[PATCH v4] Raspberrypi: updated the console interface.
Niteesh gsnb.gn at gmail.com
Tue Dec 31 14:59:34 UTC 2019
I have an idea to debug this, but not sure whether it will work or not, I
could
run raspbian on versatilepb using arm1176 as cpu and 256mb ram
this is very much similar to raspi1, I think this one also uses pl011, I
remember
seeing it in the linux bootup msgs.
I could run the examples using qemu using raspi2 as the machine but the dtb
file never gets passed to it. The register r2 is 0.
qemu-system-arm -M raspi2 -m 1G -kernel fileio.exe -serial mon:stdio
-nographic -dtb bcm2709-rpi-2-b.dtb -S -s
This is the command I use to run my examples and connect to gdb.
On Tue, Dec 31, 2019 at 7:31 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 31/12/2019 14:56, Niteesh wrote:
> > If moving uart_probe to output char, then should I move
> > rtems_device_handler_install to console_initialize because, my guess
> > is that the IO initialization system would not be initialized properly
> > at that stage.
> The uart_probe in the output char function should do a really minimal
> initialization. Only what is necessary to get the polled uart working.
> That one will only be called if you have an exception at a very early
> stage. In that case you are working in an exception context.
> > When I rename the register_arm_pl011 to init_context_pl011 since it's is
> > only initializing
> > the pl011 context, rather than registering it.
> > On Tue, Dec 31, 2019 at 6:32 PM Christian Mauderer <list at c-mauderer.de
> > <mailto:list at c-mauderer.de>> wrote:
> >     On 31/12/2019 13:22, Niteesh wrote:
> >     > It works now, the functions are getting called when used with
> >     fileio.exe.
> >     > The function bsp_start wants to print information about the board,
> >     That print maybe should be moved to a later point. It just fetches
> some
> >     information and prints it. It doesn't even do anything usefull
> >     besides that.
> >     > but
> >     > the console
> >     > initialization function is called after bsp_start, assuming that
> >     the FDT
> >     > works it still
> >     > crash since the console still isn't initialized, one way of fixing
> >     this
> >     > would be to add uart_probe into
> >     > output_char just like in imx, or we could move the printing to
> >     somewhere
> >     > else.
> >     That might would be a good idea regardless whether the print is
> moved or
> >     not. It would allow an early exception to print anything.
> >     > On Tue, Dec 31, 2019 at 4:08 PM Christian Mauderer
> >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
> >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
> >     >     On 31/12/2019 11:37, Christian Mauderer wrote:
> >     >     > On 31/12/2019 06:11, Niteesh wrote:
> >     >     >> On Tue, Dec 31, 2019 at 1:13 AM Christian Mauderer
> >     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
> >     >     >>     On 30/12/2019 19:32, Niteesh wrote:
> >     >     >>     > Just to make sure that console_initialize and
> uart_probe
> >     >     are being
> >     >     >>     > called, I manually initialized the pl011 context to
> print
> >     >     something on
> >     >     >>     > serial. But they never got called. Can you just make
> sure
> >     >     that if I am
> >     >     >>     > missing something?
> >     >     >>     I don't think that you are missing something but the
> >     >     executable is
> >     >     >>     missing something: The functions are not linked into it.
> >     >     >>     C linker can be an odd thing: It links only object
> >     files that are
> >     >     >>     referenced. You seem to have no reference to
> >     >     console-config.c/o from
> >     >     >>     anywhere else.
> >     >     >>     RTEMS_SYSINIT_ITEM(
> >     >     >>       uart_probe,
> >     >     >>       RTEMS_SYSINIT_BSP_START,
> >     >     >>       RTEMS_SYSINIT_ORDER_LAST
> >     >     >>     will be only added to the linker set if the file is
> >     linked in
> >     >     anyway.
> >     >     >>     That is a bit anoying. For the imx BSP there is a UART
> >     drain
> >     >     function
> >     >     >>     that is called from somewhere else. Thats enough to
> >     bring the
> >     >     file in.
> >     >     >>     I think you'll need to add a reference from somewhere
> >     or move
> >     >     that stuff
> >     >     >>     into another file that is referenced.
> >     >     >>     If you have some init function that has to be called in
> >     every
> >     >     case you
> >     >     >>     can call it from some other c file where it would fit
> too.
> >     >     >>     Otherwise it might is necessary to construct some odd
> >     stuff.
> >     >     I'm not
> >     >     >>     sure whether we already had a case like this. Most
> >     likely it
> >     >     would be
> >     >     >>     necessary to use a RTEMS_LINKER_ROSET_ITEM_REFERENCE
> >     for the
> >     >     >>     SYSINIT_ITEM. Maybe to define a new
> >     >     RTEMS_SYSINIT_ITEM_REFERENCE or
> >     >     >>     simmilar. This should be definitively a separate commit.
> >     >     Please ask
> >     >     >>     again if you have to go that way.
> >     >     >> I didn't understand the above part. So what I did was
> >     created a dummy
> >     >     >> function in console-config.c
> >     >     >> and referenced in places that I know we're going to be
> >     called. But
> >     >     >> still, it didn't work.
> >     >     > That's a really mean bug to find:
> >     >     > 1. My assumption was wrong. The file is linked in. Most
> >     likely due to
> >     >     > BSP_output_char which is defined in this file.
> >     >     > 2. Please remove console-termios-init.c. It would define the
> >     same
> >     >     > console_initialize() function.
