[PATCH] RSB/gdb: upgrade sis to 2.11
Jiri Gaisler jiri at gaisler.se
Mon Feb 4 09:16:27 UTC 2019
On 2/4/19 9:02 AM, Jiri Gaisler wrote:
> On 2/4/19 8:00 AM, Chris Johns wrote:
>> On 3/2/19 8:38 pm, Jiri Gaisler wrote:
>>> From 72799748f8dca595f804dcf0efd566b3a88eb36e Mon Sep 17 00:00:00 2001
>>> From: Jiri Gaisler <jiri at gaisler.se>
>>> Date: Sun, 3 Feb 2019 10:04:00 +0100
>>> Subject: [PATCH] gdb: upgrade sis to 2.11
>>> 	* support RISC-V extension IMACFD
>>> 	* fix broken erc32 memory controller settings
>> Why in this config ...
>>>  .../rtems-gdb-ce73f310150418a9a1625ab60a527d959096a9e2.cfg    | 4 ++--
>> ... is gdb-7-1 build recipe being included ..
>>>  %include %{_configdir}/gdb-7-1.cfg
>> ? Should this be:
>> %include %{_configdir}/gdb-8-1.cfg
>> Are you OK if I add this patch to:
>>  https://devel.rtems.org/ticket/3460
>> as an attachment so I can create `rtems-gdb-8.2.1-1.cfg`? I ask because `bfin`
>> is broken with gdb-8.0.1 (in the sim code) on FreeBSD 12.0-p2 ..
>>  https://lists.rtems.org/pipermail/build/2019-February/001775.html
>> A gdb-8.2.1 with this patch builds for the bfin plus all the other architectures
>> in 5/rtems-all. :)
>> Note, I have not run any simulations with this patch yet.
> Switch to gdb-8.2.1 is fine with me, I am using gdb-head for my own development. I will check the sis patch again, I did not think it would apply to gdb-8.2.1 due to some conflicting changes to configure.tgt ...
A problem with gdb-8.2.1 is that it does not recognize riscv-rtems as valid target, only riscv32- or riscv64- . This has been fixed in later versions of gdb. sis for RISC-V will therefore not build with the present patch. I will update the patch for 8.2.1 and post it on the list ...
Jiri
