[PATCH] Coverage: Add support for TSIM format
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Feb 6 08:24:12 UTC 2019
On Wed, 6 Feb 2019 at 02:35, Chris Johns <chrisj at rtems.org> wrote:
> On 6/2/19 1:41 am, Vijay Kumar Banerjee wrote:
> > On Tue, 5 Feb 2019 at 03:37, Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> On 1/2/19 10:47 pm, Vijay Kumar Banerjee wrote:
> > > self.trace = trace
> > > self.prefix = prefix
> > > + self.bsp = bsp
> > > def _find_covoar(self):
> > > covoar_exe = 'covoar'
> > > @@ -316,10 +323,18 @@ class covoar(object):
> > > if not path.exists(symbol_file):
> > > raise error.general('coverage: no symbol set file:
> %s'%
> > (symbol_file))
> > > exe = self._find_covoar()
> > > - command = exe + ' -S ' + symbol_file + \
> > > - ' -O ' + covoar_result_dir + \
> > > - ' -E ' + self.explanations_txt + \
> > > - ' -p ' + self.project_name + ' ' +
> self.executables
> > > + if 'qemu' in self.bsp.split('-'):
> > Are you checking for 'qemu' in the BSP name? The naming used here is
> a
> > convention and making the code depend on a naming convention is
> fragile. Lets
> > not do this.
> > There is a `%{qemu-cmd}` macro defined which must exist for a qemu
> run so it is
> > better to check for this. However ...
> > I'm not able to get it with macros.find(). What's the right way to find
> it?
> Find should work and `get` should also work and may be simpler.
> > Also, there's a 'cov_format' in testing.mc <http://testing.mc> that is
> hardcoded
> > to 'QEMU'. Can this value be updated from the cfg files ?
> I do not mind but maybe this logic is not needed if you can create the
> command
> line in a .cfg file. This means you can bring the needed options together
> from
> the BSP file which could hold the `-f TSIM` option you need and the code
> here is
> common for all coverage.
> > > + command = exe + ' -S ' + symbol_file + \
> > > + ' -O ' + covoar_result_dir + \
> > > + ' -E ' + self.explanations_txt + \
> > > + ' -p ' + self.project_name + ' ' +
> self.executables
> > > + else:
> > > + ' -f TSIM' + \
> self.executables
> > ... I would prefer the command be managed in the config files and
> this code
> > removed. Do you think this can be done?
> > the exe and the symbol_files are generated by the script itself. I think
> we have
> > to call covoar from the script only.
> That is fine, it is just the command line that I am asking about.
> something like the attached patch?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190206/639b46fc/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190206/639b46fc/attachment.bin>