> >     >     Just to be clear: Remove it from the
> >     >     c/src/lib/libbsp/arm/raspberrypi/Makefile.am file.
> >     >     > 3. The real proble just caused a warning which was a bit
> >     hard to spot:
> >     >     > The compile doesn't know RTEMS_SYSINIT_ITEM. It thinks it's
> >     a function
> >     >     > body and warns that it defaults the return type to int. In
> other
> >     >     words:
> >     >     > You missed to include <rtems/sysinit.h>. If you add that the
> >     >     > RTEMS_SYSINIT_ITEM works and uart_probe is linked in.
> >     >     > 4. console_initialize is still not used. It is really hard
> >     to spot
> >     >     why:
> >     >     > Most of the tests only use the configuration:
> >     >     >     CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> >     >     > This is a simplified polled console driver. From the samples
> >     only
> >     >     > capture, fileio and pppd are using the normal console with:
> >     >     >     CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> >     >     > So only for these three the console_initialize will be
> called.
> >     >     > By the way: You can use objdump to analyze your elf-files.
> >     For example
> >     >     > to get a symbol table use:
> >     >     >     arm-rtems5-objdump -t path/to/ticker.exe
> >     >     > To get the disassembled code with intermixed c-sources use
> >     >     >     arm-rtems5-objdump -dS path/to/ticker.exe
> >     >     > That's very usefull to find whether a symbol is linked in or
> >     not.
> >     >     >>     > While going through the messages from devel-request,
> Joel
> >     >     mentioned
> >     >     >>     > about qemu4 rsb package
> >     >     >>     > how is it different from the official qemu?
> >     >     >>     > On Mon, Dec 30, 2019 at 11:53 PM G S Niteesh
> >     >     <gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>
> >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>
> >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>
> >     <mailto:gsnb.gn at gmail.com <mailto:gsnb.gn at gmail.com>>>>> wrote:
> >     >     >>     >     The patch updates the older console interface
> used by
> >     >     the BSP,
> >     >     >>     >     to newer one. It also replaces the custom
> >     usart(PL011)
> >     >     driver
> >     >     >>     >     with arm-pl011. The fb function's signatures
> >     where also
> >     >     changed
> >     >     >>     >     to accommodate with interface update.
> >     >     >>     >     Update #3034
> >     >     >>     >      bsps/arm/raspberrypi/console/console-config.c |
> 186
> >     >     >>     >      bsps/arm/raspberrypi/console/console_select.c |
> 114
> >     >     >>     >      bsps/arm/raspberrypi/console/fbcons.c         |
> 78
> >     >     >>     >      bsps/arm/raspberrypi/console/usart.c          |
> 167
> >     >     >>     >      bsps/arm/raspberrypi/include/bsp/fbcons.h     |
> >     21 +-
> >     >     >>     >      .../arm/raspberrypi/include/bsp/raspberrypi.h |
> >     48 ++---
> >     >     >>     >      bsps/arm/raspberrypi/include/bsp/usart.h      |
> >      5 +-
> >     >     >>     >      c/src/lib/libbsp/arm/raspberrypi/Makefile.am  |
> >      8 +-
> >     >     >>     >      8 files changed, 220 insertions(+), 407
> deletions(-)
> >     >     >>     >      delete mode 100644
> >     >     >>     >      delete mode 100644
> >     >     >>     >     diff --git
> >     a/bsps/arm/raspberrypi/console/console-config.c
> >     >     >>     >     b/bsps/arm/raspberrypi/console/console-config.c
> >     >     >>     >     index d2186c918b..021428ff4b 100644
> >     >     >>     >     @@ -19,50 +19,164 @@
> >     >     >>     >      #include <rtems/bspIo.h>
> >     >     >>     >     +#include <rtems/console.h>
> >     >     >>     >     -#include <libchip/serial.h>
> >     >     >>     >     -#include <bspopts.h>
> >     >     >>     >     -#include <bsp/irq.h>
> >     >     >>     >     -#include <bsp/usart.h>
> >     >     >>     >     +#include <bsp.h>
> >     >     >>     >      #include <bsp/raspberrypi.h>
> >     >     >>     >     +#include <bsp/usart.h>
> >     >     >>     >     +#include <bsp/arm-pl011.h>
> >     >     >>     >      #include <bsp/fbcons.h>
> >     >     >>     >     +#include <bsp/console-termios.h>
> >     >     >>     >     +#include <bsp/fdt.h>
> >     >     >>     >     +#include <bsp/fatal.h>
> >     >     >>     >     +#include <bspopts.h>
> >     >     >>     >     +#include <libfdt.h>
> >     >     >>     >     +#include <libchip/serial.h>
> >     >     >>     >     +arm_pl011_context pl011_context;
> >     >     >>     >     +rpi_fb_context fb_context;
> >     >     >>     These could be static.
