What do you want to study in GSOC 2020?
Niteesh gsnb.gn at gmail.com
Mon Dec 30 14:45:39 UTC 2019
On Mon, Dec 30, 2019 at 7:14 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 30/12/2019 07:25, Niteesh wrote:
> > On Mon, Dec 30, 2019 at 4:44 AM Peter Dufault <dufault at hda.com
> > <mailto:dufault at hda.com>> wrote:
> >     Niteesh, what do you want to study?  Go over what most interests you
> >     most about working in a real-time environment like RTEMS, and not
> >     about working on the RPI, and look at the earlier GSOC projects.
> >     Propose an ideal project for yourself and get some feedback.
> Peter: Thanks for starting that discussion. I started to focus too much
> on the running topics about small stuff that can be done as a preparation.
> >  I love learning about how the software and hardware interact, I have
> > been programming from 9th grade and have a wide variety of
> > interests(networking, app development). But recently I took a course
> > called nandtotetris were we build an 8bit computer from scratch, we
> > start with NAND gates and finally finish with a Tetris game.
> That sounds like a really nice course. Most likely is ended in a bigger
> pile of circuit boards to have a running processor ;-)
It is a free course on coursera
https://www.coursera.org/learn/build-a-computer/home/welcome
do check it out. It's completely simulated in software. But planning to
build it on PCB.
> > Low-level
> > software, systems programming, and operating systems are always quite
> > fascinating for me. While learning about operating systems, I came
> > across the concepts of real-time systems. Back then arduino was the only
> > hardware I was having while searching for an RTOS to play with, I came
> > across RTEMS. RTOS was harder for me to grasp but were always
> > interesting, being a critical part of a system, I always wanted to learn
> > how they worked from inside. That's what bought me to contributing to
> RTOS.
> > I wanted to contribute to core of RTEMS, but it was a bit complex for me
> > to understand, so I started with driver development for RTEMS.
> That's where I started too. But don't hesitate to pick a more complex
> topic if you are interested in it. From what I've seen you can read and
> understand existing code quite fast compared to some other GSoC students
> we had. So I would say that you have a good chance to manage complex
> topics too.
Thank you, it's quite good to hear.
> > After going through some of the previous GSOC projects, BSP development
> > and real-time tracing are what I find interesting. While also converting
> > the console driver of rpi to FDT based one, *Christian Mauderer
> > *explained how
> > FDT worked in FreeBSD and Linux, and RTEMS lacked that infrastructure, I
> > have no idea of how hard it would it, and if I am even capable of
> > developing it. But one proposal would be to build the FDT infrastructure
> > similar to FreeBSD or Linux and have the driver's probe and attach to
> > the hardware.
> We start to have more and more FDT based BSPs. So it would be great if
> our infrastructure would improve. But like I said: Don't hesitate to
> pick any other topic. Device drivers (and similar) are low hanging fruit
> where it is easy to get success and it isn't very likely to start long
> tedious discussions because you only touch one BSP. Therefore I tend to
> suggest them for GSoC. But GSoC isn't limited to that.
> So if you would like to work at any other topic like (for example)
> porting a new architecture, hacking on some scheduler, do something with
> the dynamic linking support, add stuff to the libdebugger, or basically
> anything else: Just ask whether someone knows a topic in that area or is
> interested in mentoring one you suggest. Most likely the mailing list
> will become quite a bit more active again in about a week.
Once I finish with the raspberry pi, I will try to port RTEMS for esp32. I
have that board,
It has quite a lot of features and really good documentation. It is based
on xtensa CPU.
https://devel.rtems.org/wiki/TBR/UserManual/SupportedCPUs and is under
RTEMS potential port.
> >     > On Dec 28, 2019, at 05:12 , Christian Mauderer <list at c-mauderer.de
> >     <mailto:list at c-mauderer.de>> wrote:
> >     > On 28/12/2019 07:12, Niteesh wrote:
> >     >> On Sat, 28 Dec, 2019, 3:51 AM Christian Mauderer,
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     >> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >>    On 27/12/2019 19:06, Niteesh wrote:
> >     >>> Is there something else that I could work on? I am interested in
> >     >>    taking
> >     >>> part
> >     >>> GSOC of 2020. And I want to learn as much as possible.
