[PATCH 4/4] rtemstoolkit/config: Unlock when printing to avoid blocking.
chrisj at rtems.org chrisj at rtems.org
Tue Feb 5 05:10:13 UTC 2019
 tester/rt/config.py | 11 ++++++++++-
 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/tester/rt/config.py b/tester/rt/config.py
index 673c39b..457c0bd 100644
--- a/tester/rt/config.py
+++ b/tester/rt/config.py
@@ -46,6 +46,8 @@ from rtemstoolkit import execute
 from rtemstoolkit import log
 from rtemstoolkit import path
+from rtemstoolkit import stacktraces
 import console
 import gdb
 import tftp
@@ -341,7 +343,14 @@ class file(config.file):
     def _realtime_trace(self, text):
         for l in text:
-            print(''.join(l))
+            self._unlock()
+            try:
+                print(''.join(l))
+            except:
+                stacktraces.trace()
+                raise
+            finally:
+                self._lock()
     def run(self):
         self.target_start_regx = self._target_regex('target_start_regex')
2.19.1