> >     >     >>     >     +static void output_char_serial(char c)
> >     >     >>     >     +  arm_pl011_write_polled(&pl011_context.base, c);
> >     >     >>     >     +void output_char_fb(char c)
> >     >     >>     >     +  fbcons_write_polled(&fb_context.base, c);
> >     >     >>     >     -console_tbl Console_Configuration_Ports [] = {
> >     >     >>     >     -      .sDeviceName = "/dev/ttyS0",
> >     >     >>     >     -      .deviceType = SERIAL_CUSTOM,
> >     >     >>     >     -      .pDeviceFns = &bcm2835_usart_fns,
> >     >     >>     >     -      .deviceProbe = NULL,
> >     >     >>     >     -      .pDeviceFlow = NULL,
> >     >     >>     >     -      .ulCtrlPort1 = BCM2835_UART0_BASE,
> >     >     >>     >     -      .ulCtrlPort2 = 0,
> >     >     >>     >     -      .ulClock = USART0_DEFAULT_BAUD,
> >     >     >>     >     -      .ulIntVector = BCM2835_IRQ_ID_UART
> >     >     >>     >     -      .sDeviceName ="/dev/fbcons",
> >     >     >>     >     -      .pDeviceFns = &fbcons_fns,
> >     >     >>     >     -      .deviceProbe = fbcons_probe,
> >     >     >>     >     -#define PORT_COUNT \
> >     >     >>     >     -  (sizeof(Console_Configuration_Ports) \
> >     >     >>     >     -    / sizeof(Console_Configuration_Ports [0]))
> >     >     >>     >     -unsigned long Console_Configuration_Count =
> >     PORT_COUNT;
> >     >     >>     >     -static void output_char(char c)
> >     >     >>     >     +static void *get_reg_of_node(const void *fdt,
> >     int node)
> >     >     >>     >     -  const console_fns *con =
> >     >     >>     >     -    Console_Configuration_Ports
> >     >     [Console_Port_Minor].pDeviceFns;
> >     >     >>     >     +  int len;
> >     >     >>     >     +  const uint32_t *val;
> >     >     >>     >     +  val = fdt_getprop(fdt, node, "reg", &len);
> >     >     >>     >     +  if (val == NULL || len < 4) {
> >     >     >>     >     +    return NULL;
> >     >     >>     >     -  con->deviceWritePolled((int)
> >     Console_Port_Minor, c);
> >     >     >>     >     +  return (void *) fdt32_to_cpu(val[0]);
> >     >     >>     >     -BSP_output_char_function_type BSP_output_char =
> >     >     output_char;
> >     >     >>     >     +static void register_arm_pl011(
> >     >     >>     >     +  const void *fdt,
> >     >     >>     >     +  const char *serial
> >     >     >>     >     +  arm_pl011_context *ctx = &pl011_context;
> >     >     >>     >     +  int node;
> >     >     >>     >     +  if (strcmp(serial, "uart0") == 0) {
> >     >     rtems_termios_device_context_initialize(&ctx->base, "UART");
> >     >     >>     >     +    node = fdt_path_offset(fdt, serial);
> >     >     >>     >     +    ctx->regs = get_reg_of_node(fdt, node);
> >     >     >>     >     +  rtems_termios_device_install(
> >     >     >>     >     +    "/dev/ttyuart0",
> >     >     >>     >     +    &arm_pl011_fns,
> >     >     >>     >     +    NULL,
> >     >     >>     >     +    &pl011_context.base
> >     >     >>     >     +static void register_fb( void )
> >     >     >>     >     +  if (fbcons_probe(&fb_context.base) == true) {
> >     >     >>     >     +      "/dev/fbcons",
> >     >     >>     >     +      &fbcons_fns,
> >     >     >>     >     +      NULL,
> >     >     >>     >     +      &fb_context.base);
> >     >     >>     >     +static void console_select( const char *console )
> >     >     >>     >     +  const char *opt;
> >     >     >>     >     +  opt = rpi_cmdline_get_arg("--console=");
> >     >     >>     >     +  if ( opt ) {
> >     >     >>     >     +    if ( strncmp( opt, "fbcons", sizeof(
> >     "fbcons" ) -
> >     >     1 ) ==
> >     >     >>     0 ) {
> >     >     >>     >     +      if ( rpi_video_is_initialized() > 0 ) {
> >     >     >>     >     +        BSP_output_char = output_char_fb;
> >     >     >>     >     +        link("/dev/fbcons", CONSOLE_DEVICE_NAME);
> >     >     >>     >     +    }else{
> >     >     >>     >     +      if ( console == NULL ){
> >     >     >>     >     +        bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >     >     >>     >     +      BSP_output_char = output_char_serial;
> >     >     >>     >     +      link("/dev/ttyuart0", CONSOLE_DEVICE_NAME);
> >     >     >>     >     +static void uart_probe(void)
> >     >     >>     >     +  const void *fdt;
> >     >     >>     >     +  const char *console;
> >     >     >>     >     +  int node;
> >     >     >>     >     +  fdt = bsp_fdt_get();
> >     >     >>     >     +  node = fdt_path_offset(fdt, "/chosen");
> >     >     >>     >     +  console = fdt_getprop(fdt, node,
> >     "stdout-path", NULL);
> >     >     >>     >     +  node = fdt_path_offset(fdt, "/aliases");
> >     >     >>     >     +  int offset = fdt_first_property_offset(fdt,
> node);
> >     >     >>     >     +  while (offset >= 0) {
> >     >     >>     >     +    const struct fdt_property *prop;
> >     >     >>     >     +    prop = fdt_get_property_by_offset(fdt,
> >     offset, NULL);
> >     >     >>     >     +    if (prop != NULL) {
> >     >     >>     >     +      const char *name;
> >     >     >>     >     +      name = fdt_string(fdt,
> >     fdt32_to_cpu(prop->nameoff));
> >     >     >>     >     +      if(strstr(name, "serial") != NULL) {
> >     >     >>     >     +        const char *serial;
