[PATCH v4] Raspberrypi: updated the console interface.
Christian Mauderer
list at c-mauderer.de
Tue Dec 31 13:02:05 UTC 2019
On 31/12/2019 13:22, Niteesh wrote:
> It works now, the functions are getting called when used with fileio.exe.
> The function bsp_start wants to print information about the board,
That print maybe should be moved to a later point. It just fetches some
information and prints it. It doesn't even do anything usefull besides that.
> but
> the console
> initialization function is called after bsp_start, assuming that the FDT
> works it still
> crash since the console still isn't initialized, one way of fixing this
> would be to add uart_probe into
> output_char just like in imx, or we could move the printing to somewhere
> else.
That might would be a good idea regardless whether the print is moved or
not. It would allow an early exception to print anything.
> On Tue, Dec 31, 2019 at 4:08 PM Christian Mauderer <list at c-mauderer.de
> <mailto:list at c-mauderer.de>> wrote:
> On 31/12/2019 11:37, Christian Mauderer wrote:
> > On 31/12/2019 06:11, Niteesh wrote:
> >> On Tue, Dec 31, 2019 at 1:13 AM Christian Mauderer
> <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >> <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >> On 30/12/2019 19:32, Niteesh wrote:
> >> > Just to make sure that console_initialize and uart_probe
> are being
> >> > called, I manually initialized the pl011 context to print
> something on
> >> > serial. But they never got called. Can you just make sure
> that if I am
> >> > missing something?
> >> I don't think that you are missing something but the
> executable is
> >> missing something: The functions are not linked into it.
> >> C linker can be an odd thing: It links only object files that are
> >> referenced. You seem to have no reference to
> console-config.c/o from
> >> anywhere else.
> >> RTEMS_SYSINIT_ITEM(
> >> uart_probe,
> >> RTEMS_SYSINIT_BSP_START,
> >> RTEMS_SYSINIT_ORDER_LAST
> >> will be only added to the linker set if the file is linked in
> anyway.
> >> That is a bit anoying. For the imx BSP there is a UART drain
> function
> >> that is called from somewhere else. Thats enough to bring the
> file in.
> >> I think you'll need to add a reference from somewhere or move
> that stuff
> >> into another file that is referenced.
> >> If you have some init function that has to be called in every
> case you
> >> can call it from some other c file where it would fit too.
> >> Otherwise it might is necessary to construct some odd stuff.
> I'm not
> >> sure whether we already had a case like this. Most likely it
> would be
> >> necessary to use a RTEMS_LINKER_ROSET_ITEM_REFERENCE for the
> >> SYSINIT_ITEM. Maybe to define a new
> RTEMS_SYSINIT_ITEM_REFERENCE or
> >> simmilar. This should be definitively a separate commit.
> Please ask
> >> again if you have to go that way.
> >> I didn't understand the above part. So what I did was created a dummy
> >> function in console-config.c
> >> and referenced in places that I know we're going to be called. But
> >> still, it didn't work.
> > That's a really mean bug to find:
> > 1. My assumption was wrong. The file is linked in. Most likely due to
> > BSP_output_char which is defined in this file.
> > 2. Please remove console-termios-init.c. It would define the same
> > console_initialize() function.
> Just to be clear: Remove it from the
> c/src/lib/libbsp/arm/raspberrypi/Makefile.am file.
> > 3. The real proble just caused a warning which was a bit hard to spot:
> > The compile doesn't know RTEMS_SYSINIT_ITEM. It thinks it's a function
> > body and warns that it defaults the return type to int. In other
> words:
> > You missed to include <rtems/sysinit.h>. If you add that the
> > RTEMS_SYSINIT_ITEM works and uart_probe is linked in.
> > 4. console_initialize is still not used. It is really hard to spot
> why:
> > Most of the tests only use the configuration:
> > CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > This is a simplified polled console driver. From the samples only
> > capture, fileio and pppd are using the normal console with:
> > CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > So only for these three the console_initialize will be called.
