[PATCH] RSB/gdb: upgrade sis to 2.11
Mon Feb 4 07:58:01 UTC 2019
On 04/02/2019 08:00, Chris Johns wrote:
> Are you OK if I add this patch to:
>   https://devel.rtems.org/ticket/3460
> as an attachment so I can create `rtems-gdb-8.2.1-1.cfg`? I ask because `bfin`
> is broken with gdb-8.0.1 (in the sim code) on FreeBSD 12.0-p2 ..
>   https://lists.rtems.org/pipermail/build/2019-February/001775.html
> A gdb-8.2.1 with this patch builds for the bfin plus all the other architectures
> in 5/rtems-all.:)
Could we please update all standard targets to use GDB 8.2.1 in this case?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
