[PATCH] Coverage: Add support for TSIM format
Wed Feb 6 21:26:16 UTC 2019
On 6/2/19 9:33 pm, Vijay Kumar Banerjee wrote:
> On Wed, 6 Feb 2019 at 14:04, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 6/2/19 7:24 pm, Vijay Kumar Banerjee wrote:
>     > @@ -317,9 +324,11 @@ class covoar(object):
>     >              raise error.general('coverage: no symbol set file: %s'%
>     (symbol_file))
>     >          exe = self._find_covoar()
>     >          command = exe + ' -S ' + symbol_file + \
>     > -                  ' -O ' + covoar_result_dir + \
>     > -                  ' -E ' + self.explanations_txt + \
>     > -                  ' -p ' + self.project_name + ' ' + self.executables
>     > +                   ' -O ' + covoar_result_dir + \
>     > +                   ' -p ' + self.project_name + \
>     > +                   ' ' + self.executables + ' '
>     Can all these be placed in a macro variable and then accessed here?
>     Maybe in defaults.mc <http://defaults.mc>?
> I tried this but it seems like all these need bsp name or version. So we can't
> add them in default.mc <http://default.mc>
> or testing.mc <http://testing.mc>. If we want to move it to the configuration
> files then we'll have to add it in the bsp ini file (like the explanations file
> has been added ). Do we want to have it in bsp file? It might make the ini file
> complicated.
You can add references to the BSP's macro entry "%{bsp}" in defaults.mc. All
then need to do is expand the macro when you need it. For example:
https://git.rtems.org/rtems-tools/tree/tester/rt/config.py#n146
If you print the macros instance in the config class you will see what it
contains. For example this command:
$ /opt/work/chris/rtems/tools/rtems-tools.git/tester/rtems-run \
     --rtems-tools=/opt/work/rtems/5 --rtems-bsp=psim-run \
     `find . -name hello.exe`
 [ Added `print(self.macros)` as the first line of `def _dir_execute()` ]
The macro values of interest are:
[psim-run] w,r[0000]
 _target:              'none'     'none'      '%{%{bsp_arch}-rtems%{version}'
 arch:                 'none'     'none'      'powerpc'
 bsp:                  'none'     'none'      'psim'
 bsp_arch:             'none'     'none'      '%{arch}'
 bsp_run_cmd:          'none'     'none'
'%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
 bsp_run_opts:         'none'     'none'      '-f
%{_rtscripts}/bsps/psim-device-tree'
 console_stdio:        'none'     'none'      '1'
 exe_trace:            'none'     'none'      'output'
 rtems_tools:          'none'     'none'      '/opt/work/rtems/5/bin'
 rtems_version:        'none'     'none'      '5'
'/opt/work/rtems/5/bin/powerpc-rtems5-run'
/opt/work/chris/rtems/tools/rtems-tools.git/tester/rtems/testing/bsps/psim-de \
                                              vice-tree'
 test_disable_header:  'none'     'none'      '1'
 test_executable:      'none'     'none'
'./powerpc-rtems5/c/psim/testsuites/samples/hello.exe'
 test_executable_opts: 'none'     'none'      ''
 test_index:           'none'     'none'      '1'
 test_total:           'none'     'none'      '1'
 tester:               'none'     'none'      '%{_rtscripts}/run.cfg'
This means in `defaults.mc` you can use `%{arch}-%{bsp}` etc and if you expand
the macro the values will be recursively resolved.