> > By the way: You can use objdump to analyze your elf-files. For example
> > to get a symbol table use:
> > arm-rtems5-objdump -t path/to/ticker.exe
> > To get the disassembled code with intermixed c-sources use
> > arm-rtems5-objdump -dS path/to/ticker.exe
> > That's very usefull to find whether a symbol is linked in or not.
> >> > While going through the messages from devel-request, Joel
> mentioned
> >> > about qemu4 rsb package
> >> > how is it different from the official qemu?
> >> > On Mon, Dec 30, 2019 at 11:53 PM G S Niteesh
> <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> >> <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
> <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>> wrote:
> >> > The patch updates the older console interface used by
> the BSP,
> >> > to newer one. It also replaces the custom usart(PL011)
> driver
> >> > with arm-pl011. The fb function's signatures where also
> changed
> >> > to accommodate with interface update.
> >> > Update #3034
> >> > bsps/arm/raspberrypi/console/console-config.c | 186
> >> > bsps/arm/raspberrypi/console/console_select.c | 114
> >> > bsps/arm/raspberrypi/console/fbcons.c | 78
> >> > bsps/arm/raspberrypi/console/usart.c | 167
> >> > bsps/arm/raspberrypi/include/bsp/fbcons.h | 21 +-
> >> > .../arm/raspberrypi/include/bsp/raspberrypi.h | 48 ++---
> >> > bsps/arm/raspberrypi/include/bsp/usart.h | 5 +-
> >> > c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 8 +-
> >> > 8 files changed, 220 insertions(+), 407 deletions(-)
> >> > delete mode 100644
> >> > delete mode 100644 bsps/arm/raspberrypi/console/usart.c
> >> > diff --git a/bsps/arm/raspberrypi/console/console-config.c
> >> > b/bsps/arm/raspberrypi/console/console-config.c
> >> > index d2186c918b..021428ff4b 100644
> >> > --- a/bsps/arm/raspberrypi/console/console-config.c
> >> > +++ b/bsps/arm/raspberrypi/console/console-config.c
> >> > @@ -19,50 +19,164 @@
> >> > #include <rtems/bspIo.h>
> >> > +#include <rtems/console.h>
> >> > -#include <libchip/serial.h>
> >> > -#include <bspopts.h>
> >> > -#include <bsp/irq.h>
> >> > -#include <bsp/usart.h>
> >> > +#include <bsp.h>
> >> > #include <bsp/raspberrypi.h>
> >> > +#include <bsp/usart.h>
> >> > +#include <bsp/arm-pl011.h>
> >> > #include <bsp/fbcons.h>
> >> > +#include <bsp/console-termios.h>
> >> > +#include <bsp/fdt.h>
> >> > +#include <bsp/fatal.h>
> >> > +#include <bspopts.h>
> >> > +#include <libfdt.h>
> >> > +#include <libchip/serial.h>
> >> > +arm_pl011_context pl011_context;
> >> > +rpi_fb_context fb_context;
> >> These could be static.
