAL_BASE + 0x201000)
>         -#define BCM2835_UART0_DR         (BCM2835_UART0_BASE + 0x00)
>         -#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE + 0x04)
>         -#define BCM2835_UART0_FR         (BCM2835_UART0_BASE + 0x18)
>         -#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE + 0x20)
>         -#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE + 0x24)
>         -#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE + 0x28)
>         -#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE + 0x2C)
>         -#define BCM2835_UART0_CR         (BCM2835_UART0_BASE + 0x30)
>         -#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE + 0x34)
>         -#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE + 0x38)
>         -#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE + 0x3C)
>         -#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE + 0x40)
>         -#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE + 0x44)
>         -#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE + 0x48)
>         -#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE + 0x80)
>         -#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE + 0x84)
>         -#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE + 0x88)
>         -#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE + 0x8C)
>         -#define BCM2835_UART0_MIS_RX    0x10
>         -#define BCM2835_UART0_MIS_TX    0x20
>         -#define BCM2835_UART0_IMSC_RX   0x10
>         -#define BCM2835_UART0_IMSC_TX   0x20
>         -#define BCM2835_UART0_FR_RXFE   0x10
>         -#define BCM2835_UART0_FR_TXFF   0x20
>         -#define BCM2835_UART0_ICR_RX    0x10
>         -#define BCM2835_UART0_ICR_TX    0x20
>         diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
>         b/bsps/arm/raspberrypi/include/bsp/usart.h
>         index d3e710c5e9..abbf53626c 100644
>         --- a/bsps/arm/raspberrypi/include/bsp/usart.h
>         +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
>         @@ -32,9 +32,8 @@
>          extern "C" {
>          #endif /* __cplusplus */
>         -#define USART0_DEFAULT_BAUD 115000
>         -extern const console_fns bcm2835_usart_fns;
>         +#define PL011_DEFAULT_BAUD 115000
>         +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE + 0x201000)
>          #ifdef __cplusplus
>         diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         index 11a22f89e3..ce91527f92 100644
>         --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>         @@ -63,14 +63,15 @@ librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
>         ../../../../../../bsps/arm/raspberrypi/irq/irq.c
>          # Console
>         -librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/shared/dev/serial/legacy-console.c
>         ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>         ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>         ../../../../../../bsps/arm/raspberrypi/console/console_select.c
>         ../../../../../../bsps/arm/raspberrypi/console/usart.c
>         ../../../../../../bsps/arm/raspberrypi/console/fb.c
>         ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
>         ../../../../../../bsps/arm/raspberrypi/console/outch.c
>         +librtemsbsp_a_SOURCES +=
>         ../../../../../../bsps/shared/dev/serial/console-termios.c
>         ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>         ../../../../../../bsps/arm/shared/serial/arm-pl011.c
>          # Mailbox
>         ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
>         2.17.1
