Break points with latest SIS
    Sebastian Huber
    Thu Feb  7 11:20:39 UTC 2019
Hello,
I get a NULL pointer exception in one of the tests:
sparc-rtems5-sis -leon3 -nouartrx -r -tlim 200 s -m 4
smpswitchextension01.exe
  SIS - SPARC/RISCV instruction simulator 2.11,  copyright Jiri Gaisler 1995
  Bug-reports to jiri at gaisler.se
  LEON3 emulation enabled, 4 cpus online, delta 50 clocks
Waking CPU 1
*** BEGIN OF TEST SMPSWITCHEXTENSION 1 ***
*** TEST VERSION: 5.0.0.e105ead93f8e7addf1c6bba731a1eb4da99f2e85
*** TEST STATE: EXPECTED-PASS
*** TEST BUILD: RTEMS_DEBUG RTEMS_NETWORKING RTEMS_POSIX_API RTEMS_SMP
*** TEST TOOLS: 7.4.0 20181206 (RTEMS 5, RSB
c41b9d0df7e5b4a5056ca50c2534380a44e92769, Newlib 3e24fbf6f)
Unexpected trap ( 2) at address 0x00000000
illegal instruction
IU in error mode (0)
  11360600  4001d9e0  12bffffe  bne  0x000000004001d9d8
I tried to debug this issue:
sparc-rtems5-gdb smpswitchextension01.exe
GNU gdb (GDB) 8.2.1
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "--host=x86_64-linux-gnu --target=sparc-rtems5".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
     <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
No symbol table is loaded.  Use the "file" command.
Reading symbols from smpswitchextension01.exe...done.
(gdb) tar sim -leon3 -m 4
Connected to the simulator.
(gdb) load
(gdb) b *0
Breakpoint 1 at 0x0
(gdb) r
Starting program:
/build/git-build/b-leon3/sparc-rtems5/c/leon3/testsuites/smptests/smpswitchextension01.exe
Waking CPU 1
Program received signal SIGTRAP, Trace/breakpoint trap.
0x40007070 in _API_Mutex_Is_owner (the_mutex=0x40026598
<_RTEMS_Allocator_Mutex>) at
/home/EB/sebastian_h/git-rtems-5/c/src/../../cpukit/score/src/apimutexisowner.c:25
25        return the_mutex->Mutex._Mutex._Queue._owner ==
_Thread_Get_executing();
(gdb) disas
Dump of assembler code for function _API_Mutex_Is_owner:
    0x4000706c <+0>:     ld  [ %o0 + 0xc ], %g1
=> 0x40007070 <+4>:     ld  [ %g6 + 0x20 ], %g2
    0x40007074 <+8>:     xor  %g1, %g2, %g1
    0x40007078 <+12>:    cmp  %g0, %g1
    0x4000707c <+16>:    retl
    0x40007080 <+20>:    subx  %g0, -1, %o0
End of assembler dump.
(gdb) info registers
g0             0x0                 0
g1             0x40027688          1073903240
g2             0x40029b54          1073912660
g3             0x8e                142
g4             0x40029b54          1073912660
g5             0x0                 0
g6             0x40029640          1073911360
g7             0x0                 0
o0             0x40026598          1073898904
o1             0x4002f300          1073935104
o2             0x0                 0
o3             0x40023800          1073887232
o4             0x0                 0
o5             0x40029640          1073911360
sp             0x4002f2a8          0x4002f2a8
o7             0x40008444          1073775684
l0             0xf3400fc7          -213905465
l1             0x4001add8          1073851864
l2             0x4001addc          1073851868
l3             0xf34000c7          -213909305
l4             0x0                 0
l5             0x0                 0
l6             0x0                 0
l7             0x0                 0
i0             0x400263b4          1073898420
i1             0x400269cc          1073899980
i2             0x0                 0
i3             0x40029c00          1073912832
i4             0x40029b50          1073912656
i5             0x40029b50          1073912656
fp             0x4002f308          0x4002f308
i7             0x4001170c          1073813260
y              0x588               1416
psr            0xf34000e7          [ ET PS S ]
wim            0x8                 8
tbr            0x400008a0          1073744032
pc             0x40007070          0x40007070 <_API_Mutex_Is_owner+4>
npc            0x40007074          0x40007074 <_API_Mutex_Is_owner+8>
fsr            0x0                 [ ]
csr            0x0                 0
It seems the debugger doesn't stop at address 0, but somewhere else.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