> >> > +static void output_char_serial(char c)
> >> > + arm_pl011_write_polled(&pl011_context.base, c);
> >> > +void output_char_fb(char c)
> >> > + fbcons_write_polled(&fb_context.base, c);
> >> > -console_tbl Console_Configuration_Ports [] = {
> >> > - .sDeviceName = "/dev/ttyS0",
> >> > - .deviceType = SERIAL_CUSTOM,
> >> > - .pDeviceFns = &bcm2835_usart_fns,
> >> > - .deviceProbe = NULL,
> >> > - .pDeviceFlow = NULL,
> >> > - .ulCtrlPort1 = BCM2835_UART0_BASE,
> >> > - .ulCtrlPort2 = 0,
> >> > - .ulClock = USART0_DEFAULT_BAUD,
> >> > - .ulIntVector = BCM2835_IRQ_ID_UART
> >> > - .sDeviceName ="/dev/fbcons",
> >> > - .pDeviceFns = &fbcons_fns,
> >> > - .deviceProbe = fbcons_probe,
> >> > -#define PORT_COUNT \
> >> > - (sizeof(Console_Configuration_Ports) \
> >> > - / sizeof(Console_Configuration_Ports [0]))
> >> > -unsigned long Console_Configuration_Count = PORT_COUNT;
> >> > -static void output_char(char c)
> >> > +static void *get_reg_of_node(const void *fdt, int node)
> >> > - const console_fns *con =
> >> > - Console_Configuration_Ports
> [Console_Port_Minor].pDeviceFns;
> >> > + int len;
> >> > + const uint32_t *val;
> >> > + val = fdt_getprop(fdt, node, "reg", &len);
> >> > + if (val == NULL || len < 4) {
> >> > + return NULL;
> >> > - con->deviceWritePolled((int) Console_Port_Minor, c);
> >> > + return (void *) fdt32_to_cpu(val[0]);
> >> > -BSP_output_char_function_type BSP_output_char =
> output_char;
> >> > +static void register_arm_pl011(
> >> > + const void *fdt,
> >> > + const char *serial
> >> > + arm_pl011_context *ctx = &pl011_context;
> >> > + int node;
> >> > + if (strcmp(serial, "uart0") == 0) {
> rtems_termios_device_context_initialize(&ctx->base, "UART");
> >> > + node = fdt_path_offset(fdt, serial);
> >> > + ctx->regs = get_reg_of_node(fdt, node);
> >> > + rtems_termios_device_install(
> >> > + "/dev/ttyuart0",
> >> > + &arm_pl011_fns,
> >> > + NULL,
> >> > + &pl011_context.base
> >> > +static void register_fb( void )
> >> > + if (fbcons_probe(&fb_context.base) == true) {
> >> > + "/dev/fbcons",
> >> > + &fbcons_fns,
> >> > + NULL,
> >> > + &fb_context.base);
> >> > +static void console_select( const char *console )
> >> > + const char *opt;
> >> > + opt = rpi_cmdline_get_arg("--console=");
> >> > + if ( opt ) {
> >> > + if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) -
> 1 ) ==
> >> 0 ) {
> >> > + if ( rpi_video_is_initialized() > 0 ) {
> >> > + BSP_output_char = output_char_fb;
> >> > + link("/dev/fbcons", CONSOLE_DEVICE_NAME);
> >> > + }else{
> >> > + if ( console == NULL ){
> >> > + bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >> > + BSP_output_char = output_char_serial;
> >> > + link("/dev/ttyuart0", CONSOLE_DEVICE_NAME);
> >> > +static void uart_probe(void)
> >> > + const void *fdt;
> >> > + const char *console;
> >> > + int node;
> >> > + fdt = bsp_fdt_get();
> >> > + node = fdt_path_offset(fdt, "/chosen");
> >> > + console = fdt_getprop(fdt, node, "stdout-path", NULL);
> >> > + node = fdt_path_offset(fdt, "/aliases");
> >> > + int offset = fdt_first_property_offset(fdt, node);
> >> > + while (offset >= 0) {
> >> > + const struct fdt_property *prop;
> >> > + prop = fdt_get_property_by_offset(fdt, offset, NULL);
> >> > + if (prop != NULL) {
> >> > + const char *name;
> >> > + name = fdt_string(fdt, fdt32_to_cpu(prop->nameoff));
> >> > + if(strstr(name, "serial") != NULL) {
> >> > + const char *serial;
> >> > + serial = prop->data;
