[PATCH] Coverage: Add support for TSIM format
Fri Feb 8 03:04:36 UTC 2019
On 8/2/19 9:13 am, Vijay Kumar Banerjee wrote:
> On Fri, 8 Feb 2019 at 00:15, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 7/2/19 7:17 pm, Vijay Kumar Banerjee wrote:
>     > I'm trying to do this ...
>     > diff --git a/tester/rtems/testing/bsps/leon3-sis-cov.ini
>     > b/tester/rtems/testing/bsps/leon3-sis-cov.ini
>     > index d60257c..e450b60 100644
>     > --- a/tester/rtems/testing/bsps/leon3-sis-cov.ini
>     > +++ b/tester/rtems/testing/bsps/leon3-sis-cov.ini
>     > @@ -38,4 +38,4 @@ tester         = %{_rtscripts}/run.cfg
>     >  target         = sparc-rtems5
>     >  bsp_run_cmd    = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
>     >  bsp_run_opts   = -leon3 -nouartrx -r -tlim 200 s -cov
>     > -bsp_covoar_cmd = -E %{cov_explanations} -f TSIM
>     > +bsp_covoar_cmd = -S %{bsp_symbol_path} -p %{project_name} -E
>     Can the common options be moved to coverage part of qemu.cfg?
> Since I'm trying with the sis. I added it to the run.cfg like this
> # Coverage
> %if %{defined coverage}
>   %define covoar_cmd -S %{bsp_symbol_path} -p RTEMS-%{rtems_version} -E
> %{cov_explanations}
> %endif
Ahh, I wonder if this should be in a coverage.cfg file you include and this way
it can be shared?
> When I print the macros from the config.py I see this macro created like this...
>  coverage:             'none'     'none'      '1'
>  covoar_cmd:           'none'     'none'      '-S
> /home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/leo \
>                                               n3-sis-symbols.ini -p RTEMS-5 -E
> /home/lunatic/development/rtems/rtems-tools/tes \
> ter/rtems/testing/coverage/Explanations.txt'
> The only problem now is to expand it from coverage.py which is giving error.
> If I print the macros list from the coverage.py , I see that the list is missing
> this and some other macros. How to get the 'complete' list of macros? :/
Sorry I am not sute, can you see the config object from the coverage code?
I would need to review the code and figure it out and I do not have the time.