> >     >     >>     >     +        serial = prop->data;
> >     >     >>     >     +        register_arm_pl011(fdt, serial);
> >     >     >>     >     +    offset = fdt_next_property_offset(fdt,
> offset);
> >     >     >>     >     +  console_select(console);
> >     >     >>     >     +rtems_status_code console_initialize(
> >     >     >>     >     +  rtems_device_major_number major,
> >     >     >>     >     +  rtems_device_minor_number minor,
> >     >     >>     >     +  void *arg
> >     >     >>     >     +  rtems_termios_initialize();
> >     >     >>     >     +  uart_probe();
> >     >     >>     >     +  register_fb();
> >     >     >>     >     +  return RTEMS_SUCCESSFUL;
> >     >     >>     >     +BSP_output_char_function_type BSP_output_char =
> >     >     >>     output_char_serial;
> >     >     >>     >      BSP_polling_getchar_function_type BSP_poll_char
> >     = NULL;
> >     >     >>     >     +RTEMS_SYSINIT_ITEM(
> >     >     >>     >     +  uart_probe,
> >     >     >>     >     +  RTEMS_SYSINIT_BSP_START,
> >     >     >>     >     +  RTEMS_SYSINIT_ORDER_LAST
> >     >     >>     >     \ No newline at end of file
> >     >     >>     >     diff --git
> >     a/bsps/arm/raspberrypi/console/console_select.c
> >     >     >>     >     b/bsps/arm/raspberrypi/console/console_select.c
> >     >     >>     >     deleted file mode 100644
> >     >     >>     >     index bd246ca868..0000000000
> >     >     >>     >     +++ /dev/null
> >     >     >>     >     @@ -1,114 +0,0 @@
> >     >     >>     >     - * @file
> >     >     >>     >     - * @ingroup raspberrypi_console
> >     >     >>     >     - * @brief console select
> >     >     >>     >     - * Copyright (c) 2015 Yang Qiao
> >     >     >>     >     - *  The license and distribution terms for this
> file
> >     >     may be
> >     >     >>     >     - *  found in the file LICENSE in this
> >     distribution or at
> >     >     >>     >     - *  http://www.rtems.org/license/LICENSE
> >     >     >>     >     -#include <bsp.h>
> >     >     >>     >     -#include <bsp/fatal.h>
> >     >     >>     >     -#include <rtems/libio.h>
> >     >     >>     >     -#include <stdlib.h>
> >     >     >>     >     -#include <string.h>
> >     >     >>     >     -#include <assert.h>
> >     >     >>     >     -#include <termios.h>
> >     >     >>     >     -#include <rtems/termiostypes.h>
> >     >     >>     >     -#include
> "../../shared/dev/serial/legacy-console.h"
> >     >     >>     >     -#include <bsp/rpi-fb.h>
> >     >     >>     >     -rtems_device_minor_number BSPPrintkPort = 0;
> >     >     >>     >     - * Method to return true if the device
> >     associated with the
> >     >     >>     >     - * minor number probs available.
> >     >     >>     >     -static bool bsp_Is_Available(
> >     >     rtems_device_minor_number minor )
> >     >     >>     >     -  console_tbl *cptr = Console_Port_Tbl[ minor ];
> >     >     >>     >     -   * First perform the configuration dependent
> >     probe,
> >     >     then the
> >     >     >>     >     -   * device dependent probe
> >     >     >>     >     -  if ( ( !cptr->deviceProbe || cptr->deviceProbe(
> >     >     minor ) ) &&
> >     >     >>     >     -       cptr->pDeviceFns->deviceProbe( minor ) ) {
> >     >     >>     >     -    return true;
> >     >     >>     >     -  return false;
> >     >     >>     >     - * Method to return the first available device.
> >     >     >>     >     -static rtems_device_minor_number
> >     >     bsp_First_Available_Device(
> >     >     >>     void )
> >     >     >>     >     -  rtems_device_minor_number minor;
> >     >     >>     >     -  for ( minor = 0; minor < Console_Port_Count;
> >     minor++ ) {
> >     >     probe, then the
> cptr->deviceProbe(
> >     >     minor ) ) &&
> >     >     >>     >     -      return minor;
> >     >     >>     >     -   *  Error No devices were found.  We will want
> to
> >     >     bail here.
> >     >     >>     >     -  bsp_fatal( BSP_FATAL_CONSOLE_NO_DEV );
> >     >     >>     >     -void bsp_console_select( void )
> >     >     >>     >     -   *  Reset Console_Port_Minor and
> >     >     >>     >     -   *  BSPPrintkPort here if desired.
> >     >     >>     >     -   *  This default version allows the bsp to set
> >     these
> >     >     >>     >     -   *  values at creation and will not touch them
> >     again
> >     >     >>     >     -   *  unless the selected port number is not
> >     available.
> >     >     >>     >     -  const char *opt;
> >     >     >>     >     -  Console_Port_Minor = BSP_CONSOLE_UART0;
> >     >     >>     >     -  BSPPrintkPort = BSP_CONSOLE_UART0;
> >     >     >>     >     -  opt = rpi_cmdline_get_arg( "--console=" );
> >     >     >>     >     -  if ( opt ) {
> >     >     >>     >     -    if ( strncmp( opt, "fbcons", sizeof(
> >     "fbcons" ) -
> >     >     1 ) ==
> >     >     >>     0 ) {
> >     >     >>     >     -      if ( rpi_video_is_initialized() > 0 ) {
> >     >     >>     >     -        Console_Port_Minor = BSP_CONSOLE_FB;
> >     >     >>     >     -        BSPPrintkPort = BSP_CONSOLE_FB;
> >     >     >>     >     -   * If the device that was selected isn't
> >     available then
> >     >     >>     >     -   * let the user know and select the first
> >     available
> >     >     device.
