[PATCH 1/2] Support VERSION file for releasing and deployment
chrisj at rtems.org chrisj at rtems.org
Wed Feb 6 06:03:23 UTC 2019
- Shorten the GIT hash.
 common/version.py | 150 ++++++++++++++++++++++++++++++++++++++++++++++
 wscript           |  55 +++++++----------
 2 files changed, 170 insertions(+), 35 deletions(-)
 create mode 100644 common/version.py
diff --git a/common/version.py b/common/version.py
new file mode 100644
index 0000000..ad19eaf
--- /dev/null
+++ b/common/version.py
@@ -0,0 +1,150 @@
+# RTEMS Documentation Project (http://www.rtems.org/)
+# Copyright 2019 Chris Johns (chrisj at rtems.org)
+# Copyright (C) 2019 embedded brains GmbH
+# All rights reserved.
+# This file is part of the RTEMS Documentation package in 'rtems-docs'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# Releasing RTEMS Documentation
+# The VERSION file format is:
+#  The format is INI. The file requires a `[version`] section and a `revision`
+#  and 'date' values:
+#   [version]
+#   revision = <version-string>
+#   date = <date-string>
+#  The `<version-string>` has the `version` and `revision` delimited by a
+#  single `.`. An example file is:
+#   [version]
+#   revision = 5.0.not_released
+#   date = 1st February 2019
+#  where the `version` is `5` and the revision is `0` and the package is not
+#  released. The label `not_released` is reversed to mean the package is not
+#  released. A revision string can contain extra characters after the
+#  `revision` number for example `5.0-rc1` or is deploying a package
+#  `5.0-nasa-cfs`
+# User deployment:
+#  Create a git archive and then add a suitable VERSION file to the top
+#  directory of the package.
+from __future__ import print_function
+import os.path
+_version = 'invalid'
+_date = 'unknown date'
+_released = False
+def _pretty_day(day):
+    if day == 3:
+        s = 'rd'
+    elif day == 11:
+        s = 'th'
+    elif day == 12:
+        s = 'th'
+    elif day == 13:
+        s = 'th'
+    elif day % 10 == 1:
+        s = 'st'
+    elif day % 10 == 2:
+        s = 'nd'
+    else:
+        s = 'th'
+    return str(day) + s
+def get(ctx, rtems_major_version):
+    global _version
+    global _date
+    global _released
+    if _version == 'invalid':
+        version = rtems_major_version
+        date = _date
+        released = False
+        # Is there a VERSION file for a release or deployed source.
+        vc = 'VERSION'
+        if os.path.exists(vc):
+            try:
+                import configparser
+            except ImportError:
+                import ConfigParser as configparser
+            v = configparser.SafeConfigParser()
+            try:
+                v.read(vc)
+            except Exception as e:
+                ctx.fatal('Invalid version config format: %s: %s' % (vc, e))
+            try:
+                version = v.get('version', 'revision')
+                date = v.get('version', 'date')
+                ctx.fatal('Invalid version file: %s: %s' % (vc, e))
+            if not 'not_released' in version:
+                _released = True
+        else:
+            # Get date and version from Git
+            if ctx.exec_command(['git', 'diff-index', '--quiet', 'HEAD']) == 0:
+                modified = ''
+            else:
+                modified = '-modified'
+            try:
+                out = ctx.cmd_and_log(['git', 'log', '-1',
+                                       '--format=%h,%cd', '--date=format:%e,%B,%Y'],
+                                      quiet = True)
+                f = out.strip('\n').split(',')
+                version = version + '.' + f[0] + modified
+                date = _pretty_day(int(f[1])) + ' ' + f[2] + ' ' + f[3]
+            except waflib.Build.Errors.WafError:
+                date = 'unknown date'
+        _version = version
+        _date = date
+        _release = released
+    return version, date
+def string():
+    return '%s (%s)' % (_version, _date)
+def version():
+    return _version
+def date():
+    return _date
+def released():
+    return _released
diff --git a/wscript b/wscript
index e66a3f7..e86988d 100644
--- a/wscript
+++ b/wscript
@@ -2,13 +2,23 @@
 # RTEMS Project Documentation
-from sys import path
-from os.path import abspath
-path.append(abspath('common'))
+import sys
+import os.path
+sys.path.append(os.path.abspath('common'))
 import waflib
 import waf as docs_waf
+import version
+# Branch version
+rtems_major_version = '5'
+# The documents to build.
 build_all = ['user',
              'c-user',
              'bsp-howto',
@@ -49,43 +59,18 @@ def coverpage_js(ctx):
     with open(ctx.outputs[0].abspath(), 'w') as o:
         o.write(js.replace('@CATALOGUE', xml))
-def pretty_day(day):
-    if day == 3:
-        s = 'rd'
-    elif day == 11:
-        s = 'th'
-    elif day == 12:
-        s = 'th'
-    elif day == 13:
-        s = 'th'
-    elif day % 10 == 1:
-        s = 'st'
-    elif day % 10 == 2:
-        s = 'nd'
-    else:
-        s = 'th'
-    return str(day) + s
 def build(ctx):
-    # Get date and version from Git
+    # Get the version.
-    version = '5.0.0'
-    if ctx.exec_command(['git', 'diff-index', '--quiet', 'HEAD']) == 0:
-        modified = ''
-    else:
-        modified = '-modified'
-    try:
-        out = ctx.cmd_and_log(['git', 'log', '-1', '--format=%H,%cd', '--date=format:%e,%B,%Y'])
-        f = out.strip('\n').split(',')
-        version = version + '.' + f[0] + modified
-        date = pretty_day(int(f[1])) + ' ' + f[2] + ' ' + f[3]
-    except waflib.Build.Errors.WafError:
-        date = 'unknown date'
-    ctx.env.DATE = date
-    ctx.env.RELEASE = version + ' (' + date + ')'
-    ctx.env.VERSION = version
+    ver_version, ver_date = version.get(ctx, rtems_major_version)
+    ctx.env.DATE = ver_date
+    ctx.env.RELEASE = ver_version + ' (' + ver_date + ')'
+    ctx.env.VERSION = ver_version
+    ctx.to_log('Build: %s%s' % (ctx.env.RELEASE, os.linesep))
     # Generate any PlantUML images if enabled.
2.19.1