> >     >>    Do you search tasks specific to raspberry or general ones? Do
> >     you search
> >     >>    something for GSoC or just to warm up?
> >     >> Anything is fine as long as I am learning something. Since rpi3
> >     is the
> >     >> only hardware I have, I am interested in tasks specific to raspi
> and
> >     >> general ones which do not require any hardware.
> >     > For raspberry I think you could continue to get it running on
> RPi3. My
> >     > suggestion would be to replace the table based initialization
> >     (which is
> >     > handled by console-termios-init.c) with one based on the fdt that
> is
> >     > similar to the one in the imx BSP. That will allow to use the same
> >     > binary on RPi2 and RPi3. But please do that in an extra patch
> >     after the
> >     > one that you currently have sent to the mailing list.
> >     > Some other raspberry specific topics could be the following. Note
> that
> >     > this are only suggestions. I don't want to force you to do any of
> them
> >     > if you don't like them:
> >     > - Documentation how you run an application in QEMU / on real
> hardware
> >     > for the user manual:
> https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#raspberrypi
> >     > (I hope I didn't miss a patch that you already sent ;-) )
> >     > - A configuration for RTEMS tester that uses the QEMU or real
> hardware
> >     > (I think the pi3 allows network boot?). This allows regular test
> runs
> >     > for this BSP:
> >     > https://docs.rtems.org/branches/master/user/testing/index.html and
> >     > https://docs.rtems.org/branches/master/user/tools/tester.html
> >     > - Chris created a boot image generator last year. It would be
> great if
> >     > you could add a configuration to create raspberry SD images to it:
> >     > https://docs.rtems.org/branches/master/user/tools/boot-image.html
> >     > - You can pick basically any component that isn't already there and
> >     > integrate it. If you want to work with libbsd: Testing or porting
> >     > Ethernet support could be something.
> >     > - You most likely want to do something with RPi in your GSoC too.
> So
> >     > maybe some comments ("x is already done", "y seems to be still
> open")
> >     > for the ticket for it would be nice too:
> >     https://devel.rtems.org/ticket/2899
> >     > For non raspberry topics: We have a lot of open bugs where
> everyone is
> >     > happy if they are closed: https://devel.rtems.org/query
> >     > A lot of them might are even out of date and just need someone who
> >     reads
> >     > them and asks whether they can be closed.
> >     >>> On Fri, Dec 27, 2019 at 5:07 PM Christian Mauderer
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >     >>>      On 27/12/2019 12:20, Niteesh wrote:
> >     >>>      > I have sent the patch. I also sent a documentation update
> >     >>    for the
> >     >>>      > quick-start section
> >     >>>      > a few months ago. But no one took a look at it. Can you
> >     have a
> >     >>>      look at it?
> >     >>>      I'll try to have a look at it soon.
> https://www.mail-archive.com/devel@rtems.org/msg20965.html
> >     >>>      If you don't get any responses to a patch please just send a
> >     >>    reminder
> >     >>>      one or two weeks later. It's quite likely that the patch
> just
> >     >>    slipped
> >     >>>      the attention.
> >     >>>      Normally I leave documentation patches to our native
> speakers.
> >     >>    They spot
> >     >>>      a lot of errors that I won't be able to find.
> >     >>>      Can you please send a ping for the patch. You can add me to
> CC
> >     >>    and for
> >     >>>      this one I would suggest to CC Chris Johns too.
> >     > _______________________________________________
> >     > devel mailing list
> >     > devel at rtems.org <mailto:devel at rtems.org>
> >     > http://lists.rtems.org/mailman/listinfo/devel
> >     Peter
> >     Peter Dufault
> >     HD Associates, Inc.      Software and System Engineering
> >     This email is delivered through the public internet using protocols
> >     subject to interception and tampering.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191230/7003ce0c/attachment-0001.html>