> >     >     >>     >     -  if ( !bsp_Is_Available( Console_Port_Minor ) )
> >     bsp_First_Available_Device();
> >     >     >>     >     diff --git a/bsps/arm/raspberrypi/console/fbcons.c
> >     >     >>     >     b/bsps/arm/raspberrypi/console/fbcons.c
> >     >     >>     >     index 3669ba458d..0e6a430c54 100644
> >     >     >>     >     --- a/bsps/arm/raspberrypi/console/fbcons.c
> >     >     >>     >     +++ b/bsps/arm/raspberrypi/console/fbcons.c
> >     >     >>     >     @@ -18,6 +18,7 @@
> >     >     >>     >      #include <rtems.h>
> >     >     >>     >     +#include <rtems/termiostypes.h>
> >     >     >>     >      #include <stdlib.h>
> >     >     >>     >     @@ -29,15 +30,6 @@
> >     >     >>     >      #include <bsp/vc.h>
> >     >     >>     >     - *  fbcons_init
> >     >     >>     >     - *  This function initializes the fb console to a
> >     >     quiecsent
> >     >     >>     state.
> >     >     >>     >     -static void fbcons_init( int minor )
> >     >     >>     >       *  fbcons_open
> >     >     >>     >     @@ -45,13 +37,14 @@ static void fbcons_init( int
> >     minor )
> >     >     >>     >       *  Default state is 9600 baud, 8 bits, No
> >     parity, and
> >     >     1 stop
> >     >     >>     bit.
> >     >     >>     >     -static int fbcons_open(
> >     >     >>     >     -  int   major,
> >     >     >>     >     -  int   minor,
> >     >     >>     >     -  void *arg
> >     >     >>     >     +static bool fbcons_open(
> >     >     >>     >     +  struct rtems_termios_tty *tty,
> >     >     >>     >     +  rtems_termios_device_context *base,
> >     >     >>     >     +  struct termios *term,
> >     >     >>     >     +  rtems_libio_open_close_args_t *args
> >     >     >>     >     -  return RTEMS_SUCCESSFUL;
> >     >     >>     >     +  return true;
> >     >     >>     >     @@ -59,13 +52,12 @@ static int fbcons_open(
> >     >     >>     >       *  This function shuts down the requested port.
> >     >     >>     >     -static int fbcons_close(
> >     >     >>     >     -  int   major,
> >     >     >>     >     -  int   minor,
> >     >     >>     >     -  void *arg
> >     >     >>     >     +static void fbcons_close(
> >     >     >>     >     -  return ( RTEMS_SUCCESSFUL );
> >     >     >>     >     @@ -73,8 +65,8 @@ static int fbcons_close(
> >     >     >>     >       *  This routine polls out the requested
> character.
> >     >     >>     >     -static void fbcons_write_polled(
> >     >     >>     >     -  int  minor,
> >     >     >>     >     +void fbcons_write_polled(
> >     >     >>     >        char c
> >     >     >>     >     @@ -90,8 +82,8 @@ static void fbcons_write_polled(
> >     >     >>     >       *  Console Termios output entry point when using
> >     >     polled output.
> >     >     >>     >     -static ssize_t fbcons_write_support_polled(
> >     >     >>     >     -  int         minor,
> >     >     >>     >     +static void fbcons_write_support_polled(
> >     >     >>     >        const char *buf,
> >     >     >>     >        size_t      len
> >     >     >>     >     @@ -102,14 +94,9 @@ static ssize_t
> >     >     >>     >         * poll each byte in the string out of the
> port.
> >     >     >>     >        while ( nwrite < len ) {
> >     >     >>     >     -    fbcons_write_polled( minor, *buf++ );
> >     >     >>     >     +    fbcons_write_polled( base, *buf++ );
> >     >     >>     >          nwrite++;
> >     >     >>     >     -   * return the number of bytes written.
> >     >     >>     >     -  return nwrite;
> >     >     >>     >     @@ -117,7 +104,9 @@ static ssize_t
> >     >     >>     >       *  Console Termios polling input entry point.
> >     >     >>     >     -static int fbcons_inbyte_nonblocking_polled( int
> >     minor )
> >     >     >>     >     +int fbcons_inbyte_nonblocking_polled(
> >     >     >>     >        // if( rtems_kbpoll() ) {
> >     >     >>     >        //   int c = getch();
> >     >     >>     >     @@ -133,15 +122,17 @@ static int
> >     >     >>     >     int minor )
> >     >     >>     >       *  This function sets the UART channel to
> >     reflect the
> >     >     requested
> >     >     >>     >     termios
> >     >     >>     >       *  port settings.