> >> > + register_arm_pl011(fdt, serial);
> >> > + offset = fdt_next_property_offset(fdt, offset);
> >> > + console_select(console);
> >> > +rtems_status_code console_initialize(
> >> > + rtems_device_major_number major,
> >> > + rtems_device_minor_number minor,
> >> > + void *arg
> >> > + rtems_termios_initialize();
> >> > + uart_probe();
> >> > + register_fb();
> >> > + return RTEMS_SUCCESSFUL;
> >> > +BSP_output_char_function_type BSP_output_char =
> >> output_char_serial;
> >> > BSP_polling_getchar_function_type BSP_poll_char = NULL;
> >> > +RTEMS_SYSINIT_ITEM(
> >> > + uart_probe,
> >> > + RTEMS_SYSINIT_BSP_START,
> >> > + RTEMS_SYSINIT_ORDER_LAST
> >> > \ No newline at end of file
> >> > diff --git a/bsps/arm/raspberrypi/console/console_select.c
> >> > b/bsps/arm/raspberrypi/console/console_select.c
> >> > deleted file mode 100644
> >> > index bd246ca868..0000000000
> >> > --- a/bsps/arm/raspberrypi/console/console_select.c
> >> > +++ /dev/null
> >> > @@ -1,114 +0,0 @@
> >> > - * @file
> >> > - * @ingroup raspberrypi_console
> >> > - * @brief console select
> >> > - * Copyright (c) 2015 Yang Qiao
> >> > - * The license and distribution terms for this file
> may be
> >> > - * found in the file LICENSE in this distribution or at
> >> > - * http://www.rtems.org/license/LICENSE
> >> > -#include <bsp.h>
> >> > -#include <bsp/fatal.h>
> >> > -#include <rtems/libio.h>
> >> > -#include <stdlib.h>
> >> > -#include <string.h>
> >> > -#include <assert.h>
> >> > -#include <termios.h>
> >> > -#include <rtems/termiostypes.h>
> >> > -#include "../../shared/dev/serial/legacy-console.h"
> >> > -#include <bsp/rpi-fb.h>
> >> > -rtems_device_minor_number BSPPrintkPort = 0;
> >> > - * Method to return true if the device associated with the
> >> > - * minor number probs available.
> >> > -static bool bsp_Is_Available(
> rtems_device_minor_number minor )
> >> > - console_tbl *cptr = Console_Port_Tbl[ minor ];
> >> > - * First perform the configuration dependent probe,
> then the
> >> > - * device dependent probe
> >> > - if ( ( !cptr->deviceProbe || cptr->deviceProbe(
> minor ) ) &&
> >> > - cptr->pDeviceFns->deviceProbe( minor ) ) {
> >> > - return true;
> >> > - return false;
> >> > - * Method to return the first available device.
> >> > -static rtems_device_minor_number
> bsp_First_Available_Device(
> >> void )
> >> > - rtems_device_minor_number minor;
> >> > - for ( minor = 0; minor < Console_Port_Count; minor++ ) {
> probe, then the
> minor ) ) &&
> >> > - return minor;
> >> > - * Error No devices were found. We will want to
> bail here.
> >> > - bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >> > -void bsp_console_select( void )
> >> > - * Reset Console_Port_Minor and
> >> > - * BSPPrintkPort here if desired.
> >> > - * This default version allows the bsp to set these
> >> > - * values at creation and will not touch them again
> >> > - * unless the selected port number is not available.
> >> > - const char *opt;
> >> > - Console_Port_Minor = BSP_CONSOLE_UART0;
> >> > - BSPPrintkPort = BSP_CONSOLE_UART0;
> >> > - opt = rpi_cmdline_get_arg( "--console=" );
> >> > - if ( opt ) {
> >> > - if ( strncmp( opt, "fbcons", sizeof( "fbcons" ) -
> 1 ) ==
> >> 0 ) {
> >> > - if ( rpi_video_is_initialized() > 0 ) {
> >> > - Console_Port_Minor = BSP_CONSOLE_FB;
> >> > - BSPPrintkPort = BSP_CONSOLE_FB;
> >> > - * If the device that was selected isn't available then
> >> > - * let the user know and select the first available
> device.
