coverage : not getting coverage for leon3-sis-cov
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri Feb 1 07:27:47 UTC 2019
Hi,
I'm attempting to run covoar for leon3-sis-cov with the following commands.
$HOME/development/rtems/rtems-tools/tester/rtems-test \
--rtems-tools=$HOME/development/rtems/5 \
--rtems-bsp=leon3-sis-cov \
sparc-rtems5/c/leon3/testsuites/samples
/home/lunatic/development/rtems/5/share/rtems/tester/bin/covoar \
-v -f TSIM \
-S
/home/lunatic/development/rtems/5/share/rtems/tester/rtems/testing/coverage/score-symbols.ini
-E
/home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
-p RTEMS-5 \
sparc-rtems5/c/leon3/testsuites/samples/*.exe
I'm getting and "unknown option -cov" error like the one given below.
] SIS - SPARC instruction simulator 2.8, copyright Jiri Gaisler 1995
] Bug-reports to jiri at gaisler.se
] unknown option -cov
] usage: sis [-uart1 uart_device1] [-uart2 uart_device2]
] [-sparclite] [-dumbio] [-v]
] [-nfp] [-freq frequency] [-c batch_file] [files]
[12/13] p:1 f:0 u:0 e:0 I:0 B:0 t:0 i:7 W:0 | sparc/leon3:
ticker.exe
Result: invalid Time: 0:00:01.011465 ticker.exe
=> run: /home/lunatic/development/rtems/5/bin/sparc-rtems5-sis -leon3
-nouartrx -r -tlim 200 s -cov
sparc-rtems5/c/leon3/testsuites/samples/ticker.exe
the test results are 'invalid'. When I remove the `-cov` from the bsp ini
file, then the tests pass without any error. However, I'm not getting
any coverage.
Here's the summary.txt generated:
Bytes Analyzed : 26376
Bytes Not Executed : 26376
Percentage Executed : 0
Percentage Not Executed : 100
Uncovered ranges found : 173
No branch information available
Am I missing something?
--vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190201/28891659/attachment-0001.html>