> >     >     >>     >     -static int fbcons_set_attributes(
> >     >     >>     >     -  int                   minor,
> >     >     >>     >     +static bool fbcons_set_attributes(
> >     >     >>     >        const struct termios *t
> >     >     >>     >     -  return 0;
> >     >     >>     >     +  return true;
> >     >     >>     >     -bool fbcons_probe( int minor )
> >     >     >>     >     +bool fbcons_probe(
> >     >     >>     >     +  rtems_termios_device_context *context
> >     >     >>     >        // rtems_status_code status;
> >     >     >>     >        static bool firstTime = true;
> >     >     >>     >     @@ -163,15 +154,12 @@ bool fbcons_probe( int
> minor )
> >     >     >>     >        return ret;
> >     >     >>     >     -const console_fns fbcons_fns =
> >     >     >>     >     +const rtems_termios_device_handler fbcons_fns =
> >     >     >>     >     -  .deviceProbe = libchip_serial_default_probe,
> >     >     >>     deviceProbe */
> >     >     >>     >     -  .deviceFirstOpen = fbcons_open,
> >     >     >>     deviceFirstOpen */
> >     >     >>     >     -  .deviceLastClose = fbcons_close,
> >     >     >>     deviceLastClose */
> >     >     >>     >     -  .deviceRead =
> fbcons_inbyte_nonblocking_polled, /*
> >     >     >>     deviceRead */
> >     >     >>     >     -  .deviceWrite = fbcons_write_support_polled,
> >     >     >>     deviceWrite */
> >     >     >>     >     -  .deviceInitialize = fbcons_init,
> >     >     >>     >     deviceInitialize */
> >     >     >>     >     -  .deviceWritePolled = fbcons_write_polled,
> >     >     >>     >     deviceWritePolled */
> >     >     >>     >     -  .deviceSetAttributes = fbcons_set_attributes,
> >     >     >>     >     deviceSetAttributes */
> >     >     >>     >     -  .deviceOutputUsesInterrupts = FALSE,
> >     >     >>     >     deviceOutputUsesInterrupts*/
> >     >     >>     >     +  .first_open = fbcons_open,
> >     >     >>     >     +  .last_close = fbcons_close,
> >     >     >>     >     +  .poll_read = fbcons_inbyte_nonblocking_polled,
> >     >     >>     >     +  .write = fbcons_write_support_polled,
> >     >     >>     >     +  .set_attributes = fbcons_set_attributes,
> >     >     >>     >     +  .mode = TERMIOS_POLLED
> >     >     >>     >     diff --git a/bsps/arm/raspberrypi/console/usart.c
> >     >     >>     >     b/bsps/arm/raspberrypi/console/usart.c
> >     >     >>     >     index 25fb523621..0000000000
> >     >     >>     >     --- a/bsps/arm/raspberrypi/console/usart.c
> >     >     >>     >     +++ /dev/null
> >     >     >>     >     @@ -1,167 +0,0 @@
> >     >     >>     >     - * @file
> >     >     >>     >     - * @ingroup raspberrypi_usart
> >     >     >>     >     - * @brief USART support.
> >     >     >>     >     - * Copyright (c) 2013 Alan Cudmore
> file
> >     >     may be
> >     distribution or at
> >     >     >>     >     -#include <libchip/sersupp.h>
> >     >     >>     >     -#include <bsp.h>
> >     >     >>     >     -#include <bsp/raspberrypi.h>
> >     >     >>     >     -#include <rtems/bspIo.h>
> >     >     >>     >     -static void usart_delay(uint32_t n)
> >     >     >>     >     - volatile uint32_t i = 0;
> >     >     >>     >     - for(i = 0; i < n; i++)
> >     >     >>     >     -#if 0
> >     >     >>     >     - *  These will be useful when the driver supports
> >     >     interrupt
> >     >     >>     driven IO.
> >     >     >>     >     -static rtems_vector_number
> >     usart_get_irq_number(const
> >     >     >>     console_tbl *ct)
> >     >     >>     >     -  return ct->ulIntVector;
> >     >     >>     >     -static uint32_t usart_get_baud(const console_tbl
> >     *ct)
> >     >     >>     >     -  return ct->ulClock;
> >     >     >>     >     -#endif
> >     >     >>     >     -static void usart_set_baud(int minor, int baud)
> >     >     >>     >     -  * Nothing for now
> >     >     >>     >     - return;
> >     >     >>     >     -static void usart_initialize(int minor)
> >     >     >>     >     -  unsigned int gpio_reg;
> >     >     >>     >     -  ** Program GPIO pins for UART 0
> >     >     >>     >     -  gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
> >     >     >>     >     -  gpio_reg &= ~(7<<12);    /* gpio14 */
> >     >     >>     >     -  gpio_reg |=  (4<<12);    /* alt0   */
> >     >     >>     >     -  gpio_reg &= ~(7<<15);    /* gpio15 */
> >     >     >>     >     -  gpio_reg |=  (4<<15);    /* alt0   */
> >     >     >>     >     -  BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
> >     >     >>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
> >     >     >>     >     -  usart_delay(150);
> >     >     >>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) =
> >     (1<<14)|(1<<15);
> >     >     >>     >     -  usart_delay(150);
> >     >     >>     >     -  BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
> >     >     >>     >     -  ** Init the PL011 UART
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_IMSC) = 0;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_IBRD) = 1;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_FBRD) = 40;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
