coverage : not getting coverage for leon3-sis-cov
Fri Feb 1 08:34:23 UTC 2019
Hello,
you need the tools from the latest RSB.
However, the SIS crashed using an ERC32 test program:
gdb --args sparc-rtems5-sis -nouartrx -r -cov spsysinit01.exe
GNU gdb (GDB; devel:gcc) 8.2
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-suse-linux".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://bugs.opensuse.org/>.
Find the GDB manual and other documentation resources online at:
     <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
No symbol table is loaded.  Use the "file" command.
Reading symbols from sparc-rtems5-sis...done.
(gdb) r
Starting program: /build/rtems/5/bin/sparc-rtems5-sis -nouartrx -r -cov
spsysinit01.exe
Missing separate debuginfo for /lib64/ld-linux-x86-64.so.2
Try: zypper install -C
"debuginfo(build-id)=4062821f420b0c3d46ea03f208cae1a710516c4e"
Missing separate debuginfo for /lib64/libtinfo.so.6
"debuginfo(build-id)=613f86254ba17e5782301403eba051a20a0d7480"
Missing separate debuginfo for /lib64/libdl.so.2
"debuginfo(build-id)=466795ee7b9ca76122c66d034e7f18c7593d306e"
Missing separate debuginfo for /lib64/libm.so.6
"debuginfo(build-id)=1e8038d58788ff7546c54ef151a441567c5119dc"
Missing separate debuginfo for /lib64/libc.so.6
"debuginfo(build-id)=95b799e45a989e22af6e9d31ec729170e2c92dd2"
  SIS - SPARC/RISCV instruction simulator 2.10,  copyright Jiri Gaisler 1995
  Bug-reports to jiri at gaisler.se
  ERC32 emulation enabled
Program received signal SIGSEGV, Segmentation fault.
0x000000000040c0f5 in cov_start (address=33554432) at
../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:1300
1300
No such file or directory.
(gdb) bt
#0  0x000000000040c0f5 in cov_start (address=33554432) at
#1  run_sim (icount=icount at entry=9223372036854775807, dis=dis at entry=0)
at
../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:1102
#2  0x000000000040d36d in exec_cmd (cmd=cmd at entry=0x4a71cd "run") at
../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/func.c:330
#3  0x0000000000403d29 in main (argc=<optimized out>,
argv=0x7fffffffd828) at
../../../sourceware-mirror-binutils-gdb-ce73f310150418a9a1625ab60a527d959096a9e2/sim/sis/sis.c:202
(gdb) quit
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
