[rtems-docs commit] Version change, forgot to add wscript to the commit.
Fri Feb 8 06:55:01 UTC 2019
On 8/2/19 5:33 pm, Sebastian Huber wrote:
> On 08/02/2019 07:29, Sebastian Huber wrote:
>> On 07/02/2019 18:28, Chris Johns wrote:
>>> On 8/2/19 11:09 pm, Sebastian Huber wrote:
>>>> After the update I get:
>>>>    File "/home/EB/sebastian_h/git-rtems-docs/wscript", line 67, in build
>>>>      ver_version, ver_date, ver_released = version.get(ctx,
>>>> rtems_major_version)
>>>> AttributeError: 'module' object has no attribute 'get'
>>> It works on MacOS, FreeBSD 11.2-p5 and sync.rtems.org (docs.rtems.org shows the
>>> patch I pushed built).
>>> I wonder if you are loading a different `version.py`.
>>> On MacOS with Python2 I have:
>>> $ python
>>> Python 2.7.10 (default, Aug 17 2018, 19:45:58)
>>> [GCC 4.2.1 Compatible Apple LLVM 10.0.0 (clang-1000.0.42)] on darwin
>>> Type "help", "copyright", "credits" or "license" for more information.
>>>>>> import sys
>>>>>> import os.path
>>>>>> sys.path.append(os.path.abspath('common'))
>>>>>> import version
>>>>>> version.__file__
>>> '/Users/chris/development/rtems/docs/rtems-docs.git/common/version.pyc'
>>>>>> version.__dict__['get']
>>> <function get at 0x107b69410>
>>> And on FreeBSD 11.2-p5 with python3 I have:
>>> $ python3
>>> Python 3.6.6 (default, Oct  2 2018, 01:22:29)
>>> [GCC 4.2.1 Compatible FreeBSD Clang 6.0.0 (tags/RELEASE_600/final 326565)] on
>>> freebsd11
>>>>>> import sys
>>>>>> import os.path
>>>>>> import version
>>>>>> version.__file__
>>> '/opt/work/chris/rtems/docs/rtems-docs.git/common/version.py'
>>> <function get at 0x8007b7730>
>>> What are you seeing?
>> Yes, there seems to be a conflict with another version module:
>> python
>> Python 2.7.14 (default, Oct 12 2017, 15:50:02) [GCC] on linux2
>> >>> import sys
>> >>> import os.path
>> >>> import version
>> >>> version.__file__
>> '/usr/lib64/python2.7/site-packages/PIL/version.pyc'
>> Traceback (most recent call last):
>>   File "<stdin>", line 1, in <module>
>> KeyError: 'get'
>> The module concept is not really the greatest thing in Python.
I would not blame python for a package using `version` as a module name
installed in site-packages and I suppose PIL is in the sys.path.
I have done some pretty interesting things with Python modules in some projects
and I think it is a solid design.
> It works if I use:
> sys.path.insert(0, os.path.abspath('common'))
Yeah this is simplest and smallest fix so please commit and push it.
Thinking about this maybe the sys.path hack is a poor option. I am wondering if:
 from common import waf as doc_waf
 from common import version
This ripples out into all the `wscripts`. I feel this is the most robust
solution however it is a number of changes. If you push the change I can clean
it up.