> >     >     >>     >     -  BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
> >     BCM2835_UART0_IMSC_RX;
> >     >     >>     >     -  usart_set_baud(minor, 115000);
> >     >     >>     >     -static int usart_first_open(int major, int
> >     minor, void
> >     >     *arg)
> >     >     >>     >     -  rtems_libio_open_close_args_t *oc =
> >     >     >>     >     (rtems_libio_open_close_args_t *) arg;
> >     >     >>     >     -  struct rtems_termios_tty *tty = (struct
> >     >     rtems_termios_tty *)
> >     >     >>     >     oc->iop->data1;
> >     >     >>     >     -  const console_tbl *ct = Console_Port_Tbl
> [minor];
> >     >     >>     >     -  console_data *cd = &Console_Port_Data [minor];
> >     >     >>     >     -  cd->termios_data = tty;
> >     >     >>     >     -  rtems_termios_set_initial_baud(tty,
> ct->ulClock);
> >     >     >>     >     -  return 0;
> >     >     >>     >     -static int usart_last_close(int major, int
> >     minor, void
> >     >     *arg)
> >     >     >>     >     -  return 0;
> >     >     >>     >     -static int usart_read_polled(int minor)
> >     >     >>     >     -  if (minor == 0) {
> >     >     >>     >     -    if (((BCM2835_REG(BCM2835_UART0_FR)) &
> >     >     BCM2835_UART0_FR_RXFE)
> >     >     >>     >     == 0) {
> >     >     >>     >     -       return((BCM2835_REG(BCM2835_UART0_DR)) &
> >     0xFF );
> >     >     >>     >     -    } else {
> >     >     >>     >     -      return -1;
> >     >     >>     >     -  } else {
> >     >     >>     >     -    printk("Unknown console minor number: %d\n",
> >     minor);
> >     >     >>     >     -    return -1;
> >     >     >>     >     -static void usart_write_polled(int minor, char c)
> >     >     >>     >     -   while (1) {
> >     >     >>     >     -     if ((BCM2835_REG(BCM2835_UART0_FR) &
> >     >     >>     BCM2835_UART0_FR_TXFF) == 0)
> >     >     >>     >     -       break;
> >     >     >>     >     -   BCM2835_REG(BCM2835_UART0_DR) = c;
> >     >     >>     >     -static ssize_t usart_write_support_polled(
> >     >     >>     >     -  int minor,
> >     >     >>     >     -  const char *s,
> >     >     >>     >     -  size_t n
> >     >     >>     >     -  ssize_t i = 0;
> >     >     >>     >     -  for (i = 0; i < n; ++i) {
> >     >     >>     >     -    usart_write_polled(minor, s [i]);
> >     >     >>     >     -  return n;
> >     >     >>     >     -static int usart_set_attributes(int minor, const
> >     struct
> >     >     >>     termios *term)
> >     >     >>     >     -  return -1;
> >     >     >>     >     -const console_fns bcm2835_usart_fns = {
> >     >     >>     >     -  .deviceFirstOpen = usart_first_open,
> >     >     >>     >     -  .deviceLastClose = usart_last_close,
> >     >     >>     >     -  .deviceRead = usart_read_polled,
> >     >     >>     >     -  .deviceWrite = usart_write_support_polled,
> >     >     >>     >     -  .deviceInitialize = usart_initialize,
> >     >     >>     >     -  .deviceWritePolled = usart_write_polled,
> >     >     >>     >     -  .deviceSetAttributes = usart_set_attributes,
> >     >     >>     >     -  .deviceOutputUsesInterrupts = false
> >     >     >>     >     diff --git
> >     a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     >     >>     >     b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     >     >>     >     index d0e126699a..9bdb4b115e 100644
> >     >     >>     >     --- a/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     >     >>     >     +++ b/bsps/arm/raspberrypi/include/bsp/fbcons.h
> >     >     >>     >     @@ -33,12 +33,29 @@ extern "C" {
> >     >     >>     >      #define FB_CONSOLE 0x50492835
> >     >     >>     >     -bool fbcons_probe( int minor );
> >     >     >>     >     +bool fbcons_probe(
> >     >     >>     >     +  char c
> >     >     >>     >     +void output_char_fb(char c);
> >     >     >>     >     +typedef struct {
> >     >     >>     >     +    rtems_termios_device_context base;
> >     >     >>     >     +} rpi_fb_context ;
> >     >     >>     >       * Driver function table
> >     >     >>     >     -extern const console_fns fbcons_fns;
> >     >     >>     >     +extern const rtems_termios_device_handler
> >     fbcons_fns;
> >     >     >>     >      #ifdef __cplusplus
> >     >     >>     >     diff --git
> >     a/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     >     >>     >     b/bsps/arm/raspberrypi/include/bsp/raspberrypi.h
> >     >     >>     >     index 40c80cf408..e052c2becb 100644
> >     >     >>     >     @@ -24,6 +24,7 @@
> >     >     >>     >      #include <stdint.h>
> >     >     >>     >      #include <bsp/utility.h>
> >     >     >>     >       * @defgroup raspberrypi_reg Register Definitions
> >     >     >>     >     @@ -60,6 +61,17 @@
> >     >     >>     >      #define RPI_PERIPHERAL_SIZE         0x01000000
> >     >     >>     >     + * @name Console select definitions
> >     >     >>     >     +#define PL011 0
> >     >     >>     >     +#define FB    1
> >     >     >>     >       * @name Internal ARM Timer Registers
> >     >     >>     >     @@ -184,42 +196,6 @@
