[rtems-docs commit] Version change, forgot to add wscript to the commit.
Fri Feb 8 06:29:46 UTC 2019
On 07/02/2019 18:28, Chris Johns wrote:
> On 8/2/19 11:09 pm, Sebastian Huber wrote:
>> After the update I get:
>>    File "/home/EB/sebastian_h/git-rtems-docs/wscript", line 67, in build
>>      ver_version, ver_date, ver_released = version.get(ctx, rtems_major_version)
>> AttributeError: 'module' object has no attribute 'get'
> It works on MacOS, FreeBSD 11.2-p5 and sync.rtems.org (docs.rtems.org shows the
> patch I pushed built).
> I wonder if you are loading a different `version.py`.
> On MacOS with Python2 I have:
> $ python
> Python 2.7.10 (default, Aug 17 2018, 19:45:58)
> [GCC 4.2.1 Compatible Apple LLVM 10.0.0 (clang-1000.0.42)] on darwin
> Type "help", "copyright", "credits" or "license" for more information.
>>>> import sys
>>>> import os.path
>>>> sys.path.append(os.path.abspath('common'))
>>>> import version
>>>> version.__file__
> '/Users/chris/development/rtems/docs/rtems-docs.git/common/version.pyc'
>>>> version.__dict__['get']
> <function get at 0x107b69410>
> And on FreeBSD 11.2-p5 with python3 I have:
> $ python3
> Python 3.6.6 (default, Oct  2 2018, 01:22:29)
> [GCC 4.2.1 Compatible FreeBSD Clang 6.0.0 (tags/RELEASE_600/final 326565)] on
> freebsd11
>>>> import sys
>>>> import os.path
>>>> import version
>>>> version.__file__
> '/opt/work/chris/rtems/docs/rtems-docs.git/common/version.py'
> <function get at 0x8007b7730>
> What are you seeing?
Yes, there seems to be a conflict with another version module:
python
Python 2.7.14 (default, Oct 12 2017, 15:50:02) [GCC] on linux2
 >>> import sys
 >>> import os.path
 >>> import version
 >>> version.__file__
'/usr/lib64/python2.7/site-packages/PIL/version.pyc'
Traceback (most recent call last):
   File "<stdin>", line 1, in <module>
KeyError: 'get'
The module concept is not really the greatest thing in Python.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
