What do you want to study in GSOC 2020?
Niteesh gsnb.gn at gmail.com
Mon Dec 30 06:25:55 UTC 2019
On Mon, Dec 30, 2019 at 4:44 AM Peter Dufault <dufault at hda.com> wrote:
> Niteesh, what do you want to study?  Go over what most interests you most
> about working in a real-time environment like RTEMS, and not about working
> on the RPI, and look at the earlier GSOC projects. Propose an ideal project
> for yourself and get some feedback.
 I love learning about how the software and hardware interact, I have been
programming from 9th grade and have a wide variety of interests(networking,
app development). But recently I took a course called nandtotetris were we
build an 8bit computer from scratch, we start with NAND gates and finally
finish with a Tetris game. Low-level software, systems programming, and
operating systems are always quite fascinating for me. While learning about
operating systems, I came across the concepts of real-time systems. Back
then arduino was the only hardware I was having while searching for an RTOS
to play with, I came across RTEMS. RTOS was harder for me to grasp but were
always interesting, being a critical part of a system, I always wanted to
learn how they worked from inside. That's what bought me to contributing to
RTOS.
I wanted to contribute to core of RTEMS, but it was a bit complex for me to
understand, so I started with driver development for RTEMS.
After going through some of the previous GSOC projects, BSP development and
real-time tracing are what I find interesting. While also converting the
console driver of rpi to FDT based one, *Christian Mauderer *explained how
FDT worked in FreeBSD and Linux, and RTEMS lacked that infrastructure, I
have no idea of how hard it would it, and if I am even capable of
developing it. But one proposal would be to build the FDT infrastructure
similar to FreeBSD or Linux and have the driver's probe and attach to the
hardware.
> > On Dec 28, 2019, at 05:12 , Christian Mauderer <list at c-mauderer.de>
> wrote:
> > On 28/12/2019 07:12, Niteesh wrote:
> >> On Sat, 28 Dec, 2019, 3:51 AM Christian Mauderer, <list at c-mauderer.de
> >> <mailto:list at c-mauderer.de>> wrote:
> >>    On 27/12/2019 19:06, Niteesh wrote:
> >>> Is there something else that I could work on? I am interested in
> >>    taking
> >>> part
> >>> GSOC of 2020. And I want to learn as much as possible.
> >>    Do you search tasks specific to raspberry or general ones? Do you
> search
> >>    something for GSoC or just to warm up?
> >> Anything is fine as long as I am learning something. Since rpi3 is the
> >> only hardware I have, I am interested in tasks specific to raspi and
> >> general ones which do not require any hardware.
> > For raspberry I think you could continue to get it running on RPi3. My
> > suggestion would be to replace the table based initialization (which is
> > handled by console-termios-init.c) with one based on the fdt that is
> > similar to the one in the imx BSP. That will allow to use the same
> > binary on RPi2 and RPi3. But please do that in an extra patch after the
> > one that you currently have sent to the mailing list.
> > Some other raspberry specific topics could be the following. Note that
> > this are only suggestions. I don't want to force you to do any of them
> > if you don't like them:
> > - Documentation how you run an application in QEMU / on real hardware
> > for the user manual:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
> > (I hope I didn't miss a patch that you already sent ;-) )
> > - A configuration for RTEMS tester that uses the QEMU or real hardware
> > (I think the pi3 allows network boot?). This allows regular test runs
> > for this BSP:
> > https://docs.rtems.org/branches/master/user/testing/index.html and
> > https://docs.rtems.org/branches/master/user/tools/tester.html
> > - Chris created a boot image generator last year. It would be great if
> > you could add a configuration to create raspberry SD images to it:
> > https://docs.rtems.org/branches/master/user/tools/boot-image.html
> > - You can pick basically any component that isn't already there and
> > integrate it. If you want to work with libbsd: Testing or porting
> > Ethernet support could be something.
> > - You most likely want to do something with RPi in your GSoC too. So
> > maybe some comments ("x is already done", "y seems to be still open")
> > for the ticket for it would be nice too:
> https://devel.rtems.org/ticket/2899
> > For non raspberry topics: We have a lot of open bugs where everyone is
> > happy if they are closed: https://devel.rtems.org/query
> > A lot of them might are even out of date and just need someone who reads
> > them and asks whether they can be closed.
> >>> On Fri, Dec 27, 2019 at 5:07 PM Christian Mauderer
> >>    <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >>> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >>>      On 27/12/2019 12:20, Niteesh wrote:
> >>>      > I have sent the patch. I also sent a documentation update
> >>    for the
> >>>      > quick-start section
> >>>      > a few months ago. But no one took a look at it. Can you have a
> >>>      look at it?
> >>>      I'll try to have a look at it soon.
> >>>      > https://www.mail-archive.com/devel@rtems.org/msg20965.html
> >>>      If you don't get any responses to a patch please just send a
> >>    reminder
> >>>      one or two weeks later. It's quite likely that the patch just
> >>    slipped
> >>>      the attention.
> >>>      Normally I leave documentation patches to our native speakers.
> >>    They spot
> >>>      a lot of errors that I won't be able to find.
> >>>      Can you please send a ping for the patch. You can add me to CC
> >>    and for
> >>>      this one I would suggest to CC Chris Johns too.
> > devel mailing list
> > devel at rtems.org
> Peter
> Peter Dufault
> HD Associates, Inc.      Software and System Engineering
> This email is delivered through the public internet using protocols
> subject to interception and tampering.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191230/d27b5793/attachment-0001.html>
