[PATCH 11/11] libdl: Add powerpc large memory and small data support.
Tue Feb 5 06:32:04 UTC 2019
On 05/02/2019 07:19, Sebastian Huber wrote:
> On 05/02/2019 02:43, chrisj at rtems.org wrote:
>> +     * Set bsp_section_sdata_bss_maximum_size to 1 to use the
>> maximum, eg:
>> +     *  bsp_section_sdata_bss_maximum_size = 1;
>> +    bsp_section_sdata_bss_default_size =
>> +        DEFINED(bsp_section_sdata_bss_maximum_size) ? 65536 : 0;
>> +     * Set bsp_section_sdata_bss_size to the system's sdata and bss
>> data size, eg:
>> +     *  bsp_section_sdata_bss_maximum_size = 4096;
>> +    bsp_section_sdata_sbss_size = DEFINED(bsp_section_sdata_bss_size) ?
>> +        bsp_section_sdata_bss_size :
>> bsp_section_sdata_bss_default_size;
> I would not make it more complicated than necessary. The systems using
> libdl probably all have network support and file systems. For them
> wasting 64KiB shouldn't be an issue. I would rename the
> bsp_section_sdata_bss_maximum_size to something like
> bsp_section_use_maximum_sdata_size since it is actually not a size.
Maybe we can simply use:
  * Define bsp_section_sdata_fixed_size to set the size of the
small-data area to a fixed size as specified, otherwise the size of the
small-data area is defined by the section content.
  * bsp_section_sdata_fixed_size = 65536;
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