> >> > - if ( !bsp_Is_Available( Console_Port_Minor ) ) {
> >> > - Console_Port_Minor = bsp_First_Available_Device();
> >> > diff --git a/bsps/arm/raspberrypi/console/fbcons.c
> >> > b/bsps/arm/raspberrypi/console/fbcons.c
> >> > index 3669ba458d..0e6a430c54 100644
> >> > --- a/bsps/arm/raspberrypi/console/fbcons.c
> >> > +++ b/bsps/arm/raspberrypi/console/fbcons.c
> >> > @@ -18,6 +18,7 @@
> >> > #include <rtems.h>
> >> > +#include <rtems/termiostypes.h>
> >> > #include <stdlib.h>
> >> > @@ -29,15 +30,6 @@
> >> > #include <bsp/vc.h>
> >> > - * fbcons_init
> >> > - * This function initializes the fb console to a
> quiecsent
> >> state.
> >> > -static void fbcons_init( int minor )
> >> > * fbcons_open
> >> > @@ -45,13 +37,14 @@ static void fbcons_init( int minor )
> >> > * Default state is 9600 baud, 8 bits, No parity, and
> 1 stop
> >> bit.
> >> > -static int fbcons_open(
> >> > - int major,
> >> > - int minor,
> >> > - void *arg
> >> > +static bool fbcons_open(
> >> > + struct rtems_termios_tty *tty,
> >> > + rtems_termios_device_context *base,
> >> > + struct termios *term,
> >> > + rtems_libio_open_close_args_t *args
> >> > - return RTEMS_SUCCESSFUL;
> >> > + return true;
> >> > @@ -59,13 +52,12 @@ static int fbcons_open(
> >> > * This function shuts down the requested port.
> >> > -static int fbcons_close(
> >> > - int major,
> >> > - int minor,
> >> > - void *arg
> >> > +static void fbcons_close(
> >> > - return ( RTEMS_SUCCESSFUL );
> >> > @@ -73,8 +65,8 @@ static int fbcons_close(
> >> > * This routine polls out the requested character.
> >> > -static void fbcons_write_polled(
> >> > - int minor,
> >> > +void fbcons_write_polled(
> >> > char c
> >> > @@ -90,8 +82,8 @@ static void fbcons_write_polled(
> >> > * Console Termios output entry point when using
> polled output.
> >> > -static ssize_t fbcons_write_support_polled(
> >> > - int minor,
> >> > +static void fbcons_write_support_polled(
> >> > const char *buf,
> >> > size_t len
> >> > @@ -102,14 +94,9 @@ static ssize_t
> >> > * poll each byte in the string out of the port.
> >> > while ( nwrite < len ) {
> >> > - fbcons_write_polled( minor, *buf++ );
> >> > + fbcons_write_polled( base, *buf++ );
> >> > nwrite++;
> >> > - * return the number of bytes written.
> >> > - return nwrite;
> >> > @@ -117,7 +104,9 @@ static ssize_t
> >> > * Console Termios polling input entry point.
> >> > -static int fbcons_inbyte_nonblocking_polled( int minor )
> >> > +int fbcons_inbyte_nonblocking_polled(
> >> > // if( rtems_kbpoll() ) {
> >> > // int c = getch();
> >> > @@ -133,15 +122,17 @@ static int
> >> > int minor )
> >> > * This function sets the UART channel to reflect the
> requested
> >> > termios
> >> > * port settings.