> >     >     >>     >     - * @name UART 0 (PL011) Registers
> >     >     >>     >     -#define BCM2835_UART0_BASE
> >      (RPI_PERIPHERAL_BASE
> >     >     + 0x201000)
> >     >     >>     >     -#define BCM2835_UART0_DR
> >      (BCM2835_UART0_BASE +
> >     >     0x00)
> >     >     >>     >     -#define BCM2835_UART0_RSRECR
> >     >     0x04)
> >     >     >>     >     -#define BCM2835_UART0_FR
> >     >     0x18)
> >     >     >>     >     -#define BCM2835_UART0_ILPR
> >     >     0x20)
> >     >     >>     >     -#define BCM2835_UART0_IBRD
> >     >     0x24)
> >     >     >>     >     -#define BCM2835_UART0_FBRD
> >     >     0x28)
> >     >     >>     >     -#define BCM2835_UART0_LCRH
> >     >     0x2C)
> >     >     >>     >     -#define BCM2835_UART0_CR
> >     >     0x30)
> >     >     >>     >     -#define BCM2835_UART0_IFLS
> >     >     0x34)
> >     >     >>     >     -#define BCM2835_UART0_IMSC
> >     >     0x38)
> >     >     >>     >     -#define BCM2835_UART0_RIS
> >     >     0x3C)
> >     >     >>     >     -#define BCM2835_UART0_MIS
> >     >     0x40)
> >     >     >>     >     -#define BCM2835_UART0_ICR
> >     >     0x44)
> >     >     >>     >     -#define BCM2835_UART0_DMACR
> >     >     0x48)
> >     >     >>     >     -#define BCM2835_UART0_ITCR
> >     >     0x80)
> >     >     >>     >     -#define BCM2835_UART0_ITIP
> >     >     0x84)
> >     >     >>     >     -#define BCM2835_UART0_ITOP
> >     >     0x88)
> >     >     >>     >     -#define BCM2835_UART0_TDR
> >     >     0x8C)
> >     >     >>     >     -#define BCM2835_UART0_MIS_RX    0x10
> >     >     >>     >     -#define BCM2835_UART0_MIS_TX    0x20
> >     >     >>     >     -#define BCM2835_UART0_IMSC_RX   0x10
> >     >     >>     >     -#define BCM2835_UART0_IMSC_TX   0x20
> >     >     >>     >     -#define BCM2835_UART0_FR_RXFE   0x10
> >     >     >>     >     -#define BCM2835_UART0_FR_TXFF   0x20
> >     >     >>     >     -#define BCM2835_UART0_ICR_RX    0x10
> >     >     >>     >     -#define BCM2835_UART0_ICR_TX    0x20
> >     >     >>     >     diff --git
> a/bsps/arm/raspberrypi/include/bsp/usart.h
> >     >     >>     >     b/bsps/arm/raspberrypi/include/bsp/usart.h
> >     >     >>     >     index d3e710c5e9..abbf53626c 100644
> >     >     >>     >     --- a/bsps/arm/raspberrypi/include/bsp/usart.h
> >     >     >>     >     +++ b/bsps/arm/raspberrypi/include/bsp/usart.h
> >     >     >>     >     @@ -32,9 +32,8 @@
> >     >     >>     >      extern "C" {
> >     >     >>     >      #endif /* __cplusplus */
> >     >     >>     >     -#define USART0_DEFAULT_BAUD 115000
> >     >     >>     >     -extern const console_fns bcm2835_usart_fns;
> >     >     >>     >     +#define PL011_DEFAULT_BAUD 115000
> >     >     >>     >     +#define BCM2835_PL011_BASE (RPI_PERIPHERAL_BASE +
> >     >     0x201000)
> >     >     >>     >      #ifdef __cplusplus
> >     >     >>     >     diff --git
> >     a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     >     >>     >     b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     >     >>     >     index 11a22f89e3..0e0d5bef67 100644
> >     >     >>     >     --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     >     >>     >     +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
> >     >     >>     >     @@ -42,6 +42,7 @@ librtemsbsp_a_SOURCES +=
> >      ../../../../../../bsps/shared/start/bspfatal-default.c
> >       ../../../../../../bsps/shared/dev/cpucounter/cpucounterfrequency.c
> >     >      ../../../../../../bsps/shared/dev/cpucounter/cpucounterread.c
> >     >     >>     ../../../../../../bsps/shared/start/sbrk.c
> >     >     >>     >     +librtemsbsp_a_SOURCES +=
> >     >     >>     ../../../../../../bsps/shared/start/bsp-fdt.c
> >     >     >>     >     ../../../../../../bsps/shared/start/stackalloc.c
> >      ../../../../../../bsps/arm/shared/start/bsp-start-memcpy.S
>   ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
> >     >     >>     >     @@ -63,14 +64,13 @@ librtemsbsp_a_SOURCES +=
> >      ../../../../../../bsps/arm/shared/cp15/arm-cp15-set-exc
> >     >     >>     >     ../../../../../../bsps/arm/raspberrypi/irq/irq.c
> >     >     >>     >      # Console
> >     >     >>     >     -librtemsbsp_a_SOURCES +=
> >      ../../../../../../bsps/shared/dev/serial/legacy-console.c
>   ../../../../../../bsps/shared/dev/serial/legacy-console-control.c
>   ../../../../../../bsps/arm/raspberrypi/console/console-config.c
>   ../../../../../../bsps/arm/raspberrypi/console/console_select.c
> >      ../../../../../../bsps/arm/raspberrypi/console/usart.c
>  ../../../../../../bsps/arm/raspberrypi/console/fb.c
> >      ../../../../../../bsps/arm/raspberrypi/console/fbcons.c
> >      ../../../../../../bsps/arm/raspberrypi/console/outch.c
> >      ../../../../../../bsps/shared/dev/serial/console-termios.c
>   ../../../../../../bsps/shared/dev/serial/console-termios-init.c
>  ../../../../../../bsps/arm/shared/serial/arm-pl011.c
> >     >     >>     >      # Mailbox
> >      ../../../../../../bsps/arm/raspberrypi/start/mailbox.c
> >     >     >>     >     2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191231/cd60aa0d/attachment-0001.html>
