[PATCH] RSB/gdb: upgrade sis to 2.11
Jiri Gaisler jiri at gaisler.se
Mon Feb 4 10:49:59 UTC 2019
On 2/4/19 8:00 AM, Chris Johns wrote:
> On 3/2/19 8:38 pm, Jiri Gaisler wrote:
>> From 72799748f8dca595f804dcf0efd566b3a88eb36e Mon Sep 17 00:00:00 2001
>> From: Jiri Gaisler <jiri at gaisler.se>
>> Date: Sun, 3 Feb 2019 10:04:00 +0100
>> Subject: [PATCH] gdb: upgrade sis to 2.11
>> 	* support RISC-V extension IMACFD
>> 	* fix broken erc32 memory controller settings
> Why in this config ...
>>  .../rtems-gdb-ce73f310150418a9a1625ab60a527d959096a9e2.cfg    | 4 ++--
> ... is gdb-7-1 build recipe being included ..
>>  %include %{_configdir}/gdb-7-1.cfg
> ? Should this be:
> %include %{_configdir}/gdb-8-1.cfg
> Are you OK if I add this patch to:
>  https://devel.rtems.org/ticket/3460
> as an attachment so I can create `rtems-gdb-8.2.1-1.cfg`? I ask because `bfin`
> is broken with gdb-8.0.1 (in the sim code) on FreeBSD 12.0-p2 ..
>  https://lists.rtems.org/pipermail/build/2019-February/001775.html
> A gdb-8.2.1 with this patch builds for the bfin plus all the other architectures
> in 5/rtems-all. :)
> Note, I have not run any simulations with this patch yet.
These two patches should be applied to gdb-8.2.1 to build sis for SPARC and RISC-V:
https://gaisler.se/gdb/gdb-8.2.1-riscv-config.patch
https://gaisler.se/gdb/gdb-8.2.1-sis-2.11.patch
I have tested building and running all RTEMS tests - works fine.
I think it is fine to switch all other targets to gdb-8.2.1 also. Should simplify things ...
Jiri.