> >> > -static int fbcons_set_attributes(
> >> > - int minor,
> >> > +static bool fbcons_set_attributes(
> >> > const struct termios *t
> >> > - return 0;
> >> > + return true;
> >> > -bool fbcons_probe( int minor )
> >> > +bool fbcons_probe(
> >> > + rtems_termios_device_context *context
> >> > // rtems_status_code status;
> >> > static bool firstTime = true;
> >> > @@ -163,15 +154,12 @@ bool fbcons_probe( int minor )
> >> > return ret;
> >> > -const console_fns fbcons_fns =
> >> > +const rtems_termios_device_handler fbcons_fns =
> >> > - .deviceProbe = libchip_serial_default_probe, /*
> >> deviceProbe */
> >> > - .deviceFirstOpen = fbcons_open, /*
> >> deviceFirstOpen */
> >> > - .deviceLastClose = fbcons_close, /*
> >> deviceLastClose */
> >> > - .deviceRead = fbcons_inbyte_nonblocking_polled, /*
> >> deviceRead */
> >> > - .deviceWrite = fbcons_write_support_polled, /*
> >> deviceWrite */
> >> > - .deviceInitialize = fbcons_init, /*
> >> > deviceInitialize */
> >> > - .deviceWritePolled = fbcons_write_polled, /*
> >> > deviceWritePolled */
> >> > - .deviceSetAttributes = fbcons_set_attributes, /*
> >> > deviceSetAttributes */
> >> > - .deviceOutputUsesInterrupts = FALSE, /*
> >> > deviceOutputUsesInterrupts*/
> >> > + .first_open = fbcons_open,
> >> > + .last_close = fbcons_close,
> >> > + .poll_read = fbcons_inbyte_nonblocking_polled,
> >> > + .write = fbcons_write_support_polled,
> >> > + .set_attributes = fbcons_set_attributes,
> >> > + .mode = TERMIOS_POLLED
> >> > diff --git a/bsps/arm/raspberrypi/console/usart.c
> >> > b/bsps/arm/raspberrypi/console/usart.c
> >> > index 25fb523621..0000000000
> >> > --- a/bsps/arm/raspberrypi/console/usart.c
> >> > +++ /dev/null
> >> > @@ -1,167 +0,0 @@
> >> > - * @file
> >> > - * @ingroup raspberrypi_usart
> >> > - * @brief USART support.
> >> > - * Copyright (c) 2013 Alan Cudmore
> may be
> >> > -#include <libchip/sersupp.h>
> >> > -#include <bsp.h>
> >> > -#include <bsp/raspberrypi.h>
> >> > -#include <rtems/bspIo.h>
> >> > -static void usart_delay(uint32_t n)
> >> > - volatile uint32_t i = 0;
> >> > - for(i = 0; i < n; i++)
> >> > -#if 0
> >> > - * These will be useful when the driver supports
> interrupt
> >> driven IO.
> >> > -static rtems_vector_number usart_get_irq_number(const
> >> console_tbl *ct)
> >> > - return ct->ulIntVector;
> >> > -static uint32_t usart_get_baud(const console_tbl *ct)
> >> > - return ct->ulClock;
> >> > -#endif
> >> > -static void usart_set_baud(int minor, int baud)
> >> > - * Nothing for now
> >> > - return;
> >> > -static void usart_initialize(int minor)
> >> > - unsigned int gpio_reg;
> >> > - ** Program GPIO pins for UART 0
> >> > - gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> >> > - gpio_reg &= ~(7<<12); /* gpio14 */
> >> > - gpio_reg |= (4<<12); /* alt0 */
> >> > - gpio_reg &= ~(7<<15); /* gpio15 */
> >> > - gpio_reg |= (4<<15); /* alt0 */
> >> > - BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> >> > - BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> >> > - usart_delay(150);
> >> > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
> >> > - usart_delay(150);
> >> > - BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> >> > - ** Init the PL011 UART
> >> > - BCM2835_REG(BCM2835_UART0_CR) = 0;
> >> > - BCM2835_REG(BCM2835_UART0_ICR) = 0x7FF;
> >> > - BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> >> > - BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> >> > - BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> >> > - BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> >> > - BCM2835_REG(BCM2835_UART0_RSRECR) = 0;
> >> > - BCM2835_REG(BCM2835_UART0_CR) = 0x301;
