[PATCH] RSB/gdb: upgrade sis to 2.11
Mon Feb 4 10:55:44 UTC 2019
On 4/2/19 9:49 pm, Jiri Gaisler wrote:
> These two patches should be applied to gdb-8.2.1 to build sis for SPARC and RISC-V:
> https://gaisler.se/gdb/gdb-8.2.1-riscv-config.patch
> https://gaisler.se/gdb/gdb-8.2.1-sis-2.11.patch
> I have tested building and running all RTEMS tests - works fine.
> I think it is fine to switch all other targets to gdb-8.2.1 also. Should simplify things ...
Awesome, I will sort this out tomorrow.
Thanks
