[PATCH] Coverage : Add coverage support for RISCV
Mon Feb 4 22:55:56 UTC 2019
On 2/2/19 1:49 am, Vijay Kumar Banerjee wrote:
>  tester/covoar/TargetFactory.cc               |  2 +
>  tester/covoar/Target_riscv.cc                | 82 ++++++++++++++++
>  tester/covoar/Target_riscv.h                 | 98 ++++++++++++++++++++
>  tester/covoar/wscript                        |  3 +-
>  tester/rtems/testing/bsps/griscv-sis-cov.ini | 40 ++++++++
>  5 files changed, 224 insertions(+), 1 deletion(-)
>  create mode 100644 tester/covoar/Target_riscv.cc
>  create mode 100644 tester/covoar/Target_riscv.h
>  create mode 100644 tester/rtems/testing/bsps/griscv-sis-cov.ini
> diff --git a/tester/covoar/TargetFactory.cc b/tester/covoar/TargetFactory.cc
> index fc9c30b..50e92a6 100644
> --- a/tester/covoar/TargetFactory.cc
> +++ b/tester/covoar/TargetFactory.cc
> @@ -23,6 +23,7 @@
>  #include "Target_powerpc.h"
>  #include "Target_lm32.h"
>  #include "Target_sparc.h"
> +#include "Target_riscv.h"
>  namespace Target {
> @@ -56,6 +57,7 @@ namespace Target {
>      { "m68k",    Target_m68k_Constructor },
>      { "powerpc", Target_powerpc_Constructor },
>      { "sparc",   Target_sparc_Constructor },
> +	{ "riscv",   Target_riscv_Constructor },
Tab or space?
>      { "TBD",     NULL },
> diff --git a/tester/covoar/Target_riscv.cc b/tester/covoar/Target_riscv.cc
> new file mode 100644
> index 0000000..3b2e221
> --- /dev/null
> +++ b/tester/covoar/Target_riscv.cc
> @@ -0,0 +1,82 @@
> + * RTEMS Tools Project (http://www.rtems.org/)
> + * Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
> + * All rights reserved.
> + * This file is part of the RTEMS Tools package in 'rtems-tools'.
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions are met:
> + * 1. Redistributions of source code must retain the above copyright notice,
> + * this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright notice,
> + * this list of conditions and the following disclaimer in the documentation
> + * and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +/*! @file Target_riscv.cc
> + *  @brief Target_riscv Implementation
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <unistd.h>
> +namespace Target {
> +  Target_riscv::Target_riscv( std::string targetName ):
> +    TargetBase( targetName )
> +    branchInstructions.push_back("beqz");
> +    branchInstructions.push_back("bnez");
> +    branchInstructions.push_back("blez");
> +    branchInstructions.push_back("bgez");
> +    branchInstructions.push_back("bltz");
> +    branchInstructions.push_back("bgt");
> +    branchInstructions.push_back("ble");
> +    branchInstructions.push_back("bgtu");
> +    branchInstructions.push_back("bleu");
> +    branchInstructions.sort();
> +  Target_riscv::~Target_riscv()
> +  bool Target_riscv::isNopLine(
> +    const char* const line,
> +    int&              size
> +    if (!strcmp( &line[strlen(line)-3], "nop")){
> +        size = 4;
> +        return true;
> +  return false;
> +  TargetBase *Target_riscv_Constructor(
> +    std::string        targetName
> +      return new Target_riscv( targetName );
> diff --git a/tester/covoar/Target_riscv.h b/tester/covoar/Target_riscv.h
> index 0000000..112276c
> --- /dev/null
> +++ b/tester/covoar/Target_riscv.h
> @@ -0,0 +1,98 @@
> +/*! @file Target_riscv.h
> + *  @brief Target_riscv Specification
> + *  This file contains the specification of the Target_riscv class.
> +#ifndef __TARGET_RISCV_H__
> +#define __TARGET_RISCV_H__
> +#include <list>
> +#include <string>
> +#include "TargetBase.h"
> +namespace Target {
> +  /*!  @class Target_riscv
> +   * This is the class for the riscv target.
Extra line?
> +  class Target_riscv: public TargetBase {
> +  public:
> +   *  Target_riscv constructor
> +  Target_riscv( std::string targetName );
> +  virtual ~Target_riscv();
> +   *  This method determines nop instruction.
> +   *  @param[in] line contains the object dump line to check
> +   *  @param[out] size is set to the size in bytes of the nop
> +   *  @return Returns True if the instruction is nop, False otherwise.
> +  bool isNopLine(
> +	int&              size
> +   *  This method determines if it's a branch instruction
> +   *  @param[in] instruction
> +   *  @return Returns True if the instruction is a branch instruction, False otherwise.
> +  bool isBranch(
> +    const char* const instruction
> + private:
> +#endif
> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
> index a3730ea..e2644f6 100644
> --- a/tester/covoar/wscript
> +++ b/tester/covoar/wscript
> @@ -105,7 +105,8 @@ def build(bld):
>                          'Target_lm32.cc',
>                          'Target_m68k.cc',
>                          'Target_powerpc.cc',
> -                        'Target_sparc.cc'],
> +                        'Target_sparc.cc',
> +						'Target_riscv.cc'],
More tabs? I suspect this would break on python3.
>                cflags = ['-O2', '-g', '-Wall'],
>                cxxflags = ['-std=c++11', '-O2', '-g', '-Wall'],
>                includes = ['.'] + rtl_includes)
> diff --git a/tester/rtems/testing/bsps/griscv-sis-cov.ini b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> index 0000000..060bba7
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/griscv-sis-cov.ini
> @@ -0,0 +1,40 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2019 Vijay K. Banerjee (vijaykumar9597 at gmail.com)
> +# All rights reserved.
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are met:
> +# 1. Redistributions of source code must retain the above copyright notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright notice,
> +# this list of conditions and the following disclaimer in the documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The griscv BSP on sis with coverage
> +[griscv-sis-cov]
> +bsp          = griscv-sis
> +arch         = riscv
> +tester       = %{_rtscripts}/run.cfg
> +target       = riscv-rtems5
> +bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> +bsp_run_opts = -nouartrx -r -tlim 300 s -m 4 -cov