> >> > - BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
> >> > - usart_set_baud(minor, 115000);
> >> > -static int usart_first_open(int major, int minor, void
> *arg)
> >> > - rtems_libio_open_close_args_t *oc =
> >> > (rtems_libio_open_close_args_t *) arg;
> >> > - struct rtems_termios_tty *tty = (struct
> rtems_termios_tty *)
> >> > oc->iop->data1;
> >> > - const console_tbl *ct = Console_Port_Tbl [minor];
> >> > - console_data *cd = &Console_Port_Data [minor];
> >> > - cd->termios_data = tty;
> >> > - rtems_termios_set_initial_baud(tty, ct->ulClock);
> >> > - return 0;
> >> > -static int usart_last_close(int major, int minor, void
> *arg)
> >> > - return 0;
> >> > -static int usart_read_polled(int minor)
> >> > - if (minor == 0) {
> >> > - if (((BCM2835_REG(BCM2835_UART0_FR)) &
> BCM2835_UART0_FR_RXFE)
> >> > == 0) {
> >> > - return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
> >> > - } else {
> >> > - return -1;
> >> > - } else {
> >> > - printk("Unknown console minor number: %d\n", minor);
> >> > - return -1;
> >> > -static void usart_write_polled(int minor, char c)
> >> > - while (1) {
> >> > - if ((BCM2835_REG(BCM2835_UART0_FR) &
> >> BCM2835_UART0_FR_TXFF) == 0)
> >> > - break;
> >> > - BCM2835_REG(BCM2835_UART0_DR) = c;
> >> > -static ssize_t usart_write_support_polled(
> >> > - int minor,
> >> > - const char *s,
> >> > - size_t n
> >> > - ssize_t i = 0;
> >> > - for (i = 0; i < n; ++i) {
> >> > - usart_write_polled(minor, s [i]);
> >> > - return n;
> >> > -static int usart_set_attributes(int minor, const struct
> >> termios *term)
> >> > - return -1;
> >> > -const console_fns bcm2835_usart_fns = {
> >> > - .deviceFirstOpen = usart_first_open,
> >> > - .deviceLastClose = usart_last_close,
> >> > - .deviceRead = usart_read_polled,
> >> > - .deviceWrite = usart_write_support_polled,
> >> > - .deviceInitialize = usart_initialize,
> >> > - .deviceWritePolled = usart_write_polled,
> >> > - .deviceSetAttributes = usart_set_attributes,
> >> > - .deviceOutputUsesInterrupts = false
> >> > diff --git a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >> > b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >> > index d0e126699a..9bdb4b115e 100644
> >> > --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >> > +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >> > @@ -33,12 +33,29 @@ extern "C" {
> >> > #define FB_CONSOLE 0x50492835
> >> > -bool fbcons_probe( int minor );
> >> > +bool fbcons_probe(
> >> > + char c
> >> > +void output_char_fb(char c);
> >> > +typedef struct {
> >> > + rtems_termios_device_context base;
> >> > +} rpi_fb_context ;
> >> > * Driver function table
> >> > -extern const console_fns fbcons_fns;
> >> > +extern const rtems_termios_device_handler fbcons_fns;
> >> > #ifdef __cplusplus
> >> > diff --git a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >> > b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >> > index 40c80cf408..e052c2becb 100644
> >> > --- a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >> > +++ b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >> > @@ -24,6 +24,7 @@
> >> > #include <stdint.h>
> >> > #include <bsp/utility.h>
> >> > * @defgroup raspberrypi_reg Register Definitions
> >> > @@ -60,6 +61,17 @@
> >> > #define RPI_PERIPHERAL_SIZE 0x01000000
> >> > + * @name Console select definitions
> >> > +#define PL011 0
> >> > +#define FB 1
> >> > * @name Internal ARM Timer Registers
> >> > @@ -184,42 +196,6 @@
> >> > - * @name UART 0 (PL011) Registers
> >> > -#define BCM2835_UART0_BASE (RPI_PERIPHERAL_BASE
> + 0x201000)
> >> > -#define BCM2835_UART0_DR (BCM2835_UART0_BASE +
> 0x00)
> >> > -#define BCM2835_UART0_RSRECR (BCM2835_UART0_BASE +
> 0x04)
> >> > -#define BCM2835_UART0_FR (BCM2835_UART0_BASE +
