Constant Bandwidth Server
Joel Oliveira Pinto
jollp at isep.ipp.pt
Thu Feb 7 13:11:54 UTC 2019
Hello everyone,
After studying the implementation of the Constant Bandwidth Server (CBS) scheduler in RTEMS, I realized that it does not respect what is proposed in the original paper by Abeni and Buttazzo. For instance, RTEMS implementation does not support the following:
• Serve several threads within a server and deal with their deadlines accordingly;
• Replenish the budget of the server and postpone its deadline when the server budget is exhausted;
I’ve been implementing a new version of CBS that supports the rules above and that resembles the original paper as much as possible and I’m currently testing it at the moment. Thus, I would like to know from the community if there are some specific test cases/benchmarks (besides the X tests that already exists for CBS) that should be used to test this CBS version or generally speaking any scheduler in RTEMS?
Regards,
Joel Pinto
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190207/e89a91d9/attachment.html>