> 0x18)
> >> > -#define BCM2835_UART0_ILPR (BCM2835_UART0_BASE +
> 0x20)
> >> > -#define BCM2835_UART0_IBRD (BCM2835_UART0_BASE +
> 0x24)
> >> > -#define BCM2835_UART0_FBRD (BCM2835_UART0_BASE +
> 0x28)
> >> > -#define BCM2835_UART0_LCRH (BCM2835_UART0_BASE +
> 0x2C)
> >> > -#define BCM2835_UART0_CR (BCM2835_UART0_BASE +
> 0x30)
> >> > -#define BCM2835_UART0_IFLS (BCM2835_UART0_BASE +
> 0x34)
> >> > -#define BCM2835_UART0_IMSC (BCM2835_UART0_BASE +
> 0x38)
> >> > -#define BCM2835_UART0_RIS (BCM2835_UART0_BASE +
> 0x3C)
> >> > -#define BCM2835_UART0_MIS (BCM2835_UART0_BASE +
> 0x40)
> >> > -#define BCM2835_UART0_ICR (BCM2835_UART0_BASE +
> 0x44)
> >> > -#define BCM2835_UART0_DMACR (BCM2835_UART0_BASE +
> 0x48)
> >> > -#define BCM2835_UART0_ITCR (BCM2835_UART0_BASE +
> 0x80)
> >> > -#define BCM2835_UART0_ITIP (BCM2835_UART0_BASE +
> 0x84)
> >> > -#define BCM2835_UART0_ITOP (BCM2835_UART0_BASE +
> 0x88)
> >> > -#define BCM2835_UART0_TDR (BCM2835_UART0_BASE +
> 0x8C)
> >> > -#define BCM2835_UART0_MIS_RX 0x10
> >> > -#define BCM2835_UART0_MIS_TX 0x20
> >> > -#define BCM2835_UART0_IMSC_RX 0x10
> >> > -#define BCM2835_UART0_IMSC_TX 0x20
> >> > -#define BCM2835_UART0_FR_RXFE 0x10
> >> > -#define BCM2835_UART0_FR_TXFF 0x20
> >> > -#define BCM2835_UART0_ICR_RX 0x10
> >> > -#define BCM2835_UART0_ICR_TX 0x20
> >> > diff --git a/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > b/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > index d3e710c5e9..abbf53626c 100644
> >> > --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> >> > @@ -32,9 +32,8 @@
> >> > extern "C" {
> >> > #endif /* __cplusplus */
> >> > -#define USART0_DEFAULT_BAUD 115000
> >> > -extern const console_fns bcm2835_usart_fns;
> >> > +#define PL011_DEFAULT_BAUD 115000
> >> > +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE +
> 0x201000)
> >> > #ifdef __cplusplus
> >> > diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >> > b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >> > index 11a22f89e3..0e0d5bef67 100644
> >> > --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >> > +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >> > @@ -42,6 +42,7 @@ librtemsbsp_a_SOURCES +=
> >> > ../../../../../../bsps/shared/start/bspfatal-default.c
> ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
> ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
> >> ../../../../../../bsps/shared/start/sbrk.c
> >> > +librtemsbsp_a_SOURCES +=
> >> ../../../../../../bsps/shared/start/bsp-fdt.c
> >> > ../../../../../../bsps/shared/start/stackalloc.c
> >> > ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
> ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> >> > @@ -63,14 +64,13 @@ librtemsbsp_a_SOURCES +=
> >> > ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> >> > ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> >> > # Console
> >> > -librtemsbsp_a_SOURCES +=
> >> > ../../../../../../bsps/shared/dev/serial/legacy-console.c
> ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
> ../../../../../../bsps/arm/raspberrypi/console/console-config.c
> ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> >> > ../../../../../../bsps/arm/raspberrypi/console/usart.c
> >> > ../../../../../../bsps/arm/raspberrypi/console/fb.c
> >> > ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> >> > ../../../../../../bsps/arm/raspberrypi/console/outch.c
> >> > ../../../../../../bsps/shared/dev/serial/console-termios.c
> ../../../../../../bsps/shared/dev/serial/console-termios-init.c
> >> > ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> >> > # Mailbox
> >> > ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
> >> > 2.17.1
